Relations between IPQ4018 and IPQ4028 WiFi 5 Wireless Solutions|Wallys DR40X8H
When it comes to wireless networking, Two of notable offerings are the IPQ4018 and IPQ4028, which are both WiFi 5 (802.11ac) wireless solutions. While they belong to the same product family and share several similarities, there are also some key differences between them. Let’s explore the relations between these two solutions in more detail.
1 Architecture and Performance:
The IPQ4018 and IPQ4028 are based on the same architecture, featuring a quad-core ARM Cortex A7 processor and a dual-core network accelerator. This design allows for efficient processing of network traffic and enables smooth data transmission in wireless networks. In terms of performance, both solutions offer excellent throughput and coverage capabilities, ensuring reliable and high-speed connectivity.
2 WiFi Standards:
Both the IPQ4018 and IPQ4028 support the WiFi 5 standard (802.11ac), which delivers faster speeds, increased capacity, and improved reliability compared to its predecessor, WiFi 4 (802.11n). WiFi 5 is capable of providing Gigabit-level wireless connectivity, making it suitable for a wide range of applications, including home networks, small businesses, and enterprise environments.
3 Antenna Configuration:
One significant difference between the IPQ4018 and IPQ4028 lies in the number of supported spatial streams and antenna configurations. The IPQ4018 supports up to two spatial streams and can handle up to two antennas, while the IPQ4028 offers support for up to four spatial streams and can handle up to four antennas. This distinction allows the IPQ4028 to achieve higher data rates and improved performance in scenarios with multiple devices or higher network traffic.
4 Target Applications:
Both the IPQ4018 and IPQ4028 are versatile solutions suitable for various applications. They can be used in residential routers, wireless access points, network extenders, and other devices requiring reliable and high-performance WiFi connectivity. The choice between the two solutions often depends on specific requirements such as the desired coverage range, number of devices, and data throughput needs.
5 Development and Integration:
Qualcomm provides comprehensive development kits, tools, and documentation to facilitate the integration of the IPQ4018 and IPQ4028 solutions into networking products. These development resources allow manufacturers to tailor their products to meet specific market needs while leveraging the performance and features offered by the IPQ4018 and IPQ4028 platforms.
In conclusion, the IPQ4018 and IPQ4028 WiFi 5 wireless solutions from Qualcomm share a common architecture and provide robust wireless connectivity. While the IPQ4028 offers additional spatial streams and antenna configurations for improved performance in high-demand scenarios, the IPQ4018 is a more cost-effective option suitable for applications with moderate connectivity requirements. The choice between these solutions depends on the specific needs of the target application, enabling manufacturers to deliver reliable and high-performance WiFi connectivity to their customers.
Wallys//[b]IPQ4018[/b]/IPQ4028chipset/Routerboard/DR40X8H-high-powersupport-MU-MIMO-802.11ac
Website:
[u]https://www.wallystech.com/Routerboard/DR40X8H-Qualcomm-IPQ4018-IPQ4028-2T2R-Dual-Band-2-4GHz-5GHz-high-power-support-MU-MIMO-802.11ac-Wave-2.html[/u]
One of the most notable features of the Wallys Routerboard DR40X8H is its eight gigabit Ethernet ports, which provide ample connectivity options for multiple devices. The router also supports a range of advanced networking protocols, including VLANs, VPNs, and QoS, which can help to ensure a stable and efficient network connection.
In addition to its networking capabilities, the Wallys Routerboard DR40X8H also boasts a powerful processor and plenty of memory. This makes it ideal for tasks such as data-intensive applications, video streaming, and online gaming, which require a high degree of processing power.
One of the key advantages of the Wallys Routerboard DR40X8H is its ease of use. The router comes with a user-friendly interface that is easy to navigate and configure, even for those with little to no networking experience. Additionally, the router is designed to be easy to set up and deploy, making it an ideal choice for businesses or individuals who need a reliable and efficient networking solution without the hassle of complex configuration processes.
Product Parameter:
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Operating Temperature Range -40 to +60 ºC
Storage Temperature Range -65 to +105 ºC
Operating Humidity Range 5 to +95 (non-condensing )%
Hardware Specifications
Symbol Parameter
CPU IPQ4018 (Quad core ARM Cortex A7 at 710 MHz)
Antenna Connector 2 x 5G MMCX connectors;2x2.4G MMCX 10/100/1000Mbps Gigabit Ethernet
2xRJ45
SFP connector 1xSFP fiber module connector (optional) 3G/4G connector
1xminipcie 3G/4G connector support with two sim card
USB connector 1xUSB 3.0 connector
POE 24V~48V passive POE
DC Jack 24V~48V power supply
ROHS Compliance YES
Dimension 115mm x 105mm x 16mm
Nor Flash 2MB~32MB
Nand Flash 128MB
DDR 256MB
Overall, the Wallys Routerboard DR40X8H is an excellent choice for anyone in need of a high-performance router that can handle the demands of modern networking. With its advanced features, ease of use, and powerful performance, this router is sure to meet the needs of even the most demanding users.
Our company:
Wallys Communications (Suzhou) Co., LTD Wallys 802.11ax, wifi 6, IPQ4029,IPQ4019,IPQ6018,IPQ6000.Router board, wireless card.Access Point-Wallys Communications (Suzhou ) Co., LTD
EMAIL:​sales4@wallystech.com
