执行会出错固件类型:官方提供的固件
固件文件名称:AIBOX-1684X
固件下载地址:快速部署 Llama3 — Firefly Wiki
Log日志:log.txt
root@aibox-1684x:/home/bingo# ./talk_to_llama3.sh
Transformers library is already installed.
None of PyTorch, TensorFlow >= 2.0, or Flax have been found. Models won’t be available and only tokenizers, configuration and file/data utilities can be used.
Load ./llama3/Llama3/token_config/ …
Special tokens have been added in the vocabulary, make sure the associated word embeddings are fine-tuned or trained.
Device [ 0 ] loading …
[BMRT][bmcpu_setup:406] INFO:cpu_lib ‘libcpuop.so’ is loaded.
bmcpu init: skip cpu_user_defined
open usercpu.so, init user_cpu_init
Model[./llama3/bmodels/llama3-8b_int4_1dev_256.bmodel] loading …
[BMRT][load_bmodel:1084] INFO:Loading bmodel from [./llama3/bmodels/llama3-8b_int4_1dev_256.bmodel]. Thanks for your patience…
[BMRT][load_bmodel:1023] INFO:pre net num: 0, load net num: 69
Done!
_____ _ __ _ _ ___
| ___(_)_ __ ___ / _| |_ _ / \ |_ _|
| |_ | | '__/ _ \ |_| | | | | / _ \ | |
| _| | | | | __/ _| | |_| | / ___ \ | |
|_| |_|_| \___|_| |_|\__, | /_/ \_\___|
|___/
User: who are you
Llama3: [bmlib_memory][error] bm_device_mem_range_valid saddr=0x19e8b60 eaddr=0x7512f4c7 out of range
./talk_to_llama3.sh: line 13: 1475 Segmentation fault python3 ./llama3/Llama3/python_demo/pipeline.py -m ./llama3/bmodels/llama3-8b_int4_1dev_256.bmodel -t ./llama3/Llama3/token_config/ -d 0
log.txt (1.44 KB)
