The Bluetooth is not working at all. Not the AP6356S wifi-bt module nor 2 USB dongle that i have got.
Saw it some ware that AP6356S is now in the kernel. So ti is just a question of compiling the drivers in to the kernel.
Kernel module is hci_bcm and the kernel compile support is
enable HCI_BCM, SERIAL_DEV_BUS, BT_HCI_UART_SERDEV
The manufacturer might be AMPAC - Broadcom
When will we see newer kernel and Ubuntu 18.04 for firefly?
I have also got rockpro64 board and it is also using kernel 4.4.
What is good about rockpro64 is that you can bypass emmc with a jumper and start from SD card or USB if you put bootloader in to the SPI module with a SD image.
