MINIROOT instruction, right or wrong
Can anyone confirm if building “rootfs” by using “miniroot” which Firefly “Build Ubuntu rfs” offers is correct or not?
Here is the instruction: http://wiki.t-firefly.com/index.php/Firefly-RK3288/Build_Ubuntu_rfs/en
I believe it is not right as it refers to /dev/mmcblk0p1 as TF Card to install the OS, however, the /dev/mmcblk0p1 is not the TF in RK3288 and dev/mmcblk1p1 is…
Documentation and WIKI are not so clear, Why Firefly ???
SAP인증 C_BCBTM_2509시험은 중요한 IT인증자격증을 취득하는 필수시험과목입니다SAP인증 C_BCBTM_2509시험을 통과해야만 자격증 취득이 가능합니다.자격증을 많이 취득하면 자신의 경쟁율을 높여 다른능력자에 의해 대체되는 일은 면할수 있습니다.KoreaDumps에서는SAP 인증C_BCBTM_2509시험대비덤프를 출시하여 여러분이 IT업계에서 더 높은 자리에 오르도록 도움드립니다. 편한 덤프공부로 멋진 IT전문가의 꿈을 이루세요.
Thank you for your article; it is truly outstanding! The SAFe-SPC reliable braindumps book test helped me secure my promotion and raise—grab it for free today!
I’m in awe of your article, thank you so much for sharing! This is the XK0-005 new test cram sheet file exam that led to my promotion and salary increase, and it’s free today for all. Best of luck on your career path!
Your article was very memorable, thank you for sharing it. The Reliable GH-100 test dumps test questions are free for all—your key to a successful career!
