Armbian and LibreELEC for rk3399
Added new versions of armbiantv images with the legacy kernel with different DE (XFCE\Mate\Lxde) for use with the HW video acceleration media script.
https://yadi.sk/d/_nL2P2g2VRtLrQ?w=1
New versions
Armbian 20210109 kernel 5.9.16 \ 4.4 (please note that now all versions with the “new” and " old " kernel are in the same directory).
ArmbianTV 20210109 kernel 5.10.5
LibreELEC 20210108 kernel 5.10.5.
ArmbianTV 20210119 kernel 5.10.8
Libreelec 20210118 kernel 5.10.8
Armbian 20210123 kernel 5.10.9
ArmbianTV 20210123 kernel 5.10.9
LE 20210121 kernel 5.10.9
Please note that the composition of the images has changed. Now the main versions are Debian-12 Sid and Ubuntu-21.04 Hirsute. For Bullseye and Focal, only minimal server images are used (but you can install DE on them yourself). For those who need other versions of the distribution, I recommend using a self-build of the desired version directly on the device itself. To do this, there is a great video on how to build your distribution versions (your images) directly on M1 and P1.
Armbian 20210129 kernel 5.10.11
ArmbianTV 20210129 kernel 5.10.11
LE 20210129 kernel 5.10.11
The new version Armbian 20210204 and ArmbianTV 20210204-legacy.
Added support for NVMe analog audio and remote control.
Updated the Armbian\ArmbianTV images (20210211) kernel 5.10.15\4.4.
I checked both variants of Buster-legacy + media script on P1 (rk3399). I froze the kernel update, installed the script, checked the HW acceleration, everything works. Including remote control in KODI and on the desktop, analog sound works (by default, the sound level is set low, you need to go to settings and increase the volume), 4k works. :slight_smile:
Update Libreelec 20210211 kernel 5.10.15
New version of ArmbianTV 20210218. kernel 5.10.17 4.4
An important difference.
I made the transition to the startup system using the settings only in the “extlinux.conf” file. You no longer need to use a lot of complex scripts and intermediate text files to describe the startup process. Setting up the DTB is done by editing the line in “extlinux.conf”. There you can also change any other startup parameters (disable BOOTFLASH, add a forced binding to the MAC, etc.). That is, you can now use the officially supported parameter format for “extlinux.conf”. I also stop publishing versions of Armbian images, because they differ little from the official versions of images from the Armbian download site (i.e. I remove redundant duplication).
Libreelec 20210218 kernek 5.10.17
The new version 20210221.
Important information.
The installation mode in eMMC has changed. Now, the standard application “armbian-config” and the corresponding menu items in it are used for installation in eMMC.
Version 20210226 ArmbianTV.
Fixed NVMe and added a separate DTB for roc-rk3399-pc with Legacy kernel.
After testing for several weeks u-boot-2021.01 on different rk3399, the transition to u-boot-2021.01 was made
I remind you that the configuration of DTB and other startup parameters is now performed in the file /boot/extlinux/extlinux.conf
LE ver 20210226
New version ArmbianTV 20210311. Kernel 5.10.22.
Please note. The composition of the images has changed. The name of the download folder has changed.
LE ver 20210311
Update ArmbianTV to version 20210319.
Using kernel 5.10.24. Added support for Firefly-rk3399 in station-p1 images (for proper operation, you need to configure DTB in extlinux.conf). With the correct DTB setup, the HDMI audio LAN WiFi BT works in kernel 5.10. In kernel 4.4 worck remote control and analog sound.
Update Libreelec 20210319/
Add support Firefly-rk3399 (for proper operation, you need to configure DTB in extlinux.conf)
Ver ArmbianTV and Libreelec - 20210409 kernel 5.10.28
i can not boot my roc-rk3399-pc with Armbian_21.08.0-trunk_Station-p1_buster_current_5.10.32.img.
Power auto down.
ddown Posted at 5/4/2021 11:03
P …
You need to properly configure the DTB in the /extlinux/extlinux.conf file for roc-rk3399-pc.
Ver ArmbianTV 20210505 kernel 5.10.34
LibreELEC ver 20210505 kernel 5.10.34
balbes150 Posted at 5/5/2021 15:12
I had change it.
But not working
ddown Posted at 5/9/2021 08:27
I had change it.
But not working
Provide more information about what steps you are doing, the UART log.
