我想把我的RK3288板子刷ubuntu固件,但是刷了官方的固件后hdmi没输出。
我想把我的RK3288板子(他是收银台上的板子应该)刷ubuntu固件,但是刷了官方的固件后hdmi没输出。然后我手里有这个板子厂商提供的安卓7的固件,然后我解包到这几个文件,
我也试过自己编译linux固件但是到
编译Linux 固件 RK3288遇到报错 - Firefly-RK3288 - Firefly开源社区编译Linux 固件 RK3288遇到报错 (t-firefly.com)
这一步出现问题了,上边说缺少几个文件,我就把今天从厂商哪里的得到的解包里边的几个名字一样的文件替换上去了,结果生成固件后,报错
DDR Version 1.06 20171020
Channel a: DDR3 400MHz
Channel b: DDR3 400MHz
Memory OK
Memory OK
Boot1 Release Time: Apr 11 2018 10:32:58, version: 2.36
ChipType = 0x8, 224
mmc2:cmd19,256
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7457MB
FwPartOffset=2000 , 2000
mmc0:cmd8,1024
mmc0:cmd8,1024
mmc0:cmd8,1024
SdmmcInit=0 1
StorageInit ok = 35628
LOADER Check OK! 0x0, 68287
TOS    Check OK! 0x8400000, 98045
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:377: Initializing (1.1.0-316-g7b4ec90 #59 Wed May 30 08:26:33 UTC 2018 arm)
INF [0x0] TEE-CORE:init_primary_helper:378: Release version: 1.3
INF [0x0] TEE-CORE:init_primary_helper:379: Next entry point address: 0x0
U-Boot 2014.10-RK3288-06 (Jul 05 2023 - 14:17:06)
CPU: rk3288
cpu version = 0
CPU's clock information:
    arm pll = 816000000HZ
    periph pll = 594000000HZ
    ddr pll = 396000000HZ
    codec pll = 384000000HZ
Board:	Rockchip platform Board
Uboot as second level loader
DRAM:  Found dram banks: 1
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x00e00000
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 2 0
storage init OK!
GetParam
W: Invalid Parameter's tag (0x00000000)!
Invalid parameter
No pmic detect.
misc partition not found!
#Boot ver: 0000-00-00#0.00
empty serial no.
normal boot.
checkKey
====================i=0,value=1023
====================i=1,value=1018
====================i=2,value=1018
====================i=3,value=1017
====================i=4,value=1018
====================i=5,value=1018
====================i=6,value=1017
====================i=7,value=1018
====================i=8,value=1018
====================i=9,value=1018
keyValueHigh=30,keyValueLow=0
====================hCnt=0
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
Hit any key to stop autoboot:  0
'boot' does not seem to be a partition nor an address
Unable to boot:boot
try to start recovery
'recovery' does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
'backup' does not seem to be a partition nor an address
Unable to boot:backup
try to start rockusb
有什么解决办法吗?
这个是下载官方固件报的错
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-01 (Jan 21 2015 - 16:36:44)
CPU: rk3288
    arm pll = 600000000HZ
    periph pll = 297000000HZ
    ddr pll = 200000000HZ
DRAM:  Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk3288!
Unknow param: MACHINE_ID:007!
Unknow param: MANUFACTURER:RK3288!
no adc node
light power led: bank-8 pin-2
can't find dts node for ricoh619
can't find dts node for act8846
can't find dts node for rk808
can't find dts node for rk818
#Boot ver: 2015-01-21#2.19
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
failed to find part:misc
Hit any key to stop autoboot:  1  0
kernel   @ 0x02000000 (0x0062e1a0)
ramdisk  @ 0x04bf0000 (0x002988cc)
Secure Boot state: 0
bootrk: do_bootm_linux...
   Loading Device Tree to 0481e000, end 0482ae17 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x500
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.16 (zouxf@mid-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #99 SMP Thu Sep 22 16:08:46 CST 2016
[    0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Firefly-RK3288
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] PERCPU: Embedded 13 pages/cpu @eef90000 s24064 r8192 d20992 u53248
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 522752
[    0.000000] Kernel command line: earlyprintk=ttyS2,115200 console=tty0 console=ttyS2,115200 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot linuxroot rw rootfstype=ext4 init=/sbin/init  mtdparts=rk29xxnand:0x00010000@0x00002000(boot),0x00002000@0x00012000(backup),-@0x00014000(linuxroot) storagemedia=emmc loader.timestamp=2015-01-21_16:36:44
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 2061360K/2097152K available (9965K kernel code, 587K rwdata, 3248K rodata, 1024K init, 525K bss, 35792K reserved, 0K cma-reserved, 1310720K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0de7520   (14206 kB)
[    0.000000]       .init : 0xc0e00000 - 0xc0f00000   (1024 kB)
[    0.000000]       .data : 0xc0f00000 - 0xc0f92f68   ( 588 kB)
[    0.000000]        .bss : 0xc0f94000 - 0xc10175a4   ( 526 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] L2C: failed to init: -19
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000025] Switching to timer-based delay loop, resolution 41ns
[    0.002234] Console: colour dummy device 80x30
[    0.003410] console [tty0] enabled
[    0.003465] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.003540] pid_max: default: 32768 minimum: 301
[    0.003677] Security Framework initialized
[    0.003716] Yama: becoming mindful.
[    0.003812] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003860] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.004828] Initializing cgroup subsys devices
[    0.004882] Initializing cgroup subsys freezer
[    0.004943] CPU: Testing write buffer coherency: ok
[    0.005015] ftrace: allocating 32824 entries in 97 pages
[    0.082879] CPU0: update cpu_capacity 430
[    0.082925] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[    0.083281] Setting up static identity map for 0x100000 - 0x100058
[    0.086578] CPU1: update cpu_capacity 430
[    0.086585] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[    0.088540] CPU2: update cpu_capacity 430
[    0.088547] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[    0.090477] CPU3: update cpu_capacity 430
[    0.090485] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[    0.090578] Brought up 4 CPUs
[    0.090728] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.090754] CPU: All CPU(s) started in SVC mode.
[    0.092348] devtmpfs: initialized
[    0.106544] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[    0.106988] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.107468] pinctrl core: initialized pinctrl subsystem
[    0.108644] NET: Registered protocol family 16
[    0.109532] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.132596] cpuidle: using governor ladder
[    0.162621] cpuidle: using governor menu
[    0.188739] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.188790] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.227875] iommu: Adding device ff930000.vop to group 0
[    0.227989] iommu: Adding device ff940000.vop to group 1
[    0.228106] iommu: Adding device ff9a0000.video-codec to group 2
[    0.229347] SCSI subsystem initialized
[    0.229679] usbcore: registered new interface driver usbfs
[    0.229776] usbcore: registered new interface driver hub
[    0.229865] usbcore: registered new device driver usb
[    0.230048] Linux video capture interface: v2.00
[    0.230126] pps_core: LinuxPPS API ver. 1 registered
[    0.230153] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.230218] PTP clock support registered
[    0.230846] Advanced Linux Sound Architecture Driver Initialized.
[    0.231721] Bluetooth: Core ver 2.21
[    0.231785] NET: Registered protocol family 31
[    0.231812] Bluetooth: HCI device and connection manager initialized
[    0.231847] Bluetooth: HCI socket layer initialized
[    0.231877] Bluetooth: L2CAP socket layer initialized
[    0.231937] Bluetooth: SCO socket layer initialized
[    0.233434] clocksource: Switched to clocksource arch_sys_counter
[    0.288019] NET: Registered protocol family 2
[    0.288805] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.288931] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    0.289431] TCP: Hash tables configured (established 8192 bind 8192)
[    0.289542] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    0.289629] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    0.289988] NET: Registered protocol family 1
[    0.290363] Trying to unpack rootfs image as initramfs...
[    0.488006] Freeing initrd memory: 2660K (c4bf0000 - c4e89000)
[    0.488990] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[    0.490914] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.491690] Initialise system trusted keyring
[    0.503836] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.505581] fuse init (API version 7.23)
[    0.511502] NET: Registered protocol family 38
[    0.511560] Key type asymmetric registered
[    0.511592] Asymmetric key parser 'x509' registered
[    0.511704] bounce: pool size: 64 pages
[    0.511981] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.512034] io scheduler noop registered
[    0.512065] io scheduler deadline registered
[    0.512277] io scheduler cfq registered (default)
[    0.512797] rockchip-usb-phy phy: vbus_drv is not assigned!
[    0.517643] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.517696] dma-pl330 ff250000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    0.518711] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.518760] dma-pl330 ffb20000.dma-controller: 	DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[    0.519516] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.521677] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[    0.522607] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 38, base_baud = 1500000) is a 16550A
[    0.523567] console [ttyS2] disabled
[    0.523639] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 39, base_baud = 1500000) is a 16550A
[    1.254853] console [ttyS2] enabled
[    1.259261] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 40, base_baud = 1500000) is a 16550A
[    1.269734] [drm] Initialized drm 1.1.0 20060810
[    1.275548] rockchip-lvds ff96c000.lvds: Failed to get supply 'avdd1v0': -517
[    1.282779] platform ff96c000.lvds: Driver rockchip-lvds requests probe deferral
[    1.291537] usbcore: registered new interface driver udl
[    1.299067] platform vga-encoder: Driver vga-encoder requests probe deferral
[    1.306761] platform vga-connector: Driver vga-connector requests probe deferral
[    1.314485] mali ffa30000.gpu: Failed to get regulator
[    1.319644] mali ffa30000.gpu: Power control initialization failed
[    1.325945] platform ffa30000.gpu: Driver mali requests probe deferral
[    1.334003] brd: module loaded
[    1.344921] loop: module loaded
[    1.348988] zram: Added device: zram0
[    1.352698] lkdtm: No crash points registered, enable through debugfs
[    1.361099] tun: Universal TUN/TAP device driver, 1.6
[    1.366215] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.373973] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[    1.382925] platform ff290000.ethernet: Driver rk_gmac-dwmac requests probe deferral
[    1.391275] PPP generic driver version 2.4.2
[    1.395932] usbcore: registered new interface driver rndis_wlan
[    1.402113] usbcore: registered new interface driver rt2800usb
[    1.408254] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.415773] usbcore: registered new interface driver pegasus
[    1.421509] usbcore: registered new interface driver rtl8150
[    1.427270] usbcore: registered new interface driver r8152
[    1.432843] usbcore: registered new interface driver asix
[    1.438336] usbcore: registered new interface driver ax88179_178a
[    1.444531] usbcore: registered new interface driver cdc_ether
[    1.450437] usbcore: registered new interface driver dm9601
[    1.456123] usbcore: registered new interface driver smsc75xx
[    1.461959] usbcore: registered new interface driver smsc95xx
[    1.467800] usbcore: registered new interface driver net1080
[    1.473559] usbcore: registered new interface driver rndis_host
[    1.479554] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.487111] usbcore: registered new interface driver cdc_ncm
[    1.492847] usbcore: registered new interface driver cdc_mbim
[    1.499038] ff540000.usb supply vusb_d not found, using dummy regulator
[    1.505762] ff540000.usb supply vusb_a not found, using dummy regulator
[    1.672769] dwc2 ff540000.usb: DWC OTG Controller
[    1.677556] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[    1.684672] dwc2 ff540000.usb: irq 43, io mem 0x00000000
[    1.690293] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.697125] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.704390] usb usb1: Product: DWC OTG Controller
[    1.709111] usb usb1: Manufacturer: Linux 4.4.16 dwc2_hsotg
[    1.714715] usb usb1: SerialNumber: ff540000.usb
[    1.720126] hub 1-0:1.0: USB hub found
[    1.723972] hub 1-0:1.0: 1 port detected
[    1.728598] ff580000.usb supply vusb_d not found, using dummy regulator
[    1.735338] ff580000.usb supply vusb_a not found, using dummy regulator
[    2.033474] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[    2.041132] dwc2 ff580000.usb: DWC OTG Controller
[    2.045917] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[    2.053008] dwc2 ff580000.usb: irq 44, io mem 0x00000000
[    2.058623] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.065454] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.072704] usb usb2: Product: DWC OTG Controller
[    2.077455] usb usb2: Manufacturer: Linux 4.4.16 dwc2_hsotg
[    2.083045] usb usb2: SerialNumber: ff580000.usb
[    2.088460] hub 2-0:1.0: USB hub found
[    2.092267] hub 2-0:1.0: 1 port detected
[    2.097735] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.104318] ehci-platform: EHCI generic platform driver
[    2.109953] usbcore: registered new interface driver cdc_acm
[    2.115660] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.123731] usb 1-1: new high-speed USB device number 2 using dwc2
[    2.123828] usbcore: registered new interface driver cdc_wdm
[    2.123956] usbcore: registered new interface driver usb-storage
[    2.124091] usbcore: registered new interface driver usbserial
[    2.124143] usbcore: registered new interface driver usbserial_generic
[    2.124186] usbserial: USB Serial support registered for generic
[    2.124248] usbcore: registered new interface driver cp210x
[    2.124290] usbserial: USB Serial support registered for cp210x
[    2.124366] usbcore: registered new interface driver ftdi_sio
[    2.124415] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.124551] usbcore: registered new interface driver keyspan
[    2.124594] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    2.124635] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    2.124676] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    2.124716] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    2.124782] usbcore: registered new interface driver option
[    2.124824] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.124991] usbcore: registered new interface driver oti6858
[    2.125034] usbserial: USB Serial support registered for oti6858
[    2.125096] usbcore: registered new interface driver pl2303
[    2.125145] usbserial: USB Serial support registered for pl2303
[    2.125213] usbcore: registered new interface driver qcserial
[    2.125256] usbserial: USB Serial support registered for Qualcomm USB modem
[    2.125333] usbcore: registered new interface driver sierra
[    2.125376] usbserial: USB Serial support registered for Sierra USB modem
[    2.126257] usbcore: registered new interface driver iforce
[    2.126357] usbcore: registered new interface driver xpad
[    2.126544] usbcore: registered new interface driver usbtouchscreen
[    2.133759] i2c /dev entries driver
[    2.134660] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at f08be000
[    2.135353] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f08d2000
[    2.136034] rk3x-i2c ff170000.i2c: Initialized RK3xxx I2C bus at f08d4000
[    2.137074] fan53555-regulator 0-0040: Failed to get chip ID!
[    2.137535] fan53555-regulator 0-0041: Failed to get chip ID!
[    2.138096] rtc-hym8563 0-0051: could not init device, -6
[    2.139104] vcc_ddr: failed to get the current voltage(-6)
[    2.139235] act8865 0-005a: failed to register REG1
[    2.139351] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f08d6000
[    2.140158] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f08d8000
[    2.140836] probe device ff9a0000.video-codec
[    2.141865] rockchip-vpu ff9a0000.video-codec: Rockchip VPU encoder registered as /vpu/video0
[    2.142067] rockchip-vpu ff9a0000.video-codec: Rockchip VPU decoder registered as /vpu/video1
[    2.142293] usbcore: registered new interface driver uvcvideo
[    2.142297] USB Video Class driver (1.1.1)
[    2.143093] platform io-domains: Driver rockchip-iodomain requests probe deferral
[    2.144126] rk_tsadcv2_initialize: Missing rockchip,grf property
[    2.145194] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    2.145566] Bluetooth: Virtual HCI driver ver 1.5
[    2.145755] Bluetooth: HCI UART driver ver 2.3
[    2.145762] Bluetooth: HCI UART protocol H4 registered
[    2.145766] Bluetooth: HCI UART protocol LL registered
[    2.145770] Bluetooth: HCI UART protocol ATH3K registered
[    2.145881] usbcore: registered new interface driver bfusb
[    2.145972] usbcore: registered new interface driver btusb
[    2.146220] platform cpufreq-dt.0: Driver cpufreq-dt requests probe deferral
[    2.146510] platform cpufreq-dt: Driver cpufreq-dt requests probe deferral
[    2.146621] sdhci: Secure Digital Host Controller Interface driver
[    2.146623] sdhci: Copyright(c) Pierre Ossman
[    2.146635] Synopsys Designware Multimedia Card Interface Driver
[    2.147465] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[    2.147498] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[    2.147512] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[    2.147566] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[    2.147744] platform ff0c0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    2.148265] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[    2.148295] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[    2.148307] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[    2.148357] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[    2.148409] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[    2.148471] platform ff0d0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    2.148995] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[    2.149021] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[    2.149034] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[    2.149089] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[    2.149228] platform ff0f0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    2.149439] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.150126] hidraw: raw HID events driver (C) Jiri Kosina
[    2.151331] usbcore: registered new interface driver usbhid
[    2.151334] usbhid: USB HID core driver
[    2.151728] ashmem: initialized
[    2.152112] rockchip-saradc ff100000.saradc: failed to get regulator, -517
[    2.152152] platform ff100000.saradc: Driver rockchip-saradc requests probe deferral
[    2.153920] usbcore: registered new interface driver snd-usb-audio
[    2.155937] platform sound_i2s: Driver asoc-simple-card requests probe deferral
[    2.157790] u32 classifier
[    2.157805] Netfilter messages via NETLINK v0.30.
[    2.157900] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    2.158528] ctnetlink v0.93: registering with nfnetlink.
[    2.159192] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.159336] Initializing XFRM netlink socket
[    2.160433] NET: Registered protocol family 10
[    2.161604] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    2.161843] sit: IPv6 over IPv4 tunneling driver
[    2.162626] NET: Registered protocol family 17
[    2.162656] NET: Registered protocol family 15
[    2.162703] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    2.162824] Bluetooth: RFCOMM socket layer initialized
[    2.162852] Bluetooth: RFCOMM ver 1.11
[    2.162894] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.162905] Bluetooth: HIDP socket layer initialized
[    2.162915] 8021q: 802.1Q VLAN Support v1.8
[    2.162949] lib80211: common routines for IEEE802.11 drivers
[    2.163003] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    2.163244] [BT_RFKILL]: Enter rfkill_rk_init
[    2.163704] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139.
[    2.163738] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149.
[    2.163759] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146.
[    2.163779] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151.
[    2.163789] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[    2.163850] [BT_RFKILL]: Request irq for bt wakeup host
[    2.163898] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[    2.163934] [BT_RFKILL]: ** disable irq
[    2.164134] [BT_RFKILL]: bt_default device registered.
[    2.164869] ThumbEE CPU extension supported.
[    2.164890] Registering SWP/SWPB emulation handler
[    2.165818] Loading compiled-in X.509 certificates
[    2.166498] rockchip-lvds ff96c000.lvds: Failed to get supply 'avdd1v0': -517
[    2.166564] platform ff96c000.lvds: Driver rockchip-lvds requests probe deferral
[    2.167016] platform vga-encoder: Driver vga-encoder requests probe deferral
[    2.167522] mali ffa30000.gpu: Failed to get regulator
[    2.167530] mali ffa30000.gpu: Power control initialization failed
[    2.167565] platform ffa30000.gpu: Driver mali requests probe deferral
[    2.168586] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[    2.168629] platform ff290000.ethernet: Driver rk_gmac-dwmac requests probe deferral
[    2.168941] platform io-domains: Driver rockchip-iodomain requests probe deferral
[    2.169100] platform cpufreq-dt.0: Driver cpufreq-dt requests probe deferral
[    2.169211] platform cpufreq-dt: Driver cpufreq-dt requests probe deferral
[    2.169918] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[    2.169951] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[    2.169965] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[    2.169996] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[    2.170151] platform ff0c0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    2.170825] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[    2.170853] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[    2.170865] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[    2.170897] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[    2.170945] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[    2.171007] platform ff0d0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    2.171718] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[    2.171744] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[    2.171756] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[    2.171782] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[    2.171918] platform ff0f0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    2.172251] rockchip-saradc ff100000.saradc: failed to get regulator, -517
[    2.172287] platform ff100000.saradc: Driver rockchip-saradc requests probe deferral
[    2.172618] platform sound_i2s: Driver asoc-simple-card requests probe deferral
[    2.172906] rockchip-lvds ff96c000.lvds: Failed to get supply 'avdd1v0': -517
[    2.172942] platform ff96c000.lvds: Driver rockchip-lvds requests probe deferral
[    2.173673] mali ffa30000.gpu: Failed to get regulator
[    2.173680] mali ffa30000.gpu: Power control initialization failed
[    2.173759] platform ffa30000.gpu: Driver mali requests probe deferral
[    2.174760] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[    2.174801] platform ff290000.ethernet: Driver rk_gmac-dwmac requests probe deferral
[    2.175107] platform io-domains: Driver rockchip-iodomain requests probe deferral
[    2.175260] platform cpufreq-dt.0: Driver cpufreq-dt requests probe deferral
[    2.175371] platform cpufreq-dt: Driver cpufreq-dt requests probe deferral
[    2.176064] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[    2.176099] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[    2.176111] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[    2.176139] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[    2.176286] platform ff0c0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    2.176957] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[    2.176985] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[    2.176997] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[    2.177021] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[    2.177067] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[    2.177127] platform ff0d0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    2.177813] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[    2.177840] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[    2.177852] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[    2.177876] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[    2.178010] platform ff0f0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    2.178338] rockchip-saradc ff100000.saradc: failed to get regulator, -517
[    2.178373] platform ff100000.saradc: Driver rockchip-saradc requests probe deferral
[    2.178684] platform sound_i2s: Driver asoc-simple-card requests probe deferral
[    2.178962] rockchip-lvds ff96c000.lvds: Failed to get supply 'avdd1v0': -517
[    2.179037] platform ff96c000.lvds: Driver rockchip-lvds requests probe deferral
[    2.179879] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    2.180331] hctosys: unable to open rtc device (rtc0)
[    2.180537] mali ffa30000.gpu: Failed to get regulator
[    2.180544] mali ffa30000.gpu: Power control initialization failed
[    2.180632] platform ffa30000.gpu: Driver mali requests probe deferral
[    2.181696] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[    2.181743] platform ff290000.ethernet: Driver rk_gmac-dwmac requests probe deferral
[    2.182078] platform io-domains: Driver rockchip-iodomain requests probe deferral
[    2.182240] platform cpufreq-dt.0: Driver cpufreq-dt requests probe deferral
[    2.182353] platform cpufreq-dt: Driver cpufreq-dt requests probe deferral
[    2.183085] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[    2.183117] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[    2.183131] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[    2.183165] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[    2.183333] platform ff0c0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    2.184105] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[    2.184140] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[    2.184154] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[    2.184181] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[    2.184235] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[    2.184303] platform ff0d0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    2.185054] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[    2.185085] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[    2.185098] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[    2.185125] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[    2.185288] platform ff0f0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    2.185652] rockchip-saradc ff100000.saradc: failed to get regulator, -517
[    2.185689] platform ff100000.saradc: Driver rockchip-saradc requests probe deferral
[    2.186010] platform sound_i2s: Driver asoc-simple-card requests probe deferral
[    2.186325] rockchip-lvds ff96c000.lvds: Failed to get supply 'avdd1v0': -517
[    2.186433] platform ff96c000.lvds: Driver rockchip-lvds requests probe deferral
[    2.195171] dovdd_1v8: disabling
[    2.195179] vcc_sd: disabling
[    2.195184] vcc_flash: disabling
[    2.195654] ALSA device list:
[    2.195657]   No soundcards found.
[    2.683461] vendor storage:20160801 ret = -1
[    3.513166] ttyS2 - failed to request DMA
[    3.518531] Freeing unused kernel memory: 1024K (c0e00000 - c0f00000)
Loading, please wait...
/init: line 224: can't create /sys/class/display/HDMI/enable: nonexistent directory
[    3.582867] udevd[123]: starting version 175
Begin: Loading essential drivers ... FATAL: Could not load /lib/modules/4.4.16/modules.dep: No such file or directory
done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
[    3.713945] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[    3.720684] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.727981] usb 1-1: Product: USB 2.0 Hub [MTT]
[    3.738156] hub 1-1:1.0: USB hub found
[    3.742535] hub 1-1:1.0: 7 ports detected
[    3.751088] mali ffa30000.gpu: Failed to get regulator
[    3.756362] mali ffa30000.gpu: Power control initialization failed
[    3.762859] platform ffa30000.gpu: Driver mali requests probe deferral
[    3.770963] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[    3.780548] platform ff290000.ethernet: Driver rk_gmac-dwmac requests probe deferral
[    3.788919] platform io-domains: Driver rockchip-iodomain requests probe deferral
[    3.798010] platform cpufreq-dt.0: Driver cpufreq-dt requests probe deferral
[    3.805404] platform cpufreq-dt: Driver cpufreq-dt requests probe deferral
[    3.813651] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[    3.820970] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[    3.827859] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[    3.833695] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[    3.844019] platform ff0c0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    3.852785] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[    3.860142] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[    3.867009] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[    3.872922] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[    3.882820] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[    3.889200] platform ff0d0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    3.897736] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[    3.905056] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[    3.911867] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[    3.917670] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[    3.927627] platform ff0f0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
[    3.935610] rockchip-saradc ff100000.saradc: failed to get regulator, -517
[    3.942534] platform ff100000.saradc: Driver rockchip-saradc requests probe deferral
[    3.950654] platform sound_i2s: Driver asoc-simple-card requests probe deferral
[    3.958332] rockchip-lvds ff96c000.lvds: Failed to get supply 'avdd1v0': -517
[    3.965588] platform ff96c000.lvds: Driver rockchip-lvds requests probe deferral
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 2...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 3...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 4...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 5...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 6...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 7...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 8...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 9...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 10...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 11...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 12...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 13...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 14...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 15...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 16...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 17...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 18...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 19...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 20...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 21...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 22...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 23...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 24...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 25...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 26...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 27...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 28...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 29...
wait-for-root /dev/block/mtd/by-name/linuxroot, retry 30...
Gave up waiting for root device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
   - Check root= (did the system wait for the right device?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT!  /dev/block/mtd/by-name/linuxroot does not exist.  Dropping to a shell!
/bin/sh: can't access tty; job control turned off
(initramfs)
