开发板+官网4.4.2镜像 WIFI连接不上
开发版烧写了官网的Firefly-RK3288_Android4.4_201512031748.7z镜像,wifi一直连接不上,系统一直显示在获取IP地址,确认路由器没有问题,请版主帮忙分析下啊
119.857053] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 119.871423] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 119.878572] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 119.878696] cfg80211: Calling CRDA to update world regulatory domain
[ 123.843114] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 123.883071] wl_notify_connect_status nothing
[ 123.887415] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 124.129706] dhd_pno_get_for_batch : wifi location service is not supported
[ 124.136527] ANDROID-ERROR) failed to getting batching results
[ 124.142799] dhd_pno_stop_for_batch : wifi location service is not supported
[ 124.149644] ANDROID-ERROR) failed to stop batching scan
[ 154.330741] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 154.344808] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 154.351790] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 154.352108] cfg80211: Calling CRDA for country: CN
[ 157.712181] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 157.811271] wl_notify_connect_status nothing
[ 157.815620] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 157.910173] dhd_pno_get_for_batch : wifi location service is not supported
[ 157.916966] ANDROID-ERROR) failed to getting batching results
[ 157.923220] dhd_pno_stop_for_batch : wifi location service is not supported
[ 157.930110] ANDROID-ERROR) failed to stop batching scan
[ 188.110463] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 188.124405] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 188.130469] cfg80211: Calling CRDA to update world regulatory domain
[ 188.137915] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 191.487944] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 191.512507] wl_notify_connect_status nothing
[ 191.516729] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 191.683502] dhd_pno_get_for_batch : wifi location service is not supported
[ 191.690303] ANDROID-ERROR) failed to getting batching results
[ 191.696650] dhd_pno_stop_for_batch : wifi location service is not supported
[ 191.703493] ANDROID-ERROR) failed to stop batching scan
[ 221.886539] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 221.899835] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 221.904098] cfg80211: Calling CRDA for country: CN
[ 221.904180] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 225.271579] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 225.330834] wl_notify_connect_status nothing
[ 225.335052] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 225.468232] dhd_pno_get_for_batch : wifi location service is not supported
[ 225.475061] ANDROID-ERROR) failed to getting batching results
[ 225.481573] dhd_pno_stop_for_batch : wifi location service is not supported
[ 225.488487] ANDROID-ERROR) failed to stop batching scan
[ 255.669883] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 255.684127] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 255.691027] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 255.691297] cfg80211: Calling CRDA to update world regulatory domain
[ 259.011795] connect failed event=0 e->status 1 e->reason 0
[ 259.018307] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 262.366911] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 262.375790] wl_notify_connect_status nothing
[ 262.380011] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 262.563707] dhd_pno_get_for_batch : wifi location service is not supported
[ 262.570496] ANDROID-ERROR) failed to getting batching results
[ 262.577256] dhd_pno_stop_for_batch : wifi location service is not supported
[ 262.584150] ANDROID-ERROR) failed to stop batching scan
串口还一直打印这个信息
73.382053] audit_printk_skb: 15 callbacks suppressed
[ 73.387076] type=1400 audit(1452762462.040:186): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“145” dev=“proc” ino=2175 scontext=u:r:untrusted_app:s0 tcontext=u:r:installd:s0 tclass=dir permissive=1
[ 73.406842] type=1400 audit(1452762462.060:187): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“146” dev=“proc” ino=2183 scontext=u:r:untrusted_app:s0 tcontext=u:r:keystore:s0 tclass=dir permissive=1
[ 77.321128] type=1400 audit(1452762466.040:188): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8797 scontext=u:r:untrusted_app:s0 tcontext=u:r:servicemanager:s0 tclass=file permissive=1
[ 77.342590] type=1400 audit(1452762466.060:189): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/135/cmdline” dev=“proc” ino=8797 scontext=u:r:untrusted_app:s0 tcontext=u:r:servicemanager:s0 tclass=file permissive=1
[ 77.365344] type=1400 audit(1452762466.090:190): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/135/cmdline” dev=“proc” ino=8797 scontext=u:r:untrusted_app:s0 tcontext=u:r:servicemanager:s0 tclass=file permissive=1
[ 77.386404] type=1400 audit(1452762466.110:191): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8799 scontext=u:r:untrusted_app:s0 tcontext=u:r:vold:s0 tclass=file permissive=1
[ 77.405319] type=1400 audit(1452762466.130:192): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/136/cmdline” dev=“proc” ino=8799 scontext=u:r:untrusted_app:s0 tcontext=u:r:vold:s0 tclass=file permissive=1
官方固件的完整log发出来看
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Memory OK
U-Boot 2014.10-RK3288-02 (Nov 13 2015 - 10:22:31)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
Adding bank:0000000000000000(0000000040000000)
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
pmic:act8846
Enter power_led_init
#Boot ver: 2015-11-13#2.17
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
kernel @ 0x02000000 (0x00600090)
ramdisk @ 0x04bf0000 (0x00121021)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0480c000, end 048271a4 … OK
Add bank:0000000000000000, 0000000040000000
[ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #94 SMP PREEMPT Thu Dec 3 17:45:30 CST 2015
[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c16c2000 s14016 r8192 d14656 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260624
[ 0.000000] Kernel command line: console=ttyS2 earlyprintk androidboot.hardware=rk30board androidboot.console=ttyS2 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2015-11-13_10:22:31 hdmi.vic=-1
[ 0.000000] Memory: 1024MB = 1024MB total
[ 0.000000] Memory: 1006648k/1006648k available, 41928k reserved, 270336K highmem
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a8418c (10737 kB)
[ 0.000000] .init : 0xc0a85000 - 0xc0cd46c0 (2366 kB)
[ 0.000000] .data : 0xc0cd6000 - 0xc0d73288 ( 629 kB)
[ 0.000000] .bss : 0xc0d73288 - 0xc0e8e004 (1132 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rkclk_init_clks: cnt_rate = 32
[ 0.000000] Architected local timer running at 24.00MHz (phys).
[ 0.000000] process version: 1
[ 0.000000] channel:0, lkg:36
[ 0.000000] target-temp:95
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:27
[ 0.284354] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.284408] pid_max: default: 32768 minimum: 301
[ 0.284747] Security Framework initialized
[ 0.284792] SELinux: Initializing.
[ 0.285026] Mount-cache hash table entries: 512
[ 0.287076] Initializing cgroup subsys debug
[ 0.287120] Initializing cgroup subsys freezer
[ 0.287210] CPU: Testing write buffer coherency: ok
[ 0.287977] /cpus/cpu@0 missing clock-frequency property
[ 0.288021] /cpus/cpu@1 missing clock-frequency property
[ 0.288054] /cpus/cpu@2 missing clock-frequency property
[ 0.288087] /cpus/cpu@3 missing clock-frequency property
[ 0.288211] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.288327] Setting up static identity map for 0xc0795258 - 0xc07952b0
[ 0.293366] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x14bb (version 3.0)
[ 0.372257] CPU1: Booted secondary processor
[ 0.372347] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.391971] CPU2: Booted secondary processor
[ 0.392054] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.411765] CPU3: Booted secondary processor
[ 0.411846] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.412211] Brought up 4 CPUs
[ 0.412309] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.412340] CPU: All CPU(s) started in SVC mode.
[ 0.414574] devtmpfs: initialized
[ 0.432295] pinctrl core: initialized pinctrl subsystem
[ 0.433045] regulator-dummy: no parameters
[ 0.434692] NET: Registered protocol family 16
[ 0.439961] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.440895] ion_snapshot: 0x2e230000 map to 0xf0107000 and copy to 0xc0e69654 (version 0.1)
[ 0.441440] Registered FIQ tty driver
[ 0.442398] fiq-debugger is disabled in device tree
[ 0.444217] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.444293] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.444354] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.444413] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.444663] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.444877] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.445086] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.445295] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.445502] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.445707] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.445913] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.446122] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.446343] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.446559] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.446607] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.446648] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.446689] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.448428] rockchip_interrupts_register:bank_num=7
[ 0.455161] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.455235] of_get_gpio_init_config:gpio[1] = 233, value = 0
[ 0.455308] of_get_gpio_init_config:gpio[2] = 136, value = 0
[ 0.455479] rockchip_pinctrl_probe:init ok
[ 0.475729] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.476098] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.476143] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.476685] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.477007] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.477051] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.477579] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.477897] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.477941] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.478515] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.478833] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.478877] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.479435] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.479809] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.479851] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.480410] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.480725] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.480766] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.481378] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.481756] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.481798] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.487406] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.487448] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.488041] DDR DEBUG: version 1.00 20140603
[ 0.488119] DDR DEBUG: Channel a:
[ 0.488149] DDR DEBUG: DDR3 Device
[ 0.488192] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.488225] DDR DEBUG: addr=0xd79000
[ 0.488259] DDR DEBUG: dtar[0]=0x101af000, dtar[1]=0xc0267e88
[ 0.488382] DDR DEBUG: init success!!! freq=200MHz
[ 0.488409] DDR DEBUG: Channel a:
[ 0.488452] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.488496] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.488539] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.488581] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.488619] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.488650] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.488679] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.564590] bio: create slab at 0
[ 0.566313] Enter firefly_noatx8_init
[ 0.566764] firefly_noatx8_probe 51
[ 0.567508] SCSI subsystem initialized
[ 0.567998] usbcore: registered new interface driver usbfs
[ 0.568141] usbcore: registered new interface driver hub
[ 0.568409] usbcore: registered new device driver usb
[ 0.572830] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.577262] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.578673] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.580156] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.580965] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.583670] media: Linux media interface: v0.10
[ 0.583815] Linux video capture interface: v2.00
[ 0.583973] pps_core: LinuxPPS API ver. 1 registered
[ 0.584008] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.584074] PTP clock support registered
[ 0.584485] rockchip_temp_probe,line=362
[ 0.585204] tsadc ff280000.tsadc: initialized
[ 0.586421] rockchip_ion_parse_dt: num_heaps = 1
[ 0.586472] 0: 0 3 vmalloc 0x (null)
[ 0.587244] Rockchip ion module is successfully loaded (v1.0)
[ 0.587768] Advanced Linux Sound Architecture Driver Initialized.
[ 0.588914] Bluetooth: Core ver 2.16
[ 0.589030] NET: Registered protocol family 31
[ 0.589064] Bluetooth: HCI device and connection manager initialized
[ 0.589125] Bluetooth: HCI socket layer initialized
[ 0.589169] Bluetooth: L2CAP socket layer initialized
[ 0.589265] Bluetooth: SCO socket layer initialized
[ 0.590010] cfg80211: Calling CRDA to update world regulatory domain
[ 0.592231] act8846_i2c_probe,line=898
[ 0.593614] act8846_parse_dt,line=746
[ 0.595147] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.595206] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.595253] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.595300] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.597774] act_dcdc1: 1200 mV
[ 0.601748] vccio: 3300 mV
[ 0.604369] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.608140] act_dcdc4: 2000 mV
[ 0.610007] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.612882] act_ldo2: 1050 mV
[ 0.615724] act_ldo3: 2800 mV
[ 0.618581] act_ldo4: 3300 mV
[ 0.621460] act_ldo5: 3300 mV
[ 0.624366] act_ldo6: 1100 mV
[ 0.627240] vcc_18: 1800 mV
[ 0.630328] act_ldo8: 1850 mV
[ 0.636824] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.643216] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.644152] rk808_i2c_probe,line=1368
[ 0.645841] The device is not rk808 -11
[ 0.646100] rk808: probe of 0-001b failed with error -11
[ 0.648570] i2s: maxburst: 1
[ 0.650573] Switching to clocksource arch_sys_counter
[ 0.717180] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.717238] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.718332] rk-screen rk_screen.8: rockchip screen probe success
[ 0.719087] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.719854] rk32-edp ff970000.edp: screen is not edp!
[ 0.719922] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.721074] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.721838] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.722970] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.723504] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.724034] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.724570] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.726236] rk_iommu ff930300.vopb_mmu: (vopb) Enabled
[ 0.726655] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 0.726719] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.831711] alloc_buffer:ion_phy_addr=0x10000000
[ 0.875058] fb0:phy:10000000>>vir:f0191000>>len:0x1800000
[ 0.985975] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.987073] rockchip_set_mux:warning ignore bank num 15
[ 0.987471] rockchip_set_mux:warning ignore bank num 15
[ 0.987911] rockchip_set_mux:warning ignore bank num 15
[ 0.988299] rockchip_set_mux:warning ignore bank num 15
[ 0.988670] rockchip_set_mux:warning ignore bank num 15
[ 0.989039] rockchip_set_mux:warning ignore bank num 15
[ 0.989928] rockchip_set_mux:warning ignore bank num 15
[ 0.990406] rockchip_set_mux:warning ignore bank num 15
[ 0.991262] rockchip_set_mux:warning ignore bank num 15
[ 0.991751] rockchip_set_mux:warning ignore bank num 15
[ 0.992619] rockchip_set_mux:warning ignore bank num 15
[ 0.993107] rockchip_set_mux:warning ignore bank num 15
[ 0.993928] rockchip_set_mux:warning ignore bank num 15
[ 0.994435] rockchip_set_mux:warning ignore bank num 15
[ 0.998730] NET: Registered protocol family 2
[ 1.000207] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.000682] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.001168] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.001315] TCP: reno registered
[ 1.001362] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.001482] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.002122] NET: Registered protocol family 1
[ 1.002667] Unpacking initramfs…
[ 1.225206] Freeing initrd memory: 1156K (c4bf0000 - c4d11000)
[ 1.227028] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.228428] probe device ff9a0000.vpu_service
[ 1.228880] vpu_service: power on
[ 1.230030] checking hw id 4831
[ 1.231115] vpu_service set to auto frequency mode
[ 1.231347] vcodec vpu_service: vcodec ion client create success!
[ 1.232403] vpu_service: power off…
[ 1.232488] done
[ 1.232514] init success
[ 1.232669] probe device ff9c0000.hevc_service
[ 1.233256] hevc_service: power on
[ 1.234368] checking hw id 6867
[ 1.235264] vcodec hevc_service: vcodec ion client create success!
[ 1.236121] hevc_service: power off…
[ 1.236204] done
[ 1.236231] init success
[ 1.236578] rknandbase v1.0 2014-03-31
[ 1.237192] rknand_probe clk rate = 148500000
[ 1.237558] rknand_driver:ret = 0
[ 1.238661] audit: initializing netlink socket (disabled)
[ 1.238766] type=2000 audit(0.960:1): initialized
[ 1.240841] bounce pool size: 64 pages
[ 1.256447] fuse init (API version 7.22)
[ 1.257684] msgmni has been set to 1472
[ 1.263809] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.263856] io scheduler noop registered
[ 1.263889] io scheduler deadline registered
[ 1.264226] io scheduler cfq registered (default)
[ 1.266436] rga ff920000.rga: rga ion client create success!
[ 1.266846] rga: Driver loaded succesfully
[ 1.268214] IEP Power ON
[ 1.268325] iep ion client create success!
[ 1.269276] rk_iommu ff900800.iep_mmu: (iep) Enabled
[ 1.269355] IEP Power OFF
[ 1.269397] rk_iommu ff900800.iep_mmu: (iep) Disabled
[ 1.269440] rk_iommu ff900800.iep_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e244000
[ 1.269486] IEP Driver loaded succesfully
[ 1.269760] Module initialized.
[ 1.272244] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.272303] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.276651] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.276710] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.277440] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 1.277488] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 1.277517] pwm_regulator_probe:error
[ 1.277583] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 1.278652] rk_serial.c v1.8 2014-03-04
[ 1.279333] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.279962] serial ff180000.serial: membase f0172000
[ 1.280394] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 1.280513] 2, baud is:115200
[ 2.863883] console [ttyS2] enabled
[ 2.867935] serial ff690000.serial: membase fed60000
[ 2.882698] loop: module loaded
[ 2.887614] SCSI Media Changer driver v0.25
[ 2.892776] tun: Universal TUN/TAP device driver, 1.6
[ 2.897855] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.905565] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 2.912276] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 2.919293] stmmac_probe_config_dt: clock input or output? (input).
[ 2.925520] stmmac_probe_config_dt: TX delay(0x30).
[ 2.930344] stmmac_probe_config_dt: RX delay(0x20).
[ 2.935283] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 2.940616] stmmc_pltfr_init:
[ 2.943858] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 2.949400] stmmc_pltfr_init: ERROR: Request gmac phy reset pin failed.
[ 2.955952] stmmc_pltfr_init: init for RGMII
[ 2.960178] tx delay=0x30
[ 2.960178] rx delay=0x20
[ 2.966746] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 2.971738] Normal descriptors
[ 2.974890] Ring mode enabled
[ 2.977918] DMA HW capability register supported
[ 2.982397] RX Checksum Offload Engine supported (type 2)
[ 2.988033] TX Checksum insertion supported
[ 2.992251] Wake-Up On Lan supported
[ 2.995987] Enable RX Mitigation via HW Watchdog Timer
[ 3.002398] PPP generic driver version 2.4.2
[ 3.007153] PPP BSD Compression module registered
[ 3.011810] PPP Deflate Compression module registered
[ 3.016876] PPP MPPE Compression module registered
[ 3.021618] NET: Registered protocol family 24
[ 3.026109] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 3.035659] CSLIP: code copyright 1989 Regents of the University of California.
[ 3.042901] Rockchip WiFi SYS interface (V1.00) …
[ 3.048008] usbcore: registered new interface driver catc
[ 3.053494] usbcore: registered new interface driver kaweth
[ 3.059002] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 3.066430] usbcore: registered new interface driver pegasus
[ 3.072146] usbcore: registered new interface driver rtl8150
[ 3.077822] usbcore: registered new interface driver r8152
[ 3.083276] hso: drivers/net/usb/hso.c: Option Wireless
[ 3.088618] usbcore: registered new interface driver hso
[ 3.094027] usbcore: registered new interface driver asix
[ 3.099463] usbcore: registered new interface driver ax88179_178a
[ 3.105616] usbcore: registered new interface driver cdc_ether
[ 3.111511] usbcore: registered new interface driver cdc_eem
[ 3.117185] usbcore: registered new interface driver dm9601
[ 3.122820] usbcore: registered new interface driver dm9620
[ 3.128441] usbcore: registered new interface driver smsc75xx
[ 3.134294] usbcore: registered new interface driver smsc95xx
[ 3.140065] usbcore: registered new interface driver gl620a
[ 3.145706] usbcore: registered new interface driver net1080
[ 3.151455] usbcore: registered new interface driver plusb
[ 3.156970] usbcore: registered new interface driver rndis_host
[ 3.162950] usbcore: registered new interface driver cdc_subset
[ 3.168882] usbcore: registered new interface driver zaurus
[ 3.174525] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 3.182018] usbcore: registered new interface driver int51x1
[ 3.187703] usbcore: registered new interface driver kalmia
[ 3.193346] usbcore: registered new interface driver ipheth
[ 3.198959] usbcore: registered new interface driver sierra_net
[ 3.204943] usbcore: registered new interface driver cx82310_eth
[ 3.211036] usbcore: registered new interface driver cdc_ncm
[ 3.216732] usbcore: registered new interface driver qmi_wwan
[ 3.222550] usbcore: registered new interface driver cdc_mbim
[ 3.228228] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.237966] EHCI: ehci_rk_probe f1a00000 f1a00010
[ 3.242692] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 3.248892] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 3.258071] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 3.278066] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 3.284785] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.291548] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.298717] usb usb1: Product: EHCI Host Controller
[ 3.303546] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 3.308917] usb usb1: SerialNumber: ff500000.usb
[ 3.314808] hub 1-0:1.0: USB hub found
[ 3.318633] hub 1-0:1.0: 1 port detected
[ 3.323029] EHCI: ehci_rk_probe ok
[ 3.326842] usbcore: registered new interface driver cdc_acm
[ 3.332492] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.340567] usbcore: registered new interface driver usblp
[ 3.346091] usbcore: registered new interface driver cdc_wdm
[ 3.351892] usbcore: registered new interface driver usb-storage
[ 3.357967] usbcore: registered new interface driver ums-alauda
[ 3.363909] usbcore: registered new interface driver ums-cypress
[ 3.369976] usbcore: registered new interface driver ums-datafab
[ 3.375994] usbcore: registered new interface driver ums_eneub6250
[ 3.382239] usbcore: registered new interface driver ums-freecom
[ 3.388303] usbcore: registered new interface driver ums-isd200
[ 3.394234] usbcore: registered new interface driver ums-jumpshot
[ 3.400379] usbcore: registered new interface driver ums-karma
[ 3.406297] usbcore: registered new interface driver ums-onetouch
[ 3.412405] usbcore: registered new interface driver ums-sddr09
[ 3.418519] usbcore: registered new interface driver ums-sddr55
[ 3.424477] usbcore: registered new interface driver ums-usbat
[ 3.430552] usbcore: registered new interface driver usbserial
[ 3.436468] usbcore: registered new interface driver usbserial_generic
[ 3.442983] usbserial: USB Serial support registered for generic
[ 3.449055] usbcore: registered new interface driver option
[ 3.454629] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.461736] usbcore: registered new interface driver trancevibrator
[ 3.467966] usb20_otg: version 3.10a 21-DEC-2012
[ 3.473654] f1a80040
[ 3.475892] Core Release: 3.10a
[ 3.479011] Setting default values for core params
[ 3.484077] Using Buffer DMA mode
[ 3.487408] Periodic Transfer Interrupt Enhancement - disabled
[ 3.493168] Multiprocessor Interrupt Enhancement - disabled
[ 3.498702] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.503010] ^^^^^^^^^^^^^^^^^Device Mode
[ 3.506929] Dedicated Tx FIFOs mode
[ 3.510408] pcd_init otg_dev = ed910040
[ 3.514690] usb20_otg ff580000.usb: DWC OTG Controller
[ 3.519823] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 3.527312] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 3.533129] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.539889] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.547057] usb usb2: Product: DWC OTG Controller
[ 3.551714] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.557338] usb usb2: SerialNumber: ff580000.usb
[ 3.563201] hub 2-0:1.0: USB hub found
[ 3.567010] hub 2-0:1.0: 1 port detected
[ 3.571903] usb20_host: version 3.10a 21-DEC-2012
[ 3.580097] f1b00040
[ 3.582283] Core Release: 3.10a
[ 3.585452] Setting default values for core params
[ 3.590514] Using Buffer DMA mode
[ 3.593850] Periodic Transfer Interrupt Enhancement - disabled
[ 3.599610] Multiprocessor Interrupt Enhancement - disabled
[ 3.605145] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.609452] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.613320] usb20_host ff540000.usb: DWC OTG Controller
[ 3.618532] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 3.626096] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 3.631979] Init: Power Port (0)
[ 3.635374] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.642130] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.649265] usb usb3: Product: DWC OTG Controller
[ 3.653962] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.659549] usb usb3: SerialNumber: ff540000.usb
[ 3.665559] hub 3-0:1.0: USB hub found
[ 3.669321] hub 3-0:1.0: 1 port detected
[ 3.675233] .. rk pwm remotectl v1.0 init
[ 3.679420] remotectl probe j=0x0
[ 3.683270] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 3.690169] pwm enable val=0x646205
[ 3.694555] usbcore: registered new interface driver xpad
[ 3.700030] usbcore: registered new interface driver usb_acecad
[ 3.706047] usbcore: registered new interface driver aiptek
[ 3.711716] usbcore: registered new interface driver gtco
[ 3.717161] usbcore: registered new interface driver hanwang
[ 3.722906] usbcore: registered new interface driver kbtab
[ 3.728454] usbcore: registered new interface driver wacom
[ 3.734945] sensor_register_slave:mma8452,id=17
[ 3.739436] sensor_register_slave:cm3217,id=44
[ 3.743882] sensor_register_slave:cm3218,id=45
[ 3.748273] tchip_rm_init is here!
[ 3.753154] input: tchip_remote_key as /devices/virtual/input/input1
[ 3.759778] tchiprm_register_device is here!
[ 3.764448] input: tchip_remote_touch as /devices/virtual/input/input2
[ 3.771433] tchip_remote_abs_register_device is here!
[ 3.776784] input: tchip_remote_gsensor as /devices/virtual/input/input3
[ 3.783798] tchip_remote_gsensor_register_device is here!
[ 3.796233] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 3.802822] i2c /dev entries driver
[ 3.808579] IR NEC protocol handler initialized
[ 3.813125] IR RC5(x) protocol handler initialized
[ 3.817862] IR RC6 protocol handler initialized
[ 3.822367] IR JVC protocol handler initialized
[ 3.826844] IR Sony protocol handler initialized
[ 3.831437] IR RC5 (streamzap) protocol handler initialized
[ 3.836937] IR SANYO protocol handler initialized
[ 3.841613] IR MCE Keyboard/mouse protocol handler initialized
[ 3.847595] usbcore: registered new interface driver uvcvideo
[ 3.853315] USB Video Class driver (1.1.1)
[ 3.857379] CamSys driver version: v0.19.0, CamSys head file version: v0.8.0
[ 3.867585] D1:camsys_platform_probe(1061): 1-gpios-cifpower: gpio=236
[ 3.874126] D1:camsys_platform_probe(1064): gpios-cifpower: gpio_request
[ 3.880796] D1:camsys_platform_probe(1066): 1-gpios-cifpower: gpio_request=0
[ 3.887771] D1:camsys_platform_probe(1075): gpios-cifpower: 236 high
[ 3.894251] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 3.905414] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf19b0000 size: 0x4000)
[ 3.919658] D1:camsys_platform_probe(1208): ff910000.isp memory:
[ 3.925607] D1:camsys_platform_probe(1218): Register memory (phy: 0xff910000 vir: 0xf19e0000 size: 0x10000)
[ 3.935608] D1:camsys_platform_probe(1213): I2c memory (phy: 0x2d9f8000 vir: 0xed9f8000 size: 0x1000)
[ 3.945077] D1:camsys_platform_probe(1233): Probe ff910000.isp device success
[ 3.955165] device-mapper: uevent: version 1.0.3
[ 3.960515] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 3.969759] Bluetooth: HCI UART driver ver 2.2
[ 3.974165] Bluetooth: HCI H4 protocol initialized
[ 3.978951] Bluetooth: HCILL protocol initialized
[ 3.989575] cpufreq version 1.0, suspend freq 1200 MHz
[ 3.995227] cpuidle: using governor ladder
[ 3.999343] cpuidle: using governor menu
[ 4.003315] Synopsys Designware Multimedia Card Interface Driver
[ 4.010158] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 4.017145] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 4.024205] 3291..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 4.030672] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.036552] 1381..dw_mci_set_ios: no card. [mmc0]
[ 4.055361] 1381..dw_mci_set_ios: no card. [mmc0]
[ 4.075074] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 4.075095] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 4.075114] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 4.075783] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 4.105770] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 4.112835] 3285..dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 4.119196] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.125463] 1381..dw_mci_set_ios: no card. [mmc1]
[ 4.141889] mmc0: BKOPS_EN bit is not set
[ 4.145915] 1381..dw_mci_set_ios: no card. [mmc1]
[ 4.147832] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 4.150166] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 4.150189] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 4.165256] rk_sdmmc: BOOT
[ 4.165256] execute tuning: candidates_degree = SDMMC_SHIFT_DEGREE_0 SDMMC_SHIFT_DEGREE_90 SDMMC_SHIFT_DEGREE_180 SDMMC_SHIFT_DEGREE_INVALID[mmc0]
[ 4.165372] mmc0: new HS200 MMC card at address 0001
[ 4.165883] mmcblk0: mmc0:0001 AWMB3R 14.5 GiB
[ 4.166348] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 4.166361] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 4.166372] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 4.166381] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 4.166391] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 4.166400] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 4.166409] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 4.166419] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 4.166428] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 4.166437] system: 0x012400000 – 0x042400000 (768 MB)
[ 4.166447] metadata: 0x042400000 – 0x042800000 (4 MB)
[ 4.166455] userdata: 0x042800000 – 0x082800000 (1024 MB)
[ 4.166465] radical_update: 0x082800000 – 0x086800000 (64 MB)
[ 4.166475] user: 0x086800000 – 0x3a3a00000 (12754 MB)
[ 4.291572] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141381..dw_mci_set_ios: no card. [mmc1]
[ 4.291752] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 4.291766] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 4.292252] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 4.322848] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 4.329861] 3291..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 4.336230] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.342081] 1381..dw_mci_set_ios: no card. [mmc2]
[ 4.360378] 1381..dw_mci_set_ios: no card. [mmc2]
[ 4.380082] 1381..dw_mci_set_ios: no card. [mmc2]
[ 4.380266] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 4.380274] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 4.380544] leds-gpio leds.30: pins are not configured from the driver
[ 4.380781] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.384374] usbcore: registered new interface driver usbhid
[ 4.384387] usbhid: USB HID core driver
[ 4.385108] ashmem: initialized
[ 4.385377] logger: created 256K log ‘log_main’
[ 4.385631] logger: created 256K log ‘log_events’
[ 4.385871] logger: created 256K log ‘log_radio’
[ 4.386126] logger: created 256K log ‘log_system’
[ 4.388231] input: rk29-keypad as /devices/ff100000.adc/key.33/input/input4
[ 4.389527] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ; cannot claim for 2-0010
[ 4.389549] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 4.389567] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 4.389583] ES8323 2-0010: Error applying setting, reverse things back
[ 4.389945] es8323 probe i2c recv ok
[ 4.390451] i2c-core: driver [ES8323] using legacy suspend method
[ 4.390464] i2c-core: driver [ES8323] using legacy resume method
[ 4.391185] rockchip-hdmi-spdif rockchip-hdmi-spdif.26: ASoC: CPU DAI (null) not registered
[ 4.391236] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 4.391268] platform rockchip-hdmi-spdif.26: Driver rockchip-hdmi-spdif requests probe deferral
[ 4.391843] es8323_probe
[ 4.392012] es8323_probe:register ISR (irq=194)
[ 5.030774] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 5.038574] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 5.046466] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 5.054378] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 5.062255] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 5.070655] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 5.078959] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 5.086868] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 5.094883] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 5.102853] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 5.110849] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 5.119328] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 5.127734] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 5.135569] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 5.143240] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 5.150880] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 5.158514] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 5.166899] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 5.175324] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 5.183046] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 5.190788] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 5.198508] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 5.206228] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 5.214728] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 5.223228] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 5.231214] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 5.239201] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 5.247221] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 5.255198] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 5.263167] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 5.271149] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 5.279117] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 5.287129] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 5.294832] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 5.302554] EHCI: rk_ehci_hcd_enable, disable host controller
[ 5.308251] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 5.315960] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 5.323657] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 5.331789] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 5.339919] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 5.347709] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 5.355496] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 5.363274] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 5.371078] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 5.379389] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 5.387846] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 5.393766] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 5.399587] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 5.405421] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 5.411170] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 5.420180] Enter::rk29_es8323_init----135
[ 5.429397] rockchip-es8323 rockchip-es8323.28: ES8323 HiFi ↔ rockchip-i2s.0 mapping ok
[ 5.438181] u32 classifier
[ 5.440842] Actions configured
[ 5.444203] Netfilter messages via NETLINK v0.30.
[ 5.448879] nf_conntrack version 0.5.0 (16002 buckets, 64008 max)
[ 5.455229] ctnetlink v0.93: registering with nfnetlink.
[ 5.460526] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 5.467375] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 5.473395] xt_time: kernel timezone is -0000
[ 5.477880] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.483243] arp_tables: (C) 2002 David S. Miller
[ 5.487816] TCP: cubic registered
[ 5.491073] Initializing XFRM netlink socket
[ 5.495492] NET: Registered protocol family 10
[ 5.500405] mip6: Mobile IPv6
[ 5.503356] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.508778] sit: IPv6 over IPv4 tunneling driver
[ 5.513658] NET: Registered protocol family 17
[ 5.518041] NET: Registered protocol family 15
[ 5.522468] Bridge firewalling registered
[ 5.526413] Ebtables v2.0 registered
[ 5.530115] Bluetooth: RFCOMM TTY layer initialized
[ 5.534953] Bluetooth: RFCOMM socket layer initialized
[ 5.540009] Bluetooth: RFCOMM ver 1.11
[ 5.543707] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.548932] Bluetooth: BNEP filters: protocol multicast
[ 5.554093] Bluetooth: BNEP socket layer initialized
[ 5.558975] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.564808] Bluetooth: HIDP socket layer initialized
[ 5.569707] l2tp_core: L2TP core driver, V2.0
[ 5.574023] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 5.578735] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 5.583571] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 5.588286] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 5.593871] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 5.600886] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 5.609263] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 5.616561] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 5.625556] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 5.634638] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 5.639797] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 5.648140] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 5.652798] dwc_otg_hcd_enable, enable host controller
[ 5.659305] [BT_RFKILL]: Enter rfkill_rk_init
[ 5.663734] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 5.671816] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 5.679786] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 5.687741] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 5.695617] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 5.703882] [BT_RFKILL]: Request irq for bt wakeup host
[ 5.709116] [BT_RFKILL]: ** disable irq
[ 5.712960] [BT_RFKILL]: ap6335 device registered.
[ 5.718371] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
[ 5.724672] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 5.732217] rk3288_init_suspend
[ 5.735306] rk3288_suspend_init enter
[ 5.739038] rk3288_suspend_init: pm_ctrbits =40017
[ 5.743771] gpio_get_dts_info suspend:8
[ 5.747540] gpio_get_dts_info resume:8
[ 5.751228] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 5.759760] rockchip,pmic-resume_gpios:[ 5.761206] Using Buffer DMA mode
[ 5.761210] Periodic Transfer Interrupt Enhancement - disabled
[ 5.761213] Multiprocessor Interrupt Enhancement - disabled
[ 5.761217] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 5.761221] ^^^^^^^^^^^^^^^^^^Host Mode
2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 5.790797] clks_gating_suspend_init:clkgt info ok
[ 5.795584] Registering SWP/SWPB emulation handler
[ 5.800635] ddrfreq: verion 1.2 20140526
[ 5.804599] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 5.806925] Init: Power Port (0)
[ 5.818461] ddrfreq: auto-freq=0
[ 5.821632] ddrfreq: auto-freq-table[0] 240MHz
[ 5.825995] ddrfreq: auto-freq-table[1] 324MHz
[ 5.830364] ddrfreq: auto-freq-table[2] 456MHz
[ 5.834727] ddrfreq: auto-freq-table[3] 528MHz
[ 5.839520] act_ldo3: operation not allowed
[ 5.843860] vga_edid_probe: turn on ldo3 done.
[ 5.848261] act_ldo4: operation not allowed
[ 5.852600] vga_edid_probe: turn on ldo done.
[ 5.856924] act_ldo2: operation not allowed
[ 5.861262] vga_edid_probe: turn on ldo2 done.
[ 5.865642] act_ldo8: operation not allowed
[ 5.869985] vga_edid_probe: turn on ldo done.
[ 5.899393] vga-ddc: read and parse vga edid success.
[ 5.904357] vga-ddc: max mode 1280x1024@60[pixclock-108003 KHZ]
[ 5.910187] vga-ddc: best mode 1280x1024@60[pixclock-9 KHZ]
[ 5.915669] vga_edid_probe: success. 5
[ 5.919536] firefly_vga_get_enable 180, 0
[ 5.923475] firefly_vga_get_status 186
[ 5.927176] firefly_vga_set_enable 159 enable:1
[ 5.931635] firefly_vga_enable 130 start
[ 5.931675] regulator-dummy: disabling
[ 5.931940] rockchip-hdmi-spdif rockchip-hdmi-spdif.26: ASoC: CPU DAI (null) not registered
[ 5.931959] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 5.931969] platform rockchip-hdmi-spdif.26: Driver rockchip-hdmi-spdif requests probe deferral
[ 5.932054] pcd_pullup, is_on 0
[ 5.932087] file system registered
[ 5.932600] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 5.932604] android_usb gadget: Number of LUNs=2
[ 5.932608] lun0: LUN: removable file: (no medium)
[ 5.932611] lun1: LUN: removable file: (no medium)
[ 5.932743] android_usb gadget: android_usb ready
[ 5.932810] sensor_init: Probe name sensors
[ 5.932822] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 6.006585] firefly_switch_fb 55
[ 6.006599] rtc_hym8563 0-0051: setting system clock to 2016-01-14 09:06:33 UTC (1452762393)
[ 6.012019] usbcore: registered new interface driver snd-usb-audio
[ 6.012024] ALSA device list:
[ 6.012027] #0: RK_ES8323
[ 6.030001] 2, baud is:115200
[ 6.030026]
[ 6.030026] rk_fb_switch_screen lcdc_id 0 type 1 enable 1
[ 6.030042] fb0 win id 1 state 1
[ 6.030268] rk3288-lcdc lcdc0: lcdc0: dclk:118800000>>fps:66
[ 6.030300] fb1 win id 0 state 0
[ 6.030308] fb2 win id 2 state 0
[ 6.030315] fb3 win id 3 state 0
[ 6.030322] fb4 win id 4 state 0
[ 6.030330]
[ 6.030330] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 done
[ 6.030330]
[ 6.030382] VGA ENABLE
[ 6.075057] Freeing unused kernel memory: 2364K (c0a85000 - c0cd4000)
[ 6.075467] rockchip-hdmi-spdif rockchip-hdmi-spdif.26: rk-hdmi-spdif-hifi ↔ rockchip-spdif mapping ok
[ 6.098607] SELinux: Permission attach_queue in class tun_socket not defined in policy.
[ 6.106621] SELinux: the above unknown classes and permissions will be denied
[ 6.180812] Indeed it is in host mode hprt0 = 00021501
[ 6.357911] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 6.364564] Indeed it is in host mode hprt0 = 00001101
[ 6.381594] type=1403 audit(1452762393.950:2): policy loaded auid=4294967295 ses=4294967295
[ 6.389928] SELinux: Loaded policy from /sepolicy
[ 6.396381] type=1404 audit(1452762393.960:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 6.564812] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 6.571399] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 6.578433] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 6.583340] hub 3-1:1.0: USB hub found
[ 6.587099] hub 3-1:1.0: 4 ports detected
[ 6.640912] vga-ddc: read and parse vga edid success.
[ 6.645916] vga-ddc: max mode 1280x1024@60[pixclock-108003 KHZ]
[ 6.651759] vga-ddc: best mode 1280x1024@60[pixclock-9 KHZ]
[ 6.657253] VGA Devie connected 5
[ 6.660512] firefly_vga_set_mode 203
[ 6.664047] firefly_vga_set_mode 219 1280 1024 60 108000000
[ 6.669607] firefly_vga_enable 130 start
[ 6.673474] firefly_switch_fb 55
[ 6.676735]
[ 6.676735] rk_fb_switch_screen lcdc_id 0 type 1 enable 1
[ 6.683636] fb0 win id 1 state 1
[ 6.687046] rk3288-lcdc lcdc0: lcdc0: dclk:118800000>>fps:66
[ 6.692764] fb1 win id 0 state 0
[ 6.695938] fb2 win id 2 state 0
[ 6.699110] fb3 win id 3 state 0
[ 6.702295] fb4 win id 4 state 0
[ 6.705468]
[ 6.705468] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 done
[ 6.705468]
[ 6.859852] usb 3-1.1: new low-speed USB device number 3 using usb20_host
[ 6.964943] usb 3-1.1: New USB device found, idVendor=1c4f, idProduct=0002
[ 6.971729] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.978932] usb 3-1.1: Product: USB Keyboard
[ 6.983131] usb 3-1.1: Manufacturer: SIGMACHIP
[ 6.991752] input: SIGMACHIP USB Keyboard as /devices/ff540000.usb/usb3/3-1/3-1.1/3-1.1:1.0/input/input5
[ 7.001293] hid-generic 0003:1C4F:0002.0001: input,hidraw0: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-ff540000.usb-1.1/input0
[ 7.016546] input: SIGMACHIP USB Keyboard as /devices/ff540000.usb/usb3/3-1/3-1.1/3-1.1:1.1/input/input6
[ 7.026114] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-ff540000.usb-1.1/input1
[ 7.115635] usb 3-1.4: new full-speed USB device number 4 using usb20_host
[ 7.217306] usb 3-1.4: New USB device found, idVendor=062a, idProduct=4101
[ 7.224087] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.231300] usb 3-1.4: Product: 2.4G Keyboard Mouse
[ 7.236142] usb 3-1.4: Manufacturer: MOSART Semi.
[ 7.243163] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/ff540000.usb/usb3/3-1/3-1.4/3-1.4:1.0/input/input7
[ 7.253662] hid-generic 0003:062A:4101.0003: input,hidraw2: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-ff540000.usb-1.4/input0
[ 7.270725] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/ff540000.usb/usb3/3-1/3-1.4/3-1.4:1.1/input/input8
[ 7.281277] hid-generic 0003:062A:4101.0004: input,hiddev0,hidraw3: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-ff540000.usb-1.4/input1
[ 7.359626] init: init.rk30board.bootmode.emmc.rc: 8: invalid command ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc’
[ 7.369480] init: init.rk30board.bootmode.emmc.rc: 9: invalid command ‘/devices/ff0c0000.rksdmmc/mmc_host/mmc’
[ 7.379316] init: init.rk30board.bootmode.emmc.rc: 10: invalid command ‘/devices/ff580000.usb’
[ 7.387783] init: init.rk30board.bootmode.emmc.rc: 11: invalid command ‘/devices/ff580000.usb’
[ 7.396250] init: init.rk30board.bootmode.emmc.rc: 12: invalid command ‘/devices/ff500000.usb’
[ 7.405187] init: init.rk30board.bootmode.emmc.rc: 13: invalid command ‘/devices/ff500000.usb’
[ 7.413672] init: init.rk30board.bootmode.emmc.rc: 14: invalid command ‘/devices/ff540000.usb’
[ 7.422144] init: init.rk30board.bootmode.emmc.rc: 15: invalid command ‘/devices/ff540000.usb’
[ 7.430924] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 7.499810] init: /dev/hw_random not found
[ 7.503941] keychord: using input dev ff680000.pwm for fevent
[ 7.509647] keychord: using input dev tchip_remote_key for fevent
[ 7.515680] keychord: using input dev rk29-keypad for fevent
[ 7.521277] keychord: using input dev SIGMACHIP USB Keyboard for fevent
[ 7.527799] keychord: using input dev SIGMACHIP USB Keyboard for fevent
[ 7.534333] keychord: using input dev MOSART Semi. 2.4G Keyboard Mouse for fevent
[ 7.541761] keychord: using input dev MOSART Semi. 2.4G Keyboard Mouse for fevent
[ 7.549333] 2, baud is:115200
[ 7.559032] fs_mgr: parse_link_device : path = NULL
[ 7.563847] fs_mgr: parse_link_device : path = NULL
[ 7.568683] fs_mgr: parse_link_device : path = NULL
[ 7.573491] fs_mgr: parse_link_device : path = NULL
[ 7.578318] fs_mgr: parse_link_device : path = NULL
[ 7.583126] fs_mgr: parse_link_device : path = NULL
[ 7.587952] fs_mgr: parse_link_device : path = NULL
[ 7.592759] fs_mgr: parse_link_device : path = NULL
[ 7.597617] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 7.616586] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs:
[ 7.633093] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 7.660762] EXT4-fs (mmcblk0p8): recovery complete
[ 7.667824] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.678555] EXT4-fs (mmcblk0p11): warning: mounting unchecked fs, running e2fsck is recommended
[ 7.687715] EXT4-fs (mmcblk0p11): mounted filesystem without journal. Opts: noauto_da_alloc,discard
[ 7.805055] EXT4-fs (mmcblk0p12): recovery complete
[ 7.810404] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.828193] drmboot: module license ‘unspecified’ taints kernel.
[ 7.834121] Disabling lock debugging due to kernel taint
[ 7.840157] %s: ok, 20130810
[ 7.848763] mali pd enabled
[ 7.851518] clk enabled
[ 7.853968] MALI_DVFS_STEP=4,div_dvfs=10
[ 7.857824] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 7.864931] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 7.872112] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 7.879305] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 7.886675] turn on mali power
[ 7.889694] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 7.896481] mali ffa30000.gpu: Probed as mali0
[ 7.903320] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 7.925684] init: /dev/hw_random not found
[ 7.939037] init: cannot find ‘/system/vendor/bin/pvrsrvctl’, disabling ‘pvrsrvctl’
[ 7.939115] binder: 134:134 transaction failed 29189, size 0-0
[ 7.955379] init: cannot find ‘/system/bin/rild3’, disabling ‘ril-daemon3’
[ 7.964241] init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recovery’
[ 7.973694] init: cannot find ‘/system/bin/bindvbplayservice’, disabling ‘dvbdataserv’
[ 7.982044] init: cannot find ‘/system/bin/chrome.sh’, disabling ‘chrome’
[ 7.989164] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 7.999434] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 8.007379] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 8.017293] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 8.028932] 0,baud is:9600
[ 8.031777] 2, baud is:115200
[ 8.034868] 2, baud is:115200
[ 8.038142] 0,baud is:9600
[ 8.100938] rk3288-lcdc lcdc0: lcdc0: dclk:118800000>>fps:66
[ 8.101031] rknand_sys_storage_open
[ 8.101040] RKNAND_GET_DRM_KEY
[ 8.101045] return ret = 0
[ 8.151294] fs_mgr: parse_link_device : path = NULL
[ 8.156216] fs_mgr: parse_link_device : path = NULL
[ 8.161101] fs_mgr: parse_link_device : path = NULL
[ 8.165930] fs_mgr: parse_link_device : path = NULL
[ 8.170787] fs_mgr: parse_link_device : path = NULL
[ 8.175617] fs_mgr: parse_link_device : path = NULL
[ 8.180566] fs_mgr: parse_lin_device : path = NULL
[ 8.181634] init: property ‘sys.powerctl’ doesn’t exist while expanding ‘${sys.powerctl}’
[ 8.181645] init: powerctl: cannot expand ‘${sys.powerctl}’
[ 8.181661] init: property ‘sys.sysctl.extra_free_kbytes’ doesn’t exist while expanding ‘${sys.sysctl.extra_free_kbytes}’
[ 8.181668] init: cannot expand ‘${sys.sysctl.extra_free_kbytes}’ while writing to ‘/proc/sys/vm/extra_free_kbytes’
[ 8.182381] firefly_vga_get_enable 180, 1
[ 8.182402] android_usb: already disabled
[ 8.182440] firefly_vga_get_status 186
[ 8.184552] read descriptors
[ 8.184563] read strings
[ 8.184606] pcd_pullup, is_on 1
[ 8.185285] 2, baud is:115200
[ 8.208030] firefly_vga_set_mode 203
[ 8.208087] firefly_vga_set_enable 159 enable:1
[ 8.250739] fs_mgr: parse_link_device : path = NULL
shell@rk3288:/ $ [ 8.975647] rk3288-lcdc lcdc0: blank mode:0
[ 9.071466] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_hal.ver
[ 9.079419] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_trace
[ 9.087237] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_camboard.ver
[ 9.095705] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_libisp.ver
[ 9.103906] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_isi.ver
[ 9.111703] init: sys_prop: permission denied uid:1003 name:sys.gmali.version
[ 9.125313] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.132712] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.140183] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 9.146489] D1:camsys_extdev_register(226): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 9.156516] D1:camsys_extdev_register(226): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 9.166502] D1:camsys_extdev_register(226): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 9.176521] rockchip_gpio_request:GPIO7-13
[ 9.180884] rockchip_gpio_set:GPIO7-13 level = 1
[ 9.185453] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 9.191518] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.198268] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 9.209168] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.215982] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000400,result=0x400
[ 9.222847] _rockchip_pinconf_set:GPIO7-13,group=isp_flash_trigger, function=isp_pin, type=3
[ 9.231144] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10
[ 9.237603] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3
[ 9.243616] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 9.256487] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.264459] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.269442] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.274380] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.283722] D1:camsys_sysctl_extdev(326): Sysctl 11 success, gpio(11) set 1
[ 9.291673] D1:camsys_sysctl_extdev(330): Sysctl 8 success, gpio(79) set 1
[ 9.299502] D1:camsys_sysctl_extdev(330): Sysctl 7 success, gpio(78) set 1
[ 9.309556] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 9.317108] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 9.323509] D1:camsys_sysctl_extdev(326): Sysctl 7 success, gpio(78) set 0
[ 9.330332] D1:camsys_sysctl_extdev(326): Sysctl 8 success, gpio(79) set 0
[ 9.337148] D1:camsys_sysctl_extdev(330): Sysctl 11 success, gpio(11) set 0
[ 9.345124] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.351779] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.360634] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 9.369110] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 9.377362] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.384903] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.392397] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 9.404263] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.411659] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.419027] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 9.425246] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 9.432229] D1:camsys_extdev_register(248): Extdev(dev_id: 0x1000000) register success
[ 9.445095] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.453085] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.458080] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.463001] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.472300] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 9.480642] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 9.488920] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 9.499369] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
[ 9.505706] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 9.513000] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 9.520245] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 9.528671] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.535342] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.544250] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x1000000) is deregister success
[ 9.552691] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 9.561036] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.568512] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.576041] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 9.586200] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.593555] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.600970] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 9.607333] rockchip_gpio_set:GPIO7-13 level = 0
[ 9.611875] rockchip_gpio_direction_output:set GPIO7-13 level 0
[ 9.617730] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.624407] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 9.635282] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.642069] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000400,result=0x400
[ 9.648931] _rockchip_pinconf_set:GPIO7-13,group=isp_flash_trigger, function=isp_pin, type=3
[ 9.657258] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10
[ 9.663677] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3
[ 9.669691] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 9.682561] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.690537] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.695540] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.700460] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.709773] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 9.718127] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 9.726401] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 9.736897] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 9.743290] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 9.750526] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 9.757816] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 9.766242] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.772957] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.781829] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 9.790263] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 9.798566] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.806134] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.813671] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 10.075475] Enter::rk29_hw_params----52
[ 10.080225] Enter:rk29_hw_params, 86, rate=44100
[ 10.083827] warning: `zygote’ uses 32-bit capabilities (legacy support in use)
[ 10.091957] Enter:rk29_hw_params, 104, LRCK=64
[ 10.322713] Enter::rk29_hw_params----52
[ 10.327558] Enter:rk29_hw_params, 86, rate=44100
[ 10.332157] Enter:rk29_hw_params, 104, LRCK=64
[ 11.405840] [otg id chg] last id -1 current id 1
[ 11.410425] PortPower off
[ 11.413013] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 11.518808] Using Buffer DMA mode
[ 11.522073] Periodic Transfer Interrupt Enhancement - disabled
[ 11.527821] Multiprocessor Interrupt Enhancement - disabled
[ 11.533301] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 11.537634] ^^^^^^^^^^^^^^^^^Device Mode
[ 12.025919] rk_battery_charger_detect_cb , battery_charger_detect 0
[ 12.360821] es8323_mic_state_ctrl read: 0
[ 12.364777] mic_state_switch 0
[ 12.367795] hp_det = 0,insert hp
[ 12.371025] hp mic use intern
[ 13.445536] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 13.452594] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 13.457899] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 13.463307] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 13.468784] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 13.474301] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 13.479779] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 13.722464] phy_power_on: enable = 1
[ 13.760551] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 13.766884] eth0: device MAC address 66:7b:02:0d:7d:4f
[ 13.776094] libphy: stmmac: probed
[ 13.779491] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 13.785481] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
[ 13.902533] wifi_driver_write: wifi driver already rmmod
[ 14.165729] acc_open
[ 14.167892] acc_release
[ 15.481403] =======================================================
[ 15.487578] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 15.493779] =======================================================
[ 15.499976] WiFi driver (Powered by Rockchip,Ver 4.80.WFD.OOB) init.
[ 15.506333] ======== PULL WL_REG_ON HIGH! ========
[ 15.511069] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 15.515699] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 15.520865] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 15.628891] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 15.646911] [WLAN_RFKILL]: wifi turn on power. 156
[ 15.651678] mmc2:mmc host rescan start!
[ 15.655466] =========== WLAN placed in POWER ON ========
[ 15.660864] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 15.666483]
[ 15.666483] Dongle Host Driver, version 1.88.45.3 (r420671)
[ 15.666483] Compiled in drivers/net/wireless/bcmdhd on Dec 3 2015 at 17:45:09
[ 15.697511] init: no such service ‘fuse_internal_sd’
[ 15.863346] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 15.898585] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 15.905625] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 15.913058] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 15.922190] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 15.983457] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 15.993190] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 16.001732] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 16.010589] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 16.016150] mmc2: new high speed SDIO card at address 0001
[ 16.022370] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 16.027970] alloc static buf at edb80000!
[ 16.032825] FW_PATH = /system/etc/firmware/fw_bcm4339a0_ag.bin
[ 16.032825] NVRAM_PATH = /system/etc/firmware/nvram_AP6335.txt
[ 16.048823] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 16.056211] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 16.068322] wl_create_event_handler(): thread:wl_event_handler:2d4 started
[ 16.075173] tsk Enter, tsk = 0xee1f9664
[ 16.075933] dhd_attach(): thread:dhd_watchdog_thread:2dc started
[ 16.076167] dhd_attach(): thread:dhd_dpc:2dd started
[ 16.076599] dhd_attach(): thread:dhd_sysioc:2de started
[ 16.076830] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 16.076841] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 16.076846] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 16.077403] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 16.077713] ======== PULL WL_REG_ON LOW! (flag = 2) ========
[ 16.077719] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 16.178240] [WLAN_RFKILL]: wifi shut off power.
[ 16.182789] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 16.187993] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 16.197132] =========== WLAN placed in RESET ========
[ 16.283454] init: sys_prop: permission denied uid:1001 name:media.cfg.audio.soundeffect
[ 16.399239] init: sys_prop: permission denied uid:10007 name:sys.gmali.version
[ 16.496000] type=1400 audit(1452762404.230:4): avc: denied { getattr } for pid=804 comm=“nloader:connect” path=“/data/app” dev=“mmcblk0p12” ino=24578 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:apk_data_file:s0 tclass=dir permissive=1
[ 16.532005] init: sys_prop: permission denied uid:10030 name:sys.gmali.version
[ 16.719842] vpu_service: power on
[ 16.723149] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 17.029054] force_usb_mode_store 0->1
[ 17.131139] Using Buffer DMA mode
[ 17.134428] Periodic Transfer Interrupt Enhancement - disabled
[ 17.140168] Multiprocessor Interrupt Enhancement - disabled
[ 17.145652] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 17.149948] ^^^^^^^^^^^^^^^^^^Host Mode
[ 17.201796] Init: Power Port (0)
[ 17.205043] rk_battery_charger_detect_cb , battery_charger_detect 5
[ 17.239339] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
[ 17.312431] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 17.332423] dhd_conf_set_fw_name_by_chip: firmware_path=/system/etc/firmware/fw_bcm4339a0_ag.bin
[ 17.341124]
[ 17.341124] Dongle Host Driver, version 1.88.45.3 (r420671)
[ 17.341124] Compiled in drivers/net/wireless/bcmdhd on Dec 3 2015 at 17:45:09
[ 17.355190] wl_android_wifi_on in 1
[ 17.358638] wl_android_wifi_on in 2: g_wifi_on=0
[ 17.363196] ======== PULL WL_REG_ON HIGH! (flag = 2) ========
[ 17.367892] binder: undelivered transaction 5738
[ 17.373425] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 17.378056] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 17.383238] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 17.496806] [WLAN_RFKILL]: wifi turn on power. 156
[ 17.501527] =========== WLAN going back to live ========
[ 17.506914] sdio_reset_comm():
[ 17.512925] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
[ 17.522347] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc2]
[ 17.550281] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 17.558701] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 17.567116] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 17.577940] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 17.690096] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 17.699765] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 17.708507]
[ 17.708507]
[ 17.708507] dhd_bus_devreset: == WLAN ON ==
[ 17.715574] dhd_bus_devreset called when dongle is not in reset
[ 17.721427] Will call dhd_bus_start instead
[ 17.725623] dhd_conf_set_fw_name_by_chip: firmware_path=/system/etc/firmware/fw_bcm4339a0_ag.bin
[ 17.735060] Final fw_path=/system/etc/firmware/fw_bcm4339a0_ag.bin
[ 17.741135] Final nv_path=/system/etc/firmware/nvram_AP6335.txt
[ 17.747007] Final conf_path=/system/etc/firmware/config.txt
[ 17.814186] NVRAM version: AP6335_NVRAM_V1.7_04102014
[ 17.819998] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 17.999796] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 18.005744] bcmsdh_set_drvdata: Enter
[ 18.009375] bcmsdh_register_oob_intr: Enter
[ 18.013582] bcmsdh_register_oob_intr: IRQ=196 Type=414
[ 18.019584] dhd_conf_set_band: Set band 0
[ 18.023666] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 18.029013] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 18.035705] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 18.051352] Firmware up: op_mode=0x0005, Broadcom Dongle Host Driver mac=6c:fa:a7:26:0c:d2
[ 18.059499] dhd_conf_set_country: Set country ALL, revision 0
[ 18.065426] dhd_conf_set_country: country code setting failed -2
[ 18.071608] Country code: US (US/0)
[ 18.075229] dhd_conf_set_roam: Set roam_off 1
[ 18.080800] dhd_conf_set_bw: Enable HT40 in 2.4 GHz
[ 18.095722] Firmware version = wl0: Apr 3 2014 12:12:42 version 6.37.32.28.2_ip (r424058)
[ 18.103859] Driver: 1.88.45.3 (r420671)
[ 18.103859] Firmware: wl0: Apr 3 2014 12:12:42 version 6.37.32.28.2_ip (r424058)
[ 18.118163] wl_android_wifi_on: Success
[ 19.222461] force_usb_mode_store 1->0
[ 19.254462] force_usb_mode_store 0->1
[ 19.258268] dwc_otg_force_host,already in A_HOST mode,everest
[ 20.665506] vpu_service: power off…
[ 20.669090] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 20.674329] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e250000
[ 20.684705] done
[ 21.325164] force_usb_mode_store 1->0
[ 21.328789] PortPower off
[ 21.331386] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 21.461015] type=1400 audit(1452762409.270:5): avc: denied { getattr } for pid=962 comm=“StartThread” path=“/system/xbin/su” dev=“mmcblk0p10” ino=1745 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 21.482120] type=1400 audit(1452762409.290:6): avc: denied { read } for pid=962 comm=“StartThread” name=“su” dev=“mmcblk0p10” ino=1745 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 21.535408] Using Buffer DMA mode
[ 21.538678] Periodic Transfer Interrupt Enhancement - disabled
[ 21.544413] Multiprocessor Interrupt Enhancement - disabled
[ 21.549896] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 21.554181] ^^^^^^^^^^^^^^^^^Device Mode
[ 21.826417] rk_battery_charger_detect_cb , battery_charger_detect 0
[ 21.887287] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 21.933653] wl_notify_connect_status nothing
[ 21.937973] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 21.998848] type=1400 audit(1452762409.820:7): avc: denied { execute_no_trans } for pid=1034 comm=“pool-6-thread-1” path=“/data/app-lib/com.tencent.qqlive-1/libvideowatch.so” dev=“mmcblk0p12” ino=682 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:system_data_file:s0 tclass=file permissive=1
[ 22.095247] net_ratelimit: 2 callbacks suppressed
[ 22.099883] dhd_pno_get_for_batch : wifi location service is not supported
[ 22.106728] ANDROID-ERROR) failed to getting batching results
[ 22.113554] dhd_pno_stop_for_batch : wifi location service is not supported
[ 22.120412] NULL POINTER (_dhd_pno_clear_all_batch_results) : head->next is NULL
[ 22.127727] NULL POINTER (_dhd_pno_clear_all_batch_results) : head->next is NULL
[ 22.135027] ANDROID-ERROR) failed to stop batching scan
[ 26.862199] type=1400 audit(1452762414.760:8): avc: denied { execute } for pid=1068 comm=“pool-1-temporar” path=“/data/data/com.tencent.android.qqdownloader/app_plugin_dir_com.tencent.assistant.root_krsdk/libkrsdk.1.0.95_5.4_2.so” dev=“mmcblk0p12” ino=789 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:app_data_file:s0 tclass=file permissive=1
[ 28.487303] type=1400 audit(1452762416.410:9): avc: denied { search } for pid=1061 comm=“libwatch.so” name=“1” dev=“proc” ino=1138 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=dir permissive=1
[ 28.505887] type=1400 audit(1452762416.430:10): avc: denied { read } for pid=1061 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=2422 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=file permissive=1
[ 28.524745] type=1400 audit(1452762416.450:11): avc: denied { open } for pid=1061 comm=“libwatch.so” path=“/proc/1/cmdline” dev=“proc” ino=2422 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=file permissive=1
[ 28.544272] type=1400 audit(1452762416.470:12): avc: denied { getattr } for pid=1061 comm=“libwatch.so” path=“/proc/1/cmdline” dev=“proc” ino=2422 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=file permissive=1
[ 28.564125] type=1400 audit(1452762416.490:13): avc: denied { search } for pid=1061 comm=“libwatch.so” name=“2” dev=“proc” ino=2330 scontext=u:r:untrusted_app:s0 tcontext=u:r:kernel:s0 tclass=dir permissive=1
[ 28.582749] type=1400 audit(1452762416.510:14): avc: denied { read } for pid=1061 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=2424 scontext=u:r:untrusted_app:s0 tcontext=u:r:kernel:s0 tclass=file permissive=1
[ 28.601779] type=1400 audit(1452762416.530:15): avc: denied { open } for pid=1061 comm=“libwatch.so” path=“/proc/2/cmdline” dev=“proc” ino=2424 scontext=u:r:untrusted_app:s0 tcontext=u:r:kernel:s0 tclass=file permissive=1
[ 28.621469] type=1400 audit(1452762416.550:16): avc: denied { getattr } for pid=1061 comm=“libwatch.so” path=“/proc/2/cmdline” dev=“proc” ino=2424 scontext=u:r:untrusted_app:s0 tcontext=u:r:kernel:s0 tclass=file permissive=1
[ 28.643167] type=1400 audit(1452762416.570:17): avc: denied { search } for pid=1061 comm=“libwatch.so” name=“122” dev=“proc” ino=8470 scontext=u:r:untrusted_app:s0 tcontext=u:r:ueventd:s0 tclass=dir permissive=1
[ 29.724983] Enter::rk29_hw_params----52
[ 29.730010] Enter:rk29_hw_params, 86, rate=44100
[ 29.734638] Enter:rk29_hw_params, 104, LRCK=64
[ 37.941290] audit_printk_skb: 291 callbacks suppressed
[ 37.946625] type=1400 audit(1452762426.020:115): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=2422 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=file permissive=1
[ 37.966230] type=1400 audit(1452762426.050:116): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/1/cmdline” dev=“proc” ino=2422 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=file permissive=1
[ 37.985878] type=1400 audit(1452762426.070:117): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/1/cmdline” dev=“proc” ino=2422 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=file permissive=1
[ 38.009007] type=1400 audit(1452762426.090:118): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=2697 scontext=u:r:untrusted_app:s0 tcontext=u:r:system_app:s0 tclass=file permissive=1
[ 38.028381] type=1400 audit(1452762426.110:119): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/743/cmdline” dev=“proc” ino=2697 scontext=u:r:untrusted_app:s0 tcontext=u:r:system_app:s0 tclass=file permissive=1
[ 38.048584] type=1400 audit(1452762426.130:120): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/743/cmdline” dev=“proc” ino=2697 scontext=u:r:untrusted_app:s0 tcontext=u:r:system_app:s0 tclass=file permissive=1
[ 47.781048] type=1400 audit(1452762436.020:121): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8775 scontext=u:r:untrusted_app:s0 tcontext=u:r:ueventd:s0 tclass=file permissive=1
[ 47.800360] type=1400 audit(1452762436.040:122): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/122/cmdline” dev=“proc” ino=8775 scontext=u:r:untrusted_app:s0 tcontext=u:r:ueventd:s0 tclass=file permissive=1
[ 47.820450] type=1400 audit(1452762436.060:123): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/122/cmdline” dev=“proc” ino=8775 scontext=u:r:untrusted_app:s0 tcontext=u:r:ueventd:s0 tclass=file permissive=1
[ 47.842556] type=1400 audit(1452762436.080:124): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=6993 scontext=u:r:untrusted_app:s0 tcontext=u:r:wpa:s0 tclass=file permissive=1
[ 47.861576] type=1400 audit(1452762436.100:125): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/867/cmdline” dev=“proc” ino=6993 scontext=u:r:untrusted_app:s0 tcontext=u:r:wpa:s0 tclass=file permissive=1
[ 47.881378] type=1400 audit(1452762436.120:126): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/867/cmdline” dev=“proc” ino=6993 scontext=u:r:untrusted_app:s0 tcontext=u:r:wpa:s0 tclass=file permissive=1
[ 48.165685] type=1400 audit(1452762436.410:127): avc: denied { search } for pid=1061 comm=“libwatch.so” name=“122” dev=“proc” ino=8470 scontext=u:r:untrusted_app:s0 tcontext=u:r:ueventd:s0 tclass=dir permissive=1
[ 49.775530] type=1400 audit(1452762438.050:128): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=6684 scontext=u:r:untrusted_app:s0 tcontext=u:r:platform_app:s0 tclass=file permissive=1
[ 49.795248] type=1400 audit(1452762438.070:129): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/546/cmdline” dev=“proc” ino=6684 scontext=u:r:untrusted_app:s0 tcontext=u:r:platform_app:s0 tclass=file permissive=1
[ 49.815737] type=1400 audit(1452762438.090:130): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/546/cmdline” dev=“proc” ino=6684 scontext=u:r:untrusted_app:s0 tcontext=u:r:platform_app:s0 tclass=file permissive=1
[ 52.318544] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 52.331877] CFG80211-ERROR) wl_is_linkdown : [ 52.335806] cfg80211: Calling CRDA for country: CN
Link down Reason : WLC_E_LINK
[ 52.343586] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 53.686276] audit_printk_skb: 27 callbacks suppressed
[ 53.691946] type=1400 audit(1452762442.020:140): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=2424 scontext=u:r:untrusted_app:s0 tcontext=u:r:kernel:s0 tclass=file permissive=1
[ 53.712491] type=1400 audit(1452762442.050:141): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/2/cmdline” dev=“proc” ino=2424 scontext=u:r:untrusted_app:s0 tcontext=u:r:kernel:s0 tclass=file permissive=1
[ 53.733322] type=1400 audit(1452762442.070:142): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/2/cmdline” dev=“proc” ino=2424 scontext=u:r:untrusted_app:s0 tcontext=u:r:kernel:s0 tclass=file permissive=1
[ 53.759660] type=1400 audit(1452762442.100:143): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“165” dev=“proc” ino=6489 scontext=u:r:untrusted_app:s0 tcontext=u:r:adbd:s0 tclass=dir permissive=1
[ 53.779145] type=1400 audit(1452762442.120:144): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“634” dev=“proc” ino=1442 scontext=u:r:untrusted_app:s0 tcontext=u:r:shared_app:s0 tclass=dir permissive=1
[ 53.798448] type=1400 audit(1452762442.140:145): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=2592 scontext=u:r:untrusted_app:s0 tcontext=u:r:shared_app:s0 tclass=file permissive=1
[ 53.818054] type=1400 audit(1452762442.160:146): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/634/cmdline” dev=“proc” ino=2592 scontext=u:r:untrusted_app:s0 tcontext=u:r:shared_app:s0 tclass=file permissive=1
[ 53.838401] type=1400 audit(1452762442.180:147): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/634/cmdline” dev=“proc” ino=2592 scontext=u:r:untrusted_app:s0 tcontext=u:r:shared_app:s0 tclass=file permissive=1
[ 53.859145] type=1400 audit(1452762442.200:148): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“651” dev=“proc” ino=2607 scontext=u:r:untrusted_app:s0 tcontext=u:r:radio:s0 tclass=dir permissive=1
[ 53.877971] type=1400 audit(1452762442.220:149): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=2614 scontext=u:r:untrusted_app:s0 tcontext=u:r:radio:s0 tclass=file permissive=1
[ 55.676395] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 55.848901] wl_notify_connect_status nothing
[ 55.853164] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 55.878096] dhd_pno_get_for_batch : wifi location service is not supported
[ 55.884899] ANDROID-ERROR) failed to getting batching results
[ 55.891158] dhd_pno_stop_for_batch : wifi location service is not supported
[ 55.898040] ANDROID-ERROR) failed to stop batching scan
[ 63.540055] audit_printk_skb: 63 callbacks suppressed
[ 63.545121] type=1400 audit(1452762452.040:171): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“142” dev=“proc” ino=1158 scontext=u:r:untrusted_app:s0 tcontext=u:r:zygote:s0 tclass=dir permissive=1
[ 63.567072] type=1400 audit(1452762452.060:172): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8811 scontext=u:r:untrusted_app:s0 tcontext=u:r:drmserver:s0 tclass=file permissive=1
[ 63.586485] type=1400 audit(1452762452.090:173): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/143/cmdline” dev=“proc” ino=8811 scontext=u:r:untrusted_app:s0 tcontext=u:r:drmserver:s0 tclass=file permissive=1
[ 63.606808] type=1400 audit(1452762452.100:174): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/143/cmdline” dev=“proc” ino=8811 scontext=u:r:untrusted_app:s0 tcontext=u:r:drmserver:s0 tclass=file permissive=1
[ 63.627391] type=1400 audit(1452762452.130:175): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“144” dev=“proc” ino=1166 scontext=u:r:untrusted_app:s0 tcontext=u:r:mediaserver:s0 tclass=dir permissive=1
[ 63.646727] type=1400 audit(1452762452.150:176): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8813 scontext=u:r:untrusted_app:s0 tcontext=u:r:mediaserver:s0 tclass=file permissive=1
[ 63.666361] type=1400 audit(1452762452.170:177): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/144/cmdline” dev=“proc” ino=8813 scontext=u:r:untrusted_app:s0 tcontext=u:r:mediaserver:s0 tclass=file permissive=1
[ 63.686770] type=1400 audit(1452762452.190:178): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/144/cmdline” dev=“proc” ino=8813 scontext=u:r:untrusted_app:s0 tcontext=u:r:mediaserver:s0 tclass=file permissive=1
[ 63.707560] type=1400 audit(1452762452.210:179): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8815 scontext=u:r:untrusted_app:s0 tcontext=u:r:installd:s0 tclass=file permissive=1
[ 63.726953] type=1400 audit(1452762452.230:180): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/145/cmdline” dev=“proc” ino=8815 scontext=u:r:untrusted_app:s0 tcontext=u:r:installd:s0 tclass=file permissive=1
[ 73.382053] audit_printk_skb: 15 callbacks suppressed
[ 73.387076] type=1400 audit(1452762462.040:186): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“145” dev=“proc” ino=2175 scontext=u:r:untrusted_app:s0 tcontext=u:r:installd:s0 tclass=dir permissive=1
[ 73.406842] type=1400 audit(1452762462.060:187): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“146” dev=“proc” ino=2183 scontext=u:r:untrusted_app:s0 tcontext=u:r:keystore:s0 tclass=dir permissive=1
[ 77.321128] type=1400 audit(1452762466.040:188): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8797 scontext=u:r:untrusted_app:s0 tcontext=u:r:servicemanager:s0 tclass=file permissive=1
[ 77.342590] type=1400 audit(1452762466.060:189): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/135/cmdline” dev=“proc” ino=8797 scontext=u:r:untrusted_app:s0 tcontext=u:r:servicemanager:s0 tclass=file permissive=1
[ 77.365344] type=1400 audit(1452762466.090:190): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/135/cmdline” dev=“proc” ino=8797 scontext=u:r:untrusted_app:s0 tcontext=u:r:servicemanager:s0 tclass=file permissive=1
[ 77.386404] type=1400 audit(1452762466.110:191): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8799 scontext=u:r:untrusted_app:s0 tcontext=u:r:vold:s0 tclass=file permissive=1
[ 77.405319] type=1400 audit(1452762466.130:192): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/136/cmdline” dev=“proc” ino=8799 scontext=u:r:untrusted_app:s0 tcontext=u:r:vold:s0 tclass=file permissive=1
[ 77.425050] type=1400 audit(1452762466.150:193): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/136/cmdline” dev=“proc” ino=8799 scontext=u:r:untrusted_app:s0 tcontext=u:r:vold:s0 tclass=file permissive=1
[ 77.445070] type=1400 audit(1452762466.170:194): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“138” dev=“proc” ino=8582 scontext=u:r:untrusted_app:s0 tcontext=u:r:netd:s0 tclass=dir permissive=1
[ 77.463722] type=1400 audit(1452762466.190:195): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“139” dev=“proc” ino=2141 scontext=u:r:untrusted_app:s0 tcontext=u:r:debuggerd:s0 tclass=dir permissive=1
[ 81.250863] type=1400 audit(1452762470.040:196): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“135” dev=“proc” ino=2119 scontext=u:r:untrusted_app:s0 tcontext=u:r:servicemanager:s0 tclass=dir permissive=1
[ 81.270552] type=1400 audit(1452762470.060:197): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“136” dev=“proc” ino=1150 scontext=u:r:untrusted_app:s0 tcontext=u:r:vold:s0 tclass=dir permissive=1
[ 81.289268] type=1400 audit(1452762470.070:198): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8803 scontext=u:r:untrusted_app:s0 tcontext=u:r:netd:s0 tclass=file permissive=1
[ 81.308143] type=1400 audit(1452762470.090:199): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/138/cmdline” dev=“proc” ino=8803 scontext=u:r:untrusted_app:s0 tcontext=u:r:netd:s0 tclass=file permissive=1
[ 81.327843] type=1400 audit(1452762470.110:200): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/138/cmdline” dev=“proc” ino=8803 scontext=u:r:untrusted_app:s0 tcontext=u:r:netd:s0 tclass=file permissive=1
[ 81.347839] type=1400 audit(1452762470.130:201): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8805 scontext=u:r:untrusted_app:s0 tcontext=u:r:debuggerd:s0 tclass=file permissive=1
[ 81.367094] type=1400 audit(1452762470.150:202): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/139/cmdline” dev=“proc” ino=8805 scontext=u:r:untrusted_app:s0 tcontext=u:r:debuggerd:s0 tclass=file permissive=1
[ 81.387202] type=1400 audit(1452762470.170:203): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/139/cmdline” dev=“proc” ino=8805 scontext=u:r:untrusted_app:s0 tcontext=u:r:debuggerd:s0 tclass=file permissive=1
[ 81.407690] type=1400 audit(1452762470.200:204): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8807 scontext=u:r:untrusted_app:s0 tcontext=u:r:rild:s0 tclass=file permissive=1
[ 81.426511] type=1400 audit(1452762470.210:205): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/140/cmdline” dev=“proc” ino=8807 scontext=u:r:untrusted_app:s0 tcontext=u:r:rild:s0 tclass=file permissive=1
[ 86.083028] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 86.096403] CFG80211-ERROR) wl_is_linkdown : [ 86.100189] cfg80211: Calling CRDA to update world regulatory domain
[ 86.109601] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 87.159368] audit_printk_skb: 3 callbacks suppressed
[ 87.164538] type=1400 audit(1452762476.040:207): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“140” dev=“proc” ino=2146 scontext=u:r:untrusted_app:s0 tcontext=u:r:rild:s0 tclass=dir permissive=1
[ 87.184317] type=1400 audit(1452762476.070:208): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“141” dev=“proc” ino=2156 scontext=u:r:untrusted_app:s0 tcontext=u:r:surfaceflinger:s0 tclass=dir permissive=1
[ 89.451012] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 89.463421] wl_notify_connect_status nothing
[ 89.467690] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 89.646808] dhd_pno_get_for_batch : wifi location service is not supported
[ 89.654417] ANDROID-ERROR) failed to getting batching results
[ 89.662455] dhd_pno_stop_for_batch : wifi location service is not supported
[ 89.669470] ANDROID-ERROR) failed to stop batching scan
[ 91.086720] type=1400 audit(1452762480.030:209): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“134” dev=“proc” ino=2112 scontext=u:r:untrusted_app:s0 tcontext=u:r:healthd:s0 tclass=dir permissive=1
[ 91.106548] type=1400 audit(1452762480.050:210): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8795 scontext=u:r:untrusted_app:s0 tcontext=u:r:healthd:s0 tclass=file permissive=1
[ 91.126410] type=1400 audit(1452762480.070:211): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/134/cmdline” dev=“proc” ino=8795 scontext=u:r:untrusted_app:s0 tcontext=u:r:healthd:s0 tclass=file permissive=1
[ 91.147246] type=1400 audit(1452762480.090:212): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/134/cmdline” dev=“proc” ino=8795 scontext=u:r:untrusted_app:s0 tcontext=u:r:healthd:s0 tclass=file permissive=1
[ 119.857053] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 119.871423] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 119.878572] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 119.878696] cfg80211: Calling CRDA to update world regulatory domain
[ 123.843114] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 123.883071] wl_notify_connect_status nothing
[ 123.887415] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 124.129706] dhd_pno_get_for_batch : wifi location service is not supported
[ 124.136527] ANDROID-ERROR) failed to getting batching results
[ 124.142799] dhd_pno_stop_for_batch : wifi location service is not supported
[ 124.149644] ANDROID-ERROR) failed to stop batching scan
[ 154.330741] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 154.344808] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 154.351790] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 154.352108] cfg80211: Calling CRDA for country: CN
[ 157.712181] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 157.811271] wl_notify_connect_status nothing
[ 157.815620] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 157.910173] dhd_pno_get_for_batch : wifi location service is not supported
[ 157.916966] ANDROID-ERROR) failed to getting batching results
[ 157.923220] dhd_pno_stop_for_batch : wifi location service is not supported
[ 157.930110] ANDROID-ERROR) failed to stop batching scan
[ 188.110463] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 188.124405] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 188.130469] cfg80211: Calling CRDA to update world regulatory domain
[ 188.137915] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 191.487944] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 191.512507] wl_notify_connect_status nothing
[ 191.516729] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 191.683502] dhd_pno_get_for_batch : wifi location service is not supported
[ 191.690303] ANDROID-ERROR) failed to getting batching results
[ 191.696650] dhd_pno_stop_for_batch : wifi location service is not supported
[ 191.703493] ANDROID-ERROR) failed to stop batching scan
[ 221.886539] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 221.899835] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 221.904098] cfg80211: Calling CRDA for country: CN
[ 221.904180] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 225.271579] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 225.330834] wl_notify_connect_status nothing
[ 225.335052] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 225.468232] dhd_pno_get_for_batch : wifi location service is not supported
[ 225.475061] ANDROID-ERROR) failed to getting batching results
[ 225.481573] dhd_pno_stop_for_batch : wifi location service is not supported
[ 225.488487] ANDROID-ERROR) failed to stop batching scan
[ 255.669883] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 255.684127] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 255.691027] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 255.691297] cfg80211: Calling CRDA to update world regulatory domain
[ 259.011795] connect failed event=0 e->status 1 e->reason 0
[ 259.018307] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 262.366911] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 262.375790] wl_notify_connect_status nothing
[ 262.380011] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 262.563707] dhd_pno_get_for_batch : wifi location service is not supported
[ 262.570496] ANDROID-ERROR) failed to getting batching results
[ 262.577256] dhd_pno_stop_for_batch : wifi location service is not supported
[ 262.584150] ANDROID-ERROR) failed to stop batching scan
[ 292.769080] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 292.783147] CFG80211-ERROR) wl_is_linkdown : [ 292.787044] cfg80211: Calling CRDA to update world regulatory domain
[ 292.796479] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 296.155492] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 296.178199] wl_notify_connect_status nothing
[ 296.182425] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 296.352500] dhd_pno_get_for_batch : wifi location service is not supported
[ 296.359288] ANDROID-ERROR) failed to getting batching results
[ 296.368063] dhd_pno_stop_for_batch : wifi location service is not supported
[ 296.374949] ANDROID-ERROR) failed to stop batching scan
[ 326.555450] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 326.568372] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 326.572771] cfg80211: Calling CRDA for country: CN
[ 326.580050] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 329.944127] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 329.993341] wl_notify_connect_status nothing
[ 329.997572] wl_bss_connect_done succeeded with 50:bd:5f:39:31:0a
[ 330.155821] dhd_pno_get_for_batch : wifi location service is not supported
[ 330.162598] ANDROID-ERROR) failed to getting batching results
[ 330.168731] dhd_pno_stop_for_batch : wifi location service is not supported
[ 330.175588] ANDROID-ERROR) failed to stop batching scan
[ 360.360199] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 360.373876] CFG80211-ERROR) wl_is_linkdown : [ 360.377772] cfg80211: Calling CRDA to update world regulatory domain
[ 360.387166] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 50:bd:5f:39:31:0a
[ 363.684842] connect failed event=0 e->status 1 e->reason 0
[ 363.690878] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 366.987712] connect failed event=0 e->status 1 e->reason 0
[ 366.994601] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 370.285504] CFGP2P-ERROR) wl_cfgp2p_init_discovery : do nothing, already initialized
[ 370.293299] dhd_ioctl_entry_local invalid parameter
[ 370.298122] CFGP2P-ERROR) wl_cfgp2p_enable_discovery : wsec error -22
[ 370.304708] CFGP2P-ERROR) wl_cfgp2p_start_p2p_device : P2P enable discovery failed, ret=-22
[ 382.930870] connect failed event=0 e->status 1 e->reason 0
[ 382.937472] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 402.625710] connect failed event=0 e->status 1 e->reason 0
[ 402.632155] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 422.351376] connect failed event=0 e->status 1 e->reason 0
[ 422.358603] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 442.027013] connect failed event=0 e->status 1 e->reason 0
[ 442.034282] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 461.702044] connect failed event=0 e->status 1 e->reason 0
[ 461.708666] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 491.247068] connect failed event=0 e->status 1 e->reason 0
[ 491.253747] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 520.786605] connect failed event=0 e->status 1 e->reason 0
[ 520.792580] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 529.795181] Enter::rk29_hw_params----52
[ 529.800033] Enter:rk29_hw_params, 86, rate=44100
[ 529.804606] Enter:rk29_hw_params, 104, LRCK=64
[ 531.631178] connect failed event=0 e->status 1 e->reason 0
[ 531.637411] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 546.770289] Enter::rk29_hw_params----52
[ 546.775175] Enter:rk29_hw_params, 86, rate=44100
[ 546.779750] Enter:rk29_hw_params, 104, LRCK=64
[ 563.943499] connect failed event=0 e->status 1 e->reason 0
[ 563.949928] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 596.253128] connect failed event=0 e->status 1 e->reason 0
[ 596.260551] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 628.569612] connect failed event=0 e->status 1 e->reason 0
[ 628.576234] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 660.888753] connect failed event=0 e->status 1 e->reason 0
[ 660.895476] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 668.496323] Enter::rk29_hw_params----52
[ 668.502155] Enter:rk29_hw_params, 86, rate=44100
[ 668.507103] Enter:rk29_hw_params, 104, LRCK=64
[ 669.673288] type=1400 audit(1452763068.030:213): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“743” dev=“proc” ino=2691 scontext=u:r:untrusted_app:s0 tcontext=u:r:system_app:s0 tclass=dir permissive=1
[ 671.722594] init: sys_prop: permission denied uid:10029 name:sys.gmali.version
[ 672.020883] type=1400 audit(1452763070.410:214): avc: denied { search } for pid=1061 comm=“libwatch.so” name=“1” dev=“proc” ino=1138 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=dir permissive=1
[ 672.039566] type=1400 audit(1452763070.430:215): avc: denied { read } for pid=1061 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=2422 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=file permissive=1
[ 672.058634] type=1400 audit(1452763070.450:216): avc: denied { open } for pid=1061 comm=“libwatch.so” path=“/proc/1/cmdline” dev=“proc” ino=2422 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=file permissive=1
[ 672.078359] type=1400 audit(1452763070.470:217): avc: denied { getattr } for pid=1061 comm=“libwatch.so” path=“/proc/1/cmdline” dev=“proc” ino=2422 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=file permissive=1
[ 672.102145] type=1400 audit(1452763070.490:218): avc: denied { read } for pid=1061 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=2697 scontext=u:r:untrusted_app:s0 tcontext=u:r:system_app:s0 tclass=file permissive=1
[ 672.121618] type=1400 audit(1452763070.510:219): avc: denied { open } for pid=1061 comm=“libwatch.so” path=“/proc/743/cmdline” dev=“proc” ino=2697 scontext=u:r:untrusted_app:s0 tcontext=u:r:system_app:s0 tclass=file permissive=1
[ 672.141881] type=1400 audit(1452763070.530:220): avc: denied { getattr } for pid=1061 comm=“libwatch.so” path=“/proc/743/cmdline” dev=“proc” ino=2697 scontext=u:r:untrusted_app:s0 tcontext=u:r:system_app:s0 tclass=file permissive=1
[ 672.162812] type=1400 audit(1452763070.560:221): avc: denied { read } for pid=1061 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=6993 scontext=u:r:untrusted_app:s0 tcontext=u:r:wpa:s0 tclass=file permissive=1
[ 672.181813] type=1400 audit(1452763070.580:222): avc: denied { open } for pid=1061 comm=“libwatch.so” path=“/proc/867/cmdline” dev=“proc” ino=6993 scontext=u:r:untrusted_app:s0 tcontext=u:r:wpa:s0 tclass=file permissive=1
[ 685.987712] Enter::rk29_hw_params----52
[ 685.992464] Enter:rk29_hw_params, 86, rate=44100
[ 685.997109] Enter:rk29_hw_params, 104, LRCK=64
[ 686.097816] wl_bss_connect_done succeeded with c8:3a:35:11:e8:d0
[ 686.156194] wl_notify_connect_status nothing
[ 686.160411] wl_bss_connect_done succeeded with c8:3a:35:11:e8:d0
[ 686.243143] dhd_pno_get_for_batch : wifi location service is not supported
[ 686.249915] ANDROID-ERROR) failed to getting batching results
[ 686.256486] dhd_pno_stop_for_batch : wifi location service is not supported
[ 686.263360] ANDROID-ERROR) failed to stop batching scan
[ 686.562402] qtaguid: iface_stat: stat_update() wlan0 not found
[ 687.392091] audit_printk_skb: 12 callbacks suppressed
[ 687.397385] type=1400 audit(1452763086.030:227): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“122” dev=“proc” ino=8470 scontext=u:r:untrusted_app:s0 tcontext=u:r:ueventd:s0 tclass=dir permissive=1
[ 687.421980] type=1400 audit(1452763086.060:228): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“867” dev=“proc” ino=1565 scontext=u:r:untrusted_app:s0 tcontext=u:r:wpa:s0 tclass=dir permissive=1
[ 692.189683] qtaguid: iface_stat: stat_update() wlan0 not found
[ 692.207243] qtaguid: iface_stat: stat_update() wlan0 not found
[ 693.302328] type=1400 audit(1452763092.040:229): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=6684 scontext=u:r:untrusted_app:s0 tcontext=u:r:platform_app:s0 tclass=file permissive=1
[ 693.322155] type=1400 audit(1452763092.060:230): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/546/cmdline” dev=“proc” ino=6684 scontext=u:r:untrusted_app:s0 tcontext=u:r:platform_app:s0 tclass=file permissive=1
[ 693.342635] type=1400 audit(1452763092.080:231): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/546/cmdline” dev=“proc” ino=6684 scontext=u:r:untrusted_app:s0 tcontext=u:r:platform_app:s0 tclass=file permissive=1
[ 693.363431] type=1400 audit(1452763092.100:232): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“621” dev=“proc” ino=6722 scontext=u:r:untrusted_app:s0 tcontext=u:r:media_app:s0 tclass=dir permissive=1
[ 693.383838] type=1400 audit(1452763092.120:233): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=11247 scontext=u:r:untrusted_app:s0 tcontext=u:r:dhcp:s0 tclass=file permissive=1
[ 693.402758] type=1400 audit(1452763092.140:234): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/1501/cmdline” dev=“proc” ino=11247 scontext=u:r:untrusted_app:s0 tcontext=u:r:dhcp:s0 tclass=file permissive=1
[ 693.422607] type=1400 audit(1452763092.160:235): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/1501/cmdline” dev=“proc” ino=11247 scontext=u:r:untrusted_app:s0 tcontext=u:r:dhcp:s0 tclass=file permissive=1
[ 697.237566] type=1400 audit(1452763096.185:236): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“546” dev=“proc” ino=2566 scontext=u:r:untrusted_app:s0 tcontext=u:r:platform_app:s0 tclass=dir permissive=1
[ 697.257140] type=1400 audit(1452763096.205:237): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=2587 scontext=u:r:untrusted_app:s0 tcontext=u:r:media_app:s0 tclass=file permissive=1
[ 697.276437] type=1400 audit(1452763096.225:238): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/621/cmdline” dev=“proc” ino=2587 scontext=u:r:untrusted_app:s0 tcontext=u:r:media_app:s0 tclass=file permissive=1
[ 699.041902] audit_printk_skb: 42 callbacks suppressed
[ 699.047193] type=1400 audit(1452763098.015:253): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=2424 scontext=u:r:untrusted_app:s0 tcontext=u:r:kernel:s0 tclass=file permissive=1
[ 699.066763] type=1400 audit(1452763098.045:254): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/2/cmdline” dev=“proc” ino=2424 scontext=u:r:untrusted_app:s0 tcontext=u:r:kernel:s0 tclass=file permissive=1
[ 699.086594] type=1400 audit(1452763098.065:255): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/2/cmdline” dev=“proc” ino=2424 scontext=u:r:untrusted_app:s0 tcontext=u:r:kernel:s0 tclass=file permissive=1
[ 699.578216] Enter::rk29_hw_params----52
[ 699.583035] Enter:rk29_hw_params, 86, rate=44100
[ 699.587655] Enter:rk29_hw_params, 104, LRCK=64
[ 701.012473] type=1400 audit(1452763100.015:256): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“165” dev=“proc” ino=6489 scontext=u:r:untrusted_app:s0 tcontext=u:r:adbd:s0 tclass=dir permissive=1
[ 702.345231] type=1400 audit(1452763101.375:257): avc: denied { getattr } for pid=1561 comm=“.tencent.qqlive” path=“/data/app” dev=“mmcblk0p12” ino=24578 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:apk_data_file:s0 tclass=dir permissive=1
[ 702.790103] type=1400 audit(1452763101.825:258): avc: denied { read write } for pid=1561 comm=“.tencent.qqlive” name=“vpu_service” dev=“tmpfs” ino=6268 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 702.811456] type=1400 audit(1452763101.845:259): avc: denied { open } for pid=1561 comm=“.tencent.qqlive” path=“/dev/vpu_service” dev=“tmpfs” ino=6268 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 702.832736] type=1400 audit(1452763101.865:260): avc: denied { ioctl } for pid=1561 comm=“.tencent.qqlive” path=“/dev/vpu_service” dev=“tmpfs” ino=6268 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 702.856441] vpu_service: power on
[ 702.859782] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 702.976366] type=1400 audit(1452763102.015:261): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“2” dev=“proc” ino=2330 scontext=u:r:untrusted_app:s0 tcontext=u:r:kernel:s0 tclass=dir permissive=1
[ 703.027203] type=1400 audit(1452763102.065:262): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“164” dev=“proc” ino=2218 scontext=u:r:untrusted_app:s0 tcontext=u:r:init_shell:s0 tclass=dir permissive=1
[ 703.170077] init: sys_prop: permission denied uid:10055 name:sys.gmali.version
[ 704.945702] audit_printk_skb: 72 callbacks suppressed
[ 704.950716] type=1400 audit(1452763104.015:287): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8815 scontext=u:r:untrusted_app:s0 tcontext=u:r:installd:s0 tclass=file permissive=1
[ 704.969971] type=1400 audit(1452763104.045:288): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/145/cmdline” dev=“proc” ino=8815 scontext=u:r:untrusted_app:s0 tcontext=u:r:installd:s0 tclass=file permissive=1
[ 704.990048] type=1400 audit(1452763104.065:289): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/145/cmdline” dev=“proc” ino=8815 scontext=u:r:untrusted_app:s0 tcontext=u:r:installd:s0 tclass=file permissive=1
[ 705.010550] type=1400 audit(1452763104.085:290): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8817 scontext=u:r:untrusted_app:s0 tcontext=u:r:keystore:s0 tclass=file permissive=1
[ 705.029840] type=1400 audit(1452763104.105:291): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/146/cmdline” dev=“proc” ino=8817 scontext=u:r:untrusted_app:s0 tcontext=u:r:keystore:s0 tclass=file permissive=1
[ 705.049958] type=1400 audit(1452763104.125:292): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/146/cmdline” dev=“proc” ino=8817 scontext=u:r:untrusted_app:s0 tcontext=u:r:keystore:s0 tclass=file permissive=1
[ 707.298520] type=1400 audit(1452763106.405:293): avc: denied { search } for pid=1061 comm=“libwatch.so” name=“145” dev=“proc” ino=2175 scontext=u:r:untrusted_app:s0 tcontext=u:r:installd:s0 tclass=dir permissive=1
[ 709.005191] Enter::rk29_hw_params----52
[ 709.010011] Enter:rk29_hw_params, 86, rate=44100
[ 709.014624] Enter:rk29_hw_params, 104, LRCK=64
[ 709.267790] type=1400 audit(1452763108.405:294): avc: denied { read } for pid=1061 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8797 scontext=u:r:untrusted_app:s0 tcontext=u:r:servicemanager:s0 tclass=file permissive=1
[ 709.287739] type=1400 audit(1452763108.425:295): avc: denied { open } for pid=1061 comm=“libwatch.so” path=“/proc/135/cmdline” dev=“proc” ino=8797 scontext=u:r:untrusted_app:s0 tcontext=u:r:servicemanager:s0 tclass=file permissive=1
[ 709.308602] type=1400 audit(1452763108.455:296): avc: denied { getattr } for pid=1061 comm=“libwatch.so” path=“/proc/135/cmdline” dev=“proc” ino=8797 scontext=u:r:untrusted_app:s0 tcontext=u:r:servicemanager:s0 tclass=file permissive=1
[ 709.878571] vpu_service: power off…
[ 709.882050] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 709.887203] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e250000
[ 709.896880] done
[ 710.849832] audit_printk_skb: 6 callbacks suppressed
[ 710.854802] type=1400 audit(1452763110.015:299): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“135” dev=“proc” ino=2119 scontext=u:r:untrusted_app:s0 tcontext=u:r:servicemanager:s0 tclass=dir permissive=1
[ 710.874387] type=1400 audit(1452763110.045:300): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8799 scontext=u:r:untrusted_app:s0 tcontext=u:r:vold:s0 tclass=file permissive=1
[ 710.893697] type=1400 audit(1452763110.065:301): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/136/cmdline” dev=“proc” ino=8799 scontext=u:r:untrusted_app:s0 tcontext=u:r:vold:s0 tclass=file permissive=1
[ 710.913795] type=1400 audit(1452763110.085:302): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/136/cmdline” dev=“proc” ino=8799 scontext=u:r:untrusted_app:s0 tcontext=u:r:vold:s0 tclass=file permissive=1
[ 710.933993] type=1400 audit(1452763110.105:303): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8803 scontext=u:r:untrusted_app:s0 tcontext=u:r:netd:s0 tclass=file permissive=1
[ 710.952882] type=1400 audit(1452763110.125:304): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/138/cmdline” dev=“proc” ino=8803 scontext=u:r:untrusted_app:s0 tcontext=u:r:netd:s0 tclass=file permissive=1
[ 710.972640] type=1400 audit(1452763110.145:305): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/138/cmdline” dev=“proc” ino=8803 scontext=u:r:untrusted_app:s0 tcontext=u:r:netd:s0 tclass=file permissive=1
[ 710.992716] type=1400 audit(1452763110.165:306): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“139” dev=“proc” ino=2141 scontext=u:r:untrusted_app:s0 tcontext=u:r:debuggerd:s0 tclass=dir permissive=1
[ 711.011773] type=1400 audit(1452763110.185:307): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8805 scontext=u:r:untrusted_app:s0 tcontext=u:r:debuggerd:s0 tclass=file permissive=1
[ 711.031082] type=1400 audit(1452763110.205:308): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/139/cmdline” dev=“proc” ino=8805 scontext=u:r:untrusted_app:s0 tcontext=u:r:debuggerd:s0 tclass=file permissive=1
[ 713.551530] vpu_service: power on
[ 713.554905] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 717.958945] Enter::rk29_hw_params----52
[ 717.963727] Enter:rk29_hw_params, 86, rate=44100
[ 717.968316] Enter:rk29_hw_params, 104, LRCK=64
[ 718.723136] audit_printk_skb: 3 callbacks suppressed
[ 718.728142] type=1400 audit(1452763118.015:310): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“136” dev=“proc” ino=1150 scontext=u:r:untrusted_app:s0 tcontext=u:r:vold:s0 tclass=dir permissive=1
[ 718.747499] type=1400 audit(1452763118.045:311): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8807 scontext=u:r:untrusted_app:s0 tcontext=u:r:rild:s0 tclass=file permissive=1
[ 718.766567] type=1400 audit(1452763118.065:312): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/140/cmdline” dev=“proc” ino=8807 scontext=u:r:untrusted_app:s0 tcontext=u:r:rild:s0 tclass=file permissive=1
[ 718.786695] type=1400 audit(1452763118.085:313): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/140/cmdline” dev=“proc” ino=8807 scontext=u:r:untrusted_app:s0 tcontext=u:r:rild:s0 tclass=file permissive=1
[ 718.807080] type=1400 audit(1452763118.105:314): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“141” dev=“proc” ino=2156 scontext=u:r:untrusted_app:s0 tcontext=u:r:surfaceflinger:s0 tclass=dir permissive=1
[ 720.820676] vpu_service: power off…
[ 720.824178] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 720.829351] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e250000
[ 720.839148] done
[ 728.978580] type=1400 audit(1452763128.445:315): avc: denied { search } for pid=1061 comm=“libwatch.so” name=“140” dev=“proc” ino=2146 scontext=u:r:untrusted_app:s0 tcontext=u:r:rild:s0 tclass=dir permissive=1
[ 728.997914] type=1400 audit(1452763128.465:316): avc: denied { read } for pid=1061 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=6599 scontext=u:r:untrusted_app:s0 tcontext=u:r:surfaceflinger:s0 tclass=file permissive=1
[ 729.018161] type=1400 audit(1452763128.485:317): avc: denied { open } for pid=1061 comm=“libwatch.so” path=“/proc/141/cmdline” dev=“proc” ino=6599 scontext=u:r:untrusted_app:s0 tcontext=u:r:surfaceflinger:s0 tclass=file permissive=1
[ 729.038789] type=1400 audit(1452763128.505:318): avc: denied { getattr } for pid=1061 comm=“libwatch.so” path=“/proc/141/cmdline” dev=“proc” ino=6599 scontext=u:r:untrusted_app:s0 tcontext=u:r:surfaceflinger:s0 tclass=file permissive=1
[ 730.201876] init: sys_prop: permission denied uid:10017 name:sys.gmali.version
[ 730.405259] init: sys_prop: permission denied uid:10017 name:sys.glibgui
[ 730.537937] type=1400 audit(1452763130.025:319): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“134” dev=“proc” ino=2112 scontext=u:r:untrusted_app:s0 tcontext=u:r:healthd:s0 tclass=dir permissive=1
[ 730.557143] type=1400 audit(1452763130.045:320): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8795 scontext=u:r:untrusted_app:s0 tcontext=u:r:healthd:s0 tclass=file permissive=1
[ 730.577084] type=1400 audit(1452763130.075:321): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/134/cmdline” dev=“proc” ino=8795 scontext=u:r:untrusted_app:s0 tcontext=u:r:healthd:s0 tclass=file permissive=1
[ 730.597368] type=1400 audit(1452763130.095:322): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/134/cmdline” dev=“proc” ino=8795 scontext=u:r:untrusted_app:s0 tcontext=u:r:healthd:s0 tclass=file permissive=1
[ 730.851543] init: sys_prop: permission denied uid:10017 name:sys.ggralloc.version
[ 740.155136] Enter::rk29_hw_params----52
[ 740.160083] Enter:rk29_hw_params, 86, rate=44100
[ 740.164667] Enter:rk29_hw_params, 104, LRCK=64
[ 746.782830] Enter::rk29_hw_params----52
[ 746.787719] Enter:rk29_hw_params, 86, rate=44100
[ 746.792543] Enter:rk29_hw_params, 104, LRCK=64
[ 775.513816] Enter::rk29_hw_params----52
[ 775.518674] Enter:rk29_hw_params, 86, rate=44100
[ 775.523304] Enter:rk29_hw_params, 104, LRCK=64
[ 847.789417] Enter::rk29_hw_params----52
[ 847.794238] Enter:rk29_hw_params, 86, rate=44100
[ 847.798860] Enter:rk29_hw_params, 104, LRCK=64
[ 898.871177] Enter::rk29_hw_params----52
[ 898.876623] Enter:rk29_hw_params, 86, rate=44100
[ 898.881600] Enter:rk29_hw_params, 104, LRCK=64
[ 925.473320] Enter::rk29_hw_params----52
[ 925.478282] Enter:rk29_hw_params, 86, rate=44100
[ 925.482915] Enter:rk29_hw_params, 104, LRCK=64
[ 927.139799] type=1400 audit(1452763329.825:323): avc: denied { getattr } for pid=1965 comm=“.tencent.qqlive” path=“/data/app” dev=“mmcblk0p12” ino=24578 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:apk_data_file:s0 tclass=dir permissive=1
[ 927.485279] vpu_service: power on
[ 927.490878] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 927.644504] type=1400 audit(1452763330.335:324): avc: denied { write } for pid=1965 comm=“.tencent.qqlive” name=“property_service” dev=“tmpfs” ino=6465 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:property_socket:s0 tclass=sock_file permissive=1
[ 927.666817] init: sys_prop: permission denied uid:10055 name:sys.gmali.version
[ 935.116900] Enter::rk29_hw_params----52
[ 935.121977] Enter:rk29_hw_params, 86, rate=44100
[ 935.126671] Enter:rk29_hw_params, 104, LRCK=64
[ 939.888833] vpu_service: power off…
[ 939.892320] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 939.897480] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e250000
[ 939.907154] done
[ 940.985922] Enter::rk29_hw_params----52
[ 940.990731] Enter:rk29_hw_params, 86, rate=44100
[ 940.995314] Enter:rk29_hw_params, 104, LRCK=64
[ 941.492823] type=1400 audit(1452763344.415:325): avc: denied { search } for pid=1061 comm=“libwatch.so” name=“743” dev=“proc” ino=2691 scontext=u:r:untrusted_app:s0 tcontext=u:r:system_app:s0 tclass=dir permissive=1
[ 941.919885] vpu_service: power on
[ 941.923580] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 943.456820] type=1400 audit(1452763346.405:326): avc: denied { search } for pid=1061 comm=“libwatch.so” name=“1” dev=“proc” ino=1138 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=dir permissive=1
[ 943.505526] init: sys_prop: permission denied uid:10055 name:media.cfg.audio.soundeffect
[ 954.674475] type=1400 audit(1452763357.805:327): avc: denied { write } for pid=1976 comm=“Binder_1” path=2F6465762F6173686D656D2F41436F646563202864656C6574656429 dev=“tmpfs” ino=17784 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:untrusted_app_tmpfs:s0 tclass=file permissive=1
[ 954.880237] type=1400 audit(1452763358.015:328): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=2422 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=file permissive=1
[ 954.899426] type=1400 audit(1452763358.035:329): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/1/cmdline” dev=“proc” ino=2422 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=file permissive=1
[ 954.919216] type=1400 audit(1452763358.065:330): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/1/cmdline” dev=“proc” ino=2422 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=file permissive=1
[ 956.975470] bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -84
[ 957.974542] vpu_service: power off…
[ 957.978015] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 957.983163] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e250000
[ 957.992836] done
[ 962.127311] vpu_service: power on
[ 962.130642] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 966.072840] vpu_service: power off…
[ 966.076350] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 966.081507] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e250000
[ 966.091208] done
[ 973.550384] Enter::rk29_hw_params----52
[ 973.555228] Enter:rk29_hw_params, 86, rate=44100
[ 973.559800] Enter:rk29_hw_params, 104, LRCK=64
[ 974.686329] vpu_service: power on
[ 974.689646] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 977.935997] init: sys_prop: permission denied uid:10055 name:media.cfg.audio.soundeffect
[ 978.050921] Enter::rk29_hw_params----52
[ 978.055879] Enter:rk29_hw_params, 86, rate=44100
[ 978.060510] Enter:rk29_hw_params, 104, LRCK=64
[ 982.434685] type=1400 audit(1452763386.015:331): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=8775 scontext=u:r:untrusted_app:s0 tcontext=u:r:ueventd:s0 tclass=file permissive=1
[ 982.453978] type=1400 audit(1452763386.035:332): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/122/cmdline” dev=“proc” ino=8775 scontext=u:r:untrusted_app:s0 tcontext=u:r:ueventd:s0 tclass=file permissive=1
[ 982.474223] type=1400 audit(1452763386.055:333): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/122/cmdline” dev=“proc” ino=8775 scontext=u:r:untrusted_app:s0 tcontext=u:r:ueventd:s0 tclass=file permissive=1
[ 982.497733] type=1400 audit(1452763386.085:334): avc: denied { read } for pid=1134 comm=“libwatch.so” name=“cmdline” dev=“proc” ino=6993 scontext=u:r:untrusted_app:s0 tcontext=u:r:wpa:s0 tclass=file permissive=1
[ 982.516894] type=1400 audit(1452763386.105:335): avc: denied { open } for pid=1134 comm=“libwatch.so” path=“/proc/867/cmdline” dev=“proc” ino=6993 scontext=u:r:untrusted_app:s0 tcontext=u:r:wpa:s0 tclass=file permissive=1
[ 982.536644] type=1400 audit(1452763386.125:336): avc: denied { getattr } for pid=1134 comm=“libwatch.so” path=“/proc/867/cmdline” dev=“proc” ino=6993 scontext=u:r:untrusted_app:s0 tcontext=u:r:wpa:s0 tclass=file permissive=1
[ 983.498683] init: sys_prop: permission denied uid:10055 name:media.cfg.audio.soundeffect
[ 1005.531403] vpu_service: power off…
[ 1005.534987] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 1005.540188] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e250000
[ 1005.549962] done
[ 1006.785583] vpu_service: power on
[ 1006.788961] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 1006.817110] init: sys_prop: permission denied uid:10055 name:media.cfg.audio.soundeffect
[ 1006.932236] Enter::rk29_hw_params----52
[ 1006.936994] Enter:rk29_hw_params, 86, rate=44100
[ 1006.941590] Enter:rk29_hw_params, 104, LRCK=64
[ 1013.708362] vpu_service: power off…
[ 1013.711900] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 1013.717081] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e250000
[ 1013.726794] done
[ 1018.850352] rk3288-lcdc lcdc0: win1:new_addr:0x107e9000 cur_addr:0x10000000–1
[ 1026.648463] vpu_service: power on
[ 1026.651798] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 1026.752120] Enter::rk29_hw_params----52
[ 1026.757084] Enter:rk29_hw_params, 86, rate=44100
[ 1026.761669] Enter:rk29_hw_params, 104, LRCK=64
[ 1036.665042] vpu_service: power off…
[ 1036.668641] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 1036.673800] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e250000
[ 1036.683757] done
[ 1042.185264] vpu_service: power on
[ 1042.188781] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 1042.289427] Enter::rk29_hw_params----52
[ 1042.294322] Enter:rk29_hw_params, 86, rate=44100
[ 1042.298999] Enter:rk29_hw_params, 104, LRCK=64
[ 1051.159293] vpu_service: power off…
[ 1051.162820] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 1051.167979] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e250000
[ 1051.177874] done
[ 1090.116289] vpu_service: power on
[ 1090.119729] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 1090.197211] Enter::rk29_hw_params----52
[ 1090.202204] Enter:rk29_hw_params, 86, rate=44100
[ 1090.206924] Enter:rk29_hw_params, 104, LRCK=64
[ 1137.475788] vpu_service: power off…
[ 1137.479293] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 1137.484453] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e250000
[ 1137.494382] done
[ 1140.770912] vpu_service: power on
[ 1140.774670] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 1140.880953] Enter::rk29_hw_params----52
[ 1140.885890] Enter:rk29_hw_params, 86, rate=44100
[ 1140.890690] Enter:rk29_hw_params, 104, LRCK=64
[ 1269.498300] VGA Devie disconnect
[ 1269.762365] type=1400 audit(1452763678.015:337): avc: denied { search } for pid=1134 comm=“libwatch.so” name=“122” dev=“proc” ino=8470 scontext=u:r:untrusted_app:s0 tcontext=u:r:ueventd:s0 tclass=dir permissive=1
DDR只有1G,硬件应该有问题了
天线接上了吗,如果接上后还有问题,怀疑有可能硬件问题
硬件问题的话找一下淘宝售后处理
天线接了的
zhansb 发表于 2016-1-14 17:51
DDR只有1G,硬件应该有问题了
版主,上面那个是开发板的输出信息,后面如果我们自己做的板子只有1G内存,系统是否需要重新编译?
