TFTP support in uboot for rk3288
Hi,
Can someone point me to the link for bootloader source code that has TFTP enabled. I have tried building code from http://git.denx.de/?p=u-boot/u-boot-rockchip.git;a=summary and looks like it does not generated RK3288UbootLoader_V2.19.01.bin and upgrade_tool fails flashing u-boot.bin
I could boot the board using SDcard with these images and has tftp support . But I would like to understand how to flash this bootloader to eMMC.
Tried generating RK3288UbootLoader_V2.19.01.bin from u-boot.bin using rktools but that did not help, meaning boot does not boot to uboot.
Thanks
U-Boot source code for Firefly
https://bitbucket.org/T-Firefly/firenow-lollipop/src/366906861e6a9f6be29b5570dcb2d160b2e17930/u-boot/?at=fireprime
Use ‘make rk3288_box_defconfig’
https://bitbucket.org/T-Firefly/firenow-lollipop/src/366906861e6a9f6be29b5570dcb2d160b2e17930/u-boot/configs/rk3288_box_defconfig?at=fireprime&fileviewer=file-view-default
Then a normal ‘make’
I can’t remember all the steps.
Hi Dewet,
Could you please confirm if this uboot has GMAC support ? I mean to say does it has Ethernet support enabled?
Thanks
banavathvishnu Posted at 4/27/2016 19:36
Hi Dewet,
Could you please confirm if this uboot has GMAC support ? I mean to say does it has Ether …
Gigabit Ethernet support comes from the driver in the kernel as far as I know.
You can also follow all the posts here, a user got 4.6 Linux kernel running with Slackware Linux on Firefly, maybe there are also different u-boot source code to make it boot?
http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=345&extra=page%3D1
yeah you are right GbE driver is in kernel. But the point I’m trying to make here is - does rockchip bootloader supports Ethernet on firefly-rk3288 ?
I would need this board support in boot loader because, I want to download kernel Image via TFTP on the board. This will enabled me the test different kernel with a line change (change in symlink) which is much much better than flashing each image at a single time. This will help folks working remotely and want to change kernel.
Thanks
Thank you for your article, it was incredibly enlightening. Sharing the New C_ABAPD_2507 study notes materials for free—wishing you good luck!
Fast2test hat vielen IT-Zertifizierungskandidaten geholfen. Und Fast2test bekommt gute Bewertung von den Kandidaten. Die Erfolgsquote von Fast2test Prüfungsfragen erreicht 100%, was auch die Tatsache von vielen Kadidaten geprüft werden. Wenn Sie sich sehr müde für die Vorbereitung der Pegasystems PEGACPBA24V1 Zertifizierungsprüfung fühlen, können Sie die PEGACPBA24V1 Prüfungsunterlagen nicht ignorieren. Das ist ein Werkzeug für die hocheffektive Vorbereitung der Pegasystems PEGACPBA24V1 Prüfung. Es kann Ihre Effektivität am größten Teil erhöhen.
The article is absolutely magnificent, thank you for sharing it with us. The SecOps-Generalist exam material content is amazing, and it’s available to you without charge.
PK0-005J学習教材は、CompTIA専門資格試験に100%合格することを保証します。 JpexamのPK0-005Jガイドトレントの品質に自信を持っています。 PK0-005Jトレーニングブレインダンプの合格率は98%から100%です。 PK0-005J練習問題に完全に頼ることができます。 優れた品質を確認するためのPK0-005J学習準備の無料デモがあります。 PK0-005J試験問題を無料でダウンロードする限り、問題に満足し、CompTIA Project+ Certification Exam (PK0-005日本語版)試験に簡単に合格します。
This is a wonderfully inspiring article, thank you for sharing! Boost your IT knowledge with free NS0-005 test cost. Wishing you all the best in your studies!
