Linux not booting on AIORK3399
Hi,
I am trying to boot linux on a the AIO RK3399. I have tried both the rockchip-linux and the firefly limux branch. I compile the kernel into a boot.img using the default scripts ./build_all.sh in the rockchip-linux version or use the mkimg to combine the kern.imgand resource.img into one single image.
I can get uboot to show up but when linux starts booting it just hangs without throwing any specific error
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fef7000 s45800 r8192 d32024 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.mode=emmc androidboot.slot_suff4
[ 0.000000] software IO TLB [mem 0x7feae000-0x7feee000] (0MB) mapped at [ffffffc07feae000-ffff]
[ 0.000000] Memory: 2002904K/2064384K available (11582K kernel code, 1692K rwdata, 4412K rodat)
[ 0.000000] .init : 0xffffff8009030000 - 0xffffff8009140000 ( 1088 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bd0000 ( 11584 KB)
[ 0.000000] .rodata : 0xffffff8008bd0000 - 0xffffff8009030000 ( 4480 KB)
[ 0.000000] .data : 0xffffff8009140000 - 0xffffff80092e7008 ( 1693 KB)
[ 0.000000] ITS: allocated 65536 Devices @a300000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a290000
[ 0.000000] CPU0: using LPI pending table @0x000000000a2a0000
[ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/}
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclkk
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclkk
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, maxs
[ 0.002018] Console: colour dummy device 80x25
[ 0.002450] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 B)
[ 0.003416] pid_max: default: 32768 minimum: 301
[ 0.003986] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004623] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005989] Initializing cgroup subsys devices
[ 0.006416] Initializing cgroup subsys freezer
[ 0.006861] ftrace: allocating 41960 entries in 164 pages
[ 0.110640] sched-energy: Sched-energy-costs installed from DT
[ 0.111193] CPU0: update cpu_capacity 401
[ 0.111626] ASID allocator initialised with 32768 entries
[ 0.115247] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain creatd
[ 0.116536] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain d
[ 0.118665] Detected VIPT I-cache on CPU1
[ 0.118698] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.118728] CPU1: using LPI pending table @0x0000000000320000
[ 0.118771] CPU1: update cpu_capacity 401
[ 0.118775] CPU1: Booted secondary processor [410fd034]
[ 0.119299] Detected VIPT I-cache on CPU2
[ 0.119320] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.119349] CPU2: using LPI pending table @0x0000000000340000
[ 0.119376] CPU2: update cpu_capacity 401
[ 0.119379] CPU2: Booted secondary processor [410fd034]
[ 0.119898] Detected VIPT I-cache on CPU3
[ 0.119919] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.119947] CPU3: using LPI pending table @0x0000000000390000
[ 0.119973] CPU3: update cpu_capacity 401
[ 0.119977] CPU3: Booted secondary processor [410fd034]
[ 0.120489] Detected PIPT I-cache on CPU4
[ 0.120515] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.120555] CPU4: using LPI pending table @0x00000000003d0000
[ 0.120594] CPU4: update cpu_capacity 1024
[ 0.120597] CPU4: Booted secondary processor [410fd082]
[ 0.121127] Detected PIPT I-cache on CPU5
[ 0.121146] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.121186] CPU5: using LPI pending table @0x000000007d000000
[ 0.121214] CPU5: update cpu_capacity 1024
[ 0.121218] CPU5: Booted secondary processor [410fd082]
[ 0.121305] Brought up 6 CPUs
[ 0.133364] SMP: Total of 6 processors activated.
[ 0.133805] CPU features: detected feature: GIC system register CPU interface
[ 0.134481] CPU: All CPU(s) started at EL2
[ 0.134903] alternatives: patching kernel code
[ 0.136710] devtmpfs: initialized
[ 0.151627] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 191126s
[ 0.152606] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.153657] pinctrl core: initialized pinctrl subsystem
[ 0.154909] NET: Registered protocol family 16
[ 0.160658] cpuidle: using governor ladder
[ 0.165665] cpuidle: using governor menu
[ 0.166065] Registered FIQ tty driver
[ 0.166739] vdso: 2 pages (1 code @ ffffff8008bd6000, 1 data @ ffffff8009144000)
[ 0.167479] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168303] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.192587] console [ttyFIQ0] enabled
[ 0.193268] bootconsole [uart0] disabled
[ 0.194190] Registered fiq debugger ttyFIQ0
[ 0.223297] iommu: Adding device ff650000.vpu_service to group 0
[ 0.223899] iommu: Adding device ff660000.rkvdec to group 1
[ 0.224494] iommu: Adding device ff8f0000.vop to group 2
[ 0.225039] iommu: Adding device ff900000.vop to group 3
[ 0.225642] iommu: Adding device ff910000.cif_isp to group 4
[ 0.226210] iommu: Adding device ff920000.cif_isp to group 5
[ 0.228294] SCSI subsystem initialized
[ 0.228811] usbcore: registered new interface driver usbfs
[ 0.229338] usbcore: registered new interface driver hub
[ 0.229893] usbcore: registered new device driver usb
[ 0.230402] media: Linux media interface: v0.10
[ 0.230845] Linux video capture interface: v2.00
[ 0.231293] pps_core: LinuxPPS API ver. 1 registered
[ 0.231733] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@lin
[ 0.232553] PTP clock support registered
[ 0.234038] Advanced Linux Sound Architecture Driver Initialized.
[ 0.235087] Bluetooth: Core ver 2.21
[ 0.235430] NET: Registered protocol family 31
[ 0.235834] Bluetooth: HCI device and connection manager initialized
[ 0.236402] Bluetooth: HCI socket layer initialized
[ 0.236843] Bluetooth: L2CAP socket layer initialized
[ 0.237311] Bluetooth: SCO socket layer initialized
[ 0.238818] clocksource: Switched to clocksource arch_sys_counter
[ 0.286035] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.286963] NET: Registered protocol family 2
[ 0.287775] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.288546] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.289503] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.290173] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.290765] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.291619] NET: Registered protocol family 1
[ 0.292307] RPC: Registered named UNIX socket transport module.
[ 0.292847] RPC: Registered udp transport module.
[ 0.293264] RPC: Registered tcp transport module.
[ 0.293681] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.294896] Trying to unpack rootfs image as initramfs…
[ 0.481571] Freeing initrd memory: 3680K
[ 0.482456] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.483295] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.487067] Initialise system trusted keyring
[ 0.495161] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.496446] NFS: Registering the id_resolver key type
[ 0.496932] Key type id_resolver registered
[ 0.497303] Key type id_legacy registered
[ 0.497710] fuse init (API version 7.23)
[ 0.498453] SGI XFS with security attributes, no debug enabled
[ 0.503623] NET: Registered protocol family 38
[ 0.504056] Key type asymmetric registered
[ 0.504432] Asymmetric key parser ‘x509’ registered
[ 0.505027] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.505689] io scheduler noop registered
[ 0.506055] io scheduler deadline registered
[ 0.506557] io scheduler cfq registered (default)
[ 0.508356] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS supply regulator
[ 0.513963] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.514544] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.515135] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.056876] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.057597] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.059146] backlight supply power not found, using dummy regulator
[ 1.060457] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.061406] rk-vcodec ff650000.vpu_service: probe device
[ 1.061974] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07d24ac10
[ 1.062785] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.063366] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.064543] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.065178] rk-vcodec ff650000.vpu_service: init success
[ 1.066069] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.067082] rk-vcodec ff660000.rkvdec: probe device
[ 1.067553] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07d24b410
[ 1.068285] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.068801] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.069641] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.070230] rk-vcodec ff660000.rkvdec: init success
[ 1.072078] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.072748] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 N2
[ 1.075003] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.075673] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 6
http://en.t-firefly.com/doc/product/info/id/447.html
I have tried that but it doesnt seem to work. Is there something else I have to enable?
Are you try to upgrade newest update.img ?
I am trying to install all images built from source. Not using update.img(I have boot.img, uboot.img and the rest)
I have updated too, very suitable! survival race
One of the first things you notice about Friday Night Funkin is how satisfying the beat makes the game. You have to match the colored lines that move notes from left to right with the right keys at the fnf right time.
你的夢想是什麼?難道你不想在你的職業生涯中做出一番閃耀的成就嗎?肯定是想的吧。那麼,你就需要不斷提升自己,鍛煉自己。在IT行業中工作的你,通過什麼方法來實現自己的夢想呢?其中,參加IT認定考試並獲得認證資格,就是你提升自己水準的一種方式。現在,H3C的GB0-713-ENU考試就是一個非常受歡迎的考試。那麼,你也想拿到這個考試的認證資格嗎?那麼趕緊報名參加吧,Testpdf可以幫助你,所以不用擔心。
Thank you for sharing this breathtaking article, it’s truly amazing! The CAS-004 reliable exam voucher test questions are free! Wishing you success in your exam preparations!
The content of the article is very valuable and has inspired many new ideas in me. Free FCP_FAZ_AN-7.4 new test collection file exam resources—unlock your next promotion and salary increase!
