mpp编码失败
固件文件名称:dev:/tmz$ ffgo version OS: Ubuntu 20.04.6 LTS MOD
Log日志:1.txt
MODEL: Firefly AIO-3588Q MIPI101(Linux)
FIREFLY: v2.40-7-gaab3442
DATE: 20230629
KERNEL: Linux version 5.10.160 (lvsx@tchip16) (kernel commit id: dc384cc20ddf) (sdk version: rk3588_linux_release_20230704_v1.1.1a) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #111 SMP Tue Jul 4 11:41:59 CST 2023
0:00:00.073694217 181803 0x55b1bc8b60 WARN mppenc gstmppenc.c:641:gst_mpp_enc_set_format:<myenc_1> framerate (0/1) is insane!
rga_api version 1.8.1_[4]
RgaBlit(1465) RGA_BLIT fail: Invalid argument
RgaBlit(1466) RGA_BLIT fail: Invalid argument
fd-vir-phy-hnd-format[0, 0x7fe83490a0, (nil), 0, 0]
rect[0, 0, 1280, 800, 3840, 800, 1792, 0]
f-blend-size-rotation-col-log-mmu[0, 0, 0, 0, 0, 0, 1]
fd-vir-phy-hnd-format[33, (nil), (nil), 0, 0]
rect[0, 0, 1280, 800, 1280, 800, 2560, 0]
This output the user patamaters when rga call blit fail
:00:14.891498867 181803 0x55b1bc8b60 WARN mpp gstmpp.c:235:gst_mpp_rga_do_convert: failed to blit
0:00:14.891568285 181803 0x55b1bc8b60 ERROR mppenc gstmppenc.c:829:gst_mpp_enc_convert:<myenc_1> failed to convert frame
0:00:14.891586952 181803 0x55b1bc8b60 ERROR mppenc gstmppenc.c:1021:gst_mpp_enc_handle_frame:<myenc_1> not negotiated
0:00:14.891610285 181803 0x55b1bc8b60 WARN mppenc gstmppenc.c:1025:gst_mpp_enc_handle_frame:<myenc_1> can’t handle this frame
0:00:14.891973123 181803 0x55b1bc8b60 WARN basesrc gstbasesrc.c:3072:gst_base_src_loop:<mysource_1> error: Internal data stream error.
0:00:14.891999665 181803 0x55b1bc8b60 WARN basesrc gstbasesrc.c:3072:gst_base_src_loop:<mysource_1> error: streaming stopped, reason not-negotiated (-4)
源码:
CRINFO << "starting gstreamer";
    if (mGstInfo.pipeline = gst_pipeline_new("mypipeline_1"); mGstInfo.pipeline == nullptr) {
        CRERROR << "mGstInfo.pipeline nullptr";
        return false;
    if (mGstInfo.appsrc = gst_element_factory_make("appsrc", "mysource_1"); mGstInfo.appsrc == nullptr) {
        CRERROR << "mGstInfo.appsrc nullptr";
        return false;
    if (mGstInfo.appsink = gst_element_factory_make("appsink", "mysink_1"); mGstInfo.appsink == nullptr) {
        CRERROR << "mGstInfo.appsink nullptr";
        return false;
    if (mGstInfo.frame_encoder = gst_element_factory_make("mpph264enc", "myenc_1");
        mGstInfo.frame_encoder == nullptr) {
        CRERROR << "mGstInfo.frame_encoder nullptr";
        return false;
    mGstInfo.gst_elements.push_back(mGstInfo.appsrc);
    mGstInfo.gst_elements.push_back(mGstInfo.frame_encoder);
    mGstInfo.gst_elements.push_back(mGstInfo.appsink);
    GstCaps *caps_appsrc = nullptr, *caps_h264 = nullptr, *caps_conv = nullptr;
    caps_appsrc = gst_caps_new_simple("video/x-raw", "format", G_TYPE_STRING, mGstInfo.type.c_str(), "width",
                                      G_TYPE_INT, mGstInfo.width, "height", G_TYPE_INT, mGstInfo.height,
                                      "framerate", GST_TYPE_FRACTION, mGstInfo.framerate, 1, "chroma-site",
                                      G_TYPE_STRING, "mpeg2", NULL);
    if (caps_appsrc == nullptr) {
        CRERROR << "caps_appsrc nullptr";
        return false;
    // caps_h264 =
    //     gst_caps_new_simple("video/x-h264", "stream-format", G_TYPE_STRING, "byte-stream", "alignment",
    //                         G_TYPE_STRING, "au", "profile", G_TYPE_STRING, "baseline", "height", G_TYPE_INT,
    //              mGstInfo.height,"width", G_TYPE_INT, mGstInfo.width, NULL);
    caps_h264 =
                            G_TYPE_STRING, "au", NULL);
    if (caps_h264 == nullptr) {
        CRERROR << "caps_h264 nullptr";
        gst_caps_unref(caps_appsrc);
        return false;
    int blocksize = mGstInfo.width * mGstInfo.height * mGstInfo.channel;  // TODO::
    g_object_set(G_OBJECT(mGstInfo.appsrc), "caps", caps_appsrc, "blocksize", blocksize, NULL);
    CRINFO << "mGstInfo.appsrc set";
    // g_object_set(G_OBJECT(mGstInfo.appsink), "caps", caps_h264, NULL);
    // CRINFO << "mGstInfo.appsink set";
    g_object_set(G_OBJECT(mGstInfo.frame_encoder), "bps", mGstInfo.bitrate, "bps-max", mGstInfo.bitrate,
                 "bps-min", mGstInfo.bitrate, "gop", mGstInfo.iframeinterval, "header-mode", 1, "height",
                 mGstInfo.height, "profile", 66, "rc-mode", 1, "width", mGstInfo.width, NULL);
    CRINFO << "mGstInfo.encoder set";
    mGstInfo.loop = g_main_loop_new(NULL, FALSE);
    mGstInfo.bus = gst_pipeline_get_bus(GST_PIPELINE(mGstInfo.pipeline));
    mGstInfo.bus_watch_id = gst_bus_add_watch(mGstInfo.bus, busCall, mGstInfo.loop);
    gst_object_unref(mGstInfo.bus);
    for (int i = 0; i < mGstInfo.gst_elements.size(); ++i) {
        gst_bin_add(GST_BIN(mGstInfo.pipeline), mGstInfo.gst_elements[i]);
        if (i > 0) {
            if (!gst_element_link(mGstInfo.gst_elements[i - 1], mGstInfo.gst_elements[i])) {
                CRERROR << "link element [" << mGstInfo.gst_elements[i - 1]->object.name << "] and ["
                        << mGstInfo.gst_elements[i]->object.name << "] failed.";
                gst_caps_unref(caps_h264);
                return false;
    if (caps_conv != nullptr) { gst_caps_unref(caps_conv); }
    CRINFO << "iframeinterval: " << mGstInfo.iframeinterval << ", bitrate: " << mGstInfo.bitrate
           << ", for image " << mGstInfo.width << "*" << mGstInfo.height;
    // Start pipeline so it could process incoming data
    GstStateChangeReturn ret = gst_element_set_state(mGstInfo.pipeline, GST_STATE_PLAYING);
    CRINFO << "gst_element_set_state:" << ret;
    mGstreamerThreadStarted = true;  // TODO::
    CRINFO << "gstreamer thread started";
    return true;
1.txt (157 KB)
我也遇到同样的问题,请问你问题解决了吗?
