2. Camera Capture, Preview, and Recording — The FFMedia Getting Started Series
This section uses FFMedia SDK 2.6.1 as an example, and with the prebuilt ffmedia CLI builds a complete pipeline of camera capture → window preview → H.265 hardware encoding → MP4 recording.
Preparing the Environment
Hardware Environment
Prepare the following hardware:
  • Firefly RK platform (for example, ROC-RK3588-RT running Firefly Ubuntu 22.04)
  • A USB camera or another video source that the Firefly platform can recognize as a video device
After connecting the camera to the target platform, first check the video device path, permissions, and supported formats:
ls -l /dev/video*
v4l2-ctl -d /dev/video0 --all          # Show device details
v4l2-ctl -d /dev/video0 --list-formats-ext   # Show supported formats
Software Environment
Extract the SDK release package and confirm the CLI works:
tar -xzvf ffmedia_release-2.6.1.tar.gz
cd ffmedia_release-2.6.1
./bin/ffmedia --help
./bin/ffmedia run --help
Check which modules are available at runtime:
./bin/ffmedia modules
./bin/ffmedia params cam
./bin/ffmedia params mpp-enc
./bin/ffmedia params renderer-video
./bin/ffmedia params file-writer
The four modules used in this section’s pipeline:
Module Category Purpose
cam Input (vi) Capture raw camera frames via V4L2
renderer-video Output (vo) Display the camera image in a window
mpp-enc Process (vp) Encode raw frames to H.265 using Rockchip MPP
file-writer Output (vo) Mux the encoded stream into an MP4 file
Verifying the Camera Works (Capture Only)
Start with the simplest pipeline — capture only, no display — to verify that the camera works:
./bin/ffmedia run \
  -m src=cam \
  -p 'src:device=/dev/video0;capture{width=1920;height=1080}'
This command:
  • Uses -m src=cam to declare a capture module instance named src
  • Uses -p to set the device path and capture resolution (sub-parameters separated by ;)
  • Connects no Consumer, so there is no window and no output file
If this command runs without errors, the camera has been correctly recognized.
Adding Window Preview
On top of capture, add a display module to preview the captured image.
Pipeline Structure
Full Command
./bin/ffmedia run \
  -m src=cam \
  -p 'src:device=/dev/video0;capture{width=1920;height=1080}' \
  -m dis=renderer-video \
  -c src=dis
Command Breakdown
Part Meaning
-m src=cam Declare the capture module instance src
-p 'src:device=...;capture{...}' Specify the device path and capture resolution; multiple sub-parameters are separated by ;
-m dis=renderer-video Declare the window rendering module instance dis
-c src=dis Connect src → dis; omitting the channel number uses the default channel, equivalent to src@0=dis
Configuring the Preview Window Position and Size
You can configure the preview window’s position and size via the window parameter (for example, position (200, 0) and size 640×480):
./bin/ffmedia run \
  -m src=cam \
  -c src=dis \
  -p 'dis:window{x=200;y=0;width=640;height=480}'
The preview window will display at the configured position and size. Press Ctrl + C to stop the preview.
Previewing and Recording Simultaneously (Branch Pipeline)
One of FFMedia’s core features is that a single Producer can connect to multiple Consumers. This step splits the cam output into two paths:
  • Branch 1: fed directly to renderer-video for window preview
  • Branch 2: fed to mpp-enc to encode as H.265, then to file-writer to mux into an MP4 file
The two branches do not affect each other and share the same captured data.
Pipeline Structure
Full Command
./bin/ffmedia run \
  -m src=cam \
  -p 'dis:window{x=200;y=0;width=640;height=480}' \
  -c src=dis \
  -m enc=mpp-enc \
  -p 'enc:encode/codec=6' \
  -c src=enc \
  -m mux=file-writer \
  -p 'mux:path=/home/firefly/Videos/test.mp4' \
  -c enc=mux
Breakdown of the Newly Added Options
Part Meaning
-m enc=mpp-enc Declare the hardware encoding module instance enc
-p 'enc:encode/codec=6' Set the encoding format to 6, which means H.265 (encode/codec is a sub-parameter path)
-c src=enc Branch the capture output into the encoding module (the second Consumer of the same Producer)
-m mux=file-writer Declare the file output module instance mux
-p 'mux:path=...' Specify the MP4 output path
-c enc=mux Feed the encoded stream into the mux/file-writing module
Throughout the command, the cam instance is always named src, and it connects to two Consumers at the same time via -c src=dis and -c src=enc. This is the most direct demonstration of “one Producer → multiple Consumers” — no additional dispatch logic is needed; the framework handles it automatically.
Video Codec Enumeration Reference
Values of the encode/codec parameter correspond to different video encoding formats; common values are as follows:
Enum Name Integer Value Description
MEDIA_CODEC_UNKNOWN 0 Unknown codec format
MEDIA_CODEC_VIDEO_VCM 1 VCM video encoding
MEDIA_CODEC_VIDEO_MPEG4 2 MPEG-4 video encoding
MEDIA_CODEC_VIDEO_MPEG1 3 MPEG-1 video encoding
MEDIA_CODEC_VIDEO_MPEG2 4 MPEG-2 video encoding
MEDIA_CODEC_VIDEO_H264 5 H.264 (AVC) video encoding
MEDIA_CODEC_VIDEO_H265 6 H.265 (HEVC) video encoding ← used in this section’s example
MEDIA_CODEC_VIDEO_VP8 7 VP8 video encoding
MEDIA_CODEC_VIDEO_VP9 8 VP9 video encoding
MEDIA_CODEC_VIDEO_AV1 9 AV1 video encoding
MEDIA_CODEC_VIDEO_MJPEG 10 Motion JPEG video encoding
MEDIA_CODEC_VIDEO_H266 11 H.266 (VVC) video encoding
MEDIA_CODEC_VIDEO_RAW 12 Raw video data
For details, refer to the SDK’s include/ffmedia/base/ff_type.hpp.
Verifying the Recording
After running, you can observe both of the following at the same time:
  • Display window: real-time preview of the camera image
  • Videos folder: the test.mp4 file keeps growing during recording
After stopping the pipeline normally with Ctrl + C, open test.mp4 with a system player to play back the camera footage that was captured.
Note: MP4 is a container format, so it requires a graceful stop (Ctrl+C or kill -INT <PID>) to write the file index completely. If the process is force-killed (for example, with kill -9), the file may be zero bytes, have an abnormal duration, or be entirely unplayable. Always exit gracefully with Ctrl+C during day-to-day debugging.
Summary
This section used one real pipeline to turn the three CLI essentials from the previous section into runnable commands:
  1. Step 1 (capture only): use cam to verify the camera works, as the basis for subsequent steps;
  2. Step 2 (add preview): add renderer-video and complete the first connection via -c src=dis to achieve window preview;
  3. Step 3 (add recording): building on step 2, add mpp-enc + file-writer and wire up the second connection via -c src=enc and -c enc=mux — one Producer → multiple Consumers.
