1126点RGB屏幕
SDK包名称:rv1126_rv1109_linux_release_20211022
SDK修改内容:增加DTSI文件
panel@0 {
compatible = "simple-panel";
/delete-property/ power-supply;
bus-format = <MEDIA_BUS_FMT_RGB888_1X24>;
backlight = <&backlight>;
enable-gpios = <&gpio0 RK_PD6 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&lcd_ctl>;
pinctrl-names = "default";
rgb-mode = "p888";
width-mm = <99>;
height-mm = <74>;
status = "okay";
display-timings {
native-mode = <&HT043t_timing>;
HT043t_timing: timing0 {
clock-frequency = <9000000>;
hactive = <480>;
vactive = <272>;
hback-porch = <10>;
hfront-porch = <10>;
vback-porch = <4>;
vfront-porch = <4>;
hsync-len = <2>;
vsync-len = <2>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <0>;
pixelclk-active = <0>;
port {
panel_in_rgb: endpoint {
remote-endpoint = <&rgb_out_panel>;
&display_subsystem {
status = "okay";
&rgb {
status = "okay";
ports {
rgb_out: port@1 {
reg = <1>;
#address-cells = <1>;
#size-cells = <0>;
rgb_out_panel: endpoint@0 {
reg = <0>;
remote-endpoint = <&panel_in_rgb>;
&route_rgb {
status = "okay";
&vop {
status = "okay";
&rgb_in_vop{
status = "okay";
Log日志:新建文本文档 (2).txt
正在用1126 点一个普通RGB屏幕,按照文档写了DTSI文件,屏幕还是无法点亮,连背光都不正常?进系统看VOP也是disabled的。是否还是需要去改驱动的源码才能实现 。麻烦大神们帮忙看看。
启动LOG如下:
DDR Version V1.08 20210825
LPDDR4, 328MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS=1 Die BW=16 Size=1024MB
change to: 328MHz
change to: 528MHz
change to: 784MHz
change to: 924MHz(final freq)
out
U-Boot SPL board init
U-Boot SPL 2017.09(u-boot commit id: 617c0aeae793895dfbcfad2e0d67ce0620736a93)(sdk version: rv1126_rv1109_linux_release_20221222_v2.2.5d.xml)-g617c0aeae7 #alientek (Feb 11 2023 - 15:21:40)
unknown raw ID phN
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 1
spl: mmc init failed with error: -123
Trying to boot from MMC1
## Verified-boot: 0
## Checking optee 0x08400000 (gzip @0x08600000) … sha256(0e4f759f73…) + sha256(447872e443…) + OK
## Checking uboot 0x00400000 (gzip @0x00600000) … sha256(03c5d20fff…) + sha256(4a9de5a3d8…) + OK
## Checking fdt 0x004b6b1c … sha256(80f00e7967…) + OK
Jumping to U-Boot(0x00400000) via OP-TEE(0x08400000)
Total: 148.716 ms
I/TC:
I/TC: cpu feature:0x0
I/TC: RV1126 SoC
I/TC: cpu_st=0xe0
I/TC: Next entry point address: 0x00400000
I/TC: OP-TEE version: 3.13.0-549-gef7f159d #derrick.huang (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 Thu Oct 28 10:52:10 CST 2021 arm
U-Boot 2017.09(u-boot commit id: 617c0aeae793895dfbcfad2e0d67ce0620736a93)(sdk version: rv1126_rv1109_linux_release_20221222_v2.2.5d.xml)-g617c0aeae7 #alientek (Feb 11 2023 - 15:21:40 +0800)
Model: Rockchip RV1126 Evaluation Board
PreSerial: 2, raw, 0xff570000
DRAM: 1021.7 MiB
Sysmem: init
Relocation Offset: 00000000
Relocation fdt: 3bbf98f0 - 3bbfedd4
CR: M/C/I
dwmmc@ffc50000: 0, dwmmc@ffc60000: 1
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: None
DTB: rk-kernel.dtb
HASH(c): OK
I2c0 speed: 400000Hz
PMIC: RK8090 (on=0x40, off=0x00)
vdd_npu_vepu 800000 uV
vdd_arm 800000 uV
io-domain: OK
Warn: can’t find connect driver
stdio_add_devices: Video device failed (ret=-19)
Model: Firefly Core-RV1126-JD4 BE-45 Board
apll 816000 KHz
dpll 462000 KHz
gpll 1188000 KHz
cpll 500000 KHz
hpll 1400000 KHz
aclk_pdbus 500000 KHz
hclk_pdbus 198000 KHz
pclk_pdbus 99000 KHz
aclk_pdphp 297000 KHz
hclk_pdphp 198000 KHz
hclk_pdaudio 148500 KHz
hclk_pdcore 198000 KHz
pclk_pdpmu 99000 KHz
Net: eth0: ethernet@ffc40000
## Booting FIT Image at 0x3aa27ac0 with size 0x00fcee00
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 3aa27ac0 …
Using ‘conf’ configuration
optee api revision: 2.0
## Verified-boot: 0
Trying ‘kernel’ kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0x3aa40cc0
Data Size: 7312056 Bytes = 7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x02008000
Entry Point: 0x02008000
Hash algo: sha256
Hash value: cc37d1894f48bd6ffb1a08076b7264d499dbef05a0b8243c6160ba00fed9a3b6
Verifying Hash Integrity … sha256+ OK
## Loading ramdisk from FIT Image at 3aa27ac0 …
Trying ‘ramdisk’ ramdisk subimage
Type: RAMDisk Image
Data Start: 0x3b13a0c0
Data Size: 9160505 Bytes = 8.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x0a200000
Entry Point: unavailable
Hash algo: sha256
Hash value: 34c8dbec64a0c800281419dccd445b0b6ff60dcb9c431584b823cc4088347bde
Loading ramdisk from 0x3b13a0c0 to 0x0a200000
## Loading fdt from FIT Image at 3aa27ac0 …
Trying ‘fdt’ fdt subimage
Type: Flat Device Tree
Data Start: 0x3aa282c0
Data Size: 100616 Bytes = 98.3 KiB
Architecture: ARM
Load Address: 0x08300000
Hash algo: sha256
Hash value: 6831f654d9c4801077f7157f9ad0a90a2a1225bb49836e7bb45e49ff6c7d8677
Loading fdt from 0x08300000 to 0x08300000
Booting using the fdt blob at 0x08300000
Loading Kernel Image from 0x3aa40cc0 to 0x02008000 … OK
‘reserved-memory’ ramoops@8000000: addr=8000000 size=100000
Using Device Tree in place at 08300000, end 0831b907
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x08648000 - 0x40000000 (size: 0x379b8000)
Total: 444.826 ms
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 4.19.111 (alientek@ubuntu) (kernel commit id: 618d4940d48a66d78328cb3e57cd74ef9e49cc3e) (sdk version: rv1126_rv1109_linux_release_20221222_v2.2.5d.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 SMP PREEMPT Wed Feb 8 16:52:46 CST 2023
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] OF: fdt: Machine model: Firefly Core-RV1126-JD4 BE-45 Board
[ 0.000000] earlycon: uart8250 at MMIO32 0xff570000 (options ‘’)
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-logo@00000000’: base 0x00000000, size 0 MiB
[ 0.000000] Reserved memory: created CMA memory pool at 0x3f800000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x2f800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node isp, compatible id shared-dma-pool
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s32204 r8192 d21044 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 259512
[ 0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal ro rootwait earlycon=uart8250,mmio32,0xff570000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 cgroup_enable=memory swapaccount=1 snd_aloop.index=7 net.ifnames=0
[ 0.000000] Memory: 741768K/1046240K available (9216K kernel code, 423K rwdata, 2468K rodata, 1024K init, 321K bss, 34136K reserved, 270336K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xb0000000 - 0xf0000000 (1024 MB)
[ 0.000000] pkmap : 0xafe00000 - 0xb0000000 ( 2 MB)
[ 0.000000] modules : 0xaf000000 - 0xafe00000 ( 14 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (10208 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 424 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 322 kB)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x328/0x4ac with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000010] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000757] Switching to timer-based delay loop, resolution 41ns
[ 0.002645] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003608] pid_max: default: 4096 minimum: 301
[ 0.004221] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004847] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.006295] CPU: Testing write buffer coherency: ok
[ 0.007138] /cpus/cpu@f00 missing clock-frequency property
[ 0.007663] /cpus/cpu@f01 missing clock-frequency property
[ 0.008183] /cpus/cpu@f02 missing clock-frequency property
[ 0.008704] /cpus/cpu@f03 missing clock-frequency property
[ 0.009221] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.010539] Setting up static identity map for 0x100000 - 0x100060
[ 0.011285] rcu: Hierarchical SRCU implementation.
[ 0.012371] smp: Bringing up secondary CPUs …
[ 0.014431] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.016164] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.017904] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.018042] smp: Brought up 1 node, 4 CPUs
[ 0.020045] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.020626] CPU: All CPU(s) started in SVC mode.
[ 0.021960] devtmpfs: initialized
[ 0.048771] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.048821] Unpacking initramfs…
[ 0.050132] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.051127] futex hash table entries: 16 (order: -2, 1024 bytes)
[ 0.051941] pinctrl core: initialized pinctrl subsystem
[ 0.053729] NET: Registered protocol family 16
[ 0.055064] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.057738] cpuidle: using governor menu
[ 0.058142] Registered FIQ tty driver
[ 0.059309] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.060085] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.062944] console [pstore-1] enabled
[ 0.063684] pstore: Registered ramoops as persistent store backend
[ 0.064268] ramoops: attached 0x100000@0x8000000, ecc: 0/0
[ 0.114386] cryptd: max_cpu_qlen set to 1000
[ 0.115837] fiq debugger fiq mode enabled
[[ 0.116674] console [ttyFIQ0] enabled
[ 0.117360] bootconsole [uart8250] disabled
[ 0.118075] Registered fiq debugger ttyFIQ0
[ 0.118811] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 0.123881] rk_iommu ffb00f00.iommu: version = 1
[ 0.124665] rk_iommu ffb20800.iommu: version = 1
[ 0.125211] rk_iommu ffb60e00.iommu: version = 1
[ 0.125772] rk_iommu ffb80480.iommu: version = 1
[ 0.126191] rk_iommu ffb90800.iommu: version = 1
[ 0.126629] rk_iommu ffbb0f00.iommu: version = 1
[ 0.127627] SCSI subsystem initialized
[ 0.127972] usbcore: registered new interface driver usbfs
[ 0.128081] usbcore: registered new interface driver hub
[ 0.128221] usbcore: registered new device driver usb
[ 0.128379] media: Linux media interface: v0.10
[ 0.128471] videodev: Linux video capture interface: v2.00
[ 0.128545] pps_core: LinuxPPS API ver. 1 registered
[ 0.128569] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.128617] PTP clock support registered
[ 0.130168] Advanced Linux Sound Architecture Driver Initialized.
[ 0.130860] Bluetooth: Core ver 2.22
[ 0.130952] NET: Registered protocol family 31
[ 0.130982] Bluetooth: HCI device and connection manager initialized
[ 0.131016] Bluetooth: HCI socket layer initialized
[ 0.131046] Bluetooth: L2CAP sockeyer initialized
[ 0.131115] Bluetooth: SCO socket layer init86] rockchip-cpuinfo cpuinfo: SoC: 11260000
[ 0.131727] rofo: Serial : c6718f8a4b9bc3cd
[ 0.132995] clocksource: Swith_sys_counter
_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 by TCP established hash table entries: 8192 (order: 3, 32768 bytesbind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.13es configured (established 8192 bind 8192)
[ 0.137395] UDP h512 (order: 2, 16384 bytes)
[ 0.137482] UDP-Lite hash table , 16384 bytes)
[ 0.137753] NET: Registered protocol family 1 perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters42684] Initialise system trusted keyrings
[ 0.142953] workin=29 max_order=18 bucket_order=0
[ 0.150564] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.153416] Key type asymmetric registered
[ 0.153457] Asymmetric key parser ‘x509’ registered
[ 0.153535] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.153564] io scheduler noop registered
[ 0.153587] io scheduler deadline registered
[ 0.153783] io scheduler cfq registered (default)
[ 0.153815] io scheduler mq-deadline registered
[ 0.153838] io scheduler kyber registered
[ 0.154003] io scheduler bfq registered
[ 0.158349] phy phy-ff4c0000.usb2-phy.1: Linked as a consumer to regulator.4
[ 0.160590] phy phy-ff4c8000.usb2-phy.2: Linked as a consumer to regulator.3
[ 0.164557] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.164717] pwm-backlight backlight: Linked as a consumer to regulator.0
[ 0.165111] mpp_service mpp-srv: 92c80ddf68f6 author: Yandong Lin 2021-08-10 video: rockchip: mpp: workaround patch for rv1126 iommu issue
[ 0.165140] mpp_service mpp-srv: probe start
[ 0.166178] iommu: Adding device ffb80000.rkvdec to group 3
[ 0.166240] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[ 0.166489] mpp_rkvdec ffb80000.rkvdec: probing start
[ 0.167195] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[ 0.167233] rkvdec_init:1190: No niu aclk reset resource define
[ 0.167264] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[ 0.167288] rkvdec_init:1193: No niu hclk reset resource define
[ 0.167607] mpp_rkvdec ffb80000.rkvdec: probing finish
[ 0.168461] iommu: Adding device ffbb0000.rkvenc to group 5
[ 0.168528] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[ 0.168860] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 0.169512] mpp_rkvenc ffbb0000.rkvvenc regulator not ready, retry
[ 0.169549] rkvenc_init:1202 devfreq
[ 0.170814] iommu: Adding device ffb90400.vdpu to g] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommp_vdpu2 ffb90400.vdpu: probe device
[ 0.171574] mpp_vdpu2 ffgroup->rw_sem_on=0
[ 0.171631] mpp_vdpu2 ffb90400.vdpu: rese 0.171905] mpp_vdpu2 ffb90400.vdpu: probing finish
[ 0.17device ffb90000.vepu to group 4
[ 0.172646] mpp_vepu2 ffb900onsumer to ffb90800.iommu
[ 0.172783] mpp_vepu2 ffb90000.vep 0.173363] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[epu2 ffb90000.vepu: reset_group->rw_sem_on=0
[ 0.173680] mppprobing finish
[ 0.174264] iommu: Adding device ffb20000.iep.174323] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb208002] mpp-iep2 ffb20000.iep: probe device
[ 0.175107] mpp-iep2 roi buffer failed
[ 0.175338] mpp-iep2 ffb20000.iep: probin632] mpp_service mpp-srv: probe success
[ 0.180927] dma-pl33oller: Loaded driver for PL330 DMAC-241330
[ 0.180972] dma-pontroller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-ockchip-system-monitor rockchip-system-monitor: system monitor p[ 0.184153] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.185090] ff410000.serial: ttyS1 at MMIO 0xff410000 (irq = 31, base_baud = 1500000) is a 16550A
[ 0.185908] ff560000.serial: ttyS0 at MMIO 0xff560000 (irq = 34, base_baud = 1500000) is a 16550A
[ 0.186768] ff580000.serial: ttyS3 at MMIO 0xff580000 (irq = 35, base_baud = 1500000) is a 16550A
[ 0.187512] ff590000.serial: ttyS4 at MMIO 0xff590000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.189686] random: fast init done
[ 0.190089] random: crng init done
[ 0.190715] iommu: Adding device ffb00000.vop to group 0
[ 0.190784] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[ 0.194430] rockchip-drm display-subsystem: Linked as a consumer to ffb00000.vop
[ 0.196905] rockchip-drm display-subsystem: devfreq is not set
[ 0.197439] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb0a3e140)
[ 0.197467] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.197482] [drm] No driver support for vblank timestamp query.
[ 0.197638] rockchip-drm display-subsystem: failed to parse loader memory
[ 0.198532] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 0.203558] panel-simple panel@0: panel@0 supply power not found, using dummy regulator
[ 0.203701] panel-simple panel@0: Linked as a consumer to regulator.0
[ 0.203753] panel-simple panel@0: panel@0 supply vsp not found, using dummy regulator
[ 0.203877] panel-simple panel@0: panel@0 supply vsn not found, using dummy regulator
[ 0.212944] loop: module loaded
[ 0.213737] zram: Added device: zram0
[ 0.216371] libphy: Fixed MDIO Bus: probed
[ 0.216472] tun: Universal TUN/TAP device driver, 1.6
[ 0.218062] PPP generic driver version 2.4.2
[ 0.218331] PPP BSD Compression module registered
[ 0.218352] PPP Deflate Compression module registered
[ 0.218401] PPP MPPE Compression module registered
[ 0.218427] NET: Registered protocol family 24
[ 0.218550] usbcore: registered new interface driver r8152
[ 0.218663] usbcore: registered new interface driver asix
[ 0.218755] usbcore: registered new interface driver ax88179_178a
[ 0.218831] usbcore: registered new interface driver cdc_ether
[ 0.218897] usbcore: registered new interface driver net1080
[ 0.218973] usbcore: registered new interface driver cdc_subset
[ 0.219045] usbcore: registered new interface driver zaurus
[ 0.219157] usbcore: registered new interface driver cdc_ncm
[ 0.219235] usbcore: registered new interface driver qmi_wwan
[ 0.221128] dwc3 ffd00000.dwc3: Failed to get clk ‘ref’: -2
[ 0.227781] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.227837] ehci-platform: EHCI generic platform driver
[ 0.231517] ehci-platform ffe00000.usb: EHCI Host Controller
[ 0.231605] ehci-platform ffe00000.usb: new USB bus registered, assigned bus number 1
[ 0.231819] ehci-platform ffe00000.usb: irq 68, io mem 0xffe00000
[ 0.243073] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[ 0.243403] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.243441] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.243468] usb usb1: Product: EHCI Host Controller
[ 0.243494] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[ 0.243520] usb usb1: SerialNumber: ffe00000.usb
[ 0.244420] hub 1-0:1.0: USB hub found
[ 0.244502] hub 1-0:1.0: 1 port detected
[ 0.245295] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.245352] ohci-platform: OHCI generic platform driver
[ 0.246028] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[ 0.246095] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[ 0.246306] ohci-platform ffe10000.usb: irq 69, io mem 0xffe10000
[ 0.307358] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 0.307416] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.307437] usb usb2: Product: Generic Platform OHCI controller
[ 0.307496] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[ 0.307515] usb usb2: SerialNumber: ffe10000.usb
[ 0.308435] hub 2-0:1.0: USB hub found
[ 0.308521] hub 2-0:1.0: 1 port detected
[ 0.310373] usbcore: registered new interface driver cdc_wdm
[ 0.310542] usbcore: registered new interface driver usb-storage
[ 0.310713] usbcore: registered new interface driver option
[ 0.310778] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.311957] i2c /dev entries driver
[ 0.314080] rk808 0-0020: chip id: 0x8090
[ 0.314204] rk808 0-0020: No cache defaults, reading back from HW
[ 0.320644] rk808 0-0020: source: on=0x40, off=0x00
[ 0.320700] rk808 0-0020: support dcdc3 fb mode:-22, -1329981084
[ 0.320729] rk808 0-0020: support pmic reset mode:0,0
[ 0.325253] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.325383] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.325492] DCDC_REG1: supplied by vcc5v0_sys
[ 0.326226] DCDC_REG2: supplied by vcc5v0_sys
[ 0.326968] DCDC_REG3: supplied by vcc5v0_sys
[ 0.327475] DCDC_REG4: supplied by vcc5v0_sys
[ 0.327996] DCDC_REG5: supplied by vcc5v0_sys
[ 0.328647] LDO_REG1: supplied by vcc_buck5
[ 0.329274] LDO_REG2: supplied by vcc_buck5
[ 0.329812] LDO_REG3: supplied by vcc_buck5
[ 0.330349] LDO_REG4: supplied by vcc_buck5
[ 0.330879] LDO_REG5: supplied by vcc_buck5
[ 0.331376] LDO_REG6: supplied by vcc_buck5
[ 0.331465] vcc_dvdd: Bringing 1100000uV into 1200000-1200000uV
[ 0.332100] LDO_REG7: supplied by vcc5v0_sys
[ 0.332636] LDO_REG8: supplied by vcc5v0_sys
[ 0.333342] LDO_REG9: supplied by vcc5v0_sys
[ 0.334011] SWITCH_REG1: supplied by vcc5v0_sys
[ 0.334458] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.336898] input: rk805 pwrkey as /devices/platform/ff3f0000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[ 0.340057] rk808-rtc rk808-rtc: registered as rtc0
[ 0.340685] rk808-rtc rk808-rtc: setting system clock to 2017-08-04 09:00:02 UTC (1501837202)
[ 0.343753] pca953x 1-0020: 1-0020 supply vcc not found, using dummy regulator
[ 0.343884] pca953x 1-0020: Linked as a consumer to regulator.0
[ 0.790214] Freeing initrd memory: 8948K
[ 1.359782] rk3x-i2c ff510000.i2c: timeout, ipd: 0x90, state: 1
[ 1.359840] pca953x 1-0020: failed reading register
[ 1.359953] pca953x 1-0020: Dropping the link to regulator.0
[ 1.360034] pca953x: probe of 1-0020 failed with error -110
[ 1.439710] phy phy-ff4c0000.usb2-phy.1: charger = USB_SDP_CHARGER
[ 2.479715] rk3x-i2c ff510000.i2c: timeout, ipd: 0x90, state: 1
[ 3.493071] rk3x-i2c ff510000.i2c: timeout, ipd: 0x90, state: 1
[ 4.506398] rk3x-i2c ff510000.i2c: timeout, ipd: 0x90, state: 1
[ 4.506493] himax_tp: probe of 1-0048 failed with error -9
[ 4.506765] rockchip-pinctrl pinctrl: pin gpio3-0 already requested by ff580000.serial; cannot claim for ff530000.i2c
[ 4.506801] rockchip-pinctrl pinctrl: pin-96 (ff530000.i2c) status -22
[ 4.506832] rockchip-pinctrl pinctrl: could not request pin 96 (gpio3-0) from group i2c4m0-xfer on device rockchip-pinctrl
[ 4.506858] rk3x-i2c ff530000.i2c: Error applying setting, reverse things back
[ 4.506898] rk3x-i2c: probe of ff530000.i2c failed with error -22
[ 4.507888] ircut cam_ircut: driver version: 00.01.00
[ 4.508148] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 4.508227] ircut cam_ircut: Failed to get ircut-open-gpios
[ 4.508300] ircut cam_ircut: Failed to get ircut-close-gpios
[ 4.508428] ircut cam_ircut: probe successful!
[ 4.509302] rockchip-mipi-csi2: probe success, v4l2_dev:(null)!
[ 4.510779] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
[ 4.510834] r0000.rkcif: assigned reserved memory node isp
[ 4.510979] rk driver version: v00.01.0a
[ 4.511078] rkcif rkcif_dvp: atta[ 4.511110] rkcif rkcif_dvp: rkcif wait line 0
[ 4.512258bdev_notifier: no subdev be found!
[ 4.512291] rkcif_dvp: Fadev notifier(-19)
[ 4.513423] rkcif rkcif_dvp: detach to cif3552] rkcif rkcif_mipi_lvds: rkcif driver version: v00.01.0a
[ kcif_mipi_lvds: attach to cif hw node
[ 4.513688] rkcif rkciwait line 0
[ 4.514697] rkcif rkcif_mipi_lvds: Entity type fipi-csi2 was not initialized!
[ 4.514724] rockchip-mipi-csi2subdev
[ 4.517197] rkisp_hw ffb50000.rkisp: is_thunderboot: kisp_hw ffb50000.rkisp: Missing rockchip,grf property
[ 4.510000.rkisp: iommu is disabled, using non-iommu buffers
[ 4.50000.rkisp: assigned reserved memory node isp
[ 4.517953] rksp driver version: v01.06.02
[ 4.518196] rkisp rkisp-vir0: Nrboot specified
[ 4.518451] rkisp rkisp-vir0: Entity type foubdev was not initialized!
[ 4.518498] rkisp rkisp-vir0: Entrkisp-csi-subdev was not initialized!
[ 4.518531] rkisp rkise for entity rkisp-bridge-ispp was not initialized!
[ 4.5222vice ffb60000.rkispp to group 2
[ 4.522301] rkispp_hw ffb600consumer to ffb60e00.iommu
[ 4.522715] rkispp_hw ffb60000.rk@0fps
[ 4.522767] rkispp_hw ffb60000.rkispp: can’t request rmem 0xffb60000-0xffb7ffff]
[ 4.523070] rkispp_hw ffb60000.rkcru reset
[ 4.523376] rkispp rkispp-vir0: rkispp driver vers4.525596] rkispp rkispp-vir2: rkispp driver version: v01.06.02
e: registered new interface driver uvcvideo
[ 4.528299] USB 1)
[ 4.528821] rockchip-iodomain fe020000.syscon:io-domains: fe020000.syscon:io-domains: vccio2(3300000 uV) supplied by vcci fe020000.syscon:io-domains: Linked as a consumer to regulator.1chip-iodomain fe020000.syscon:io-domains: vccio3(1800000 uV) sup4.529250] rockchip-iodomain fe020000.syscon:io-domains: vccio4(1 vcc_1v8
[ 4.529390] rockchip-iodomain fe020000.syscon:io-dosumer to regulator.22
[ 4.529451] rockchip-iodomain fe020000io5(3300000 uV) supplied by vcc_3v3
[ 4.529621] rockchip-iod:io-domains: vccio6(3300000 uV) supplied by vcc_3v3
[ 4.5298n fe020000.syscon:io-domains: vccio7(1800000 uV) supplied by vccockchip-iodomain fe020000.syscon:io-domains: Linked as a consume 4.529999] rockchip-iodomain fe020000.syscon:io-domains: pmuio0by vcc1v8_pmu
[ 4.530148] rockchip-iodomain fe020000.syscon: a consumer to regulator.10
[ 4.530192] rockchip-iodomain feins: pmuio1(3300000 uV) supplied by vcc3v3_sys
[ 4.533579] r0000.tsadc: tsadc trimmed value = -7
[ 4.533991] rockchip-th tsadc is probed successfully!
[ 4.534480] rockchip-thermal trimmed value = -4
[ 4.534743] rockchip-thermal ff5f8000.tsccessfully!
[ 4.535742] Bluetooth: HCI UART driver ver 2.3
ooth: HCI UART protocol H4 registered
[ 4.536114] cpu cpu0: pu cpu0: leakage=1.500
[ 4.536385] cpu cpu0: Linked as a con[ 4.548070] cpu cpu0: temp=27800, pvtm=100744 (100344 + 400)
[ 4.548187] cpu cpu0: pvtm-volt-sel=1
[ 4.548294] cpu cpu0: Dropping the link to regulator.8
[ 4.548363] cpu cpu0: bin-scale=5
[ 4.548747] cpu cpu0: Linked as a consumer to regulator.8
[ 4.548838] cpu cpu0: Dropping the link to regulator.8
[ 4.549079] cpu cpu0: Linked as a consumer to regulator.8
[ 4.550390] cpu cpu0: avs=0
[ 4.550881] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 4.550932] cpu cpu0: failed to read out thermal zone (-22)
[ 4.551773] cpu cpu0: failed to find power_model node
[ 4.551853] cpuidle: enable-method property ‘psci’ found operations
[ 4.551953] cpuidle: enable-method property ‘psci’ found operations
[ 4.552031] cpuidle: enable-method property ‘psci’ found operations
[ 4.552096] cpuidle: enable-method property ‘psci’ found operations
[ 4.552716] Synopsys Designware Multimedia Card Interface Driver
[ 4.553399] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.553448] dp ffc50000.dwmmc: Using internal DMA controller.
[ 4.553467]0000.dwmmc: Version ID is 270a
[ 4.553523] dwmmc_rockchip ffntroller at irq 63,32 bit host data width,256 deep fifo
[ 4.: card is non-removable.
[ 4.566686] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.581310] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.581455] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[ 4.581504] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[ 4.581663] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[ 4.581983] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.20
[ 4.582212] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.19
[ 4.596069] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.610767] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.610900] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 4.610943] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 4.611101] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[ 4.611520] dwmmc_rockchip ffc70000.dwmmc: allocated mmc-pwrseq
[ 4.611568] mmc_host mmc1: card is non-removable.
[ 4.617881] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[ 4.617951] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[ 4.618619] mmc0: new HS200 MMC card at address 0001
[ 4.620977] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 4.622061] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[ 4.623124] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[ 4.623884] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (241:0)
[ 4.624613] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.635344] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 4.638548] usbcore: registered new interface driver usbkbd
[ 4.638696] usbcore: registered new interface driver usbmouse
[ 4.641560] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.15
[ 4.642486] rksfc_base v1.1 2016-01-08
[ 4.643148] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[ 4.643264] rkflash_dev_init enter
[ 4.643298] sfc nor id: 0 0 0
[ 4.643413] rkflash[1] is invalid
[ 4.643421] rkflash_dev_init enter
[ 4.643463] sfc_nand id: 0 0 0
[ 4.643474] rkflash[2] is invalid
[ 4.650756] rk817-codec rk817-codec: DMA mask not set
[ 4.650922] rk817_codec_parse_dt_property: rk809 have no io-channels defined
[ 4.654298] NET: Registered protocol family 17
[ 4.654370] NET: Registered protocol family 15
[ 4.654926] Bluetooth: RFCOMM TTY layer initialized
[ 4.654977] Bluetooth: RFCOMM socket layer initialized
[ 4.655014] Bluetooth: RFCOMM ver 1.11
[ 4.655032] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.655047] Bluetooth: HIDP socket layer initialized
[ 4.655058] [BT_RFKILL]: Enter rfkill_rk_init
[ 4.655067] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 4.655375] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 4.655421] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6236
[ 4.655434] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 4.655444] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 4.655503] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 8, flags = 0.
[ 4.655537] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 4.655548] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 4.655883] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 48.
[ 4.655911] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 7.
KILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.T,wake_host_irq = 5.
[ 4.6quest irq for bt wakeup host
[ 4.656109] [BT_RFKILL]: ** dis [BT_RFKILL]: bt shut off power
[ 4.656259] [BT_RFKILL]: bt_tered.
[ 4.657249] flash vendor_init_thread!
[ 4.657282]170308 ret = -1
[ 4.658292] Registering SWP/SWPB emulation h] Loading compiled-in X.509 certificates
[ 4.660736] rga2: Dully ver:3.2.56726
[ 4.661060] rga2: Module initialized.
[ ing unknown CIS tuple 0x80 (2 bytes)
[ 4.669351] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.671224] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.675078] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 4.679762] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 4.685611] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 4.686521] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.7
[ 4.686620] mpp_rkvenc ffbb0000.rkvenc: bin=0
[ 4.686659] mpp_rkvenc ffbb0000.rkvenc: leakage=1.375
[ 4.686749] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[ 4.686782] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[ 4.687178] mpp_rkvenc ffbb0000.rkvenc: avs=0
[ 4.687522] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[ 4.687552] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[ 4.687756] mpp_rkvenc ffbb0000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 4.687797] mpp_rkvenc ffbb0000.rkvenc: failed to read out thermal zone (-22)
[ 4.688829] mpp_rkvenc ffbb0000.rkvenc: probing finish
[ 4.689305] input: adc-keys as /devices/platform/adc-keys/input/input1
[ 4.692745] asoc-simple-card rk809-sound: rk817-hifi ↔ ff800000.i2s mapping ok
[ 4.692785] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 4.692799] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 4.692801] vendor storage:20190527 ret = 0
[ 4.692821] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 4.692833] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 2845] asoc-simple-card rk809-sound: ASoC: no source widget found2857] asoc-simple-card rk809-sound: ASoC: Failed to add route HPhone Jack
[ 4.692868] asoc-simple-card rk809-sound: ASoC: noor HPOR
[ 4.692880] asoc-simple-card rk809-sound: ASoC: Fail → direct → Headphone Jack
[ 4.694010] input: rockchip,rk8ck as /devices/platform/rk809-sound/sound/card0/input2
[ 4.6 in Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20395] ======== dhd_wlan_init_plat_data ========
[ 4.696407] [hip_wifi_get_oob_irq: Enter
[ 4.696468] dhd_wlan_init_gpio: 109, oob_irq_flags=0x414
[ 4.696480] dhd_wlan_init_gpio: WL_90] dhd_wifi_platform_load: Enter
[ 4.696502] Power-up adaptr’
[ 4.696553] wifi_platform_set_power = 1
[ 4.696566] =N(-1) HIGH! ========
[ 4.696577] [WLAN_RFKILL]: rockchip_wif96589] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 4.6966[ 4.696704] ret=0
[ 4.696744] rkcif rkcif_mipi_lvds: clea1
[ 4.696760] rockchip-mipi-dphy-rx: No link between dphy an65] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ ds: Async subdev notifier completed
[ 4.698252] cfg80211: Lo certificates for regulatory database
[ 4.708270] cfg80211: forshee: 00b28ddf47aef9cea7’
[ 4.708432] platform regulatory for regulatory.db failed with error -2
[ 4.708455] cfg80211atory.db
[ 4.709266] rkisp rkisp-vir0: clear unready subdev 5] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ ipi-dphy-rx: No link between dphy and sensor
[ 4.709835] rkita type
[ 4.709845] rkisp0: update sensor failed
[ 4.710ffc50000.dwmmc: Successfully tuned phase to 180
[ 4.710695] 00.dwmmc: Successfully tuned phase to 90
[ 4.711098] ret 102 ALSA device list:
[ 4.711295] #0: rockchip,rk809-codec
[Loopback 1
[ 4.712131] Freeing unused kernel memory: 1024K
init as init process
Loading, please wait…
Couldn’t get a file descriptor referring to the console
[ 4.768660] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 4.770431] mmc1: new high speed SDIO card at address 0001
starting version 237
[ 5.003136] wifi_platform_bus_enumerate device present 1
[ 5.003168] ======== Card detection to detect SDIO card! ========
[ 5.003176] mmc1:mmc host rescan start!
[ 5.019462] bcmsdh_register: register client driver
[ 5.019824] bcmsdh_sdmmc_probe: Enter num=1
[ 5.020202] bcmsdh_sdmmc_probe: Enter num=2
[ 5.020225] bus num (host idx)=1, slot num (rca)=1
[ 5.020233] found adapter info ‘DHD generic adapter’
[ 5.020293] sdioh_attach: set sd_f2_blocksize 256
[ 5.020352] sdioh_attach: sd clock rate = 0
[ 5.020669] dhdsdio_probe : no mutex held. set lock
[ 5.020794] F1 signature read @0x18000000=0x1541a9a6
[ 5.024858] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 5.026002] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 5.026224] [dhd] dhd_conf_set_chiprev : chip=0xa9a6, chiprev=1
[ 5.026617] [dhd] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 5.027117] [dhd] CFG80211-ERROR) wl_setup_wiphy : SAE support
[ 5.027624] [dhd] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 5.029068] dhd_attach(): thread:dhd_watchdog_thread:7b started
[ 5.029272] dhd_attach(): thread:dhd_dpc:7d started
[ 5.035934] dhd_attach(): thread:dhd_rxf:7e started
[ 5.035971] dhd_deferred_work_init: work queue initialized
[ 5.035982] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 5.036027] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 5.036996] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 5.048839] Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[ 5.049363] Register interface [wlan0] MAC: b8:13:32:30:d9:70
[ 5.049363]
[ 5.049434] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 → mode 0
[ 5.049451] dhd_wl_ioctl: returning as busstate=0
[ 5.049459] dhd_dbg_detach_pkt_monitor, 2204
[ 5.049467] dhd_bus_devreset: == Power OFF ==
[ 5.050335] bcmsdh_oob_intr_unregister: Enter
[ 5.050352] bcmsdh_oob_intr_unregister: irq is not registered
[ 5.050365] dhd_txglom_enable: enable 0
[ 5.050375] dhd_bus_devreset: WLAN OFF DONE
[ 5.050437] wifi_platform_set_power = 0
[ 5.050448] ======== PULL WL_REG_ON(-1) LOW! ========
[ 5.050456] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 5.050473] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 5.050482] dhdsdio_probe : the lock is released.
[ 5.050812] dhd_module_init: Exit err=0
/scripts/init-top/console_setup: line 134: can’t create /dev/tty1: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty1: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty2: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty2: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty3: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty3: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty4: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty4: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty5: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty5: No such device or address
/scripts/init-top/console_setup: line 1: can’t create /dev/tty6: No such device or address
/scripts/init-top/console_setup: line 1: can’t open /dev/tty6: No such device or address
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Running /scripts/local-premount … done.
Warning: fsck not present, so skipping root file system
[ 7.241421] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … Warning: overlayroot: configuring overlayroot with driver=overlay mode=device opts=‘dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ per kernel cmdline
[ 7.377619] EXT4-fs (mmcblk0p8): warning: mounting unchecked fs, running e2fsck is recommended
[ 7.400474] EXT4-fs (mmcblk0p8): mounted filesystem without journal. Opts: (null)
[[: missing ]]
ln: /root/var/lib/docker: File exists
Success: overlayroot: configured root with ‘device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ using overlay per kernel cmdline
Warning: Something odd, no /lib/modules/4.19.111 in initramfs.
done.
[ 7.787816] systemd[1]: System time before build time, advancing clock.
[ 7.796570] systemd[1]: Failed to lookup module alias ‘autofs4’: Function not implemented
[ 7.814704] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 7.815725] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 10 (buster)!
[ 7.819127] systemd[1]: Set hostname to .
[ 7.987238] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 7.987309] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 8.294856] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 8.295854] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 8.297205] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 8.298851] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ OK ] Reached target Remote File Systems.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 8.299456] systemd[1]: Reached target Remote File Systems.
[ OK ] Listening on Syslog Socket.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ OK ] Listening on udev Control Socket.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ OK ] Listening on Journal Socket.
Starting udev Coldplug all Devices…
Starting Remount Root and Kernel File Systems…
Mounting Kernel Debug File System…
Starting Load Kernel Modules…
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting Journal Service…
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Mounted Kernel Debug File System.
Starting Create System Users…
Starting Load/Save Random Seed…
[ OK ] Started Load Kernel Modules.
Mounting Kernel Configuration File System…
Starting Apply Kernel Variables…
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create System Users.
[ OK ] Started Load/Save Random Seed.
Starting Create Static Device Nodes in /dev…
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager…
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage…
[ OK ] Started udev Coldplug all Devices.
Starting Helper to synchronize boot up for ifupdown…
[ OK ] Started Helper to synchronize boot up for ifupdown.
[ 8.719100] systemd-journald[407]: Received request to flush runtime journal from PID 1
Starting Raise network interfaces…
[ OK ] Started Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories…
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen …ness of backlight:backlight…
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization…
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Started Load/Save Screen B…htness of backlight:backlight.
[ OK ] Found device /dev/ttyFIQ0.
[ 9.157921] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 9.169446] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 9.171945] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ OK ] Started Network Time Synchronization.
[ 9.180079] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ 9.216731] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ OK ] Started Raise network interfaces.
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[ OK ] Reached target System Time Synchronized.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily man-db regeneration.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Basic System.
[ OK ] Started Manage Sound Card State (restore and store).
[ OK ] Started Regular background program processing daemon.
Starting Restore /etc/reso… the ppp link was shut down…
Starting System Logging Service…
Starting Npu Init…
Starting Modem Manager…
Starting Adbd for linux…
Starting Login Service…
Starting Save/Restore Sound Card State…
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Reached target Timers.
[ OK ] Started D-Bus System Message Bus.
Starting WPA supplicant…
[ 9.940267] galcore: loading out-of-tree module taints kernel.
[ 9.948511] galcore: npu init.
[ 9.957674] galcore: start npu probe.
Starting Network Manager…
[ 9.958392] galcore ffbc0000.npu: Linked as a consumer to regulator.7
[ OK ] Started System Logging Service.
[ 9.967398] npu: platform_get_irq irq = 67
[ 9.967473] npu: platform_get_resource registerMemBase = ffbc0000, registerMemSize = 4000
[ 9.967507] Galcore version 6.4.6.5.351518
[ 9.967534] Galcore options:
[ 9.967562] irqLine = 67
[ 9.967580] registerMemBase = 0xFFBC0000
[ 9.967597] registerMemSize = 0x00004000
[ 9.967616] contiguousSize = 0x00400000
[ 9.967632] contiguousBase = 0x0
[ 9.967649] externalSize = 0x00000000
[ 9.967687] externalBase = 0x0
[ 9.967707] exclusiveSize = 0x00000000
[ 9.967732] exclusiveBase = 0x0
[ 9.967751] bankSize = 0x00000000
[ 9.967780] fastClear = -1
[ 9.967800] compression = 15
[ 9.967817] powerManagement = 1
[ 9.967834] baseAddress = 0x00000000
[ 9.967862] physSize = 0x00000000
[ 9.967883] recovery = 1
[ 9.967938] stuckDump = 0
[ 9.967962] GPU smallBatch = 1
[ 9.967986] allMapInOne = 1
[ 9.968015] enableNN = 0xff
[ 9.968045] userClusterMasks =
[ 9.968048] ff,
[ 9.968072] ff,
[ 9.968089] ff,
[ 9.968105] ff,
[ 9.968122] ff,
[ 9.968177] ff,
[ 9.968200] ff,
[ 9.968229] ff,
[ 9.968249]
[ 9.968272] irqs =
[ 9.968274] 67,
[ 9.968290] -1,
[ 9.968307] -1, 9.968324] -1,
[ 9.968339] -1,
[ 9.968355] -1,
[ 9.968413] -1,
[ 9.968445] -1,
[ 9.968470] -1,
[ Started -1,
[ 9.968500]
[ 9mRestore pp l.968524] registerBases =
0, ink was shut down.
[ 9.968549] 0x00000000,
[ 9.968566] 0x00000000,
[000,
[ 9.968601] 0x00000000,
00, 9.968645] 0x00000000,
[ 9.968723] 0x00000000,
[ 9.968760] 0x00000000,
0000,
[ 9.968829] 0x00000000,
[ 9.968886]
[ 9.968 =
[ 9.968929] 0x00004000,
[ 9.968955] 0x00000000, 0000,
[ 9.969016] 0x00000000,
[ 9.969051] 0x00000000, 000000,
[ 9.969163] 0x00000000,
[ 9.969199] 0x00000000x00000000,
[ 9.969270] 0x00000000,
[ 9.969304] 0x00000[ 9.969399] chipIDs =
[ 9.969401] 0xFFFFFFFFFFFFFFF,
[ 9.969438] 0xFFFFFFFF,
[ 9.969457] 0xFFFFFFFFFFFFFFF,
[ 9.969496] 0xFFFFFFFF,
[ 9.969527] 0xFFFFFFFFFFFFF,
[ 9.969605] 0xFFFFFFFF,
[ 9.976594] 0xFFFFFFFFFFFFFF,
[ 9.976708]
[ 9.976734] core 0 internal sRA735] 0xFFFFFFFFFFFFFFFF,
[ 9.976760] 0xFFFFFFFFFFFFFFFF,
9.976802] core 1 internal sRAMBases =
[ 9.976803] 0xFFFFF.976822] 0xFFFFFFFFFFFFFFFF,
[ 9.976839]
[ 9.976861] s =
[ 9.976863] 0xFFFFFFFFFFFFFFFF,
[ 9.976879] 0xFFFF.976914]
[ 9.976938] core 3 internal sRAMBases =
[ 9FFFFF,
[ 9.976959] 0xFFFFFFFFFFFFFFFF,
[ 9.976975]
[internal sRAMBases =
[ 9.976997] 0xFFFFFFFFFFFFFFFF,
[ FFFFFFF,
[ 9.977029]
[ 9.977049] core 5 internal sRA50] 0xFFFFFFFFFFFFFFFF,
[ 9.977066] 0xFFFFFFFFFFFFFFFF,
[977104] core 6 internal sRAMBases =
[ 9.977106] 0xFFFFFFF OK ] Started
9.977188] mSave/Restore Sound Card State core 7 internal 977190] 0xFFFFFFFFFFFFFFFF,
[ 9.977208] 0xFFFFFFFFFFFFFFFF, 9.977249] core 8 internal sRAMBases =
[ 9.977251] 0xF[ 9.977271] 0xFFFFFFFFFFFFFFFF,
[ 9.977289]
[ 9.977l sRAMBases =
[ 9.977313] 0xFFFFFFFFFFFFFFFF,
[ 9.9773FF,
[ 9.977346]
[ 9.977384] core 10 internal sRAMBas0xFFFFFFFFFFFFFFFF,
[ 9.977402] 0xFFFFFFFFFFFFFFFF,
[ 977439] External sRAMBases =
[ 9.977441] 0xffffffffffffff 0xffffffffffffffff,
[ 9.977472]
[ 9.977491] mmuPage.977507] mmuDynamicMap = 1
[ 9.977523] isrPoll 9.977540] Build options:
[ 9.977556] gcdGPU_TIMEOUT 7573] gcdGPU_2D_TIMEOUT = 4000
[ 9.977589] gcdINTERRUPT_88736] Galcore Info: ContiguousBase=0x3f956000 ContiguousSize=0x22] Galcore Info: MMU mapped core 0 SRAM[0] hardware virtual addx40000
[ 9.993987] Galcore Info: MMU mapped core 0 SRAM[1] hss=0x440000 size=0x40000
[ 9.999585] galcore ffbc0000.npu: I9.999741] galcore ffbc0000.npu: bin=0
[ 9.999808] galcore ff
[ 10.012272] galcore ffbc0000.npu: temp=28900, pvtm=100641 (10.012668] galcore ffbc0000.npu: pvtm-volt-sel=1
[ 10.012743]u: bin-scale=23
[ 10.013996] galcore ffbc0000.npu: avs=0
[ 10.014823] galcore ffbc0000.npu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 10.014950] galcore ffbc0000.npu: failed to read out thermal zone (-22)
[ 10.015109] galcore ffbc0000.npu: failed to find power_model node
[ 10.015180] galcore ffbc0000.npu: failed to initialize power model
Starting Load/Save RF Kill Switch Status…
[ OK ] Reached target Sound Card.
[ OK ] Started Npu Init.
[ 10.071062] file system registered
[ 10.076223] [BT_RFKILL]: bt shut off power
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Started WPA supplicant.
[ OK ] Started Login Service.
[ 10.127026] read descriptors
[ 10.127160] read strings
Starting Authorization Manager…
[ OK ] Started Authorization Manager.
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
Starting Permit User Sessions…
Starting OpenBSD Secure Shell server…
Starting Hostname Service…
[ OK ] Started Permit User Sessions.
[ OK ] Started Serial Getty on ttyFIQ0.
[ OK ] Reached target Login Prompts.
[ OK ] Started Modem Manager.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started Hostname Service.
Starting Network Manager Script Dispatcher Service…
[ OK ] Started Network Manager Script Dispatcher Service.
[ 10.638249] dhd_open: Enter c0d12a61
[ 10.638297] dhd_open : no mutex held. set lock
[ 10.638310]
[ 10.638310] Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[ 10.638326] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 10.638334] wifi_platform_set_power = 1
[ 10.638343] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 10.638351] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 10.638365] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 10.943378] sdio_reset_comm():
[ 10.959190] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 10.976968] mmc_host mmc1: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 11.038856] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 11.047391] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 11.054476] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 11.067364] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 11.081418] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ OK ] Started Adbd for linux.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes…
[ OK ] Started Update UTMP about System Runlevel Changes.
[ 11.209918] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2
Debian GNU/Linux 10 firefly ttyFIQ0
firefly login: root (automatic login)
[ 11.235729] dwc3 ffd00000.dwc3: device reset
Last login: Thu Feb 14 10:12:01 UTC 2019 on ttyFIQ0
Linux firefly 4.19.111 #1 SMP PREEMPT Wed Feb 8 16:52:46 CST 2023 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
[ 11.343580] android_work: sent uevent USB_STATE=CONNECTED
[ 11.423969] configfs-gadget gadget: high-speed config #1: b
[ 11.424176] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.434460] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 11.434590] sdioh_start: set sd_f2_blocksize 256
[ 11.434911]
[ 11.434911]
[ 11.434911] dhd_bus_devreset: == WLAN ON ==
[ 11.435065] F1 signature read @0x18000000=0x1541a9a6
[ 11.440991] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 11.442359] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 11.442520] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 11.444292] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 11.444333] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43438a1.bin
[ 11.444343] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6212a.txt
[ 11.444352] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43438a1.blob
[ 11.444367] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 11.445307] dhd_os_open_image: /vendor/etc/firmware/fw_bcm43438a1.bin (414579 bytes) open success
[ 11.502902] dhd_os_open_image: /vendor/etc/firmware/nvram_ap6212a.txt (1017 bytes) open success
[ 11.503723] NVRAM version: AP6212A_NVRAM_V1.0.2_20191121
[ 11.504378] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 11.579786] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 11.579936] bcmsdh_oob_intr_register: HW_OOB irq=109 flags=0x4
[ 11.580266] dhd_get_memdump_info: File [/data/misc/wifi/.memdump.info] doesn’t exist
[ 11.580305] dhd_get_memdump_info: MEMDUMP ENABLED = 2
[ 11.581328] Disable tdls_auto_op failed. -1
[ 11.581351] dhd_tcpack_suppress_set 352: already set to 0
[ 11.581708] dhd_apply_default_clm: Ignore clm file /vendor/etc/firmware/clm_bcm43438a1.blob
[ 11.584344] Firmware up: op_mode=0x0005, MAC=b8:13:32:30:d9:70
[ 11.587510] dhd_preinit_ioctls Set scancache failed -23
[ 11.598564] Driver: 1.579.77.41.22 (r-20191105-2)(20191120-1)
[ 11.598564] Firmware: wl0: Jun 13 2018 13:18:38 version 7.45.96.24 (7ffe8b7@shgit) (r) FWID 01-40f9deb0 es7.c5.n4.a3
[ 11.598564] CLM: 7.11.15 (2014-05-26 10:53:55)
[ 11.598812] dhd_txglom_enable: enable 1
[ 11.598826] [dhd] dhd_conf_set_txglom_params : txglom_mode=copy
[ 11.598836] [dhd] dhd_conf_set_txglom_params : txglomsize=36, deferred_tx_len=0
[ 11.598843] [dhd] dhd_conf_set_txglom_params : txinrx_thres=-1, dhd_txminmax=1
[ 11.598852] [dhd] dhd_conf_set_txglom_params : tx_max_offset=0, txctl_tmo_fix=300
[ 11.598865] [dhd] dhd_conf_get_disable_proptx : fw_proptx=1, disable_proptx=-1
[ 11.600018] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[ 11.601921] dhd_pno_init: Support Android Location Service
[ 11.629208] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[ 11.631520] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
[ 11.631561] dhd_rtt_init : FTM is not supported
[ 11.631570] dhd_preinit_ioctls: SensorHub diabled 0
[ 11.632500] dhd_preinit_ioctls failed to set ShubHub disable
[ 11.634256] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23
[ 11.634271] failed to get wnm_bsstrans_resp
[ 11.634891] failed to set WNM capabilities
[ 11.635179] [dhd] dhd_conf_set_country : set country CN, revision 0
[ 11.635202] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[ 11.638317] [dhd] dhd_conf_set_country : Country code: CN (CN/0)
[ 11.642788] [dhd] CONFIG-ERROR) dhd_conf_set_intiovar : ampdu_mpdu setting failed -29
[ 11.642822] [dhd-wlan0] wl_android_wifi_on : Success
[ 11.672421] [dhd] CFG80211-ERROR) __wl_update_wiphybands : error reading vhtmode (-23)
[ 11.685040] dhd_open : the lock is released.
[ 11.685074] dhd_open: Exit ret=0
[ 11.804629] P2P interface registered
[ 11.804677] wl_cfgp2p_add_p2p_disc_if: wdev: 49951420, wdev->net: (null)
[ 11.829960] WLC_E_IF: NO_IF set, event Ignored
[ 11.831977] P2P interface started
DTSI增加内容如下:
 panel@0 {
    	rgb-mode = "p888";
	width-mm = <99>;
	height-mm = <74>;
	status = "okay";
	display-timings {
			hactive = <480>;
			vactive = <272>;
			hback-porch = <10>;
			vback-porch = <4>;
			vfront-porch = <4>;
			hsync-len = <2>;
			vsync-len = <2>;
	                hsync-active = <0>;
            		vsync-active = <0>;
            		de-active = <0>;
	port {
status = “okay”;
&rgb {
status = “okay”;
ports {
	rgb_out: port@1 {
		reg = <1>;
		#size-cells = <0>;
			reg = <0>;
&route_rgb {
status = “okay”;
&vop {
status = “okay”;
&rgb_in_vop{
status = “okay”;
新建文本文档 (2).txt (57.9 KB)
7_HT043DA-V.0单屏(2) (1).pdf (350 KB)
你好,请问屏点亮了吗?能否告知下方法?
