Core-1126-JD4 linux sdk编译报错
SDK包名称:rv1126_rv1109_linux_ai_camera_release_20210306
SDK修改内容:未作修改
Log日志:build.log
解压缩后:
.repo/repo/repo sync -l.repo/repo/repo sync -c --no-tags.repo/repo/repo start firefly --all
./build.sh aio-rv1126-uvcc.mk ./build.sh编译kernel时报错:arch/arm/boot/dts/rv1126-firefly-jd4.dtb: ERROR (phandle_references): /ethernet@ffc40000: Reference to non-existent node or label "rgmiim1_pins"arch/arm/boot/dts/rv1126-firefly-jd4.dtb: ERROR (phandle_references): /ethernet@ffc40000: Reference to non-existent node or label "clk_out_ethernetm1_pins"ERROR: Input tree has errors, aborting (use -f to force output)make[1]: *** [scripts/Makefile.lib:307: arch/arm/boot/dts/rv1126-firefly-jd4.dtb] Error 2make: *** [arch/arm/Makefile:358: rv1126-firefly-jd4.dtb] Error 2ERROR: Running build_kernel failed!ERROR: exit code 2 from line 561:
build.log (1.15 MB)
