Hi everyone,
I am working on a project using the Firefly ROC-RK3566-PC (v1.2) board and I need to connect to two separate Wi-Fi networks simultaneously:
Using the onboard Wi-Fi module for Internet connectivity.
Using an external USB Wi-Fi adapter to connect to a Wi-Fi Digital Microscope Camera for live video feed.
The Problem: When I connect to the microscope camera using the onboard Wi-Fi, I can receive the video stream fine, but the board loses its internet connection since the camera network does not provide internet access. To resolve this, I want to attach an external USB Wi-Fi adapter and split the network traffic.
However, when I try to compile the driver for the USB Wi-Fi adapter on the board (via DKMS or building from source using make), I hit a Kernel Headers dependency error. The board runs Linux kernel version 4.19.232, but I have not been able to install the matching linux-headers-4.19.232 packages on the system via the SDK or Ubuntu repositories.
Available USB Wi-Fi Dongles:
Realtek RTL8192EU
MediaTek MT7601U
Questions:
How can I install or generate the Linux 4.19.232 kernel headers on the Firefly Ubuntu image/SDK to compile modules on-device?
What are the steps to add the MT7601U or RTL8192EU drivers to the Firefly kernel configuration (
make menuconfig) and compile them as modules via the SDK cross-compilation environment? -
Is there a different USB Wi-Fi chipset you would recommend that works out-of-the-box with Linux Kernel 4.19 on RK3566?
best regards
Alpaslan Sahan
