RK3566板子接通信模组没法ping通百度
Hi:
rk3566外设usb接口接着通信模组,ifconfig看可以枚举出网卡,DNS通过setprop net.eth1.dns命令进行了设置,但是依旧没法通ping通百度,这个设置
DNS具体怎么设置?
不对吧,通信模组,那不应该设置eth1网卡吧
是这个网卡,这个可以确定。
ifconfig -a看一下
android系统,如果手动关闭eth0,接上USB以太网开启eth1的话,要让eth1能够连外网,需要在板子的/vendor/build.prop里添加如下属性:
ro.net.eth_primary=eth1
或者修改SDK源码,重新编译固件
diff --git a/device/rockchip/rk356x/rk3566_roc_pc/rk3566_roc_pc.mk b/device/rockchip/rk356x/rk3566_roc_pc/rk3566_roc_pc.mk
index 963dce12154..e05701e3e3a 100644
--- a/device/rockchip/rk356x/rk3566_roc_pc/rk3566_roc_pc.mk
+++ b/device/rockchip/rk356x/rk3566_roc_pc/rk3566_roc_pc.mk
@@ -45,6 +45,7 @@ PRODUCT_PROPERTY_OVERRIDES += vendor.hwc.device.primary=HDMI-A
 PRODUCT_PROPERTY_OVERRIDES += ro.sf.lcd_density=280
 PRODUCT_PROPERTY_OVERRIDES += ro.wifi.sleep.power.down=true
 PRODUCT_PROPERTY_OVERRIDES += persist.usb.mode=otg
+PRODUCT_PROPERTY_OVERRIDES += ro.net.eth_primary=eth1
 PRODUCT_COPY_FILES += \
        device/rockchip/rk356x/rk3566_roc_pc/gps/u-blox.conf:system/etc/u-blox.conf
