Linux 6.1 SDK编译固件无法安装libgstreamer-plugins-base1.0-dev
SDK包名称:Firefly_RK3588_Linux6.1_SDK
SDK修改内容:prebuilt_rootfs使用Ubuntu22.04-Xfce_COMMON_v3.11-71_20260512.img
Log日志:MobaXterm_192.168.137.45_20260611_112525.txt
官方链接下载Linux 6.1 SDK并更新bundle。使用官方提供的rootfs(Ubuntu22.04-Xfce_COMMON_v3.11-71_20260512)生成update.img固件并写入后:
1、apt update无法连接Firefly官方源,显示Could not connect to wiki.t-firefly.com:80 (0.0.0.0);hosts、sources.list、resolv.conf未进行任何修改,且其他源可正常连接;
2、apt安装libgstreamer-plugins-base1.0-dev时,显示The following packages have unmet dependencies:
libgbm-dev : Depends: libgbm1 (= 23.2.1-1ubuntu3.1~22.04.3)
libudev-dev : Depends: libudev1 (= 249.11-0ubuntu3.21) but 249.11-0ubuntu4.16 is to be installed
通过apt policy libudev1 libudev-dev libgbm1 libgbm-dev查看,libudev1:安装和候选都是249.11-0ubuntu4.16,Version table包含4.16 100 /var/lib/dpkg/status和3.21 500 ustc jammy-updates/main arm64 Packages;libudev-dev:安装(none),候选249.11-0ubuntu3.21;libgdm1:安装和候选都是25.0.7-0ubuntu0.24.04.1,Version tabl包含3个:25.0.7,23.2.1,22.0.1;libgbm-dev安装None,Version table包含23.2.1和22.0.1
目前编译OpenCV 4.8.0时无法使用gstreamer。
MobaXterm_192.168.137.45_20260611_112525.txt (14.5 KB)
