固件文件名称:0622最新的固件,linux ubuntu20环境固件
固件下载地址:…
Log日志:1.zip
错误如下:
模拟都正常,联机后出现的,请大佬指教,linux ubuntu20环境固件
I rknn buiding done
done
→ Export rknn model
done
→ Init runtime environment
I target set by user is: rk3588
I Starting ntp or adb, target is RK3588
I Device [470342e0551dad2c] not found in ntb device list.
I Start adb…
I Connect to Device success!
I NPUTransfer: Starting NPU Transfer Client, Transfer version 2.1.0 (b5861e7@2020-11-23T11:50:36)
D NPUTransfer: Transfer spec = local:transfer_proxy
D NPUTransfer: Transfer interface successfully opened, fd = 4
D RKNNAPI: ==============================================
D RKNNAPI: RKNN VERSION:
D RKNNAPI: API: 1.3.0 (121b661 build: 2022-04-29 11:07:20)(null)
D RKNNAPI: DRV: rknn_server: 1.3.0 (121b661 build: 2022-04-29 11:12:02)
D RKNNAPI: DRV: rknnrt: 1.3.0 (c193be371@2022-05-04T20:16:33)
E RKNNAPI: rknn_init, msg_load_ack fail, ack = 1(ACK_FAIL), expect 0(ACK_SUCC)!
D NPUTransfer: Transfer client closed, fd = 4
E init_runtime: Catch exception when init runtime!
E init_runtime: Traceback (most recent call last):
E init_runtime: File “rknn/api/rknn_base.py”, line 2011, in rknn.api.rknn_base.RKNNBase.init_runtime
E init_runtime: File “rknn/api/rknn_runtime.py”, line 361, in rknn.api.rknn_runtime.RKNNRuntime.build_graph
E init_runtime: Exception: RKNN init failed. error code: RKNN_ERR_MODEL_INVALID
Init runtime environment failed!
1.zip (1.34 KB)
