SDK包名称:rk356x_linux5.10_release_20241220_v1.4.0c.xml
SDK修改内容:基于SDK编译 修改了蓝牙通话模式 。
Log日志:wifi起不来被软锁.zip
大佬帮看看日志里面wifi怎么起不来。折腾好几天了。
###AMPAK FW Auto detection patch version = [v1.1 20161117]###
FW folder path = /system/etc/firmware
port --no2bytes could not be opened, error 2
Successfully initialized wpa_supplicant
rfkill: WLAN soft blocked
[ 8.732120] [dhd] CFG80211-ERROR) wl_cfg80211_add_virtual_iface : device is not ready
Failed to create interface p2p-dev-wlan0: -19 (No such device)
nl80211: Failed to create a P2P Device interface p2p-dev-wlan0
P2P: Failed to enable P2P Device interface
[ 8.835324] rk-pcie 3c0000000.pcie: PCIe Link Fail, LTSSM is 0x3, hw_retries=1
[ 9.116259] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host high!
[ 9.141963] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host input!
[ 9.142036] [BT_RFKILL]: ENABLE UART_RTS
[ 9.248639] [BT_RFKILL]: DISABLE UART_RTS
[ 9.248723] [BT_RFKILL]: bt turn on power
[ 9.248746] [BT_RFKILL]: Request irq for bt wakeup host
[ 9.248779] [BT_RFKILL]: ** disable irq
[ 9.391899] dwhdmi-rockchip fe0a0000.hdmi: failed to get edid
[ 9.443809] dwhdmi-rockchip fe0a0000.hdmi: failed to get edid
[ 9.454911] watchdog: watchdog0: watchdog did not stop!
[ 9.455091] watchdog: watchdog0: watchdog did not stop!
鏂版棩蹇鈫/doc/log/startup_20260509_174943.log
QStandardPaths: runtime directory ‘/var/run’ is not a directory, but a symbolic link to a directory permissions 0755 owned by UID 0 GID 0
[ 9.851984] rk-pcie 3c0000000.pcie: failed to initialize host
[ 9.880272] dwhdmi-rockchip fe0a0000.hdmi: failed to get edid
QCssParser::parseHexColor: Unknown color name ‘#01C3D74’
Could not parse application stylesheet
mpi_vo 09:49:44-865 {RK_MPI_VO_DisableL:1090} layer 0 had already been diabled
mpi_vo 09:49:44-866 {RK_MPI_VO_DisableL:1090} layer 0 had already been diabled
mpi_vo 09:49:44-866 {RK_MPI_VO_DisableL:1090} layer 2 had already been diabled
mpi_vo 09:49:44-866 {RK_MPI_VO_DisableL:1090} layer 4 had already been diabled
mpi_vo 09:49:44-866 {RK_MPI_VO_DisableL:1090} layer 5 had already been diabled
mpi_vo 09:49:44-866 {RK_MPI_VO_DisableL:1090} layer 6 had already been diabled
wifi起不来被软锁.zip (22.9 KB)
