OK found a fix, install “Market Helper” set device to Tablet>Nvidia Shield, then set Country and Carrier. This will alow more downloads, however i still got errors. So I changed the Android ID to that of my phone, and clear play store cache. Now I can download everything!
No longer works for some reason - just installs the market helper which doesn’t work despite active wifi connection. I’ve seen a lot of read/write errors in the script - any ideas how do I install google apps? Tried multiple options - none work.
No longer works as euroeffie’s said. I’ve also seen a lot of read/write errors in the script. Btw maybe the cause is Google update their authentification method. Just another case, a few days ago i install gapps on my android with old apps (google service, service framework, etc) but it doesn’t work but after install new app from apkmirror and androidapksbox it works. Or any update about the tutorial @BiatuAutMiahn?
This script has not been updated since 2017 is not guaranteed to work. When making this script I simply follow the script in the gApps install script and did the equivalent commands via ADB.
At some point I may write a wrapper that will interpret a flashable ZIP and install it via adb.
Certvalue is the top ISO 27018 Consultants in Bahrain for providing ISO 27018 Certification in Manama, Riffa, Hamad Town, Sitra ,Budaiya and other major Cities in Bahrain with services of implementation.
