LVDS for RK3399C AIO for Android10
I was looking into using the LVDS HSX101H40C display with the RK3399C-AIO board, but have not been able to get it working yet. For the builds I have been attempting to use the rk3399-firefly-aio-lvds-HSX10140C project, but when looking at the files that support it, it appears that one is really for the RK3399J. When I received this device the board and panel were working properly with the stock android 7.1 image loaded on it, but when I go to use the Android10 build built with that project, the display is not working. Is there a different project I should be using or a specific set of changes to .dst files that can get this display working on the latest android build? The error message I am seeing during boot up is this.
0.207690] rockchip-vop ff900000.vop: Linked as a consumer to ff903f00.iommu
[ 0.210996] rockchip-drm display-subsystem: Linked as a consumer to ff8f0000.vop
[ 0.211028] rockchip-drm display-subsystem: Linked as a consumer to ff900000.vop
[ 0.211989] rockchip-drm display-subsystem: Linked as a consumer to ff940000.hdmi
[ 0.212302] rockchip-drm display-subsystem: Linked as a consumer to ff960000.dsi
[ 0.213174] rockchip-drm display-subsystem: defer getting devfreq
[ 0.213325] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 0.213443] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 0.213492] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 0.213670] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 0.213797] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.214217] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.214654] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 0.214706] dw-mipi-dsi ff960000.dsi: [drm:dw_mipi_dsi_bind] ERROR Failed to find panel or bridge: -517
[ 0.214726] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 0.215323] rockchip-drm display-subsystem: master bind failed: -517
[ 0.218242] panel-simple-dsi ff960000.dsi.0: ff960000.dsi.0 supply power not found, using dummy regulator
[ 0.218320] panel-simple-dsi ff960000.dsi.0: Linked as a consumer to regulator.0
[ 0.218353] panel-simple-dsi ff960000.dsi.0: ff960000.dsi.0 supply vsp not found, using dummy regulator
[ 0.218412] panel-simple-dsi ff960000.dsi.0: ff960000.dsi.0 supply vsn not found, using dummy regulator
No hesitation, just hitting like for this great content. The New study C-ARCON-2508 questions ebook exam questions are free for everyone—unlock career growth and salary increases!
Such a phenomenal article, I appreciate your sharing it with us. UiPath-ABAv1 exam online content is excellent and available for free.
IT業種が新しい業種で、経済発展を促進するチェーンですから、極めて重要な存在だということを良く知っています。JPNTestの MicrosoftのAZ-140J試験トレーニング資料は高度に認証されたIT領域の専門家の経験と創造を含めているものです。その権威性は言うまでもありません。あなたはJPNTestの学習教材を購入した後、私たちは一年間で無料更新サービスを提供することができます。
Fast2testは、認定資格を取得し、社内でより重要な地位を獲得することで、希望するより高い給与を達成するための最良かつ最速の方法を提供します。低品質のMB-500試験資料が会社に不信感をもたらす可能性があるという信念があるためです。 MB-500学習の質問は、メリットに満ちた否定できない優れた製品です。したがって、MB-500試験の資料は、私たち自身のイメージを高めることができます。一方、当社のMB-500試験の教材は、複雑な知識の本質をつかむのに役立つ非常に効果的です。
I’m inspired by the message in this article, thank you for sharing! I believe the Training CSSBB Solutions content will be helpful, and it’s totally free for you.
