The IPQ8072 and IPQ8072A are high-performance wireless connectivity solutions designed by Qualcomm Technologies. These solutions are based on the Qualcomm Networking Pro 800 Platform and offer advanced features such as support for Wi-Fi 6E, Multi-Gigabit Ethernet, and advanced security protocols.
The IPQ8072 and IPQ8072A are highly integrated solutions that combine a powerful 64-bit quad-core ARM CPU with a wide range of wireless and wired connectivity interfaces. These interfaces include 2.5Gbps and 5Gbps Ethernet, 2x2 802.11ax Wi-Fi, Bluetooth 5.2, and support for Zigbee and Thread mesh networks.
To further enhance the performance and reliability of the IPQ8072 and IPQ8072A, Qualcomm has also developed the QCN9074 and QCN9024 wireless chipsets. These chipsets are designed to work in conjunction with the IPQ8072 and IPQ8072A to provide high-speed, low-latency wireless connectivity for a wide range of devices and applications.
The QCN9074 is a 4x4 Wi-Fi 6E chipset that supports peak data rates of up to 4.8Gbps. This chipset supports both the 2.4GHz and 5GHz bands, as well as the new 6GHz band that is now available for use in many regions around the world. The QCN9074 also supports advanced features such as MU-MIMO, OFDMA, and 1024-QAM, which help to improve the efficiency and throughput of wireless networks.
The QCN9024, on the other hand, is a 2x2 Wi-Fi 6E chipset that supports peak data rates of up to 1.2Gbps. This chipset is designed for use in smaller, lower-power devices such as smartphones, tablets, and IoT devices. The QCN9024 also supports advanced features such as MU-MIMO and OFDMA, which help to improve the performance and efficiency of wireless networks.
In conclusion, the combination of the IPQ8072 and IPQ8072A wireless solutions with the QCN9074 and QCN9024 chipsets offers a powerful and flexible wireless connectivity platform that is well-suited for a wide range of applications. Whether you are building a high-speed home network, a large enterprise Wi-Fi network, or a low-power IoT network, these solutions can provide the performance, reliability,you need to succeed.
Wallys IPQ8072 IPQ8072A with QCN9074 QCN9024 Networking Solution
1.DR8072A(HK09)
Website:
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate 8 MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ Support 802.11ac TX Beamforming
■ Support 802.11ac/802.11ax MU-MIMO DL and UL
■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz ) + 4x4/2.4GHz
■ Supports Dynamic Frequency Selection (DFS)
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to +70 ºC
Storage Temperature Range -40 to +90 ºC
Storage Humidity Range 0 to +90 (non-condensing)
Hardware Specifications
Symbol Parameter
CPU Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency Derived from Qualcomm Atheros AP.HK09
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface
Frequency Range 2.412~2.472GHz, 5.150~5.825GHz
MiniPCIe Slot 1x MiniPCIe Slot with PCIe 3.0
Modulation Techniques OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
Flash NOR Flash: 8 MB
NAND Flash: 256MB
Wireless On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 17dBm per chain
On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 17dBm per chain 8x U.FL Connectors
Reset Buttons 1x S/W Reset Button
DC Jack Input 1x DC Jack Connector: 12V
Interface 4x 1Gbps Ethernet Port, 2x 2.5Gbps Ethernet Port 2x USB 3.0 Port 1x JTAG 20 Pin Connector 1x Serial Port 4 Pin Connector
LED 2x RGB LED Indicators
Power Consumption TBD
2.DR8072V01
Website:
Features
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Symbol Parameter
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range 2.412~2.472GHz, 5.150~5.825GHZ M.2 Slot 1x M.2 Slot with PCIe 3.0
NOR Flash: 8 MB
Interface 4x 1Gbps Ethernet Port, 1x 10Gbps Ethernet Port 1x 10Gbps SFP
Our company:
Wallys Communications (Suzhou) Co., LTD www.wallystech.com/index.html
EMAIL:sales4@wallystech.com
