Hi,
I recently tried to boot my Firefly-RK3288 and now it emits a high pitched whine and I get no display from HDMI.
I have erased flash and flashed “Firefly-RK3288_Android4.4_201504181055.img” via AndroidTool_v2.33 on Windows 7.
I connected UART and have attached the log:
[ 14.DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-02 (Jan 21 2015 - 17:07:53)
CPU: rk3288
CPU's clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
light power led: bank-8 pin-1
can't find dts node for ricoh619
pmic:act8846
#Boot ver: 2015-01-21#2.17
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
kernel @ 0x02000000 (0x005fc428)
ramdisk @ 0x04bf0000 (0x00121028)
Secure Boot state: 0
bootrk: do_bootm_linux...
Loading Device Tree to 0480c000, end 048271a4 ... OK
Starting kernel ...
[ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #49 SMP PREEMPT Fri Apr 17 10:17:31 CST 2015
[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1ebc000 s14016 r8192 d14656 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
[ 0.000000] Kernel command line: console=ttyS2 earlyprintk androidboot.hardware=rk30board androidboot.console=ttyS2 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2015-01-21_17:07:53 hdmi.vic=-1
[ 0.000000] Memory: 2047056k/2047056k available, 50096k reserved, 1318912K highmem
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a7ced4 (10708 kB)
[ 0.000000] .init : 0xc0a7d000 - 0xc0ccc6c0 (2366 kB)
[ 0.000000] .data : 0xc0cce000 - 0xc0d6afc8 ( 628 kB)
[ 0.000000] .bss : 0xc0d6afc8 - 0xc0e84e84 (1128 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rkclk_init_clks: cnt_rate = 32
[ 0.000000] Architected local timer running at 24.00MHz (phys).
[ 0.000000] process version: 0
[ 0.000000] channel:0, lkg:0
[ 0.000000] target-temp:95
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:0
[ 0.525825] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.525878] pid_max: default: 32768 minimum: 301
[ 0.526220] Security Framework initialized
[ 0.526263] SELinux: Initializing.
[ 0.526497] Mount-cache hash table entries: 512
[ 0.528540] Initializing cgroup subsys debug
[ 0.528585] Initializing cgroup subsys freezer
[ 0.528678] CPU: Testing write buffer coherency: ok
[ 0.529441] /cpus/cpu@0 missing clock-frequency property
[ 0.529484] /cpus/cpu@1 missing clock-frequency property
[ 0.529519] /cpus/cpu@2 missing clock-frequency property
[ 0.529549] /cpus/cpu@3 missing clock-frequency property
[ 0.529670] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.529781] Setting up static identity map for 0xc078fcd8 - 0xc078fd30
[ 0.534423] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x14bc (version 3.0)
[ 0.613723] CPU1: Booted secondary processor
[ 0.613814] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.633453] CPU2: Booted secondary processor
[ 0.633536] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.653238] CPU3: Booted secondary processor
[ 0.653320] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.653694] Brought up 4 CPUs
[ 0.653792] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.653823] CPU: All CPU(s) started in SVC mode.
[ 0.656058] devtmpfs: initialized
[ 0.673789] pinctrl core: initialized pinctrl subsystem
[ 0.674522] regulator-dummy: no parameters
[ 0.676156] NET: Registered protocol family 16
[ 0.681385] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.682261] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0e604d4 (version 0.1)
[ 0.682770] Registered FIQ tty driver
[ 0.683710] fiq-debugger is disabled in device tree
[ 0.685481] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.685555] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.685617] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.685675] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.685925] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.686140] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.686352] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.686557] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.686777] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.686992] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.687203] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.687414] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.687639] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.687855] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.687902] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.687943] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.687984] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.689709] rockchip_interrupts_register:bank_num=7
[ 0.696509] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.696583] of_get_gpio_init_config:gpio[1] = 233, value = 0
[ 0.696655] of_get_gpio_init_config:gpio[2] = 136, value = 0
[ 0.696854] rockchip_pinctrl_probe:init ok
[ 0.717055] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.717397] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.717441] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.717981] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.718294] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.718336] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.718885] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.719208] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.719250] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.719790] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.720098] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.720141] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.720720] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.721090] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.721133] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.721734] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.722049] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.722092] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.722674] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.723046] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.723088] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.728640] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.728682] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.729276] DDR DEBUG: version 1.00 20140603
[ 0.729349] DDR DEBUG: Channel a:
[ 0.729379] DDR DEBUG: DDR3 Device
[ 0.729422] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.729451] DDR DEBUG: Channel b:
[ 0.729476] DDR DEBUG: DDR3 Device
[ 0.729516] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.729547] DDR DEBUG: addr=0xd70000
[ 0.729579] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.729610] DDR DEBUG: socAddr[0]=0xd70000, socAddr[1]=0xd70100
[ 0.729641] DDR DEBUG: chAddr[0]=0xd70000, chAddr[1]=0xd70000
[ 0.729675] DDR DEBUG: dtar[0]=0x1ae000, dtar[1]=0x1ae000
[ 0.729823] DDR DEBUG: init success!!! freq=200MHz
[ 0.729850] DDR DEBUG: Channel a:
[ 0.729892] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.729936] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.729978] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.730021] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.730058] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.730091] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.730120] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.730145] DDR DEBUG: Channel b:
[ 0.730185] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.730228] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.730270] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.730312] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.730349] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.730380] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.730409] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.805757] bio: create slab <bio-0> at 0
[ 0.807538] Enter firefly_noatx8_init
[ 0.808023] firefly_noatx8_probe 51
[ 0.808779] SCSI subsystem initialized
[ 0.809257] usbcore: registered new interface driver usbfs
[ 0.809410] usbcore: registered new interface driver hub
[ 0.809682] usbcore: registered new device driver usb
[ 0.812729] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.816958] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.818399] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.819811] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.820702] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.823446] media: Linux media interface: v0.10
[ 0.823589] Linux video capture interface: v2.00
[ 0.823747] pps_core: LinuxPPS API ver. 1 registered
[ 0.823782] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.823848] PTP clock support registered
[ 0.824264] rockchip_temp_probe,line=362
[ 0.824993] tsadc ff280000.tsadc: initialized
[ 0.826204] rockchip_ion_parse_dt: num_heaps = 1
[ 0.826255] 0: 0 3 vmalloc 0x (null)
[ 0.826996] Rockchip ion module is successfully loaded (v1.0)
[ 0.827515] Advanced Linux Sound Architecture Driver Initialized.
[ 0.828678] Bluetooth: Core ver 2.16
[ 0.828800] NET: Registered protocol family 31
[ 0.828834] Bluetooth: HCI device and connection manager initialized
[ 0.828884] Bluetooth: HCI socket layer initialized
[ 0.828927] Bluetooth: L2CAP socket layer initialized
[ 0.829012] Bluetooth: SCO socket layer initialized
[ 0.829680] cfg80211: Calling CRDA to update world regulatory domain
[ 0.831943] act8846_i2c_probe,line=898
[ 0.833348] act8846_parse_dt,line=746
[ 0.834863] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.834924] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.834972] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.835021] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.837510] act_dcdc1: 1200 mV
[ 0.841223] vccio: 3300 mV
[ 0.843852] vdd_logic: 700 <--> 1500 mV at 1100 mV
[ 0.847515] act_dcdc4: 2000 mV
[ 0.849406] vccio_sd: 1800 <--> 3300 mV at 3300 mV
[ 0.852354] act_ldo2: 1050 mV
[ 0.855227] act_ldo3: 2800 mV
[ 0.858108] act_ldo4: 3300 mV
[ 0.861003] act_ldo5: 3300 mV
[ 0.863889] act_ldo6: 1100 mV
[ 0.866801] vcc_18: 1800 mV
[ 0.869697] act_ldo8: 1850 mV
[ 0.876193] vdd_arm: 712 <--> 1500 mV at 1000 mV
[ 0.877675] The device is not syr82x fffffff5
[ 0.877740] syr82x: probe of 0-0041 failed with error -11
[ 0.878161] rk808_i2c_probe,line=1368
[ 0.879849] The device is not rk808 -11
[ 0.880112] rk808: probe of 0-001b failed with error -11
[ 0.884423] Switching to clocksource arch_sys_counter
[ 0.914891] usb_battery_charger_detect_synop , battery_charger_detect 1, pass DCD, dcd_state = 1
[ 0.952090] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.952146] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.953215] rk-screen rk_screen.8: rockchip screen probe success
[ 0.954056] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.954730] rk32-edp ff970000.edp: screen is not edp!
[ 0.954793] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.955918] rk3288-lcdc lcdc0: can't find power_ctr node for lcdc0
[ 0.956663] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.957725] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.958344] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.958887] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.959406] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.961064] rk_iommu ff930300.vopb_mmu: (vopb) Enabled
[ 0.961488] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 0.961551] rk3288-lcdc lcdc0: wakeup from standby!
[ 1.066842] alloc_buffer:ion_phy_addr=0x10000000
[ 1.110193] fb0:phy:10000000>>vir:f0191000>>len:0x1800000
[ 1.233611] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 1.234744] rockchip_set_mux:warning ignore bank num 15
[ 1.235146] rockchip_set_mux:warning ignore bank num 15
[ 1.235549] rockchip_set_mux:warning ignore bank num 15
[ 1.235941] rockchip_set_mux:warning ignore bank num 15
[ 1.236299] rockchip_set_mux:warning ignore bank num 15
[ 1.236688] rockchip_set_mux:warning ignore bank num 15
[ 1.237598] rockchip_set_mux:warning ignore bank num 15
[ 1.238087] rockchip_set_mux:warning ignore bank num 15
[ 1.238933] rockchip_set_mux:warning ignore bank num 15
[ 1.239433] rockchip_set_mux:warning ignore bank num 15
[ 1.240261] rockchip_set_mux:warning ignore bank num 15
[ 1.240749] rockchip_set_mux:warning ignore bank num 15
[ 1.241568] rockchip_set_mux:warning ignore bank num 15
[ 1.242071] rockchip_set_mux:warning ignore bank num 15
[ 1.246445] NET: Registered protocol family 2
[ 1.247885] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.248361] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.248937] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.249092] TCP: reno registered
[ 1.249142] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.249264] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.249921] NET: Registered protocol family 1
[ 1.250541] Unpacking initramfs...
[ 1.473063] Freeing initrd memory: 1156K (c4bf0000 - c4d11000)
[ 1.474855] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.476370] probe device ff9a0000.vpu_service
[ 1.476791] vpu_service: power on
[ 1.477938] checking hw id 4831
[ 1.478958] vpu_service set to auto frequency mode
[ 1.479160] vcodec vpu_service: vcodec ion client create success!
[ 1.480255] vpu_service: power off...
[ 1.480340] done
[ 1.480366] init success
[ 1.480538] probe device ff9c0000.hevc_service
[ 1.481130] hevc_service: power on
[ 1.482246] checking hw id 6867
[ 1.483082] vcodec hevc_service: vcodec ion client create success!
[ 1.483951] hevc_service: power off...
[ 1.484038] done
[ 1.484064] init success
[ 1.484406] rknandbase v1.0 2014-03-31
[ 1.485112] rknand_probe clk rate = 148500000
[ 1.485490] rknand_driver:ret = 0
[ 1.486574] audit: initializing netlink socket (disabled)
[ 1.486679] type=2000 audit(0.970:1): initialized
[ 1.488944] bounce pool size: 64 pages
[ 1.504635] fuse init (API version 7.22)
[ 1.505901] msgmni has been set to 1456
[ 1.512073] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.512120] io scheduler noop registered
[ 1.512153] io scheduler deadline registered
[ 1.512470] io scheduler cfq registered (default)
[ 1.514839] rga ff920000.rga: rga ion client create success!
[ 1.515230] rga: Driver loaded succesfully
[ 1.516661] IEP Power ON
[ 1.516771] iep ion client create success!
[ 1.517751] rk_iommu ff900800.iep_mmu: (iep) Enabled
[ 1.517831] IEP Power OFF
[ 1.517873] rk_iommu ff900800.iep_mmu: (iep) Disabled
[ 1.517916] rk_iommu ff900800.iep_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e235000
[ 1.517961] IEP Driver loaded succesfully
[ 1.518264] Module initialized.
[ 1.520702] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.520760] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.525151] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.525211] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.525954] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 1.526003] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 1.526033] pwm_regulator_probe:error
[ 1.526100] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 1.527189] rk_serial.c v1.8 2014-03-04
[ 1.527886] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.528513] serial ff180000.serial: membase f0172000
[ 1.528946] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 1.528998] 2, baud is:115200
[ 3.211726] console [ttyS2] enabled
[ 3.215753] serial ff690000.serial: membase fed60000
[ 3.230512] loop: module loaded
[ 3.235417] SCSI Media Changer driver v0.25
[ 3.240666] tun: Universal TUN/TAP device driver, 1.6
[ 3.245664] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.253410] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 3.260177] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 3.267177] stmmac_probe_config_dt: clock input or output? (input).
[ 3.273368] stmmac_probe_config_dt: TX delay(0x30).
[ 3.278223] stmmac_probe_config_dt: RX delay(0x20).
[ 3.283129] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 3.288490] stmmc_pltfr_init:
[ 3.291700] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 3.297278] stmmc_pltfr_init: ERROR: Request gmac phy reset pin failed.
[ 3.303801] stmmc_pltfr_init: init for RGMII
[ 3.308061] tx delay=0x30
[ 3.308061] rx delay=0x20
[ 3.314634] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 3.319673] Normal descriptors
[ 3.322785] Ring mode enabled
[ 3.325869] DMA HW capability register supported
[ 3.330351] RX Checksum Offload Engine supported (type 2)
[ 3.335984] TX Checksum insertion supported
[ 3.340204] Wake-Up On Lan supported
[ 3.343912] Enable RX Mitigation via HW Watchdog Timer
[ 3.350340] PPP generic driver version 2.4.2
[ 3.355117] PPP BSD Compression module registered
[ 3.359774] PPP Deflate Compression module registered
[ 3.364837] PPP MPPE Compression module registered
[ 3.369578] NET: Registered protocol family 24
[ 3.374030] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 3.383583] CSLIP: code copyright 1989 Regents of the University of California.
[ 3.390830] Rockchip WiFi SYS interface (V1.00) ...
[ 3.395968] usbcore: registered new interface driver catc
[ 3.401408] usbcore: registered new interface driver kaweth
[ 3.406961] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 3.414388] usbcore: registered new interface driver pegasus
[ 3.420065] usbcore: registered new interface driver rtl8150
[ 3.425787] usbcore: registered new interface driver r8152
[ 3.431207] hso: drivers/net/usb/hso.c: Option Wireless
[ 3.436584] usbcore: registered new interface driver hso
[ 3.441942] usbcore: registered new interface driver asix
[ 3.447426] usbcore: registered new interface driver ax88179_178a
[ 3.453577] usbcore: registered new interface driver cdc_ether
[ 3.459427] usbcore: registered new interface driver cdc_eem
[ 3.465147] usbcore: registered new interface driver dm9601
[ 3.470736] usbcore: registered new interface driver dm9620
[ 3.476403] usbcore: registered new interface driver smsc75xx
[ 3.482211] usbcore: registered new interface driver smsc95xx
[ 3.488029] usbcore: registered new interface driver gl620a
[ 3.493763] usbcore: registered new interface driver net1080
[ 3.499447] usbcore: registered new interface driver plusb
[ 3.505013] usbcore: registered new interface driver rndis_host
[ 3.510947] usbcore: registered new interface driver cdc_subset
[ 3.516925] usbcore: registered new interface driver zaurus
[ 3.522568] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 3.530016] usbcore: registered new interface driver int51x1
[ 3.535751] usbcore: registered new interface driver kalmia
[ 3.541393] usbcore: registered new interface driver ipheth
[ 3.547007] usbcore: registered new interface driver sierra_net
[ 3.552988] usbcore: registered new interface driver cx82310_eth
[ 3.559039] usbcore: registered new interface driver cdc_ncm
[ 3.564807] usbcore: registered new interface driver qmi_wwan
[ 3.570579] usbcore: registered new interface driver cdc_mbim
[ 3.576298] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.585978] ehci_rk_probe f1a00000 f1a00010
[ 3.590137] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
[ 3.597712] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 3.606976] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 3.630007] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
[ 3.636724] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.643488] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.650658] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
[ 3.656937] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 3.662307] usb usb1: SerialNumber: ff500000.usb
[ 3.668173] hub 1-0:1.0: USB hub found
[ 3.672001] hub 1-0:1.0: 1 port detected
[ 3.698872] ehci_rk_probe ok
[ 3.702125] usbcore: registered new interface driver cdc_acm
[ 3.707719] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.715803] usbcore: registered new interface driver usblp
[ 3.721375] usbcore: registered new interface driver cdc_wdm
[ 3.727132] usbcore: registered new interface driver usb-storage
[ 3.733218] usbcore: registered new interface driver ums-alauda
[ 3.739217] usbcore: registered new interface driver ums-cypress
[ 3.745240] usbcore: registered new interface driver ums-datafab
[ 3.751307] usbcore: registered new interface driver ums_eneub6250
[ 3.757498] usbcore: registered new interface driver ums-freecom
[ 3.763565] usbcore: registered new interface driver ums-isd200
[ 3.769680] usbcore: registered new interface driver ums-jumpshot
[ 3.775791] usbcore: registered new interface driver ums-karma
[ 3.781698] usbcore: registered new interface driver ums-onetouch
[ 3.787854] usbcore: registered new interface driver ums-sddr09
[ 3.793788] usbcore: registered new interface driver ums-sddr55
[ 3.799781] usbcore: registered new interface driver ums-usbat
[ 3.805788] usbcore: registered new interface driver usbserial
[ 3.811701] usbcore: registered new interface driver usbserial_generic
[ 3.818260] usbserial: USB Serial support registered for generic
[ 3.824289] usbcore: registered new interface driver option
[ 3.829910] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.837043] usbcore: registered new interface driver trancevibrator
[ 3.843234] usb20_otg: version 3.10a 21-DEC-2012
[ 3.848893] f1a80040
[ 3.851080] Core Release: 3.10a
[ 3.854195] Setting default values for core params
[ 3.859361] Using Buffer DMA mode
[ 3.862652] Periodic Transfer Interrupt Enhancement - disabled
[ 3.868456] Multiprocessor Interrupt Enhancement - disabled
[ 3.873961] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.878301] ^^^^^^^^^^^^^^^^^Device Mode
[ 3.882194] Dedicated Tx FIFOs mode
[ 3.885669] pcd_init otg_dev = ed979040
[ 3.889944] usb20_otg ff580000.usb: DWC OTG Controller
[ 3.895076] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 3.902568] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 3.908423] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.915141] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.922313] usb usb2: Product: DWC OTG Controller
[ 3.927007] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.932603] usb usb2: SerialNumber: ff580000.usb
[ 3.938497] hub 2-0:1.0: USB hub found
[ 3.942260] hub 2-0:1.0: 1 port detected
[ 3.947091] usb20_host: version 3.10a 21-DEC-2012
[ 3.955124] f1b00040
[ 3.957310] Core Release: 3.10a
[ 3.960426] Setting default values for core params
[ 3.965580] Using Buffer DMA mode
[ 3.968873] Periodic Transfer Interrupt Enhancement - disabled
[ 3.974677] Multiprocessor Interrupt Enhancement - disabled
[ 3.980183] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.984521] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.988361] usb20_host ff540000.usb: DWC OTG Controller
[ 3.993572] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 4.001131] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 4.007052] Init: Power Port (0)
[ 4.010417] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.017181] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.024352] usb usb3: Product: DWC OTG Controller
[ 4.029012] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 4.034640] usb usb3: SerialNumber: ff540000.usb
[ 4.040502] hub 3-0:1.0: USB hub found
[ 4.044431] hub 3-0:1.0: 1 port detected
[ 4.049931] .. rk pwm remotectl v1.0 init
[ 4.054170] remotectl probe j=0x0
[ 4.057947] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 4.064968] pwm enable val=0x646205
[ 4.069317] usbcore: registered new interface driver xpad
[ 4.074837] usbcore: registered new interface driver usb_acecad
[ 4.080793] usbcore: registered new interface driver aiptek
[ 4.086457] usbcore: registered new interface driver gtco
[ 4.091899] usbcore: registered new interface driver hanwang
[ 4.097665] usbcore: registered new interface driver kbtab
[ 4.103265] usbcore: registered new interface driver wacom
[ 4.109695] sensor_register_slave:mma8452,id=17
[ 4.114236] sensor_register_slave:cm3217,id=44
[ 4.118633] sensor_register_slave:cm3218,id=45
[ 4.123058] tchip_rm_init is here!
[ 4.127907] input: tchip_remote_key as /devices/virtual/input/input1
[ 4.134566] tchiprm_register_device is here!
[ 4.139192] input: tchip_remote_touch as /devices/virtual/input/input2
[ 4.146169] tchip_remote_abs_register_device is here!
[ 4.151601] input: tchip_remote_gsensor as /devices/virtual/input/input3
[ 4.158553] tchip_remote_gsensor_register_device is here!
[ 4.171030] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 4.177624] i2c /dev entries driver
[ 4.183432] IR NEC protocol handler initialized
[ 4.187920] IR RC5(x) protocol handler initialized
[ 4.192700] IR RC6 protocol handler initialized
[ 4.197180] IR JVC protocol handler initialized
[ 4.201693] IR Sony protocol handler initialized
[ 4.206257] IR RC5 (streamzap) protocol handler initialized
[ 4.211786] IR SANYO protocol handler initialized
[ 4.216436] IR MCE Keyboard/mouse protocol handler initialized
[ 4.222446] usbcore: registered new interface driver uvcvideo
[ 4.228122] USB Video Class driver (1.1.1)
[ 4.232221] CamSys driver version: v0.19.0, CamSys head file version: v0.8.0
[ 4.242516] D1:camsys_platform_probe(1061): 1-gpios-cifpower: gpio=236
[ 4.248999] D1:camsys_platform_probe(1064): gpios-cifpower: gpio_request
[ 4.255692] D1:camsys_platform_probe(1066): 1-gpios-cifpower: gpio_request=0
[ 4.262705] D1:camsys_platform_probe(1075): gpios-cifpower: 236 high
[ 4.269165] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 4.280347] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf19b0000 size: 0x4000)
[ 4.294636] D1:camsys_platform_probe(1208): ff910000.isp memory:
[ 4.300635] D1:camsys_platform_probe(1218): Register memory (phy: 0xff910000 vir: 0xf19e0000 size: 0x10000)
[ 4.310622] D1:camsys_platform_probe(1213): I2c memory (phy: 0x2d9e4000 vir: 0xed9e4000 size: 0x1000)
[ 4.320085] D1:camsys_platform_probe(1233): Probe ff910000.isp device success
[ 4.330186] device-mapper: uevent: version 1.0.3
[ 4.335475] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 4.344789] Bluetooth: HCI UART driver ver 2.2
[ 4.349276] Bluetooth: HCI H4 protocol initialized
[ 4.354016] Bluetooth: HCILL protocol initialized
[ 4.359688] DVFS ERR: clk_enable_dvfs: vd(vd_gpu) can't get regulator(vdd_gpu)!
[ 4.369681] cpufreq version 1.0, suspend freq 1200 MHz
[ 4.375331] cpuidle: using governor ladder
[ 4.379451] cpuidle: using governor menu
[ 4.383422] Synopsys Designware Multimedia Card Interface Driver
[ 4.390284] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 4.397264] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 4.404332] 3291..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 4.410787] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.416707] 1381..dw_mci_set_ios: no card. [mmc0]
[ 4.436818] 1381..dw_mci_set_ios: no card. [mmc0]
[ 4.456554] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 4.456569] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 4.456583] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 4.456913] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 4.487414] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 4.494483] 3285..dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 4.500838] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.507173] 1381..dw_mci_set_ios: no card. [mmc1]
[ 4.522751] mmc0: BKOPS_EN bit is not set
[ 4.526760] 1381..dw_mci_set_ios: no card. [mmc1]
[ 4.528689] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 4.531018] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 4.531041] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 4.546108] rk_sdmmc: BOOT
[ 4.546108] execute tuning: candidates_degree = SDMMC_SHIFT_DEGREE_0 SDMMC_SHIFT_DEGREE_90 SDMMC_SHIFT_DEGREE_180 SDMMC_SHIFT_DEGREE_INVALID[mmc0]
[ 4.546225] mmc0: new HS200 MMC card at address 0001
[ 4.546691] mmcblk0: mmc0:0001 AWMB3R 14.5 GiB
[ 4.547165] mtd: partition size too small (7)
[ 4.547182] uboot: 0x000400000 -- 0x000800000 (4 MB)
[ 4.547193] misc: 0x000800000 -- 0x000c00000 (4 MB)
[ 4.547203] resource: 0x000c00000 -- 0x001c00000 (16 MB)
[ 4.547213] kernel: 0x001c00000 -- 0x002c00000 (16 MB)
[ 4.547223] boot: 0x002c00000 -- 0x004c00000 (32 MB)
[ 4.547232] recovery: 0x004c00000 -- 0x006c00000 (32 MB)
[ 4.547241] backup: 0x006c00000 -- 0x00a000000 (52 MB)
[ 4.547250] cache: 0x00a000000 -- 0x012000000 (128 MB)
[ 4.547260] kpanic: 0x012000000 -- 0x012400000 (4 MB)
[ 4.547269] system: 0x012400000 -- 0x042400000 (768 MB)
[ 4.547279] metadata: 0x042400000 -- 0x042800000 (4 MB)
[ 4.547288] userdata: 0x042800000 -- 0x082800000 (1024 MB)
[ 4.547297] radical_update: 0x082800000 -- 0x086800000 (64 MB)
[ 4.547307] user: 0x086800000 -- 0x3a3a00000 (12754 MB)
[ 4.673016] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141381..dw_mci_set_ios: no card. [mmc1]
[ 4.673149] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 4.673159] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 4.673538] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 4.704294] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 4.711259] 3291..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 4.717599] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.723423] 1381..dw_mci_set_ios: no card. [mmc2]
[ 4.741835] 1381..dw_mci_set_ios: no card. [mmc2]
[ 4.761536] 1381..dw_mci_set_ios: no card. [mmc2]
[ 4.761703] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 4.761710] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 4.761957] leds-gpio leds.30: pins are not configured from the driver
[ 4.762156] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.763445] usbcore: registered new interface driver usbhid
[ 4.763449] usbhid: USB HID core driver
[ 4.763757] ashmem: initialized
[ 4.763874] logger: created 256K log 'log_main'
[ 4.763964] logger: created 256K log 'log_events'
[ 4.764055] logger: created 256K log 'log_radio'
[ 4.764151] logger: created 256K log 'log_system'
[ 4.765110] input: rk29-keypad as /devices/ff100000.adc/key.33/input/input4
[ 4.765686] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ; cannot claim for 2-0010
[ 4.765696] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 4.765703] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 4.765710] ES8323 2-0010: Error applying setting, reverse things back
[ 4.765989] es8323 probe i2c recv ok
[ 4.766204] i2c-core: driver [ES8323] using legacy suspend method
[ 4.766209] i2c-core: driver [ES8323] using legacy resume method
[ 4.766510] rockchip-hdmi-spdif rockchip-hdmi-spdif.26: ASoC: CPU DAI (null) not registered
[ 4.766533] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 4.766547] platform rockchip-hdmi-spdif.26: Driver rockchip-hdmi-spdif requests probe deferral
[ 4.766783] es8323_probe
[ 4.766867] es8323_probe:register ISR (irq=194)
[ 5.402433] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> NULL --> Left Line Mux
[ 5.410231] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> NULL -> Left Line Mux
[ 5.418126] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> NULL --> Left Line Mux
[ 5.426046] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> NULL -> Left Line Mux
[ 5.433926] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> NULL --> Left Line Mux
[ 5.442285] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> NULL -> Left Line Mux
[ 5.450833] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> NULL --> Right Line Mux
[ 5.458717] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> NULL -> Right Line Mux
[ 5.466766] iep dpi mode inactivity
[ 5.470438] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> NULL --> Right Line Mux
[ 5.478353] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> NULL -> Right Line Mux
[ 5.486358] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> NULL --> Right Line Mux
[ 5.494931] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> NULL -> Right Line Mux
[ 5.503482] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left PGA Mux
[ 5.511284] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left PGA Mux
[ 5.519007] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left PGA Mux
[ 5.526856] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left PGA Mux
[ 5.534646] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> LAMP --> Left PGA Mux
[ 5.543254] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> LAMP -> Left PGA Mux
[ 5.552039] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right PGA Mux
[ 5.559953] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right PGA Mux
[ 5.567800] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right PGA Mux
[ 5.575638] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right PGA Mux
[ 5.583551] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> RAMP --> Right PGA Mux
[ 5.592173] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> RAMP -> Right PGA Mux
[ 5.600886] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Differential Mux
[ 5.608996] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Differential Mux
[ 5.617092] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Differential Mux
[ 5.625257] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Differential Mux
[ 5.633415] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Differential Mux
[ 5.641550] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Differential Mux
[ 5.649894] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Differential Mux
[ 5.658137] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Differential Mux
[ 5.666169] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left Line Mux
[ 5.673886] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left Line Mux
[ 5.681623] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left Line Mux
[ 5.689343] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left Line Mux
[ 5.697087] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> LAMP --> Left Line Mux
[ 5.705221] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> LAMP -> Left Line Mux
[ 5.713379] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right Line Mux
[ 5.721200] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right Line Mux
[ 5.729017] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right Line Mux
[ 5.736831] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right Line Mux
[ 5.744636] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> RAMP --> Right Line Mux
[ 5.752973] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> RAMP -> Right Line Mux
[ 5.761543] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 5.767473] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 5.773304] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 5.779152] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 5.784926] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 5.794064] Enter::rk29_es8323_init----135
[ 5.802503] rockchip-es8323 rockchip-es8323.28: ES8323 HiFi <-> rockchip-i2s.0 mapping ok
[ 5.811341] u32 classifier
[ 5.814004] Actions configured
[ 5.817373] Netfilter messages via NETLINK v0.30.
[ 5.822052] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.828429] ctnetlink v0.93: registering with nfnetlink.
[ 5.833710] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 5.840575] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 5.846612] xt_time: kernel timezone is -0000
[ 5.851118] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.856544] arp_tables: (C) 2002 David S. Miller
[ 5.861120] TCP: cubic registered
[ 5.864393] Initializing XFRM netlink socket
[ 5.868847] NET: Registered protocol family 10
[ 5.873855] mip6: Mobile IPv6
[ 5.876797] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.882233] sit: IPv6 over IPv4 tunneling driver
[ 5.887166] NET: Registered protocol family 17
[ 5.891556] NET: Registered protocol family 15
[ 5.896021] Bridge firewalling registered
[ 5.899978] Ebtables v2.0 registered
[ 5.903672] Bluetooth: RFCOMM TTY layer initialized
[ 5.908498] Bluetooth: RFCOMM socket layer initialized
[ 5.913583] Bluetooth: RFCOMM ver 1.11
[ 5.917273] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.922498] Bluetooth: BNEP filters: protocol multicast
[ 5.927650] Bluetooth: BNEP socket layer initialized
[ 5.932553] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.938384] Bluetooth: HIDP socket layer initialized
[ 5.943301] l2tp_core: L2TP core driver, V2.0
[ 5.947595] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 5.952350] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 5.957228] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 5.961950] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 5.967531] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 5.974567] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 5.982952] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 5.990243] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 5.999252] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 6.008319] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 6.013493] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 6.021813] dwc_otg_hcd_enable, enable host controller
[ 6.030937] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 6.035615] [BT_RFKILL]: Enter rfkill_rk_init
[ 6.040049] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 6.048111] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 6.056084] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 6.064049] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 6.071933] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 6.080189] [BT_RFKILL]: Request irq for bt wakeup host
[ 6.085425] [BT_RFKILL]: ** disable irq
[ 6.089280] [BT_RFKILL]: ap6335 device registered.
[ 6.130219] Using Buffer DMA mode
[ 6.133478] Periodic Transfer Interrupt Enhancement - disabled
[ 6.139213] Multiprocessor Interrupt Enhancement - disabled
[ 6.144687] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 6.148975] ^^^^^^^^^^^^^^^^^^Host Mode
[ 6.198372] Init: Power Port (0)
[ 6.385397] Indeed it is in host mode hprt0 = 00021501
[ 6.562465] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 6.569529] Indeed it is in host mode hprt0 = 00001101
[ 6.719729] ******** Show Sink Info ********
[ 6.723946] Max tmds clk is 0
[ 6.726909] Support video mode:
[ 6.730133] 1920x1080p@60Hz
[ 6.733011] 1920x1080p@50Hz
[ 6.735884] 1280x720p@60Hz
[ 6.738670] 1280x720p@50Hz
[ 6.741576] 720x576p@50Hz
[ 6.744275] 720x480p@60Hz
[ 6.746938] Support video color mode:
[ 6.750553] RGB
[ 6.752364] YCbCr422
[ 6.754600] YCbCr444
[ 6.756836] Support video color depth:
[ 6.760545] 24bit
[ 6.762527] Support audio type:
[ 6.765617] LPCM
[ 6.767513] Support max audio channel is 2
[ 6.769296] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 6.769311] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 6.769323] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 6.769944] hub 3-1:1.0: USB hub found
[ 6.770017] hub 3-1:1.0: 4 ports detected
[ 6.797224] Support audio sample rate:
[ 6.800922] 32000
[ 6.802901] 44100
[ 6.804879] 48000
[ 6.806858] Support audio word lenght:
[ 6.810557] 16bit
[ 6.812536] 20bit
[ 6.814514] 24bit
[ 6.816492]
[ 6.817958] ******** Show Sink Info ********
[ 6.822179]
[ 6.822179] rk_fb_switch_screen lcdc_id 0 type 6 enable 1
[ 6.828966] fb0 win id 1 state 1
[ 6.832155] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 6.837823] fb1 win id 0 state 0
[ 6.840996] fb2 win id 2 state 0
[ 6.844168] fb3 win id 3 state 0
[ 6.847339] fb4 win id 4 state 0
[ 6.850522]
[ 6.850522] rk_fb_switch_screen lcdc_id 0 type 6 enable 1 done
[ 6.850522]
[ 6.859170] pixel clk is 148500000 tmds clk is 148500000
[ 6.864426] rk3288-hdmi ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
[ 6.881082] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
[ 6.887419] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 6.895176] rk3288_init_suspend
[ 6.898305] rk3288_suspend_init enter
[ 6.902097] rk3288_suspend_init: pm_ctrbits =40017
[ 6.906879] gpio_get_dts_info suspend:8
[ 6.910664] gpio_get_dts_info resume:8
[ 6.914347] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.922920] rockchip,pmic-resume_gpios:2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.931509] clks_gating_suspend_init:clkgt info ok
[ 6.936343] Registering SWP/SWPB emulation handler
[ 6.941516] ddrfreq: verion 1.2 20140526
[ 6.945543] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 6.956240] ddrfreq: auto-freq=0
[ 6.959414] ddrfreq: auto-freq-table[0] 240MHz
[ 6.963780] ddrfreq: auto-freq-table[1] 324MHz
[ 6.968157] ddrfreq: auto-freq-table[2] 456MHz
[ 6.972523] ddrfreq: auto-freq-table[3] 528MHz
[ 6.977487] act_ldo3: operation not allowed
[ 6.981844] vga_edid_probe: turn on ldo3 done.
[ 6.986267] act_ldo4: operation not allowed
[ 6.990634] vga_edid_probe: turn on ldo done.
[ 6.994963] act_ldo2: operation not allowed
[ 6.999372] vga_edid_probe: turn on ldo2 done.
[ 7.003769] act_ldo8: operation not allowed
[ 7.008141] vga_edid_probe: turn on ldo done.
[ 7.017519] unable to read EDID block.
[ 7.055782] unable to read EDID block.
[ 7.094050] unable to read EDID block.
[ 7.097740] vga-ddc: read and parse edid failed errno:-5.
[ 7.103044] vga_edid_probe: success. 10
[ 7.107052] firefly_vga_get_enable 180, 0
[ 7.110993] firefly_vga_get_status 186
[ 7.114695] firefly_vga_set_enable 159 enable:0
[ 7.119204] regulator-dummy: disabling
[ 7.123259] rockchip-hdmi-spdif rockchip-hdmi-spdif.26: ASoC: CPU DAI (null) not registered
[ 7.131502] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 7.138045] platform rockchip-hdmi-spdif.26: Driver rockchip-hdmi-spdif requests probe deferral
[ 7.146755] pcd_pullup, is_on 0
[ 7.149890] file system registered
[ 7.154074] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 7.160832] android_usb gadget: Number of LUNs=2
[ 7.165392] lun0: LUN: removable file: (no medium)
[ 7.170187] lun1: LUN: removable file: (no medium)
[ 7.175167] android_usb gadget: android_usb ready
[ 7.179889] sensor_init: Probe name sensors
[ 7.184035] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 7.192781] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:28:38 UTC (1293884918)
[ 7.209228] usbcore: registered new interface driver snd-usb-audio
[ 7.215382] ALSA device list:
[ 7.218327] #0: RK_ES8323
[ 7.219764] rockchip-hdmi-spdif rockchip-hdmi-spdif.26: rk-hdmi-spdif-hifi <-> rockchip-spdif mapping ok
[ 7.230529] #1: RK-HDMI-SPDIF
[ 7.233769] 2, baud is:115200
[ 7.238186] Freeing unused kernel memory: 2364K (c0a7d000 - c0ccc000)
[ 7.251913] SELinux: Permission attach_queue in class tun_socket not defined in policy.
[ 7.259890] SELinux: the above unknown classes and permissions will be denied
[ 7.506904]
[ 7.506904] rk_fb_switch_screen lcdc_id 0 type 6 enable 0
[ 7.540185] type=1403 audit(1293884918.840:2): policy loaded auid=4294967295 ses=4294967295
[ 7.548541] SELinux: Loaded policy from /sepolicy
[ 7.554963] type=1404 audit(1293884918.850:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 8.461825] init: init.rk30board.bootmode.emmc.rc: 8: invalid command '/devices/ff0f0000.rksdmmc/mmc_host/mmc'
[ 8.472250] init: init.rk30board.bootmode.emmc.rc: 9: invalid command '/devices/ff0c0000.rksdmmc/mmc_host/mmc'
[ 8.482102] init: init.rk30board.bootmode.emmc.rc: 10: invalid command '/devices/ff580000.usb'
[ 8.490565] init: init.rk30board.bootmode.emmc.rc: 11: invalid command '/devices/ff580000.usb'
[ 8.499038] init: init.rk30board.bootmode.emmc.rc: 12: invalid command '/devices/ff500000.usb'
[ 8.507507] init: init.rk30board.bootmode.emmc.rc: 13: invalid command '/devices/ff500000.usb'
[ 8.515986] init: init.rk30board.bootmode.emmc.rc: 14: invalid command '/devices/ff540000.usb'
[ 8.524461] init: init.rk30board.bootmode.emmc.rc: 15: invalid command '/devices/ff540000.usb'
[ 8.533683] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 8.612417] init: /dev/hw_random not found
[ 8.616504] keychord: using input dev ff680000.pwm for fevent
[ 8.622176] keychord: using input dev tchip_remote_key for fevent
[ 8.628161] keychord: using input dev rk29-keypad for fevent
[ 8.633822] 2, baud is:115200
[ 8.642950] fs_mgr: parse_link_device : path = NULL
[ 8.647768] fs_mgr: parse_link_device : path = NULL
[ 8.648341] ******** Show Sink Info ********
[ 8.648346] Max tmds clk is 0
[ 8.648350] Support video mode:
[ 8.648353] 1920x1080p@60Hz
[ 8.648356] 1920x1080p@50Hz
[ 8.648359] 1280x720p@60Hz
[ 8.648362] 1280x720p@50Hz
[ 8.648364] 720x576p@50Hz
[ 8.648366] 720x480p@60Hz
[ 8.648369] Support video color mode:
[ 8.648372] RGB
[ 8.648374] YCbCr422
[ 8.648377] YCbCr444
[ 8.648379] Support video color depth:
[ 8.648381] 24bit
[ 8.648385] Support audio type:
[ 8.648387] LPCM
[ 8.648390] Support max audio channel is 2
[ 8.648393] Support audio sample rate:
[ 8.648395] 32000
[ 8.648397] 44100
[ 8.648399] 48000
[ 8.648402] Support audio word lenght:
[ 8.648405] 16bit
[ 8.648407] 20bit
[ 8.648409] 24bit
[ 8.648411]
[ 8.648414] ******** Show Sink Info ********
[ 8.648449]
[ 8.648449] rk_fb_switch_screen lcdc_id 0 type 6 enable 1
[ 8.648458] fb0 win id 1 state 1
[ 8.648475] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 8.648490] fb1 win id 0 state 0
[ 8.648494] fb2 win id 2 state 0
[ 8.648498] fb3 win id 3 state 0
[ 8.648501] fb4 win id 4 state 0
[ 8.648505]
[ 8.648505] rk_fb_switch_screen lcdc_id 0 type 6 enable 1 done
[ 8.648505]
[ 8.648518] pixel clk is 148500000 tmds clk is 148500000
[ 8.648558] rk3288-hdmi ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
[ 8.778142] fs_mgr: parse_link_device : path = NULL
[ 8.782996] fs_mgr: parse_link_device : path = NULL
[ 8.787852] fs_mgr: parse_link_device : path = NULL
[ 8.792684] fs_mgr: parse_link_device : path = NULL
[ 8.797537] fs_mgr: parse_link_device : path = NULL
[ 8.802653] fs_mgr: parse_link_device : path = NULL
[ 8.807730] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 8.826409] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs:
[ 8.843188] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 8.866268] EXT4-fs (mmcblk0p8): recovery complete
[ 8.871521] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 8.882260] EXT4-fs (mmcblk0p11): warning: mounting unchecked fs, running e2fsck is recommended
[ 8.891422] EXT4-fs (mmcblk0p11): mounted filesystem without journal. Opts: noauto_da_alloc,discard
[ 8.934082] EXT4-fs (mmcblk0p12): recovery complete
[ 8.939420] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 8.957106] drmboot: module license 'unspecified' taints kernel.
[ 8.963012] Disabling lock debugging due to kernel taint
[ 8.969092] %s: ok, 20130810
[ 8.977533] mali pd enabled
[ 8.980287] clk enabled
[ 8.982692] MALI_DVFS_STEP=4,div_dvfs=10
[ 8.986582] mali_dvfs_infotbl[0].clock=200000,min_threshold=0,max_threshold=70
[ 8.993689] mali_dvfs_infotbl[1].clock=300000,min_threshold=70,max_threshold=80
[ 9.000870] mali_dvfs_infotbl[2].clock=420000,min_threshold=81,max_threshold=90
[ 9.008065] mali_dvfs_infotbl[3].clock=500000,min_threshold=93,max_threshold=100
[ 9.015449] turn on mali power
[ 9.018466] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 9.025268] mali ffa30000.gpu: Probed as mali0
[ 9.030836] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 '
[ 9.050213] init: /dev/hw_random not found
[ 9.061054] init: cannot find '/system/vendor/bin/pvrsrvctl', disabling 'pvrsrvctl'
[ 9.061138] binder: 132:132 transaction failed 29189, size 0-0
[ 9.077159] init: cannot find '/system/bin/rild3', disabling 'ril-daemon3'
[ 9.085747] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 9.095072] init: cannot find '/system/bin/bindvbplayservice', disabling 'dvbdataserv'
[ 9.103269] init: cannot find '/system/bin/chrome.sh', disabling 'chrome'
[ 9.110294] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper'
[ 9.118929] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[ 9.126833] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
[ 9.136607] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
[ 9.147932] 0,baud is:9600
[ 9.150923] 2, baud is:115200
[ 9.153989] 2, baud is:115200
[ 9.155867] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 9.163769] 0,baud is:9600
[ 9.163963] firefly_vga_get_enable 180, 0
[ 9.164008] firefly_vga_get_status 186
[ 9.174510] firefly_vga_set_enable 159 enable:0
[ 9.221208] fs_mgr: parse_link_device : path = NULL
[ 9.226044] fs_mgr: parse_link_device : path = NULL
[ 9.230943] fs_mgr: parse_link_device : path = NULL
[ 9.235771] fs_mgr: parse_link_device : path = NULL
[ 9.240637] fs_mgr: parse_link_device : path = NULL
[ 9.245453] fs_mgr: parse_link_device : path = NULL
[ 9.250340] fs_mgr: parse_link_device : path = NULL
[ 9.255167] fs_mgr: parse_link_device : path = NULL
[ 9.262320] init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
[ 9.270656] init: powerctl: cannot expand '${sys.powerctl}'
[ 9.276257] init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
[ 9.287300] init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
[ 9.298549] android_usb: already disabled
[ 9.303403] 2, baud is:115200
[ 9.305179] read descriptors
[ 9.305188] read strings
[ 9.305220] pcd_pullup, is_on 1
[ 9.343252] wifi_driver_write: wifi driver already rmmod
shell@rk3288:/ $ [ 10.070231] rk3288-lcdc lcdc0: blank mode:0
[ 10.185875] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_hal.ver
[ 10.193740] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_trace
[ 10.201296] init: sys_prop: permission denied uid:1003 name:sys.gmali.version
[ 10.208525] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_camboard.ver
[ 10.216874] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_libisp.ver
[ 10.225151] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_isi.ver
[ 10.238711] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 10.246119] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 10.253494] D1:camsys_open(710): camsys_marvin(ed87bd10) is opened!
[ 10.259715] D1:camsys_extdev_register(226): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 10.269678] D1:camsys_extdev_register(226): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 10.279617] D1:camsys_extdev_register(226): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 10.289579] rockchip_gpio_request:GPIO7-13
[ 10.293628] rockchip_gpio_set:GPIO7-13 level = 1
[ 10.298170] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 10.304019] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 10.310712] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 10.321603] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 10.328381] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000400,result=0x400
[ 10.335246] _rockchip_pinconf_set:GPIO7-13,group=isp_flash_trigger, function=isp_pin, type=3
[ 10.343563] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10
[ 10.349982] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3
[ 10.356018] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 10.368882] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 10.376854] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 10.381853] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 10.386760] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 10.396048] D1:camsys_sysctl_extdev(326): Sysctl 11 success, gpio(11) set 1
[ 10.403970] D1:camsys_sysctl_extdev(330): Sysctl 8 success, gpio(79) set 1
[ 10.411796] D1:camsys_sysctl_extdev(330): Sysctl 7 success, gpio(78) set 1
[ 10.421791] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 10.429259] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 10.435587] D1:camsys_sysctl_extdev(326): Sysctl 7 success, gpio(78) set 0
[ 10.442414] D1:camsys_sysctl_extdev(326): Sysctl 8 success, gpio(79) set 0
[ 10.449207] D1:camsys_sysctl_extdev(330): Sysctl 11 success, gpio(11) set 0
[ 10.457143] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 10.463782] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 10.472638] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 10.481061] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 10.489327] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.496776] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.504305] D1:camsys_release(734): camsys_marvin(ed87bd10) is closed
[ 10.514747] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 10.522136] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 10.529531] D1:camsys_open(710): camsys_marvin(ed87bd10) is opened!
[ 10.535741] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 10.542713] D1:camsys_extdev_register(248): Extdev(dev_id: 0x1000000) register success
[ 10.555568] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 10.563536] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 10.568529] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 10.573436] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 10.582713] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 10.591064] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 10.599312] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 10.609744] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
[ 10.616059] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 10.623333] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 10.630555] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 10.638957] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 10.645606] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 10.654434] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x1000000) is deregister success
[ 10.662866] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 10.671143] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.678620] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.686087] D1:camsys_release(734): camsys_marvin(ed87bd10) is closed
[ 10.698684] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 10.706067] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 10.713422] D1:camsys_open(710): camsys_marvin(ed87bd10) is opened!
[ 10.719693] rockchip_gpio_set:GPIO7-13 level = 0
[ 10.724250] rockchip_gpio_direction_output:set GPIO7-13 level 0
[ 10.730091] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 10.736787] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 10.747654] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 10.754455] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000400,result=0x400
[ 10.761303] _rockchip_pinconf_set:GPIO7-13,group=isp_flash_trigger, function=isp_pin, type=3
[ 10.769611] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10
[ 10.776064] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3
[ 10.782060] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 10.794918] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 10.802874] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 10.807872] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 10.812784] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 10.822073] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 10.825471] rknand_sys_storage_open
[ 10.825480] RKNAND_GET_DRM_KEY
[ 10.825486] return ret = 0
[ 10.839611] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 10.847867] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 10.858340] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 10.864666] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 10.871919] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 10.879274] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 10.886618] mali ffa30000.gpu: Unhandled Page fault in AS0 at VA 0x0000000100200900
[ 10.886618] raw fault status 0x20001C2
[ 10.886618] decoded fault status: SLAVE FAULT
[ 10.886618] exception type 0xC2: TRANSLATION_FAULT
[ 10.886618] access type 0x1: EXECUTE
[ 10.886618] source id 0x200
[ 10.913093] mali ffa30000.gpu: Issueing GPU soft-reset after hard stopping due to hardware issue
[ 10.921903] mali ffa30000.gpu: Preparing to soft-reset GPU: Waiting (upto 500 ms) for all jobs to complete soft-stop
[ 10.932323] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 10.938949] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 10.947781] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 10.956200] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 10.964428] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.971881] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.979318] D1:camsys_release(734): camsys_marvin(ed87bd10) is closed
[ 11.129071] mali ffa30000.gpu: JS: Job Hard-Stopped (took more than 4 ticks at 50 ms/tick)
[ 11.176051] Enter::rk29_hw_params----52
[ 11.180782] Enter:rk29_hw_params, 86, rate=44100
[ 11.185327] Enter:rk29_hw_params, 104, LRCK=64
[ 11.206959] hjc:hp_det_irq_handler>>>>
[ 11.235612] mali ffa30000.gpu: JS: Job has been on the GPU for too long (KBASE_CONFIG_ATTR_JS_RESET_TICKS_SS/NSS timeout hit). Issueing GPU soft-reset to resolve.
[ 11.305129] hjc:hp_detect_do_switch,irq=194
[ 11.309264] mic_state_switch 0
[ 11.312268] hp_det = 0,insert hp
[ 11.315457] hp mic use intern
[ 11.415103] Enter::rk29_hw_params----52
[ 11.419829] Enter:rk29_hw_params, 86, rate=44100
[ 11.424451] mali ffa30000.gpu: Resetting GPU (allowing up to 500 ms)
[ 11.430723] mali ffa30000.gpu: Register state:
[ 11.435093] mali ffa30000.gpu: GPU_IRQ_RAWSTAT=0x00000200 GPU_STATUS=0x00000009
[ 11.442447] mali ffa30000.gpu: JOB_IRQ_RAWSTAT=0x00000000 JOB_IRQ_JS_STATE=0x00000000 JOB_IRQ_THROTTLE=0x00000000
[ 11.452700] mali ffa30000.gpu: JS0_STATUS=0x00000008 JS0_HEAD_LO=0xb36ae640
[ 11.460138] mali ffa30000.gpu: JS1_STATUS=0x00000000 JS1_HEAD_LO=0xb36ae440
[ 11.467575] mali ffa30000.gpu: JS2_STATUS=0x00000000 JS2_HEAD_LO=0x00000000
[ 11.475012] mali ffa30000.gpu: MMU_IRQ_RAWSTAT=0x00000000 GPU_FAULTSTATUS=0x00000000
[ 11.482791] mali ffa30000.gpu: GPU_IRQ_MASK=0x00010581 JOB_IRQ_MASK=0x00070007 MMU_IRQ_MASK=0x00ff00ff
[ 11.492702] mali ffa30000.gpu: PWR_OVERRIDE0=0x00000000 PWR_OVERRIDE1=0x00000000
[ 11.500310] mali ffa30000.gpu: SHADER_CONFIG=0x00000000 L2_MMU_CONFIG=0x00000000
[ 11.507958] Enter:rk29_hw_params, 104, LRCK=64
[ 11.508019] mali ffa30000.gpu: Job stuck in slot 0 on the GPU was cancelled
[ 11.508026] mali ffa30000.gpu: t6xx: GPU fault 0x4002 from job slot 0
[ 11.508062] mali ffa30000.gpu: Reset complete
[ 11.508141] mali ffa30000.gpu: Replaying jobs retry=0
[ 11.508369] mali ffa30000.gpu: error detected from slot 0, job status 0x00000058 (DATA_INVALID_FAULT)
[ 11.508377] mali ffa30000.gpu: t6xx: GPU fault 0x58 from job slot 0
[ 11.508403] mali ffa30000.gpu: Replaying jobs retry=1
[ 11.508448] mali ffa30000.gpu: kbasep_replay_parse_jc: failed to map jc
[ 11.508590] fence error -14 on [ecb90900]
[ 11.508619] objs:
[ 11.508619] --------------
[ 11.508619] fb-timeline sw_sync: 0
[ 11.508619]
[ 11.508619] malitl_139_0xb8469bf8 Mali: 0
[ 11.508619]
[ 11.508619] malitl_139_0xb846ee50 Mali: 1
[ 11.508619] pt error@11.156787: 1(-14)
[ 11.508619]
[ 11.508619] malitl_446_0xb7e0bc10 Mali: 0
[ 11.508619]
[ 11.508619] malitl_446_0xb7e0bf88 Mali: 0
[ 11.508619]
[ 11.508619] fences:
[ 11.508619] [ecb90900] mali_fence: error
[ 11.508619] malitl_139_0xb846ee50_pt error@11.156787: 1(-14) / 1
[ 11.508619]
[ 11.943748] mali ffa30000.gpu: JS: Job Hard-Stopped (took more than 4 ticks at 50 ms/tick)
[ 11.951881] mali ffa30000.gpu: JS: Job Hard-Stopped (took more than 4 ticks at 50 ms/tick)
[ 12.058420] mali ffa30000.gpu: JS: Job has been on the GPU for too long (KBASE_CONFIG_ATTR_JS_RESET_TICKS_SS/NSS timeout hit). Issueing GPU soft-reset to resolve.
[ 12.072708] mali ffa30000.gpu: Preparing to soft-reset GPU: Waiting (upto 500 ms) for all jobs to complete soft-stop
[ 12.575071] mali ffa30000.gpu: Resetting GPU (allowing up to 500 ms)
[ 12.581332] mali ffa30000.gpu: Register state:
[ 12.585700] mali ffa30000.gpu: GPU_IRQ_RAWSTAT=0x00000200 GPU_STATUS=0x00000009
[ 12.593051] mali ffa30000.gpu: JOB_IRQ_RAWSTAT=0x00000000 JOB_IRQ_JS_STATE=0x00000000 JOB_IRQ_THROTTLE=0x00000000
[ 12.603301] mali ffa30000.gpu: JS0_STATUS=0x00000008 JS0_HEAD_LO=0xb4aec340
[ 12.610729] mali ffa30000.gpu: JS1_STATUS=0x00000008 JS1_HEAD_LO=0xb36ae680
[ 12.618165] mali ffa30000.gpu: JS2_STATUS=0x00000000 JS2_HEAD_LO=0x00000000
[ 12.625600] mali ffa30000.gpu: MMU_IRQ_RAWSTAT=0x00000000 GPU_FAULTSTATUS=0x00000000
[ 12.633378] mali ffa30000.gpu: GPU_IRQ_MASK=0x00010581 JOB_IRQ_MASK=0x00070007 MMU_IRQ_MASK=0x00ff00ff
[ 12.643287] mali ffa30000.gpu: PWR_OVERRIDE0=0x00000000 PWR_OVERRIDE1=0x00000000
[ 12.650894] mali ffa30000.gpu: SHADER_CONFIG=0x00000000 L2_MMU_CONFIG=0x00000000
[ 12.658623] mali ffa30000.gpu: Job stuck in slot 0 on the GPU was cancelled
[ 12.665467] mali ffa30000.gpu: t6xx: GPU fault 0x4002 from job slot 0
[ 12.671799] mali ffa30000.gpu: Job stuck in slot 1 on the GPU was cancelled
[ 12.678637] mali ffa30000.gpu: t6xx: GPU fault 0x4002 from job slot 1
[ 12.685038] mali ffa30000.gpu: Reset complete
[ 12.689572] es8323_mic_state_ctrl read:
[ 12.693535] mic_state_switch 0
[ 12.696564] hp_det = 0,insert hp
[ 12.699757] hp mic use intern
[ 12.702779] mali ffa30000.gpu: Replaying jobs retry=0
[ 12.707914] mali ffa30000.gpu: Replaying jobs retry=0
[ 12.712956] mali ffa30000.gpu: Job already not started
[ 12.718197] fence error -14 on [ec427700]
[ 12.722186] objs:
malitl_139_0xb846ee50 Mali: 2
pt error@12.386062: 2(-14)
malitl_446_0xb7e0bc10 Mali: 1
pt signaled@11.337980: 1(0)
pt active: 2(0)
pt active: 3(0)
fences:
malitl_139_0xb846ee50_pt error@11.156787: 1(-14) / 2
[ec000180] mali_fence: signaled
malitl_446_0xb7e0bc10_pt signaled@11.337980: 1(0) / 1
[ec000080] mali_fence: active
malitl_446_0xb7e0bc10_pt active: 2(0) / 1
[ec427700] mali_fence: error
malitl_139_0xb846ee50_pt error@12.386062: 2(-14) / 2
[ec000c80] mali_fence: active
malitl_446_0xb7e0bc10_pt active: 3(0) / 1
[ 12.953785] mali ffa30000.gpu: JS: Job Hard-Stopped (took more than 4 ticks at 50 ms/tick)
[ 13.011125] mali ffa30000.gpu: JS: Job Hard-Stopped (took more than 4 ticks at 50 ms/tick)
[ 13.068461] mali ffa30000.gpu: JS: Job has been on the GPU for too long (KBASE_CONFIG_ATTR_JS_RESET_TICKS_SS/NSS timeout hit). Issueing GPU soft-reset to resolve.
[ 13.082729] mali ffa30000.gpu: Preparing to soft-reset GPU: Waiting (upto 500 ms) for all jobs to complete soft-stop
[ 13.142276] mali ffa30000.gpu: JS: Job has been on the GPU for too long (KBASE_CONFIG_ATTR_JS_RESET_TICKS_SS/NSS timeout hit). Issueing GPU soft-reset to resolve.
[ 13.585097] mali ffa30000.gpu: Resetting GPU (allowing up to 500 ms)
[ 13.591415] mali ffa30000.gpu: Register state:
[ 13.595784] mali ffa30000.gpu: GPU_IRQ_RAWSTAT=0x00000200 GPU_STATUS=0x00000009
[ 13.603136] mali ffa30000.gpu: JOB_IRQ_RAWSTAT=0x00000000 JOB_IRQ_JS_STATE=0x00000000 JOB_IRQ_THROTTLE=0x00000000
[ 13.613388] mali ffa30000.gpu: JS0_STATUS=0x00000008 JS0_HEAD_LO=0xb4aec340
[ 13.620824] mali ffa30000.gpu: JS1_STATUS=0x00000008 JS1_HEAD_LO=0xb42972c0
[ 13.628260] mali ffa30000.gpu: JS2_STATUS=0x00000000 JS2_HEAD_LO=0x00000000
[ 13.635695] mali ffa30000.gpu: MMU_IRQ_RAWSTAT=0x00000000 GPU_FAULTSTATUS=0x00000000
[ 13.643473] mali ffa30000.gpu: GPU_IRQ_MASK=0x00010581 JOB_IRQ_MASK=0x00070007 MMU_IRQ_MASK=0x00ff00ff
[ 13.653383] mali ffa30000.gpu: PWR_OVERRIDE0=0x00000000 PWR_OVERRIDE1=0x00000000
[ 13.660991] mali ffa30000.gpu: SHADER_CONFIG=0x00000000 L2_MMU_CONFIG=0x00000000
[ 13.668755] mali ffa30000.gpu: Job stuck in slot 0 on the GPU was cancelled
[ 13.675601] mali ffa30000.gpu: t6xx: GPU fault 0x4002 from job slot 0
[ 13.681935] mali ffa30000.gpu: Job stuck in slot 1 on the GPU was cancelled
[ 13.688775] mali ffa30000.gpu: t6xx: GPU fault 0x4002 from job slot 1
[ 13.695230] mali ffa30000.gpu: Reset complete
[ 13.699583] mali ffa30000.gpu: Replaying jobs retry=1
[ 13.704724] mali ffa30000.gpu: Replaying jobs retry=0
[ 13.709797] mali ffa30000.gpu: Job already not started
[ 13.914651] mali ffa30000.gpu: JS: Job Hard-Stopped (took more than 4 ticks at 50 ms/tick)
[ 14.021195] mali ffa30000.gpu: JS: Job has been on the GPU for too long (KBASE_CONFIG_ATTR_JS_RESET_TICKS_SS/NSS timeout hit). Issueing GPU soft-reset to resolve.
[ 14.035479] mali ffa30000.gpu: Preparing to soft-reset GPU: Waiting (upto 500 ms) for all jobs to complete soft-stop
[ 14.537846] mali ffa30000.gpu: Resetting GPU (allowing up to 500 ms)
[ 14.544141] mali ffa30000.gpu: Register state:
[ 14.548512] mali ffa30000.gpu: GPU_IRQ_RAWSTAT=0x00000200 GPU_STATUS=0x00000009
[ 14.555866] mali ffa30000.gpu: JOB_IRQ_RAWSTAT=0x00000000 JOB_IRQ_JS_STATE=0x00000000 JOB_IRQ_THROTTLE=0x00000000
[ 14.566118] mali ffa30000.gpu: JS0_STATUS=0x00000008 JS0_HEAD_LO=0xb4aec340
[ 14.573556] mali ffa30000.gpu: JS1_STATUS=0x00000000 JS1_HEAD_LO=0xb36ae500
[ 14.580993] mali ffa30000.gpu: JS2_STATUS=0x00000000 JS2_HEAD_LO=0x00000000
[ 14.588430] mali ffa30000.gpu: MMU_IRQ_RAWSTAT=0x00000000 GPU_FAULTSTATUS=0x00000000
[ 14.596210] mali ffa30000.gpu: GPU_IRQ_MASK=0x00010581 JOB_IRQ_MASK=0x00070007 MMU_IRQ_MASK=0x00ff00ff
[ 14.606121] mali ffa30000.gpu: PWR_OVERRIDE0=0x00000000 PWR_OVERRIDE1=0x00000000
[ 14.613729] mali ffa30000.gpu: SHADER_CONFIG=0x00000000 L2_MMU_CONFIG=0x00000000
[ 14.621521] mali ffa30000.gpu: Job stuck in slot 0 on the GPU was cancelled
[ 14.628368] mali ffa30000.gpu: t6xx: GPU fault 0x4002 from job slot 0
[ 14.634763] mali ffa30000.gpu: Reset complete
[ 14.639158] mali ffa30000.gpu: Replaying jobs retry=2
[ 14.644148] mali ffa30000.gpu: GPU Fault 0x00000088 (UNKNOWN) at 0x000000007649e3c0
[ 14.651672] mali ffa30000.gpu: There were multiple GPU faults - some have not been reported
[ 14.660118] mali ffa30000.gpu: Unhandled Page fault in AS1 at VA 0x00000001111D51E0
[ 14.660118] raw fault status 0x2A002C2
[ 14.660118] decoded fault status: SLAVE FAULT
[ 14.660118] exception type 0xC2: TRANSLATION_FAULT
[ 14.660118] access type 0x2: READ
[ 14.660118] source id 0x2A0
[ 14.686365] mali ffa30000.gpu: Issueing GPU soft-reset after hard stopping due to hardware issue
[ 14.695174] mali ffa30000.gpu: Preparing to soft-reset GPU: Waiting (upto 500 ms) for all jobs to complete soft-stop
[ 14.883101] mali ffa30000.gpu: JS: Job Hard-Stopped (took more than 4 ticks at 50 ms/tick)
[ 14.891231] mali ffa30000.gpu: JS: Job Hard-Stopped (took more than 4 ticks at 50 ms/tick)
[ 14.997767] mali ffa30000.gpu: JS: Job has been on the GPU for too long (KBASE_CONFIG_ATTR_JS_RESET_TICKS_SS/NSS timeout hit). Issueing GPU soft-reset to resolve.
[ 15.197538] mali ffa30000.gpu: Resetting GPU (allowing up to 500 ms)
[ 15.203818] mali ffa30000.gpu: Register state:
[ 15.208189] mali ffa30000.gpu: GPU_IRQ_RAWSTAT=0x00000200 GPU_STATUS=0x00000009
[ 15.215542] mali ffa30000.gpu: JOB_IRQ_RAWSTAT=0x00000000 JOB_IRQ_JS_STATE=0x00000000 JOB_IRQ_THROTTLE=0x00000000
[ 15.225793] mali ffa30000.gpu: JS0_STATUS=0x00000008 JS0_HEAD_LO=0xb36ae700
[ 15.233230] mali ffa30000.gpu: JS1_STATUS=0x00000008 JS1_HEAD_LO=0xb4aec2c0
[ 15.240666] mali ffa30000.gpu: JS2_STATUS=0x00000000 JS2_HEAD_LO=0x00000000
[ 15.248102] mali ffa30000.gpu: MMU_IRQ_RAWSTAT=0x00000000 GPU_FAULTSTATUS=0x00ff0388
[ 15.255883] mali ffa30000.gpu: GPU_IRQ_MASK=0x00010581 JOB_IRQ_MASK=0x00070007 MMU_IRQ_MASK=0x00ff00ff
[ 15.265793] mali ffa30000.gpu: PWR_OVERRIDE0=0x00000000 PWR_OVERRIDE1=0x00000000
[ 15.273401] mali ffa30000.gpu: SHADER_CONFIG=0x00000000 L2_MMU_CONFIG=0x00000000
[ 15.773213] mali ffa30000.gpu: Failed to soft-reset GPU (timed out after 500 ms), now attempting a hard reset
[ 15.783030] mali ffa30000.gpu: Job stuck in slot 0 on the GPU was cancelled
[ 15.789881] mali ffa30000.gpu: t6xx: GPU fault 0x4002 from job slot 0
[ 15.796218] mali ffa30000.gpu: Job stuck in slot 1 on the GPU was cancelled
[ 15.803059] mali ffa30000.gpu: t6xx: GPU fault 0x4002 from job slot 1
[ 15.809500] mali ffa30000.gpu: Reset complete
[ 15.813871] mali ffa30000.gpu: Replaying jobs retry=0
[ 15.818968] mali ffa30000.gpu: Replaying jobs retry=3
[ 15.824035] mali ffa30000.gpu: Job already not started
[ 15.844891] mali ffa30000.gpu: Flush for GPU page table update did not complete. Issueing GPU soft-reset to recover
[ 15.855195] mali ffa30000.gpu: Preparing to soft-reset GPU: Waiting (upto 500 ms) for all jobs to complete soft-stop
[ 15.865601] mali ffa30000.gpu: Replaying jobs retry=0
[ 16.020777] mali ffa30000.gpu: JS: Job Hard-Stopped (took more than 4 ticks at 50 ms/tick)
[ 16.127316] mali ffa30000.gpu: JS: Job has been on the GPU for too long (KBASE_CONFIG_ATTR_JS_RESET_TICKS_SS/NSS timeout hit). Issueing GPU soft-reset to resolve.
[ 16.357618] mali ffa30000.gpu: Resetting GPU (allowing up to 500 ms)
[ 16.363928] mali ffa30000.gpu: Register state:
[ 16.368299] mali ffa30000.gpu: GPU_IRQ_RAWSTAT=0x00000200 GPU_STATUS=0x00000009
[ 16.375564] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[ 16.382748] mali ffa30000.gpu: JOB_IRQ_RAWSTAT=0x00000000 JOB_IRQ_JS_STATE=0x00000000 JOB_IRQ_THROTTLE=0x00000000
[ 16.393004] mali ffa30000.gpu: JS0_STATUS=0x00000000 JS0_HEAD_LO=0x00000000
[ 16.400441] mali ffa30000.gpu: JS1_STATUS=0x00000008 JS1_HEAD_LO=0xb36ae680
[ 16.407877] mali ffa30000.gpu: JS2_STATUS=0x00000000 JS2_HEAD_LO=0x00000000
[ 16.415311] mali ffa30000.gpu: MMU_IRQ_RAWSTAT=0x00000000 GPU_FAULTSTATUS=0x00000000
[ 16.423089] mali ffa30000.gpu: GPU_IRQ_MASK=0x00010581 JOB_IRQ_MASK=0x00070007 MMU_IRQ_MASK=0x00ff00ff
[ 16.433000] mali ffa30000.gpu: PWR_OVERRIDE0=0x00000000 PWR_OVERRIDE1=0x00000000
[ 16.440605] mali ffa30000.gpu: SHADER_CONFIG=0x00000000 L2_MMU_CONFIG=0x00000000
[ 16.940392] mali ffa30000.gpu: Failed to soft-reset GPU (timed out after 500 ms), now attempting a hard reset
[ 16.950198] mali ffa30000.gpu: Job stuck in slot 1 on the GPU was cancelled
[ 16.957042] mali ffa30000.gpu: t6xx: GPU fault 0x4002 from job slot 1
[ 16.963475] mali ffa30000.gpu: Reset complete
[ 16.967850] mali ffa30000.gpu: Replaying jobs retry=1
[ 16.972864] mali ffa30000.gpu: Job already not started
[ 17.002540] mali ffa30000.gpu: Flush for GPU page table update did not complete. Issueing GPU soft-reset to recover
[ 17.012869] mali ffa30000.gpu: Preparing to soft-reset GPU: Waiting (upto 500 ms) for all jobs to complete soft-stop
[ 17.038977] mali ffa30000.gpu: Flush for GPU page table update did not complete. Issueing GPU soft-reset to recover
[ 17.049332] fence error -14 on [edb2a200]
[ 17.053342] objs:
[ 17.053342] --------------
[ 17.053342] fb-timeline sw_sync: 0
[ 17.053342]
[ 17.053342] malitl_139_0xb8469bf8 Mali: 1
[ 17.053342]
[ 17.053342] malitl_139_0xb846ee50 Mali: 3
[ 17.053342] pt error@11.156787: 1(-14)
[ 17.053342] pt error@12.386062: 2(-14)
[ 17.053342] pt error@16.787618: 3(-14)
[ 17.053342]
[ 17.053342] malitl_446_0xb7e0bc10 Mali: 4
[ 17.053342] pt signaled@13.399038: 2(-14)
[ 17.092996] pt signaled@13.399038: 3(0)
pt error@13.399039: 4(-14)
fences:
malitl_139_0xb846ee50_pt error@11.156787: 1(-14) / 3
[ec000080] mali_fence: signaled
malitl_446_0xb7e0bc10_pt signaled@13.399038: 2(-14) / 4
malitl_139_0xb846ee50_pt error@12.386062: 2(-14) / 3
[ec000c80] mali_fence: signaled
malitl_446_0xb7e0bc10_pt signaled@13.399038: 3(0) / 4
[ee1d6d80] mali_fence: error
malitl_446_0xb7e0bc10_pt error@13.399039: 4(-14) / 4
[edb2a200] mali_fence: error
malitl_139_0xb846ee50_pt error@16.787618: 3(-14) / 3
[ 17.186329] mali ffa30000.gpu: JS: Job Hard-Stopped (took more than 4 ticks at 50 ms/tick)
[ 17.292872] mali ffa30000.gpu: JS: Job has been on the GPU for too long (KBASE_CONFIG_ATTR_JS_RESET_TICKS_SS/NSS timeout hit). Issueing GPU soft-reset to resolve.
[ 17.515283] mali ffa30000.gpu: Resetting GPU (allowing up to 500 ms)
[ 17.521545] mali ffa30000.gpu: Register state:
[ 17.525914] mali ffa30000.gpu: GPU_IRQ_RAWSTAT=0x00000200 GPU_STATUS=0x00000009
[ 17.533268] mali ffa30000.gpu: JOB_IRQ_RAWSTAT=0x00000000 JOB_IRQ_JS_STATE=0x00000000 JOB_IRQ_THROTTLE=0x00000000
[ 17.543519] mali ffa30000.gpu: JS0_STATUS=0x00000000 JS0_HEAD_LO=0x00000000
[ 17.550956] mali ffa30000.gpu: JS1_STATUS=0x00000008 JS1_HEAD_LO=0xb321e2c0
[ 17.558393] mali ffa30000.gpu: JS2_STATUS=0x00000000 JS2_HEAD_LO=0x00000000
[ 17.565830] mali ffa30000.gpu: MMU_IRQ_RAWSTAT=0x00000000 GPU_FAULTSTATUS=0x00000000
[ 17.573609] mali ffa30000.gpu: GPU_IRQ_MASK=0x00010581 JOB_IRQ_MASK=0x00070007 MMU_IRQ_MASK=0x00ff00ff
[ 17.583518] mali ffa30000.gpu: PWR_OVERRIDE0=0x00000000 PWR_OVERRIDE1=0x00000000
[ 17.591131] mali ffa30000.gpu: SHADER_CONFIG=0x00000000 L2_MMU_CONFIG=0x00000000
[ 18.090918] mali ffa30000.gpu: Failed to soft-reset GPU (timed out after 500 ms), now attempting a hard reset
[ 18.100714] mali ffa30000.gpu: Job stuck in slot 1 on the GPU was cancelled
[ 18.107557] mali ffa30000.gpu: t6xx: GPU fault 0x4002 from job slot 1
[ 18.113940] mali ffa30000.gpu: Reset complete
[ 18.118287] mali ffa30000.gpu: Replaying jobs retry=1
[ 18.123292] mali ffa30000.gpu: Job already not started
[ 18.141894] mali ffa30000.gpu: Flush for GPU page table update did not complete. Issueing GPU soft-reset to recover
[ 18.152210] mali ffa30000.gpu: Preparing to soft-reset GPU: Waiting (upto 500 ms) for all jobs to complete soft-stop
[ 18.162596] mali ffa30000.gpu: Replaying jobs retry=0
[ 18.167622] mali ffa30000.gpu: Job already not started
[ 18.186176] mali ffa30000.gpu: Flush for GPU page table update did not complete. Issueing GPU soft-reset to recover
[ 18.344051] mali ffa30000.gpu: JS: Job Hard-Stopped (took more than 4 ticks at 50 ms/tick)
[ 18.450596] mali ffa30000.gpu: JS: Job has been on the GPU for too long (KBASE_CONFIG_ATTR_JS_RESET_TICKS_SS/NSS timeout hit). Issueing GPU soft-reset to resolve.
[ 18.654610] mali ffa30000.gpu: Resetting GPU (allowing up to 500 ms)
[ 18.660913] mali ffa30000.gpu: Register state:
[ 18.665286] mali ffa30000.gpu: GPU_IRQ_RAWSTAT=0x00000200 GPU_STATUS=0x00000009
[ 18.672639] mali ffa30000.gpu: JOB_IRQ_RAWSTAT=0x00000000 JOB_IRQ_JS_STATE=0x00000000 JOB_IRQ_THROTTLE=0x00000000
[ 18.682892] mali ffa30000.gpu: JS0_STATUS=0x00000000 JS0_HEAD_LO=0x00000000
[ 18.690329] mali ffa30000.gpu: JS1_STATUS=0x00000008 JS1_HEAD_LO=0xb4aec2c0
[ 18.697766] mali ffa30000.gpu: JS2_STATUS=0x00000000 JS2_HEAD_LO=0x00000000
[ 18.705203] mali ffa30000.gpu: MMU_IRQ_RAWSTAT=0x00000000 GPU_FAULTSTATUS=0x00000000
[ 18.712982] mali ffa30000.gpu: GPU_IRQ_MASK=0x00010581 JOB_IRQ_MASK=0x00070007 MMU_IRQ_MASK=0x00ff00ff
[ 18.722893] mali ffa30000.gpu: PWR_OVERRIDE0=0x00000000 PWR_OVERRIDE1=0x00000000
[ 18.730501] mali ffa30000.gpu: SHADER_CONFIG=0x00000000 L2_MMU_CONFIG=0x00000000
[ 19.230284] mali ffa30000.gpu: Failed to soft-reset GPU (timed out after 500 ms), now attempting a hard reset
[ 19.240087] mali ffa30000.gpu: Job stuck in slot 1 on the GPU was cancelled
[ 19.246931] mali ffa30000.gpu: t6xx: GPU fault 0x4002 from job slot 1
[ 19.253396] mali ffa30000.gpu: Reset complete
[ 19.476201] mali ffa30000.gpu: JS: Job Hard-Stopped (took more than 4 ticks at 50 ms/tick)
[ 19.582747] mali ffa30000.gpu: JS: Job has been on the GPU for too long (KBASE_CONFIG_ATTR_JS_RESET_TICKS_SS/NSS timeout hit). Issueing GPU soft-reset to resolve.
[ 19.597021] mali ffa30000.gpu: Preparing to soft-reset GPU: Waiting (upto 500 ms) for all jobs to complete soft-stop
[ 19.659305] *****************vbus detect*******************
[ 19.847776] Using Buffer DMA mode
[ 19.851041] Periodic Transfer Interrupt Enhancement - disabled
[ 19.856789] Multiprocessor Interrupt Enhancement - disabled
[ 19.862267] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 19.866558] ^^^^^^^^^^^^^^^^^Device Mode
[ 19.870449] *******************soft connect!!!*******************
[ 20.068224] USB RESET
[ 20.099389] mali ffa30000.gpu: Resetting GPU (allowing up to 500 ms)
[ 20.105687] mali ffa30000.gpu: Register state:
[ 20.110060] mali ffa30000.gpu: GPU_IRQ_RAWSTAT=0x00000200 GPU_STATUS=0x00000009
[ 20.117415] mali ffa30000.gpu: JOB_IRQ_RAWSTAT=0x00000000 JOB_IRQ_JS_STATE=0x00000000 JOB_IRQ_THROTTLE=0x00000000
[ 20.127667] mali ffa30000.gpu: JS0_STATUS=0x00000000 JS0_HEAD_LO=0x00000000
[ 20.135106] mali ffa30000.gpu: JS1_STATUS=0x00000008 JS1_HEAD_LO=0xb36ae680
[ 20.142543] mali ffa30000.gpu: JS2_STATUS=0x00000000 JS2_HEAD_LO=0x00000000
[ 20.149980] mali ffa30000.gpu: MMU_IRQ_RAWSTAT=0x00000000 GPU_FAULTSTATUS=0x00000000
[ 20.157759] mali ffa30000.gpu: GPU_IRQ_MASK=0x00010581 JOB_IRQ_MASK=0x00070007 MMU_IRQ_MASK=0x00ff00ff
[ 20.167669] mali ffa30000.gpu: PWR_OVERRIDE0=0x00000000 PWR_OVERRIDE1=0x00000000
[ 20.175277] mali ffa30000.gpu: SHADER_CONFIG=0x00000000 L2_MMU_CONFIG=0x00000000
[ 20.675088] mali ffa30000.gpu: Failed to soft-reset GPU (timed out after 500 ms), now attempting a hard reset
[ 20.684889] mali ffa30000.gpu: Job stuck in slot 1 on the GPU was cancelled
[ 20.691734] mali ffa30000.gpu: t6xx: GPU fault 0x4002 from job slot 1
[ 20.698150] mali ffa30000.gpu: Reset complete
[ 20.702496] mali ffa30000.gpu: Replaying jobs retry=0
[ 20.707523] mali ffa30000.gpu: Job already not started
[ 20.712795] fence error -14 on [eda69180]
[ 20.716804] objs:
[ 20.716804] --------------
[ 20.716804] fb-timeline sw_sync: 0
[ 20.716804]
[ 20.716804] malitl_139_0xb8469bf8 Mali: 2
[ 20.716804]
[ 20.716804] malitl_139_0xb846ee50 Mali: 4
[ 20.716804] pt error@12.386062: 2(-14)
[ 20.716804] pt error@16.787618: 3(-14)
[ 20.716804] pt error@20.510649: 4(-14)
[ 20.716804]
[ 20.716804] malitl_446_0xb7e0bc10 Mali: 5
[ 20.716804] pt signaled@13.399038: 3(-14)
[ 20.728644] USB RESET
[ 20.758710] pt error@13.399039: 4(-14)
pt error@17.953419: 5(-14)
fences:
malitl_139_0xb846ee50_pt error@12.386062: 2(-14) / 4
malitl_446_0xb7e0bc10_pt signaled@13.399038: 3(-14) / 5
malitl_446_0xb7e0bc10_pt error@13.399039: 4(-14) / 5
malitl_139_0xb846ee50_pt error@16.787618: 3(-14) / 4
[ed6fcb80] mali_fence: error
malitl_446_0xb7e0bc10_pt error@17.953419: 5(-14) / 5
[eda69180] mali_fence: error
malitl_139_0xb846ee50_pt error@20.510649: 4(-14) / 4
[ 20.816970] mali ffa30000.gpu: Replaying jobs retry=0
[ 20.822082] mali ffa30000.gpu: Job already not started
[ 21.017210] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 21.030972] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 21.233686] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 21.247443] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 21.254344] ###################WARNING:set voltage is error!voltage set is 1200000 mv -110
[ 21.262464] DVFS ERR: dvfs_regulator_set_voltage_readback: now read back to check voltage
[ 21.459997] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 21.473745] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 21.480646] DVFS ERR: dvfs_regulator_set_voltage_readback: set ERROR AND NOT effected, volt=937500
[ 21.489505] DVFS ERR: dvfs_scale_volt_direct: vd_arm set voltage up err ret = -110, Vnew = 1200000(was 1100000)mV
[ 41.464701] INFO: rcu_preempt detected stalls on CPUs/tasks: { 0} (detected by 3, t=2102 jiffies, g=4294967253, c=4294967252, q=28)
[ 41.476372] Backtrace for cpu 3 (current):
[ 41.480400] CPU: 3 PID: 0 Comm: swapper/3 Tainted: P O 3.10.0 #49
[ 41.487256] [<c0013e04>] (unwind_backtrace+0x0/0xe0) from [<c0011720>] (show_stack+0x10/0x14)
[ 41.495636] [<c0011720>] (show_stack+0x10/0x14) from [<c0012d1c>] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 41.504956] [<c0012d1c>] (smp_send_all_cpu_backtrace+0x60/0xcc) from [<c009a84c>] (print_other_cpu_stall+0x264/0x2e0)
[ 41.515384] [<c009a84c>] (print_other_cpu_stall+0x264/0x2e0) from [<c009b188>] (__rcu_pending+0x90/0x190)
[ 41.524787] [<c009b188>] (__rcu_pending+0x90/0x190) from [<c009ce5c>] (rcu_check_callbacks+0x160/0x230)
[ 41.534022] [<c009ce5c>] (rcu_check_callbacks+0x160/0x230) from [<c003bccc>] (update_process_times+0x38/0x64)
[ 41.543769] [<c003bccc>] (update_process_times+0x38/0x64) from [<c00775c8>] (tick_sched_timer+0xac/0xe0)
[ 41.553088] [<c00775c8>] (tick_sched_timer+0xac/0xe0) from [<c004fc2c>] (__run_hrtimer+0x1a4/0x2b8)
[ 41.561980] [<c004fc2c>] (__run_hrtimer+0x1a4/0x2b8) from [<c0050818>] (hrtimer_interrupt+0x11c/0x278)
[ 41.571127] [<c0050818>] (hrtimer_interrupt+0x11c/0x278) from [<c0517f10>] (arch_timer_handler_phys+0x28/0x30)
[ 41.580958] [<c0517f10>] (arch_timer_handler_phys+0x28/0x30) from [<c00971a8>] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 41.591214] [<c00971a8>] (handle_percpu_devid_irq+0xf8/0x1b4) from [<c0093ddc>] (generic_handle_irq+0x20/0x30)
[ 41.601047] [<c0093ddc>] (generic_handle_irq+0x20/0x30) from [<c000e3ac>] (handle_IRQ+0x64/0x8c)
[ 41.609680] [<c000e3ac>] (handle_IRQ+0x64/0x8c) from [<c0008538>] (gic_handle_irq+0x34/0x58)
[ 41.617974] [<c0008538>] (gic_handle_irq+0x34/0x58) from [<c000d600>] (__irq_svc+0x40/0x70)
[ 41.626178] Exception stack(0xee0bdf30 to 0xee0bdf78)
[ 41.631143] df20: ee0bdf78 00000029 af8da25a 00000009
[ 41.639179] df40: c1ed9318 00000000 adc44fcf 00000009 c0ce0e80 ee0bc000 c0ce0e90 00000000
[ 41.647213] df60: 1024259a ee0bdf78 c006ff14 c04fcf80 60070013 ffffffff
[ 41.653718] [<c000d600>] (__irq_svc+0x40/0x70) from [<c04fcf80>] (cpuidle_enter_state+0x54/0xec)
[ 41.662355] [<c04fcf80>] (cpuidle_enter_state+0x54/0xec) from [<c04fd184>] (cpuidle_idle_call+0x16c/0x27c)
[ 41.671843] [<c04fd184>] (cpuidle_idle_call+0x16c/0x27c) from [<c000e730>] (arch_cpu_idle+0x8/0x38)
[ 41.680736] [<c000e730>] (arch_cpu_idle+0x8/0x38) from [<c006f2f4>] (cpu_idle_loop+0x1b8/0x224)
[ 41.689286] [<c006f2f4>] (cpu_idle_loop+0x1b8/0x224) from [<c006f36c>] (freezing_slow_path+0x0/0x64)
[ 41.698257]
[ 41.698257] sending IPI to all other CPUs:
[ 41.703736] IPI backtrace for cpu 1
[ 41.707165]
[ 41.708633] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P O 3.10.0 #49
[ 41.715474] task: ee093700 ti: ee0b8000 task.ti: ee0b8000
[ 41.720780] PC is at cpuidle_enter_state+0x54/0xec
[ 41.725489] LR is at ktime_get+0x98/0xdc
[ 41.729345] pc : [<c04fcf80>] lr : [<c006ff14>] psr: 60010013
[ 41.729345] sp : ee0b9f78 ip : 1024259a fp : 00000000
[ 41.740621] r10: c0ce0e90 r9 : ee0b8000 r8 : c0ce0e80
[ 41.745754] r7 : 00000009 r6 : be065218 r5 : 00000000 r4 : c1ec7318
[ 41.752167] r3 : 00000009 r2 : be086e22 r1 : 00000029 r0 : ee0b9f78
[ 41.758574] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 41.765754] Control: 10c5387d Table: 2d7a406a DAC: 00000015
[ 41.771399]
[ 41.771399] PC: 0xc04fcf00:
[ 41.775596] cf00 e1a00004 e12fff33 e8bd8010 e2411001 e3510000 aafffff5 e3e00012 e8bd8010
[ 41.783728] cf20 e3e00012 e8bd8010 c0ccb310 e92d45f0 e3a0a04c e02a129a e24dd014 e1a04000
[ 41.791860] cf40 e1a08001 e1a05002 e1a0000d ebedcbca e1a02005 e1a01008 e1a00004 e59a3054
[ 41.799990] cf60 e28aa010 e1cd60d0 e12fff33 e1a05000 e1a0000d ebedcbc0 e1cd20d0 f1080080
[ 41.808121] cf80 e0522006 e0c33007 e28d0008 ebecdb04 e59d000c e59f3078 e59d2008 e1a01fc0
[ 41.816252] cfa0 e0e10293 e3a03000 e3e02102 e1520000 e0d3c001 b1a00002 e3550000 e5840008
[ 41.824381] cfc0 e1a0c000 b3a03000 b5843008 ba00000d e3a01018 e0204591 e1c022d0 e092200c
[ 41.832511] cfe0 e0a33fcc e285c001 e1c022f0 e3a00001 e00c0c91 e3a01000 e18420dc e0922000
[ 41.840642]
[ 41.840642] LR: 0xc006fe94:
[ 41.844837] fe94 e59f00b0 e3001152 ebfef5f0 e59f50a8 e5958090 e3180001 0a000000 eafffffb
[ 41.852969] feb4 f57ff05f e1c523d8 e5954000 e5951054 e0926001 e1a00004 e0a37fc1 e5943000
[ 41.861098] fed4 e1cd60f0 e12fff33 e1c420d8 e0500002 e0c11003 e1c421d0 e0033001 e5951004
[ 41.869230] fef4 e0022000 e0876192 e5952008 e0277391 e1c504d0 e0900006 e0a11007 eb07ca16
[ 41.877359] ff14 e595c058 e090200c e0a13fcc f57ff05f e5951090 e1510008 1affffdc e59f101c
[ 41.885489] ff34 e1a0000a e59d7000 e0e32791 e1ca20f0 e8bd85fe c0cd64dc c094fcf6 c0e0b580
[ 41.893619] ff54 3b9aca00 e92d40f8 e1a07000 e59f5030 e2854094 e1a00004 eb1c7cf3 e1a01007
[ 41.901749] ff74 e1a06000 e2850098 ebff86b9 e1a01006 e1a05000 e1a00004 eb1c7dba e1a00005
[ 41.909878]
[ 41.909878] SP: 0xee0b9ef8:
[ 41.914074] 9ef8 00000007 c0012f60 fed91000 ee0b9f30 c0cd73dc ee0b9f64 c0ce0e80 ee0b8000
[ 41.922204] 9f18 c0ce0e90 c0008554 c04fcf80 60010013 ffffffff c000d600 ee0b9f78 00000029
[ 41.930335] 9f38 be086e22 00000009 c1ec7318 00000000 be065218 00000009 c0ce0e80 ee0b8000
[ 41.938465] 9f58 c0ce0e90 00000000 1024259a ee0b9f78 c006ff14 c04fcf80 60010013 ffffffff
[ 41.946594] 9f78 be086e22 00000009 ee0b8000 c1ec7318 ee0b8000 c1ec7318 00000000 c0d6838c
[ 41.954724] 9f98 00000000 c0ce0e80 00000001 c04fd184 ee0b8000 ee0b8000 10c0387d c0794218
[ 41.962854] 9fb8 0000406a 410fc0d1 00000000 c000e730 000358ae c006f2f4 c00081a4 2e09c06a
[ 41.970984] 9fd8 00000015 10c0387d c0d6b34c 0000406a 00000000 c006f36c c00081a4 000081bc
[ 41.979113]
[ 41.979113] R0: 0xee0b9ef8:
[ 41.983309] 9ef8 00000007 c0012f60 fed91000 ee0b9f30 c0cd73dc ee0b9f64 c0ce0e80 ee0b8000
[ 41.991438] 9f18 c0ce0e90 c0008554 c04fcf80 60010013 ffffffff c000d600 ee0b9f78 00000029
[ 41.999568] 9f38 be086e22 00000009 c1ec7318 00000000 be065218 00000009 c0ce0e80 ee0b8000
[ 42.007699] 9f58 c0ce0e90 00000000 1024259a ee0b9f78 c006ff14 c04fcf80 60010013 ffffffff
[ 42.015829] 9f78 be086e22 00000009 ee0b8000 c1ec7318 ee0b8000 c1ec7318 00000000 c0d6838c
[ 42.023959] 9f98 00000000 c0ce0e80 00000001 c04fd184 ee0b8000 ee0b8000 10c0387d c0794218
[ 42.032090] 9fb8 0000406a 410fc0d1 00000000 c000e730 000358ae c006f2f4 c00081a4 2e09c06a
[ 42.040220] 9fd8 00000015 10c0387d c0d6b34c 0000406a 00000000 c006f36c c00081a4 000081bc
[ 42.048352]
[ 42.048352] R4: 0xc1ec7298:
[ 42.052547] 7298 00000000 00000000 0e550e55 00000000 02030707 00000000 027e6f0a 00000000
[ 42.060677] 72b8 00000000 00000000 027e6f0a 00000000 ed87c840 ee046200 06680668 00124f80
[ 42.068807] 72d8 00124f80 001b7740 027e6f07 00000000 027e6f07 00000000 00000000 774f774f
[ 42.076937] 72f8 c1ec72f8 c1ec72f8 00000001 00000000 00000000 00000000 c1ec7318 00000000
[ 42.085066] 7318 00000003 00000001 0000018a 00000001 00000000 00000000 0000d8cb 00000000
[ 42.093196] 7338 01cb73a4 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.101326] 7358 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.109456] 7378 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.117586]
[ 42.117586] R8: 0xc0ce0e00:
[ 42.121782] 0e00 e58511d4 e5901184 e5851210 e5901188 e5851214 e5901194 e5851250 e5901198
[ 42.129912] 0e20 e5851254 e59011a4 e5851290 e59001a8 e5850294 e1a01007 e1a00005 ebfffeaa
[ 42.138042] 0e40 e2866001 e3560002 3affffd2 e59402c0 e3700001 0a000003 e5901000 e59422c4
[ 42.146173] 0e60 e1811002 e5801000 e59402c8 e3700001 08bd81f0 e3a00001 e8bd41f0 eafffe4f
[ 42.154303] 0e80 c0949cc9 00000000 00000000 00000000 00494657 00000000 00000000 00000000
[ 42.162432] 0ea0 204d5241 00494657 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.170563] 0ec0 00000001 00000001 ffffffff 00000001 00000000 c0020ea4 00000000 00000000
[ 42.178692] 0ee0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.186823]
[ 42.186823] R9: 0xee0b7f80:
[ 42.191019] 7f80 ee0b7f80 ee0b7f80 00000000 00000000 ee0b7f90 ee0b7f90 ee0b7fac ee073f08
[ 42.199149] 7fa0 c004c9f0 00000000 00000000 c000da98 00000000 00000000 00000000 00000000
[ 42.207279] 7fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.215409] 7fe0 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff ffffffff
[ 42.223539] 8000 00000000 00000003 00000000 ee093700 c0cf1ab8 00000001 00000015 ee093700
[ 42.231671] 8020 c1ec7f40 ee0b8000 ed931a40 00000000 410fc0d1 ee199e00 ee0b9fbc ee0b9f38
[ 42.239802] 8040 c078e644 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.247933] 8060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.256063]
[ 42.256063] R10: 0xc0ce0e10:
[ 42.260344] 0e10 e5851214 e5901194 e5851250 e5901198 e5851254 e59011a4 e5851290 e59001a8
[ 42.268475] 0e30 e5850294 e1a01007 e1a00005 ebfffeaa e2866001 e3560002 3affffd2 e59402c0
[ 42.276605] 0e50 e3700001 0a000003 e5901000 e59422c4 e1811002 e5801000 e59402c8 e3700001
[ 42.284735] 0e70 08bd81f0 e3a00001 e8bd41f0 eafffe4f c0949cc9 00000000 00000000 00000000
[ 42.292865] 0e90 00494657 00000000 00000000 00000000 204d5241 00494657 00000000 00000000
[ 42.300995] 0eb0 00000000 00000000 00000000 00000000 00000001 00000001 ffffffff 00000001
[ 42.309124] 0ed0 00000000 c0020ea4 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.317254] 0ef0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.325387] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P O 3.10.0 #49
[ 42.332232] [<c0013e04>] (unwind_backtrace+0x0/0xe0) from [<c0011720>] (show_stack+0x10/0x14)
[ 42.340611] [<c0011720>] (show_stack+0x10/0x14) from [<c0012f60>] (handle_IPI+0x1d8/0x2c8)
[ 42.348732] [<c0012f60>] (handle_IPI+0x1d8/0x2c8) from [<c0008554>] (gic_handle_irq+0x50/0x58)
[ 42.357194] [<c0008554>] (gic_handle_irq+0x50/0x58) from [<c000d600>] (__irq_svc+0x40/0x70)
[ 42.365398] Exception stack(0xee0b9f30 to 0xee0b9f78)
[ 42.370361] 9f20: ee0b9f78 00000029 be086e22 00000009
[ 42.378388] 9f40: c1ec7318 00000000 be065218 00000009 c0ce0e80 ee0b8000 c0ce0e90 00000000
[ 42.386422] 9f60: 1024259a ee0b9f78 c006ff14 c04fcf80 60010013 ffffffff
[ 42.392924] [<c000d600>] (__irq_svc+0x40/0x70) from [<c04fcf80>] (cpuidle_enter_state+0x54/0xec)
[ 42.401559] [<c04fcf80>] (cpuidle_enter_state+0x54/0xec) from [<c04fd184>] (cpuidle_idle_call+0x16c/0x27c)
[ 42.411046] [<c04fd184>] (cpuidle_idle_call+0x16c/0x27c) from [<c000e730>] (arch_cpu_idle+0x8/0x38)
[ 42.419937] [<c000e730>] (arch_cpu_idle+0x8/0x38) from [<c006f2f4>] (cpu_idle_loop+0x1b8/0x224)
[ 42.428486] [<c006f2f4>] (cpu_idle_loop+0x1b8/0x224) from [<c006f36c>] (freezing_slow_path+0x0/0x64)
[ 42.437459] IPI backtrace for cpu 2
[ 42.440887]
[ 42.442355] CPU: 2 PID: 0 Comm: swapper/2 Tainted: P O 3.10.0 #49
[ 42.449194] task: ee093c00 ti: ee0ba000 task.ti: ee0ba000
[ 42.454500] PC is at cpuidle_enter_state+0x54/0xec
[ 42.459208] LR is at ktime_get+0x98/0xdc
[ 42.463064] pc : [<c04fcf80>] lr : [<c006ff14>] psr: 600b0013
[ 42.463064] sp : ee0bbf78 ip : 1024259a fp : 00000000
[ 42.474340] r10: c0ce0e90 r9 : ee0ba000 r8 : c0ce0e80
[ 42.479474] r7 : 00000009 r6 : bdd181c0 r5 : 00000000 r4 : c1ed0318
[ 42.485886] r3 : 00000009 r2 : be086f46 r1 : 00000029 r0 : ee0bbf78
[ 42.492298] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 42.499478] Control: 10c5387d Table: 2caf806a DAC: 00000015
[ 42.505122]
[ 42.505122] PC: 0xc04fcf00:
[ 42.509318] cf00 e1a00004 e12fff33 e8bd8010 e2411001 e3510000 aafffff5 e3e00012 e8bd8010
[ 42.517453] cf20 e3e00012 e8bd8010 c0ccb310 e92d45f0 e3a0a04c e02a129a e24dd014 e1a04000
[ 42.525584] cf40 e1a08001 e1a05002 e1a0000d ebedcbca e1a02005 e1a01008 e1a00004 e59a3054
[ 42.533717] cf60 e28aa010 e1cd60d0 e12fff33 e1a05000 e1a0000d ebedcbc0 e1cd20d0 f1080080
[ 42.541850] cf80 e0522006 e0c33007 e28d0008 ebecdb04 e59d000c e59f3078 e59d2008 e1a01fc0
[ 42.549981] cfa0 e0e10293 e3a03000 e3e02102 e1520000 e0d3c001 b1a00002 e3550000 e5840008
[ 42.558112] cfc0 e1a0c000 b3a03000 b5843008 ba00000d e3a01018 e0204591 e1c022d0 e092200c
[ 42.566244] cfe0 e0a33fcc e285c001 e1c022f0 e3a00001 e00c0c91 e3a01000 e18420dc e0922000
[ 42.574376]
[ 42.574376] LR: 0xc006fe94:
[ 42.578572] fe94 e59f00b0 e3001152 ebfef5f0 e59f50a8 e5958090 e3180001 0a000000 eafffffb
[ 42.586704] feb4 f57ff05f e1c523d8 e5954000 e5951054 e0926001 e1a00004 e0a37fc1 e5943000
[ 42.594834] fed4 e1cd60f0 e12fff33 e1c420d8 e0500002 e0c11003 e1c421d0 e0033001 e5951004
[ 42.602967] fef4 e0022000 e0876192 e5952008 e0277391 e1c504d0 e0900006 e0a11007 eb07ca16
[ 42.611097] ff14 e595c058 e090200c e0a13fcc f57ff05f e5951090 e1510008 1affffdc e59f101c
[ 42.619227] ff34 e1a0000a e59d7000 e0e32791 e1ca20f0 e8bd85fe c0cd64dc c094fcf6 c0e0b580
[ 42.627359] ff54 3b9aca00 e92d40f8 e1a07000 e59f5030 e2854094 e1a00004 eb1c7cf3 e1a01007
[ 42.635491] ff74 e1a06000 e2850098 ebff86b9 e1a01006 e1a05000 e1a00004 eb1c7dba e1a00005
[ 42.643623]
[ 42.643623] SP: 0xee0bbef8:
[ 42.647819] bef8 00000007 c0012f60 fed91000 ee0bbf30 c0cd73dc ee0bbf64 c0ce0e80 ee0ba000
[ 42.655950] bf18 c0ce0e90 c0008554 c04fcf80 600b0013 ffffffff c000d600 ee0bbf78 00000029
[ 42.664082] bf38 be086f46 00000009 c1ed0318 00000000 bdd181c0 00000009 c0ce0e80 ee0ba000
[ 42.672214] bf58 c0ce0e90 00000000 1024259a ee0bbf78 c006ff14 c04fcf80 600b0013 ffffffff
[ 42.680345] bf78 be086f46 00000009 ee0ba000 c1ed0318 ee0ba000 c1ed0318 00000000 c0d6838c
[ 42.688476] bf98 00000000 c0ce0e80 00000002 c04fd184 ee0ba000 ee0ba000 10c0387d c0794218
[ 42.696608] bfb8 0000406a 410fc0d1 00000000 c000e730 000040d2 c006f2f4 c00081a4 2e09c06a
[ 42.704739] bfd8 00000015 10c0387d c0d6b34c 0000406a 00000000 c006f36c c00081a4 000081bc
[ 42.712870]
[ 42.712870] R0: 0xee0bbef8:
[ 42.717066] bef8 00000007 c0012f60 fed91000 ee0bbf30 c0cd73dc ee0bbf64 c0ce0e80 ee0ba000
[ 42.725199] bf18 c0ce0e90 c0008554 c04fcf80 600b0013 ffffffff c000d600 ee0bbf78 00000029
[ 42.733329] bf38 be086f46 00000009 c1ed0318 00000000 bdd181c0 00000009 c0ce0e80 ee0ba000
[ 42.741460] bf58 c0ce0e90 00000000 1024259a ee0bbf78 c006ff14 c04fcf80 600b0013 ffffffff
[ 42.749590] bf78 be086f46 00000009 ee0ba000 c1ed0318 ee0ba000 c1ed0318 00000000 c0d6838c
[ 42.757718] bf98 00000000 c0ce0e80 00000002 c04fd184 ee0ba000 ee0ba000 10c0387d c0794218
[ 42.765849] bfb8 0000406a 410fc0d1 00000000 c000e730 000040d2 c006f2f4 c00081a4 2e09c06a
[ 42.773983] bfd8 00000015 10c0387d c0d6b34c 0000406a 00000000 c006f36c c00081a4 000081bc
[ 42.782114]
[ 42.782114] R4: 0xc1ed0298:
[ 42.786310] 0298 00000000 00000000 09b109b1 00000000 024bfaa4 00000000 027e6ad1 00000000
[ 42.794442] 02b8 00000000 00000000 027e6ad1 00000000 ed87c840 ee046200 04160416 00124f80
[ 42.802573] 02d8 00124f80 001b7740 027e6acf 00000000 027e6acf 00000000 00000000 5c855c85
[ 42.810703] 02f8 c1ed02f8 c1ed02f8 00000001 00000000 00000000 00000000 c1ed0318 00000000
[ 42.818834] 0318 00000003 00000002 0000c33a 00000001 00000000 00000000 00001329 00000000
[ 42.826966] 0338 01eddf49 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.835096] 0358 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.843225] 0378 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.851357]
[ 42.851357] R8: 0xc0ce0e00:
[ 42.855552] 0e00 e58511d4 e5901184 e5851210 e5901188 e5851214 e5901194 e5851250 e5901198
[ 42.863682] 0e20 e5851254 e59011a4 e5851290 e59001a8 e5850294 e1a01007 e1a00005 ebfffeaa
[ 42.871812] 0e40 e2866001 e3560002 3affffd2 e59402c0 e3700001 0a000003 e5901000 e59422c4
[ 42.879945] 0e60 e1811002 e5801000 e59402c8 e3700001 08bd81f0 e3a00001 e8bd41f0 eafffe4f
[ 42.888078] 0e80 c0949cc9 00000000 00000000 00000000 00494657 00000000 00000000 00000000
[ 42.896209] 0ea0 204d5241 00494657 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.904339] 0ec0 00000001 00000001 ffffffff 00000001 00000000 c0020ea4 00000000 00000000
[ 42.912470] 0ee0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.920602]
[ 42.920602] R9: 0xee0b9f80:
[ 42.924798] 9f80 ee0b8000 c1ec7318 ee0b8000 c1ec7318 00000000 c0d6838c 00000000 c0ce0e80
[ 42.932930] 9fa0 00000001 c04fd184 ee0b8000 ee0b8000 10c0387d c0794218 0000406a 410fc0d1
[ 42.941063] 9fc0 00000000 c000e730 00036cd6 c006f2f4 c00081a4 2e09c06a 00000015 10c0387d
[ 42.949194] 9fe0 c0d6b34c 0000406a 00000000 c006f36c c00081a4 000081bc ffffffff ffffffff
[ 42.957325] a000 00000000 00000003 00000000 ee093c00 c0cf1ab8 00000002 00000015 ee093c00
[ 42.965456] a020 c1ed0f40 ee0ba000 ed43fc00 00000000 410fc0d1 ee19a800 ee0bbfbc ee0bbf38
[ 42.973587] a040 c078e644 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.981717] a060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 42.989846]
[ 42.989846] R10: 0xc0ce0e10:
[ 42.994128] 0e10 e5851214 e5901194 e5851250 e5901198 e5851254 e59011a4 e5851290 e59001a8
[ 43.002258] 0e30 e5850294 e1a01007 e1a00005 ebfffeaa e2866001 e3560002 3affffd2 e59402c0
[ 43.010389] 0e50 e3700001 0a000003 e5901000 e59422c4 e1811002 e5801000 e59402c8 e3700001
[ 43.018521] 0e70 08bd81f0 e3a00001 e8bd41f0 eafffe4f c0949cc9 00000000 00000000 00000000
[ 43.026653] 0e90 00494657 00000000 00000000 00000000 204d5241 00494657 00000000 00000000
[ 43.034783] 0eb0 00000000 00000000 00000000 00000000 00000001 00000001 ffffffff 00000001
[ 43.042913] 0ed0 00000000 c0020ea4 00000000 00000000 00000000 00000000 00000000 00000000
[ 43.051044] 0ef0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 43.059177] CPU: 2 PID: 0 Comm: swapper/2 Tainted: P O 3.10.0 #49
[ 43.066022] [<c0013e04>] (unwind_backtrace+0x0/0xe0) from [<c0011720>] (show_stack+0x10/0x14)
[ 43.074400] [<c0011720>] (show_stack+0x10/0x14) from [<c0012f60>] (handle_IPI+0x1d8/0x2c8)
[ 43.082521] [<c0012f60>] (handle_IPI+0x1d8/0x2c8) from [<c0008554>] (gic_handle_irq+0x50/0x58)
[ 43.090984] [<c0008554>] (gic_handle_irq+0x50/0x58) from [<c000d600>] (__irq_svc+0x40/0x70)
[ 43.099188] Exception stack(0xee0bbf30 to 0xee0bbf78)
[ 43.104152] bf20: ee0bbf78 00000029 be086f46 00000009
[ 43.112187] bf40: c1ed0318 00000000 bdd181c0 00000009 c0ce0e80 ee0ba000 c0ce0e90 00000000
[ 43.120222] bf60: 1024259a ee0bbf78 c006ff14 c04fcf80 600b0013 ffffffff
[ 43.126725] [<c000d600>] (__irq_svc+0x40/0x70) from [<c04fcf80>] (cpuidle_enter_state+0x54/0xec)
[ 43.135361] [<c04fcf80>] (cpuidle_enter_state+0x54/0xec) from [<c04fd184>] (cpuidle_idle_call+0x16c/0x27c)
[ 43.144849] [<c04fd184>] (cpuidle_idle_call+0x16c/0x27c) from [<c000e730>] (arch_cpu_idle+0x8/0x38)
[ 43.153739] [<c000e730>] (arch_cpu_idle+0x8/0x38) from [<c006f2f4>] (cpu_idle_loop+0x1b8/0x224)
[ 43.162288] [<c006f2f4>] (cpu_idle_loop+0x1b8/0x224) from [<c006f36c>] (freezing_slow_path+0x0/0x64)
[ 51.737679] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 51.751437] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 51.758344] DVFS WARNING: dvfs_reset_volt:vd(vd_arm) try to reload volt = 937500
[ 51.954161] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 51.967918] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 52.170635] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 52.184392] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 52.191291] ###################WARNING:set voltage is error!voltage set is 1300000 mv -110
[ 52.199409] DVFS ERR: dvfs_regulator_set_voltage_readback: now read back to check voltage
[ 52.396960] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 52.410716] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 52.417616] DVFS ERR: dvfs_regulator_set_voltage_readback: set ERROR AND NOT effected, volt=937500
[ 52.426569] DVFS ERR: dvfs_scale_volt_direct: vd_arm set voltage up err ret = -110, Vnew = 1300000(was 937500)mV
[ 75.442217] ------------[ cut here ]------------
[ 75.446763] WARNING: at kernel/watchdog.c:259 watchdog_check_hardlockup_other_cpu+0xd0/0xf8()
[ 75.455138] Watchdog detected hard LOCKUP on cpu 0
[ 75.459672] Modules linked in: mali_kbase drmboot(PO)
[ 75.464854] CPU: 3 PID: 0 Comm: swapper/3 Tainted: P O 3.10.0 #49
[ 75.471702] [<c0013e04>] (unwind_backtrace+0x0/0xe0) from [<c0011720>] (show_stack+0x10/0x14)
[ 75.480084] [<c0011720>] (show_stack+0x10/0x14) from [<c002d648>] (warn_slowpath_common+0x4c/0x68)
[ 75.488891] [<c002d648>] (warn_slowpath_common+0x4c/0x68) from [<c002d6e4>] (warn_slowpath_fmt+0x2c/0x3c)
[ 75.498296] [<c002d6e4>] (warn_slowpath_fmt+0x2c/0x3c) from [<c00937d4>] (watchdog_check_hardlockup_other_cpu+0xd0/0xf8)
[ 75.508979] [<c00937d4>] (watchdog_check_hardlockup_other_cpu+0xd0/0xf8) from [<c0093834>] (watchdog_timer_fn+0x38/0x168)
[ 75.519748] [<c0093834>] (watchdog_timer_fn+0x38/0x168) from [<c004fc2c>] (__run_hrtimer+0x1a4/0x2b8)
[ 75.528809] [<c004fc2c>] (__run_hrtimer+0x1a4/0x2b8) from [<c0050818>] (hrtimer_interrupt+0x11c/0x278)
[ 75.537956] [<c0050818>] (hrtimer_interrupt+0x11c/0x278) from [<c0517f10>] (arch_timer_handler_phys+0x28/0x30)
[ 75.547785] [<c0517f10>] (arch_timer_handler_phys+0x28/0x30) from [<c00971a8>] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 75.558041] [<c00971a8>] (handle_percpu_devid_irq+0xf8/0x1b4) from [<c0093ddc>] (generic_handle_irq+0x20/0x30)
[ 75.567870] [<c0093ddc>] (generic_handle_irq+0x20/0x30) from [<c000e3ac>] (handle_IRQ+0x64/0x8c)
[ 75.576504] [<c000e3ac>] (handle_IRQ+0x64/0x8c) from [<c0008538>] (gic_handle_irq+0x34/0x58)
[ 75.584797] [<c0008538>] (gic_handle_irq+0x34/0x58) from [<c000d600>] (__irq_svc+0x40/0x70)
[ 75.593001] Exception stack(0xee0bdf30 to 0xee0bdf78)
[ 75.597965] df20: ee0bdf78 0000004b b9b39e6e 00000011
[ 75.606000] df40: c1ed9318 00000000 b91b8612 00000011 c0ce0e80 ee0bc000 c0ce0e90 00000000
[ 75.614034] df60: 1024259a ee0bdf78 c006ff14 c04fcf80 60070013 ffffffff
[ 75.620538] [<c000d600>] (__irq_svc+0x40/0x70) from [<c04fcf80>] (cpuidle_enter_state+0x54/0xec)
[ 75.629174] [<c04fcf80>] (cpuidle_enter_state+0x54/0xec) from [<c04fd184>] (cpuidle_idle_call+0x16c/0x27c)
[ 75.638662] [<c04fd184>] (cpuidle_idle_call+0x16c/0x27c) from [<c000e730>] (arch_cpu_idle+0x8/0x38)
[ 75.647553] [<c000e730>] (arch_cpu_idle+0x8/0x38) from [<c006f2f4>] (cpu_idle_loop+0x1b8/0x224)
[ 75.656104] [<c006f2f4>] (cpu_idle_loop+0x1b8/0x224) from [<c006f36c>] (freezing_slow_path+0x0/0x64)
[ 75.665075] ---[ end trace bb98ec6129aa180c ]---
[ 75.865362] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 75.879120] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 75.886024] DVFS WARNING: dvfs_reset_volt:vd(vd_arm) try to reload volt = 937500
[ 76.081835] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 76.095592] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 76.298321] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 76.312078] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 76.318978] ###################WARNING:set voltage is error!voltage set is 1300000 mv -110
[ 76.327097] DVFS ERR: dvfs_regulator_set_voltage_readback: now read back to check voltage
[ 76.524644] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 76.538401] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 76.545300] DVFS ERR: dvfs_regulator_set_voltage_readback: set ERROR AND NOT effected, volt=937500
[ 76.554253] DVFS ERR: dvfs_scale_volt_direct: vd_arm set voltage up err ret = -110, Vnew = 1300000(was 937500)mV
