UI is not smooth with Linux
I am currently using RK3399 with Expansion board and POE image file. But, the Firefly UI doesn’t respond to the commands. I have to click on Shutdown atleast 10 times before it activates the command. Has anyone experienced this and is there any solution?
On a Raspberry Pi. Reflash and see if it persists? What about amd x64 Kali?
I have reflashed the board several times but it still has the same problem.
slow refresh? commands (ie “command prompt”) or GUI?
POE image file?
GUI and Development board with POE and Expansion Board
You implied there’s an image to use the expansion? And you’re saying that running commands is slow? If you boot up and then shut down after a full boot is it still slow?
UI is not responsive even after full boot up.
Switch the flash/eMMC and boot up 16.04…persistent? If so, seems hardware related. Put an ssd in the expansion? Brand? What about Wifi/bt e key? Brand?
How is it being powered? Which that up too. If using POE switch to usbc…
Could you send me a bootup Image file with Ubuntu 16.04 including kernel?
http://wiki.t-firefly.com/en/NCCS1/images.html#ubuntu-16-04
Grab it from above…
