開機時完整的串口記錄:
[ 233.3 42078] c pufreq: cpufreq: reboot set core rate=12 00000000 , volt=1 100000
[ 233.342101] m ali_reboot_notifier_even t enter
[ 233. 342109] mali_reb oot_notifier_eve nt exit
[ 233.342288] mmcblk m mc0:0001: Unbalanced pm_ runtime_ enable!
[ 233.9 57375] Chenzy— ----hkw- ------es8323_i2c _shutdown
[ 234.0 61978] dwc_otg_d river_shutdown: disconnect USB d evice mode
[ 234.0 71756] Restartin g system with command ‘l oader’.
DR Vers ion 1.00 2015031 8
SRX
Chan nel a: DDR3 200MHz
Bus Widt h=32 Col=10 Bank=8 Row=1 5 CS=1 Die Bus-W idth=16 Size=102 4MB
Channel b: DDR3 200MHz
Bus Widt h=32 Col =10 Bank=8 Row=1 5 CS=1 D ie Bus-W idth=16 Size=102 4MB
U-Bo ot 2014.10-RK328 8-10-g65 679f1 (J ul 20 20 15 - 10: 28:11)
CPU: r k3288
CPU’s clock infor mation:
arm pll = 6 00000000HZ
periph pll = 300 000000HZ
dd r pll = 200000000HZ
codec p ll = 594000000HZ
Board: Rockchi p platform Board
DRAM: Found dram bank s:1
Add ing bank:0000000 00000000 0(00000000800000 00)
128 MiB
remotectl v0.1
storage init OK!
Using default environm ent
G etParam
check p arameter success
failed t o prepar e fdt fr om boot!
power ke y: bank- 0 pin-5
can’t fi nd dts node for ricoh619
pmic:act 8846
Can’t fi nd dts node for fuel guage cw201 x
Secur eBootEn = 0, Sec ureBootLock = 0
#Boot ver: 2015-07-20#2.19
empty ser ial no.
reboot to rocku sb.
DDR Vers ion 1.00 2015031 8
S RX
Chan nel a: D DR3 200MHz
Bus Widt h=32 Col =10 Bank =8 Row=1 5 CS=1 D ie Bus-W idth=16 Size=102 4MB
Cha nnel b: DDR3 200MHz
U-Bo ot 2014. 10-RK328 8-10-g65 679f1 (J ul 20 20 15 - 10: 28:11)
CPU: r k3288
CPU’s clo ck infor mation:
periph p ll = 300 000000HZ
128 MiB
remotect l v0.1
storage init OK!
G etParam
power ke y: bank-0 pin-5
pmic:act 8846
SecureBootEn = 0, SecureBootL ock = 0
#Boot ver: 20 15-07-20#2.19
empty ser ial no.
reboot to rocku sb.
DDR Vers ion 1.00 20150318
S RX
Channel a: DDR3 200MHz
Bus Width=32 Col =10 Bank=8 Row=15 CS=1 Die Bus-W idth=16 Size=1024MB
Bus Widt h=32 Col=10 Bank=8 Row=15 CS=1 D ie Bus-Width=16 Size=102 4MB
U-Bo ot 2014.10-RK3288-10-g65679f1 (Jul 20 2015 - 10: 28:11)
CPU: r k3288
CPU’s clock information:
ddr pll = 200000000HZ
Board: Rockchip platfo rm Board
DRAM: Found dram banks:1
Adding bank:0000000 000000000(0000000080000000)
128 MiB
remotect l v0.1
storage init OK!
GetParam
check parameter success
failed to prepar e fdt from boot!
pmic:act 8846
Can’t fi nd dts node for fuel gua ge cw201x
empty serial no.
checkKe y
vbus = 1
board_fbt_key_pressed: ir_k eycode = 0x0, frt = 0
no fuel gauge fou nd
no fuel gauge found
read log o_on switch from dts [0]
no fue l gauge found
checkKey
vbus = 1
board_fbt_key_pressed: ir_keycode = 0 x0, frt = 0
got recovery cmd from misc.
load fdt from resouce.
ERROR: [get_entry_ram]: Cannot f ind logo_kernel. bmp!
Secure B oot state: 0
kernel @ 0x02000000 (0x006a6e80)
ramdisk @ 0x05bf0000 (0x002c6ad4)
bootrk: do_bootm_l inux…
Loading Devi ce Tree to 05600000, end 0561c8c5 … OK
Add bank :000000000000000 0, 0000000080000 000
Starti ng kernel …
[ 0.0 00000] Booting Linux on physical CPU 0x5 00
[ 0.00000 0] Initializing cgroup subsys cp u
[ 0.000000] Initia lizing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.0 (user@ ubuntu) (gcc version 4.6.x-googl e 20120106 (prerelease) (GCC) ) #925 SMP PREEMPT Thu Jan 20 15:59:08 CST 2022
[ 0.000000] CP U: ARMv7 Processor [410fc0d1] re vision 1 (ARMv7), cr=10c 5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasi ng data cache, V IPT aliasing ins truction cache
[ 0.0 00000] Machine: Rockchip RK3288 (Flattened Devic e Tree), model: rockchip,rk3288
[ 0. 000000] rockchip_uboot_l ogo_setup: mem: 0x020000 00@0x7dc00000, o ffset:0x 00000000
[ 0.000000] hdmi in it vic is -1
[ 0.000000] rockchip_ub oot_mem_ reserve: reserve 0x02000 000@0x7d c00000 for uboot logo
[ 0.000000] ro ckchip_i on_reserve
[ 0.000000] ion h eap(drm): base(0 ) size(0 ) align(0)
[ 0.00000 0] ion heap(cma) : base(0 ) size(28000000) align(0 )
[ 0.000000] ion heap(vmall oc): base(0) siz e(0) ali gn(0)
[ 0.00 0000] cm a: CMA: reserved 640 MiB at 55c0 0000
[ 0.000 000] ion_reserve: cma re served b ase 55c00000 siz e 671088 640
[ 0.0000 00] cma: CMA: re served 16 MiB at 1f00000 0
[ 0.000000 ] Memory policy: ECC dis abled, D ata cach e writealloc
[ 0.000000] Boot mode: RECOVERY (2) flag: RECOV ER (0xc3 524203)
[ 0. 000000] PERCPU: Embedded 9 pages /cpu @c1 f1f000 s13376 r8 192 d152 96 u36864
[ 0.000000 ] Built 1 zoneli sts in Z one orde r, mobility grou ping on. Total pages: 5 23264
[ 0.000000] Ke rnel com mand line: vmall oc=496M console= ttyS2 androidboo t.selinu x=permissive and roidboot .hardware=rk30bo ard andr oidboot.console= ttyS2 in it=/init mtdparts=rk29x xnand:0x 00002000@0x00000 000(para meter),0x0000200 0@0x0000 2000(uboot),0x00 002000@0 x0000400 0(misc),0x000080 00@0x000 06000(resource), 0x000080 00@0x0000e000(ke rnel),0x 00010000@0x00016 000(boot ),0x0001 0000@0x00026000( recovery ),0x0001a000@0x0 0036000( backup),0x000400 00@0x000 50000(ca che),0x00002000@ 0x000900 00(kpanic),0x003 00000@0x 00092000(system) ,0x00008 000@0x00392000(m etadata) ,0x00002 000@0x0039A000(b aseparam er),0x00200000@0 x0039C00 0(userdata),0x00 020000@0 x0059C000(radica l_update ),-@0x00 5BC000(user) sto ragemedi a=emmc uboot_log o=0x0200 0000@0x7dc00000 loader.t imestamp=2015-07 -20_10:2 8:11 hdm i.vic=-1
[ 0 .000000] PID hash table entries: 2048 (order: 1, 8192 by tes)
[ 0.000 000] Den try cach e hash table ent ries: 65 536 (order: 6, 2 62144 by tes)
[ 0.000 000] Ino de-cache hash table entr ies: 327 68 (order: 5, 13 1072 byt es)
[ 0.0000 00] allo cated 4194304 by tes of p age_cgro up
[ 0.00000 0] pleas e try ‘cgroup_di sable=me mory’ option if you don’ t want memory cg roups
[ 0.00 0000] Memory: 20 48MB = 2 048MB total
[ 0.0000 00] Memory: 1353 140k/135 3140k available, 744012k reserve d, 884736K highm em
[ 0.000000] Virtu al kerne l memory layout:
[ 0 .000000] vector : 0 xffff000 0 - 0xffff1000 ( 4 k B)
[ 0.000000] f ixmap : 0xfff00 000 - 0x fffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe08 00000 - 0xff0000 00 ( 488 MB)
[ 0.0 00000] lowmem : 0xc 0000000 - 0xe000 0000 ( 512 MB)
[ 0 .000000] pkm ap : 0 xbfe00000 - 0xc0 000000 ( 2 MB)
[ 0.00000 0] m odules : 0xbf000 000 - 0x bfe00000 ( 14 MB)
[ 0.000000] .text : 0xc00 08000 - 0xc0bb5c 70 (11960 kB)
[ 0. 000000] .init : 0x c0bb6000 - 0xc0c0f440 ( 358 kB)
[ 0.000000] .data : 0xc0c10000 - 0xc 0da21c0 (1609 kB)
[ 0.0000 00] .bss : 0xc0da 21c0 - 0 xc0ec387c (115 8 kB)
[ 0.000000] SL UB: HWal ign=64, Order=0- 3, MinOb jects=0, CPUs=4, Nodes=1
[ 0 .000000] Preempt ible hie rarchical RCU im plementa tion.
[ 0.00 0000] RCU dyntick-idle grace-pe riod acceleration is ena bled.
[ 0.000000] r k_clk_tree_init start!
[ 0.000000] r kclk: r kclk_add_provider: fail to get ehci1phy 12m_div
[ 0.000000] rkclk: r kclk_cache_parents: ehci 1phy_12m _div clk_get error
[ 0.000000] rk_ge t_uboot_display_flag: uboot_logo _on = 0
[ 0.000000] rkclk_in it_clks: cnt_parent = 7
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.0 00000] rk3288 se t GPLL BW 20 for HDMI!
[ 0.000000] Architect ed cp15 timer(s) running at 24.00MHz (ph ys).
[ 0.000 000] Switching to timer- based de lay loop
[ 0 .000000] sched_c lock: ARM arch t imer >56 bits at 24000kH z, resolution 41ns
[ 0.00000 0] process version: 0
[ 0.00 0000] channel:0, lkg:18
[ 0.000000] target-t emp:80
[ 0.000000] c hannel:2 , lkg:0
[ 0. 000000] channel:0, lkg:1 8
[ 0.000000] channel:1, lkg :12
[ 0.0000 00] sched_clock: 32 bits at 100 Hz, reso lution 10000000n s, wraps every 429496728 6ms
[ 0.345053] Calibrating delay lo op (skipped), va lue calc ulated using tim er frequ ency.. 48.00 BogoMIPS (l pj=240000)
[ 0.345068] pid_m ax: default: 327 68 minim um: 301
[ 0.345183] Security Framewo rk initi alized
[ 0.3 45200] SELinux: Initializing.
[ 0.3 45272] Mount-cac he hash table entries: 5 12
[ 0.345913] Initializing cgroup s ubsys debug
[ 0.3459 27] Initializing cgroup subsys memory
[ 0.345952] In itializing cgrou p subsys freezer
[ 0 .345980] CPU: Testing wr ite buff er coherency: ok
[ 0 .346293] /cpus/cpu@0 mis sing clo ck-frequency pro perty
[ 0.346306] /c pus/cpu@ 1 missing clock- frequenc y proper ty
[ 0.34631 5] /cpus/cpu@2 missing c lock-fre quency property
[ 0. 346325] /cpus/cpu@3 miss ing cloc k-frequency prop erty
[ 0.346380] CPU0: threa d -1, cpu 0, soc ket 5, m pidr 80000500
[ 0.346430] Se tting up static identity map for 0xc086b db0 - 0x c086be08
[ 0 .349553] last_lo g: 0x1e900000 ma p to 0xe 0804000 and copy to 0xe0 886000, size 0x8 0000 ear ly 0x1879 (versi on 3.1)
[ 0. 423189] CPU1: Bo oted sec ondary processor
[ 0 .423222] CPU1: thread -1 , cpu 1, socket 5, mpidr 8000050 1
[ 0.442860 ] CPU2: Booted secondary process or
[ 0.44288 4] CPU2: thread -1, cpu 2, socke t 5, mpi dr 80000502
[ 0.4625 68] CPU3: Booted seconda ry processor
[ 0.462591] CPU3: threa d -1, cp u 3, soc ket 5, mpidr 800 00503
[ 0.462693] Brought up 4 CPUs
[ 0. 462722] SMP: Total of 4 processo rs activ ated (192.00 Bog oMIPS).
[ 0.462731] CPU: All CPU(s) started in SVC m ode.
[ 0.463461] devtmpfs: i nitialized
[ 0.46772 8] VFP support v 0.3: imp lementor 41 arch itecture 3 part 30 variant d rev 0
[ 0.468826] pinct rl core: initialized pin ctrl sub system
[ 0.4 69073] regulator -dummy: no param eters
[ 0.493628] NE T: Regis tered protocol f amily 16
[ 0.495492] DMA: pr eallocat ed 256 KiB pool for atom ic coherent allo cations
[ 0.495815] ion_snap shot: 0x1ea98000 map to 0xe09070 00 and copy to 0 xc0e9eb4 c (version 0.1)
[ 0.496041] Register ed FIQ tty driver
[ 0.496435] fiq-de bugger is disabl ed in de vice tree
[ 0.497131] rockchip_get_b ank_data :name=ba se start=0xff750 000,end= 0xff7500ff
[ 0.497153] rockchip_get_ bank_dat a:name=mux_bank0 start=0 xff73008 4,end=0xff73008f
[ 0 .497171] rockchip_get_ba nk_data:name=pul l_bank0 start=0xff730064 ,end=0xf f73006f
[ 0.497187] rockchip get_bank_data:n ame=drv bank0 start=0xff 730070,e nd=0xff73007b
[ 0.49 7282] ro ckchip_get_bank_ data:nam e=/pinctrl@ff770 000/gpio 1@ff780000 start =0xff780000,end=0xff7800 ff
[ 0.497350] rockchip_get_ bank_dat a:name=/pinctrl@ ff770000 /gpio2@ff790000 start=0x ff790000,end=0xf f7900ff
[ 0. 497413] rockchip _get_ban k_data:name=/pinctrl@ff7 70000/gpio3@ff7a 0000 sta rt=0xff7 a0000,end=0xff7a 00ff
[ 0.497477] roc kchip_ge t_bank_data:name =/pinctr l@ff770000/gpio4@ff7b000 0 start= 0xff7b0000,end=0 xff7b00f f
[ 0.497539] rockch ip_get_bank_data :name=/p inctrl@ff770000/ gpio5@ff 7c0000 start=0xff7c0000, end=0xff 7c00ff
[ 0.4 97602] rockchip_get_bank _data:na me=/pinctrl@ff77 0000/gpi o6@ff7d0000 start=0xff7d 0000,end =0xff7d00ff
[ 0.4976 65] rockchip_get_bank_da ta:name=/pinctrl @ff77000 0/gpio7@ ff7e0000 start=0 xff7e000 0,end=0xff7e00ff
[ 0.497728] rockchi p_get_ba nk_data:name=/pi nctrl@ff 770000/g pio8@ff7f0000 start=0xff 7f0000,end=0xff7 f00ff
[ 0.497798] ro ckchip_g et_bank_ data:name=/pinctrl@ff770 000/gpio15@ff7f2 000 star t=0xff7f2000,end =0xff7f2 0ff
[ 0.497863] rock chip_pin ctrl_probe:name= RK3288-G PIO,type=3
[ 0.497877] rockchip_pinc trl_prob e:name=base star t=0xff77 0000,end =0xff77013f
[ 0.497889] rockchip_pin ctrl_pro be:name=pull sta rt=0xff7 70140,end=0xff77 01bf
[ 0.497 906] rockchip_pi nctrl_pr obe:name=drv sta rt=0xff7 701c0,end=0xff77023f
[ 0.498525] rockchip_interrupts_register:bank_num=7
[ 0.500443] of_get_gpio_init_config:gpio[0] = 2 e = 0
[ 0.500463] of _get_gpi o_init_c onfig:gp io[1] = 136, value = 0
[ 0.500527] rockchip_ pinctrl_ probe:in it ok
[ 0.50 7205] rk_iommu ff900800. iep_mmu: (iep) Enter
[ 0.507 293] rk_iommu ff 900800.iep_mmu: IOVMM: Created 0 x3ffff00 0 B IOVMM from 0 x1000000 0.
[ 0.50730 6] rk_iommu ff900800.iep _mmu: (i ep) Init ialized
[ 0. 507477] rk_iommu ff95080 0.vip_mm u: (vip) Enter
[ 0.5 07548] r k_iommu ff950800 .vip_mmu : IOVMM: Created 0x3ffff000 B IOVMM from 0x10000 000.
[ 0.507 560] rk_ iommu ff 950800.vip_mmu: (vip) Initialized
[ 0.507725 ] rk_iommu ff930 300.vopb _mmu: (vopb) Ent er
[ 0.507794] rk_iommu ff93 0300.vop b_mmu: IOVMM: Cr eated 0x 3ffff000 B IOVMM from 0x 10000000.
[ 0.507806] rk_iom mu ff930300.vopb _mmu: (vopb) Initialized
[ 0 .507975] rk_iomm u ff940300.vopl_mmu: (vo pl) Ente r
[ 0.508047] rk_iom mu ff940 300.vopl_mmu: IO VMM: Cre ated 0x3ffff000 B IOVMM from 0x10000000.
[ 0 .508059] rk_iommu ff9403 00.vopl_mmu: (vopl) Init ialized
[ 0.508228] rk_iommu ff9c044 0.hevc_mmu: (hev c) Enter
[ 0.508301] rk_iomm u ff9c0440.hevc_mmu: IOV MM: Created 0x3f fff000 B IOVMM f rom 0x10000000.
[ 0.508313] rk_iommu ff9c044 0.hevc_mmu: (hev c) Initi alized
[ 0.508484] r k_iommu ff9a0800.vpu_mmu : (vpu) Enter
[ 0.50 8555] rk_iommu ff9a0800. vpu_mmu: IOVMM: Created 0x3ffff0 00 B IOV MM from 0x100000 00.
[ 0.508568] rk_iommu ff9 a0800.vpu_mmu: ( vpu) Ini tialized
[ 0 .508737] rk_iomm u ff914000.isp_m mu: (isp _mmu) Enter
[ 0.5088 12] rk_iommu ff9 14000.is p_mmu: IOVMM: Cr eated 0x 3ffff000 B IOVMM from 0x 10000000 .
[ 0.508825 ] rk_iom mu ff914000.isp_ mmu: (is p_mmu) I nitialized
[ 0.510718] hw-breakpoint : found 5 (+1 reserved) breakpoi nt and 4 watchpo int regi sters.
[ 0.510731] hw-breakp oint: maximum wa tchpoint size is 4 bytes .
[ 0.511324] rk3368_init_ro ckchip_p mu_ops: could no t find p mu dt node
[ 0.51134 7] DDR DEBUG: ve rsion 1.00 20150126
[ 0.511 373] DDR DEBUG: Channel a:
[ 0.511382] DDR DEBUG: D DR3 Device
[ 0.51139 5] DDR DEBUG: Bus Width= 32 Col=1 0 Bank=8 Row=15 CS=1 Tot al Capability=10 24MB
[ 0.511404] DDR DEBUG: Channel b:
[ 0.5114 11] DDR DEBUG: DDR3 Devi ce
[ 0.511423] DDR D EBUG: Bu s Width=32 Col=1 0 Bank=8 Row=15 CS=1 Total Capab ility=10 24MB
[ 0.511 432] DDR DEBUG: addr=0xd ac000
[ 0.511442] DD R DEBUG: stride=9, size=256, hal fcap=400 00000
[ 0.51 1450] DD R DEBUG: socAddr [0]=0xda c000, socAddr[1] =0xdac10 0
[ 0.511460] DDR DEBUG: chA ddr[0]=0xdac000, chAddr[ 1]=0xdac000
[ 0.511471] DDR DEBUG: d tar[0]=0 x401b500 0, dtar[1]=0x401 b5000
[ 0.511560] DD R DEBUG: init success!!! freq=20 0MHz
[ 0.511 569] DDR DEBUG: Channel a:
[ 0.5115 81] DDR DEBUG: D TONE=0x1, DTERR=0x0, DTI ERR=0x0, DTPASS=4,0, DGS L=1,0 ex tra cloc k, DGPS=180,270
[ 0.511594] DDR DEBU G: DTONE =0x1, DTERR=0x0, DTIERR= 0x0, DTP ASS=4,0, DGSL=1, 0 extra clock, DGPS=180, 270
[ 0.511606] DDR DEBUG: D TONE=0x1, DTERR= 0x0, DTI ERR=0x0, DTPASS=4,0, DGS L=1,0 ex tra clock, DGPS= 180,270
[ 0.511619] DDR DEBU G: DTONE=0x1, DTERR=0x0, DTIERR= 0x0, DTPASS=4,0, DGSL=1, 0 extra clock, D GPS=180, 270
[ 0.511631] DDR DEBUG: ZERR=0, Z DONE=0, ZPD=0x0, ZPU=0x0, OPD=0x 0, OPU=0 x0
[ 0.51164 0] DDR DEBUG: DRV Pull-U p=0x19, DRV Pull-Dwn=0x1 9
[ 0.511649 ] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-D wn=0x2
[ 0.511656] DDR DEBUG : Channel b:
[ 0.51 1668] DD R DEBUG: DTONE=0 x1, DTER R=0x0, DTIERR=0x 0, DTPAS S=4,0, DGSL=1,0 extra cl ock, DGP S=180,270
[ 0.511680] DDR DEBUG: DTO NE=0x1, DTERR=0x0, DTIER R=0x0, D TPASS=4,0, DGSL= 1,0 extr a clock, DGPS=180,270
[ 0.511692] DDR DEBUG: DTONE=0 x1, DTERR=0x0, D TIERR=0x 0, DTPASS=4,0, D GSL=1,0 extra cl ock, DGPS=180,27 0
[ 0.511705] DDR DE BUG: DTO NE=0x1, DTERR=0x 0, DTIER R=0x0, DTPASS=4, 0, DGSL= 1,0 extr a clock, DGPS=180,270
[ 0.511716] DD R DEBUG: ZERR=0, ZDONE=0 , ZPD=0x 0, ZPU=0x0, OPD= 0x0, OPU =0x0
[ 0.511725] DDR DEBUG: DRV Pull-Up=0x19 , DRV Pu ll-Dwn=0x19
[ 0.511733] DDR DEBUG: O DT Pull- Up=0x2, ODT Pull-Dwn=0x2
[ 0 .536417] bio: create sla b at 0
[ 0.5 36903] R ockchip hdmi dri ver vers ion 2.0
[ 0. 536903] .
[ 0.538061 ] SCSI s ubsystem initial ized
[ 0.538222] usbcore: re gistered new interface d river us bfs
[ 0.5382 68] usbc ore: registered new inte rface dr iver hub
[ 0 .538351] usbcore: regist ered new device driver u sb
[ 0.540996] rockc hip_i2c ff650000 .i2c: i2c-0: Roc kchip I2 C adapter
[ 0.541565] rockchip_i2c f f140000. i2c: i2c-1: Rock chip I2C adapter
[ 0.542024] rockchip_i2c ff660000.i 2c: i2c- 2: Rockchip I2C adapter
[ 0.542275] rockchip_i2c ff1 50000.i2c: i2c-3: Rockch ip I2C adapter
[ 0.5 42400] media: Li nux medi a interface: v0. 10
[ 0.542442] Linux video c apture i nterface: v2.00
[ 0.542503] pps_core : LinuxP PS API v er. 1 registered
[ 0 .542513] pps_core: Softw are ver. 5.3.6 - Copyrig ht 2005-2007 Rod olfo Gio metti <g iometti@linux.it >
[ 0.542533] PTP cl ock supp ort registered
[ 0.542586] i2c-core: driver [bq24296 ] using legacy s uspend m ethod
[ 0.54 2596] i2c-core: driver [ bq24296] using legacy re sume met hod
[ 0.543282] ion_drm_heap _create: 0@0
[ 0.543 405] Rockchip io n module is successfully loaded (v1.1)
[ 0.543571] Advanced Linux Sound Arch itecture Driver Initiali zed.
[ 0.543973] Blu etooth: Core ver 2.16
[ 0.54 4027] NE T: Registered pr otocol f amily 31
[ 0 .544038] Bluetoo th: HCI device a nd conne ction manager in itialize d
[ 0.544053 ] Blueto oth: HCI socket layer in itialize d
[ 0.544067 ] Blueto oth: L2CAP socke t layer initialized
[ 0.5440 92] Bluetooth: S CO socke t layer initialized
[ 0.5443 22] cfg80211: Ca lling CR DA to update wor ld regul atory domain
[ 0.545 059] — rk_mipi_screen_p robe–
[ 0.545071] r k_mipi_s creen_init_dt: 3 05
[ 0.545232] rk_m ipi_scre en_init_ dt: lcd->screen_ init = 1 .
[ 0.545243 ] rk_mip i_screen_init_dt : mipi_l cd->dsi_ lane = 4.
[ 0.545254 ] rk_mipi_screen _init_dt : lcd->screen->h s_tx_clk = 389000000.
[ 0.54 5264] rk _mipi_screen_ini t_dt: lc d->screen.mipi_d si_num = 1.
[ 0.5453 26] rk_m ipi_screen_init_ dt: lcd- >screen- >lcd_rst_delay = 100.
[ 0.545358] lc d->lcd_r st_gpio=233,dsi- >lcd_rst _atv_val=1
[ 0.54536 8] rk_mi pi_screen_init_d t: Can n ot read property : mipi_l cd_en.
[ 0.5 45376] r k_mipi_screen_in it_dt: 4 28
[ 0.545442]
[ 0.545 442] childnode- >name =r ockchip,on-cmds1 :length= 2
[ 0.545456 ] cmd[1] =05 cmd[ 2]=11 dcs_cmd->d cs_cmd.c md_len=2
[ 0 .545476]
[ 0.545476 ] child node->name =rock chip,on- cmds2:le ngth=2
[ 0.5 45489] cmd[1]=05 cmd[2]= 29 dcs_c md->dcs_cmd.cmd_ len=2
[ 0.54 5507]
[ 0.5 45507] dcs_name:rockchi p,on-cmd s1,dcs_type:1,si de_id:0, cmd_len:2,delay: 150
[ 0.5455 07]
[ 0.545 524] [1]=05,[2]=11,
[ 0.5455 24] dcs_name:ro ckchip,o n-cmds2,dcs_type :1,side_ id:0,cmd _len:2,delay:10
[ 0.545524]
[ 0 .545543] [1]=05,[2]=29,- --rk_mip i_screen_probe-- end
[ 0.5456 45] act8846_i2c_ probe,li ne=898
[ 0.5 46622] act8846_parse_dt, line=746
[ 0.547098] act8846 _i2c_pro be: act8846_pmic _hold=1
[ 0.547118] act8846_ i2c_probe: act88 46_pmic_ sleep=1
[ 0.547132] act8846_ i2c_probe: act8846_pmic_ cpu_det_gpio=1
[ 0.5 47146] act8846_i 2c_probe : act884 6_pmic_usb_hub_r eset_gpi o=1
[ 0.549209] act_ dcdc1: 1200 mV
[ 0. 552185] vccio: 3300 mV
[ 0. 554064] vdd_logic: 700 < → 1500 mV at 1 125 mV
[ 0.557039] act_dcdc4: 2000 mV
[ 0.5582 57] vcci o_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.5605 67] act_ldo2: 10 50 mV
[ 0.562880] act_ldo3: 2800 mV
[ 0.565185 ] act_ld o4: 3300 mV
[ 0.567481] act_ldo5: 3 300 mV
[ 0.569805] act_ldo6: 1100 m V
[ 0.57211 3] vcc_1 8: 1800 mV
[ 0.574411] act_ldo8: 18 50 mV
[ 0.5 79176] vdd_arm: 712 ↔ 1500 mV at 1100 mV
[ 0.583878] vdd_gpu: 71 2 ↔ 1500 mV a t 900 mV
[ 0.584626] rk808_ i2c_prob e,line=1355
[ 0.585962] The device i s not rk 808 -11
[ 0. 586047] rk808: p robe of 0-001b f ailed wi th error -11
[ 0.586114] i2c-core: d river [r k818] using lega cy suspe nd metho d
[ 0.586123 ] i2c-co re: driver [rk81 8] using legacy resume m ethod
[ 0.587827] Switching to clock source arch_sys_ counter
[ 0.611305] rga: Module initialized.
[ 0 .612000] rga2 ff 920000.r ga: rga ion client creat e succes s!
[ 0.61217 1] rga: Driver loaded su ccesfull y
[ 0.612368 ] fb dis p policy is sdk
[ 0. 612410] rk-fb rockchip-f b: rk fb ion client crea te succe ss!
[ 0.612422] rk-f b rockch ip-fb: rockchip framebuf fer driver probe
[ 0 .612684] prmry screen ti ming par se success
[ 0.61270 0] rk-screen rk_ screen.8 : can’t find pow er_ctr n ode for lcdc0
[ 0.61 2709] pr mry screen power ctrl pa rse failed
[ 0.612775] extend screen timing parse success
[ 0.61 2822] pw r_ctr_name:lcd_e n
[ 0.612822] pwr_type:gpio
[ 0.612822] gpio:227
[ 0.612822] atv_val :1
[ 0.612822] delay:10
[ 0.612822]
[ 0.612853] extend scre en power ctrl pa rse success
[ 0.6128 65] rk-screen rk _screen. 8: rockchip scre en probe success
[ 0 .613318] Use EDP as prmry screen
[ 0 .613474] rk32-edp rk32-e dp: failed to ge t reset
[ 0.613487] rk32-edp rk32-ed p: failed to get reset
[ 0.613629] r k32-edp rk32-edp: 1829 r k32 edp driver probe suc cess
[ 0.613818] Use mipi_lc d as ext end screen
[ 0.61382 9] rk32-dsi
[ 0.613950] rk32_mipi_ds i_probe: 1840:dsi ->host.irq =51
[ 0.6 13968] mipi dsi chip is not found, read id:fffff fff, but 3133302 a is cor rect
[ 0.613981] rk3 2-mipi f f960000.mipi: rk mipi_ds i probe fail!
[ 0.61 3993] rk32-mipi ff960000 .mipi: r ockchip mipi_dsi v1.1 2014-06-17
[ 0 .614022] rk32-mipi: prob e of ff9 60000.mi pi failed with e rror -1
[ 0.614750] graphics fb0: rockchip framebuff er registerd:fb0
[ 0 .615057] graphics fb1: r ockchip framebuffer regi sterd:fb 1
[ 0.615232 ] graphi cs fb2: rockchip framebu ffer reg isterd:fb2
[ 0.615399] graphics fb3: rockchi p framebuffer re gisterd: fb3
[ 0.6160 11] rk32 88-lcdc lcdc0: lcdc0: dc lk:13260 0000>>fps:51
[ 0.61 6221] rk32-edp r k32-edp: edp pll locked
[ 0.639453] rk_battery_charg er_detec t_cb , battery_c harger_d etect 1
[ 0. 674148] rk32-edp rk32-ed p: 955 m ax link rate:0.0Gps max number o f lanes:0
[ 0.674163] rk32-edp rk32- edp: Rx Mx Link Rate is abnormal :0!defau lt link rate:1.6 2Gps
[ 0.674176] rk32-edp rk 32-edp: Rx Max L ane coun t is abn ormal :0 !use de fault la nes:4
[ 0.68 0111] rk32-edp rk32-edp: hw lt e rr:1
[ 0.680 122] rk3 2-edp rk32-edp: link tra in faile d!
[ 0.74128 2] rk32- edp rk32-edp: 12 20 EDID_ ADDR50 rom_addr 0 LENGTH 80
[ 5.426318] rk3 2-edp rk 32-edp: EDID Rea d failed !
[ 5.426332 ] rk3288-lcdc lcdc0: wak eup from standby !
[ 5.451366 ] alloc_buffer:ion_phy_a ddr=0x55 c00000
[ 5.4 63946] f b0:phy:55c00000> >vir:e0991000>>l en:0x1800000
[ 5.463 963] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu di sabled
[ 5.464401] g raphics fb4: rockchip fr amebuffe r registerd:fb4
[ 5. 464732] graphics fb5: ro ckchip f ramebuffer registerd:fb5
[ 5.464907] graphics fb6: rockchip framebuf fer registerd:fb 6
[ 5.465073] graphics fb7: rockchip framebuffer reg isterd:f b7
[ 5.47524 7] rk3288-lcdc lcdc1: lc dc1: dcl k:176800 000>>fps:220
[ 5.475262] rk3288-lcd c lcdc1: wakeup from sta ndby!
[ 5.475274] fb 4:phy:55c00000>> vir:e0991000>>le n:0x1800 000
[ 5.4753 02] rk3288-lcdc lcdc1: l cdc1 pro be ok, iommu dis abled
[ 5.47 6192] rockchip_s et_mux:w arning ignore ba nk num 1 5
[ 5.476321 ] rockchip_set_m ux:warning ignor e bank n um 15
[ 5.47 6443] rockchip_set_mux:w arning i gnore bank num 1 5
[ 5.476561 ] rockchip_set_m ux:warni ng ignore bank n um 15
[ 5.476679] rockchip_s et_mux:warning i gnore ba nk num 1 5
[ 5.476792 ] rockchip_set_mux:warni ng ignor e bank num 15
[ 5.47 7361] rockchip_s et_mux:w arning i gnore bank num 1 5
[ 5.477515] rockchip_set_m ux:warning ignor e bank n um 15
[ 5.47 8057] rockchip_s et_mux:warning i gnore ba nk num 15
[ 5.478212 ] rockchip_set_m ux:warning ignore bank n um 15
[ 5.47 8756] rockchip_s et_mux:w arning ignore ba nk num 1 5
[ 5.478904 ] rockchip_set_m ux:warning ignor e bank n um 15
[ 5.47 9455] rockchip_set_mux:w arning i gnore bank num 1 5
[ 5.479604 ] rockchip_set_m ux:warni ng ignore bank n um 15
[ 5.481141] NE T: Registered protocol f amily 2
[ 5. 481806] TCP established hash table entri es: 4096 (order: 3, 3276 8 bytes)
[ 5.481881] TCP bind hash t able entries: 40 96 (orde r: 3, 32768 byte s)
[ 5.481954] TCP: Hash tab les configured ( establis hed 4096 bind 4096)
[ 5.482018] TCP: reno re gistered
[ 5.482034] UDP has h table entries: 256 (or der: 1, 8192 bytes)
[ 5.482058] UDP-Lite has h table entries: 256 (or der: 1, 8192 byt es)
[ 5.4822 52] NET: Registered prot ocol fam ily 1
[ 5.48 2860] Un packing initramf s…
[ 5.621 489] Freeing ini trd memo ry: 2840K (c5bf0 000 - c5 eb6000)
[ 5. 622323] hw perfevents: e nabled w ith ARMv 7 Cortex-A12 PMU driver, 7 counters avai lable
[ 5.622888] vcodec_ser vice: probe devi ce ff9a0 000.vpu_ service
[ 5. 623104] vcodec_service: No reset resource define
[ 5 .623293] vcodec_ service: ff9a000 0.vpu_service: p ower on
[ 5.623383] vcodec_s ervice: probe de vice ff9a0000.vpu_servic e
[ 5.623398 ] vcodec_service : checki ng hw id 4831
[ 5.624442] vcodec_ser vice: ff 9a0000.v pu_service: powe r off…
[ 5.624487] vcodec_service: done
[ 5.62 4496] vcodec_ser vice: in it succe ss
[ 5.624568] vcode c_service: probe device ff9c0000.hevc_se rvice
[ 5.624925] vcodec_ser vice: ff 9c0000.hevc_serv ice: pow er on
[ 5.624989] vc odec_service: pr obe devi ce ff9c0000.hevc _service
[ 5 .625004] vcodec_service: checking hw id 6867
[ 5.625562] vcodec_serv ice: ff9c0000.he vc_servi ce: powe r off…
[ 5 .625604] vcodec_service: done
[ 5.625612] vc odec_ser vice: init succe ss
[ 5.625752] rknandbase v1 .0 2014- 03-31
[ 5.62 5886] rk nand: probe of f f400000. nandc fa iled with error -1
[ 5.626030] rknand_driver :ret = 0
[ 5.627177 ] audit: initial izing ne tlink so cket (disabled)
[ 5.627223] type=200 0 audit( 5.360:1): initia lized
[ 5.628068] bo unce poo l size: 64 pages
[ 5 .632648] fuse init (API version 7.22)
[ 5.63 3025] ms gmni has been se t to 952
[ 5 .634801] Block layer SCS I generic (bsg) driver v ersion 0.4 loade d (major 246)
[ 5.63 4816] io schedul er noop register ed
[ 5.634826] io sc heduler deadline registe red
[ 5.634922] io scheduler cfq reg istered (default )
[ 5.636613] IEP Driver loa ded succesfully
[ 5. 636705] Module initializ ed.
[ 5.637485] dma-pl330 ff b20000.pdma: Loa ded driv er for PL330 DMA C-236420 8
[ 5.637501] dma-pl330 ffb2 0000.pdma: DBUF F-64x8by tes Num_Chans-5 Num_Peri -6 Num_Events-10
[ 5.638838] dma-pl330 ff250 000.pdma : Loaded driver for PL33 0 DMAC-2364208
[ 5.638855] dma-pl330 ff25000 0.pdma: DBUFF-128x8byte s Num_Chans-8 Num_Peri-2 0 Num_Ev ents-16
[ 5.639133] pwm-voltage-regulator pwm_regula tor.22: unable t o request PWM, trying le gacy API
[ 5.639147] pwm-vol tage-regulator pwm_regul ator.22: unable to request legac y PWM
[ 5.639156] pw m_regulator_probe:error
[ 5. 639178] platform pwm_reg ulator.22: Driver pwm-vo ltage-regulator requests probe deferral
[ 5.639386] rk_serial.c v1.8 2014-03 -04
[ 5.6396 10] ff180000.serial: tty S0 at MMIO 0xff180000 (i rq = 87) is a rk29_serial.0
[ 5.639796] serial ff180 000.serial: membase e219 2000
[ 5.639945] ff690000.se rial: ttyS2 at MMIO 0xff 690000 ( irq = 89) is a rk29_seri al.2
[ 5.640 039] 2, baud is:115200
[ 5.641747] c onsole [ttyS2] enabled
[ 5.641935] serial ff 690000.serial: m embase fed60000
[ 5. 644767] loop: mo dule loaded
[ 5.645160] zram: Create d 1 device(s) …
[ 5.645242] i2c-co re: driver [mpu6 050B1] using legacy susp end method
[ 5.64525 5] i2c-core: driver [mpu 6050B1] using legacy resume meth od
[ 5.645272] mpu_i nit: Probe name mpu6050B 1
[ 5.645427] ak8963_mod_ini t: Probe name ak8963_mod
[ 5 .646178] SCSI Media Chan ger driver v0.25
[ 5.646436] dws->r egs: e21be000
[ 5.647678] ro ckchip_spi_probe:num_cs= 2,bus_num=0,irq=76,freq= 45692308 ok
[ 5.647982] tun: Univers al TUN/TAP devic e driver , 1.6
[ 5.64 7996] tu n: (C) 1 999-2004 Max Kra snyansky <maxk@q ualcomm.com>
[ 5.648 119] vmac_init.
[ 5.648686] stmmac_probe_con fig_dt: Can not read pro perty: pmu_regulator.
[ 5.64 8703] stmmac_pro be_confi g_dt: cl ock input/output? (input ).
[ 5.64871 6] stmma c_probe_config_d t: TX de lay(0x30).
[ 5.648728] stmma c_probe_config_d t: RX de lay(0x20).
[ 5.64877 7] stmmac_probe_ config_d t: is rockchip,r k3288-gm ac
[ 5.648788] stmmc_pltfr_i nit:
[ 5.648 798] stm mc_pltfr_init: E RROR: Ge t power-gpio fai led.
[ 5.648 830] gmac_phy_re set: ERR OR: Request pin stmmc_pl tfr_init failed.
[ 5 .648842] stmmc_p ltfr_ini t: init for RGMII
[ 5.648853 ] tx delay=0x30
[ 5. 648853] rx delay =0x20
[ 5.64 8869] tx delay=0 x30
[ 5.648869] rx d elay=0x2 0
[ 5.649341 ] stmmac - user ID: 0x10 , Synops ys ID: 0 x35
[ 5.6493 54] Nor mal descriptors
[ 5. 649363] Ring mo de enabl ed
[ 5.64937 4] DMA HW capab ility register s upported
[ 5.649386] RX Che cksum Offload En gine sup ported (type 2)
[ 5. 649396] TX Checksum ins ertion s upported
[ 5 .649405] Wake-Up On Lan support ed
[ 5.64944 4] Enab le RX Mi tigation via HW Watchdog Timer
[ 5.6 49900] P PP generic drive r versio n 2.4.2
[ 5. 650049] PPP BSD Compression modu le regis tered
[ 5.65 0063] PP P Deflate Compre ssion mo dule reg istered
[ 5. 650085] PPP MPPE Compres sion mod ule registered
[ 5.6 50099] NET: Regi stered p rotocol family 24
[ 5.650137 ] SLIP: version 0.8.4-NE T3.019-NEWTTY (d ynamic c hannels, max=256 ) (6 bit encapsu lation enabled).
[ 5 .650151] CSLIP: code cop yright 1989 Rege nts of t he University of Califor nia.
[ 5.650165] Roc kchip Wi Fi SYS interface (V1.00) …
[ 5.65 0198] esp_mem_init enter date Ma r 20 201 7 00:37:10
[ 5.65021 0] esp_mem_init VERSION [V2.5]
[ 5.6 50254] e sp_mem_i nit complete
[ 5.650340] usbcore: r egistere d new interface driver c atc
[ 5.6503 79] usbc ore: reg istered new inte rface driver kaweth
[ 5.6503 92] pegasus: v0. 9.3 (201 3/04/25), Pegasu s/Pegasu s II USB Ethernet driver
[ 5 .650437] usbcore: regist ered new interfa ce drive r pegasus
[ 5.650476] usbcor e: registered ne w interf ace driver rtl81 50
[ 5.650514] usbco re: regi stered new inter face driver r815 2
[ 5.650526 ] hso: d rivers/net/usb/h so.c: Op tion Wireless
[ 5.65 0597] usbcore: r egistere d new in terface driver hso
[ 5.650641] usbcore: regi stered new inter face dri ver asix
[ 5 .650681] usbcore : registered new interfa ce driver ax8817 9_178a
[ 5.650725] u sbcore: register ed new interface driver cdc_ether
[ 5.650764 ] usbcore: regis tered ne w interface driv er cdc_e em
[ 5.650802] usbcore: regi stered new inter face dri ver dm9601
[ 5.65083 9] usbcore: regi stered n ew interface driver dm96 20
[ 5.650886] usbco re: regi stered new inter face dri ver smsc75xx
[ 5.650931] usb core: registered new int erface driver sm sc95xx
[ 5.650976] usbcore: registered new i nterface driver gl620a
[ 5.6 51016] u sbcore: register ed new i nterface driver net1080
