在ubuntu22.04.5下编译ITX-3588J开发板的【linux-5.10内核】出现找不到types.h头文件
SDK包名称:rk3588_linux_release_20250114_v1.4.0g.sdk.split00
SDK修改内容:没有任何修改
Log日志:头文件.zip
20250803在ubuntu22.04.5下编译ITX-3588J开发板的Buildoort系统【linux-5.10内核】出现找不到types.h头文件
Value of CONFIG_IP_NF_ARPTABLES is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_IP_NF_ARPTABLES is not set
New value: CONFIG_IP_NF_ARPTABLES=m
Value of CONFIG_NF_SOCKET_IPV6 is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_NF_SOCKET_IPV6 is not set
New value: CONFIG_NF_SOCKET_IPV6=m
Value of CONFIG_NF_TPROXY_IPV6 is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_NF_TPROXY_IPV6 is not set
New value: CONFIG_NF_TPROXY_IPV6=m
Value of CONFIG_NF_DUP_IPV6 is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_NF_DUP_IPV6 is not set
New value: CONFIG_NF_DUP_IPV6=m
Value of CONFIG_NF_LOG_IPV6 is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_NF_LOG_IPV6 is not set
New value: CONFIG_NF_LOG_IPV6=m
Value of CONFIG_R8125 is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_R8125 is not set
New value: CONFIG_R8125=m
Value of CONFIG_RTL8822CE is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_RTL8822CE is not set
New value: CONFIG_RTL8822CE=m
Value of CONFIG_RTL8852BE is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_RTL8852BE is not set
New value: CONFIG_RTL8852BE=m
Value of CONFIG_SND_SOC_BT_SCO is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_SND_SOC_BT_SCO is not set
New value: CONFIG_SND_SOC_BT_SCO=m
Value of CONFIG_EXFAT_FS is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_EXFAT_FS is not set
New value: CONFIG_EXFAT_FS=y
Value of CONFIG_BONDING is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_BONDING is not set
New value: CONFIG_BONDING=m
Value of CONFIG_USBIP_CORE is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_USBIP_CORE is not set
New value: CONFIG_USBIP_CORE=m
Value of CONFIG_NEW_LEDS is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: CONFIG_NEW_LEDS=y
New value: CONFIG_NEW_LEDS=y
Value of CONFIG_LEDS_CLASS is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: CONFIG_LEDS_CLASS=y
New value: CONFIG_LEDS_CLASS=y
Value of CONFIG_LEDS_GPIO is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: CONFIG_LEDS_GPIO=y
New value: CONFIG_LEDS_GPIO=y
Value of CONFIG_LEDS_TRIGGERS is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_LEDS_TRIGGERS is not set
New value: CONFIG_LEDS_TRIGGERS=y
Value of CONFIG_BINFMT_MISC is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_BINFMT_MISC is not set
New value: CONFIG_BINFMT_MISC=y
Value of CONFIG_RTC_DRV_PCF8563 is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_RTC_DRV_PCF8563 is not set
New value: CONFIG_RTC_DRV_PCF8563=y
Value of CONFIG_EEPROM_AT24 is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_EEPROM_AT24 is not set
New value: CONFIG_EEPROM_AT24=y
# merged configuration written to .config (needs make)
.config:7179:warning: override: reassigning to symbol BT_RTKBTUSB
.config:7183:warning: override: reassigning to symbol IP_VS
.config:7184:warning: override: reassigning to symbol VXLAN
.config:7187:warning: override: reassigning to symbol SCSI
.config:7224:warning: override: reassigning to symbol VETH
.config:7329:warning: override: reassigning to symbol NF_CONNTRACK
.config:7345:warning: override: reassigning to symbol NF_CONNTRACK_FTP
.config:7354:warning: override: reassigning to symbol NF_CONNTRACK_TFTP
.config:7368:warning: override: reassigning to symbol NF_TABLES
.config:7369:warning: override: reassigning to symbol NF_TABLES_INET
.config:7370:warning: override: reassigning to symbol NF_TABLES_NETDEV
.config:7371:warning: override: reassigning to symbol NFT_NUMGEN
.config:7372:warning: override: reassigning to symbol NFT_CT
.config:7373:warning: override: reassigning to symbol NFT_FLOW_OFFLOAD
.config:7374:warning: override: reassigning to symbol NFT_CONNLIMIT
.config:7375:warning: override: reassigning to symbol NFT_LOG
.config:7376:warning: override: reassigning to symbol NFT_LIMIT
.config:7377:warning: override: reassigning to symbol NFT_MASQ
.config:7378:warning: override: reassigning to symbol NFT_REDIR
.config:7379:warning: override: reassigning to symbol NFT_NAT
.config:7380:warning: override: reassigning to symbol NFT_TUNNEL
.config:7381:warning: override: reassigning to symbol NFT_OBJREF
.config:7383:warning: override: reassigning to symbol NFT_QUOTA
.config:7384:warning: override: reassigning to symbol NFT_REJECT
.config:7386:warning: override: reassigning to symbol NFT_COMPAT
.config:7387:warning: override: reassigning to symbol NFT_HASH
.config:7391:warning: override: reassigning to symbol NFT_SOCKET
.config:7392:warning: override: reassigning to symbol NFT_OSF
.config:7393:warning: override: reassigning to symbol NFT_TPROXY
.config:7396:warning: override: reassigning to symbol NFT_DUP_NETDEV
.config:7397:warning: override: reassigning to symbol NFT_FWD_NETDEV
.config:7400:warning: override: reassigning to symbol NF_FLOW_TABLE_INET
.config:7401:warning: override: reassigning to symbol NF_FLOW_TABLE
.config:7408:warning: override: reassigning to symbol NETFILTER_XT_MARK
.config:7446:warning: override: reassigning to symbol NETFILTER_XT_MATCH_ADDRTYPE
.config:7450:warning: override: reassigning to symbol NETFILTER_XT_MATCH_COMMENT
.config:7455:warning: override: reassigning to symbol NETFILTER_XT_MATCH_CONNTRACK
.config:7467:warning: override: reassigning to symbol NETFILTER_XT_MATCH_IPVS
.config:7471:warning: override: reassigning to symbol NETFILTER_XT_MATCH_MAC
.config:7502:warning: override: reassigning to symbol NFT_DUP_IPV4
.config:7503:warning: override: reassigning to symbol NFT_FIB_IPV4
.config:7504:warning: override: reassigning to symbol NF_TABLES_ARP
.config:7508:warning: override: reassigning to symbol NF_REJECT_IPV4
.config:7512:warning: override: reassigning to symbol IP_NF_IPTABLES
.config:7517:warning: override: reassigning to symbol IP_NF_FILTER
.config:7518:warning: override: reassigning to symbol IP_NF_TARGET_REJECT
.config:7520:warning: override: reassigning to symbol IP_NF_NAT
.config:7521:warning: override: reassigning to symbol IP_NF_TARGET_MASQUERADE
.config:7523:warning: override: reassigning to symbol IP_NF_TARGET_REDIRECT
.config:7524:warning: override: reassigning to symbol IP_NF_MANGLE
.config:7545:warning: override: reassigning to symbol NF_REJECT_IPV6
.config:7547:warning: override: reassigning to symbol IP6_NF_IPTABLES
.config:7559:warning: override: reassigning to symbol IP6_NF_FILTER
.config:7560:warning: override: reassigning to symbol IP6_NF_TARGET_REJECT
.config:7562:warning: override: reassigning to symbol IP6_NF_MANGLE
.config:7563:warning: override: reassigning to symbol IP6_NF_RAW
.config:7565:warning: override: reassigning to symbol IP6_NF_NAT
.config:7566:warning: override: reassigning to symbol IP6_NF_TARGET_MASQUERADE
SYNC include/config/auto.conf.cmd
UPD include/config/kernel.release
HOSTCC scripts/dtc/dtc.o
HOSTCC scripts/dtc/flattree.o
HOSTCC scripts/dtc/fstree.o
HOSTCC scripts/dtc/data.o
HOSTCC scripts/dtc/livetree.o
HOSTCC scripts/dtc/treesource.o
HOSTCC scripts/dtc/srcpos.o
HOSTCC scripts/dtc/checks.o
HOSTCC scripts/dtc/util.o
LEX scripts/dtc/dtc-lexer.lex.c
YACC scripts/dtc/dtc-parser.tab.[ch]
HOSTCC scripts/mod/mk_elfconfig
CC scripts/mod/empty.o
CC scripts/mod/devicetable-offsets.s
WRAP arch/arm64/include/generated/uapi/asm/kvm_para.h
WRAP arch/arm64/include/generated/uapi/asm/errno.h
WRAP arch/arm64/include/generated/uapi/asm/ioctl.h
WRAP arch/arm64/include/generated/uapi/asm/ioctls.h
WRAP arch/arm64/include/generated/uapi/asm/ipcbuf.h
WRAP arch/arm64/include/generated/uapi/asm/msgbuf.h
WRAP arch/arm64/include/generated/uapi/asm/poll.h
WRAP arch/arm64/include/generated/uapi/asm/resource.h
WRAP arch/arm64/include/generated/uapi/asm/sembuf.h
WRAP arch/arm64/include/generated/uapi/asm/shmbuf.h
WRAP arch/arm64/include/generated/uapi/asm/siginfo.h
In file included from ./include/linux/types.h:6,
WRAP arch/arm64/include/generated/uapi/asm/socket.h
from ./include/linux/mod_devicetable.h:12,
from scripts/mod/devicetable-offsets.c:3:
./include/uapi/linux/types.h:5:10: fatal error: asm/types.h: No such file or directory
5 | #include <asm/types.h>
compilation terminated.
WRAP arch/arm64/include/generated/uapi/asm/sockios.h
WRAP arch/arm64/include/generated/uapi/asm/stat.h
WRAP arch/arm64/include/generated/uapi/asm/swab.h
make[2]: *** [scripts/Makefile.build:117: scripts/mod/devicetable-offsets.s] Error 1
WRAP arch/arm64/include/generated/uapi/asm/termbits.h
make[2]: *** Waiting for unfinished jobs…
WRAP arch/arm64/include/generated/uapi/asm/termios.h
WRAP arch/arm64/include/generated/uapi/asm/types.h
UPD include/generated/uapi/linux/version.h
UPD include/generated/utsrelease.h
make[1]: *** [Makefile:1505: scripts_mod] Error 2
make[1]: *** Waiting for unfinished jobs…
HOSTCC scripts/dtc/dtc-lexer.lex.o
HOSTCC scripts/dtc/dtc-parser.tab.o
HOSTLD scripts/dtc/dtc
make: *** [arch/arm64/Makefile:214: rk3588-firefly-itx-3588j-mipi101-BSD1218-A101KL68.img] Error 2
ERROR: Running build_extboot failed!
ERROR: exit code 2 from line 787:
make ARCH=$RK_ARCH $RK_KERNEL_DTS.img -j$RK_JOBS
rootroot@rootroot-HP-245-14-inch-G10-Notebook-PC:~/firefly_rk3588_SDK$
头文件.zip (2 KB)
