自己编译的固件起不来
重复打印如下信息
DDR Version 1.00 20140404
Channel a: DDR3 300MHz
Channel b: DDR3 300MHz
Memory OK
Memory OK
U-Boot 2014.01-00643-g77f8e4c-dirty (Apr 21 2014 - 15:36:44)
CPU: RK32xx
arm pll: 1008000000
general pll: 594000000
codec pll: 594000000
ddr pll: 300000000
new pll: 24000000
Board: RK32xx platform Board
DRAM: 128 MiB
arch_interrupt_init
storage init OK!
In: serial
Out: serial
Err: serial
In: serial
Out: serial
Err: serial
board_late_init
PowerKeyInit start
PowerKeyInit end
charger_init, charger_type = 1, dc_is_charging= 0
pmic_charger_setting charger_type = 1
i2c_set_bus_num: I2C bus = 0
rk_i2c_init: I2C bus = 0
i2c->regs_addr = ff650000,set clk(I2C_CLKDIV: 0x003f003f)
pmic_charger_setting charge ic id = 0xff
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
partition(uboot): offset=0x00002000, size=0x00002000
partition(misc): offset=0x00004000, size=0x00002000
partition(resource): offset=0x00006000, size=0x00008000
partition(kernel): offset=0x0000E000, size=0x00008000
partition(boot): offset=0x00016000, size=0x00010000
partition(recovery): offset=0x00026000, size=0x00010000
partition(backup): offset=0x00036000, size=0x0001A000
partition(cache): offset=0x00050000, size=0x00040000
partition(kpanic): offset=0x00090000, size=0x00002000
partition(system): offset=0x00092000, size=0x00180000
partition(metadata): offset=0x00212000, size=0x00002000
partition(userdata): offset=0x00214000, size=0x00200000
partition(radical_update): offset=0x00414000, size=0x00020000
partition(user): offset=0x00434000, size=0xFFFFFFFF
sn:1006120001000018
checkKey
vbus = 0
Loaded dtb file:rk-kernel.dtb,load_addr = 0x54df510 size:96667
node:78196 read logo_on switch from dts [0]
rkclk_soft_reset
got recovery cmd from misc.
fix ramdisk_addr:05bf0000
fix kernel_addr:02000000
SecureBootCheckOK:0
rk_bootm_start
booti: do_bootm_linux…
Loading Device Tree to 05431000, end 0544b99a … OK
undefined instruction
pc : [<55000004>] lr : [<05584588>]
sp : 0543d878 ip : 05431341 fp : 00000d93
r10: 00000009 r9 : 0545eb30 r8 : 05586c57
r7 : 05447c08 r6 : 0001a99b r5 : 05448c3c r4 : 21010000
r3 : 05431340 r2 : 00000000 r1 : 054310a8 r0 : 05431340
Flags: nZCv IRQs on FIQs off Mode SVC_32
Resetting CPU …
用官网上下载的固件就可以起来,是什么问题呢?
编译的固件大小和官方的差距大不,可能是parameter.txt分区的问题
我对比了一下正常启动的固件的分区和我编译的parameter.txt的分区是一样的
换loader
正在更新源码,完了再试试
楼主内核有没有编译错.
编译正式版(0930)开发板的内核:
cd ~/proj/firefly-rk3288/kernel
make firefly-rk3288_defconfig
make -j8 firefly-rk3288.img
编译公测版(0809)开发板的内核:
make firefly-rk3288_beta_defconfig
make -j8 firefly-rk3288_beta.img
我编译的是正式版0930,应该没错,现在感觉是uboot.bin的版本不对,不知道各位版主用的是什么版本?
楼主先确认两个问题:
1、楼主电源电流用多少A的,官方配置是2A
2、自己编译的固件大小和官方的固件对比下
换了一个uboot.bin起来了
请问大大直接下载默认版Android SDK后里的uboots编译就可以起来了吗?
