I can see only linux 4.19 in the SDK, but I need at least linux 5.4. The documentation states that there is linux 5.10 working with the itx-3568. Where can I get the sources?
The sdk I have is rk356x_linux_release_v1.3.0b_20221213, last commit
The linux kernel in firefly’s sdk is 4.19, and the image is built quite ok, but I need at least 5.4. So I tried to build it according to buildroot’s instructions (arch/arm64/configs/rockchip_linux_defconfig), and got Image.gz and rootfs (cpio, ext2 ant tar). I reckon, all I have to do, is to partition the emmc the right way. What should be done to make the firmware image out of this?
Kernel 5.10 from https://github.com/linux-rockchip also is built, but w/o modules (ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- make -j6 rockchip_linux_defconfig).
The whole deal is being done in linux mint, hence I don’t think that the containerization (docker, podman, etc) should make any sense…
I have just built kernel.img and upgrade_tool refuses to flash it to emmc with
# ./upgrade_tool uf rk356x_linux_release/rk356x_linux_release_v1.3.0b_20221213/kernel/kernel.img
Using /home/geekay/devel/firefly3568/rk356x_linux_release/rk356x_linux_release_v1.3.0b_20221213/tools/linux/Linux_Upgrade_Tool/Linux_Upgrade_Tool/config.ini
Program Log will save in the /root/upgrade_tool/log/
Loading firmware...
Loading firmware failed!
Note:invalid tag of firmware,please check firmware
What else should be done to flash the new kernel.img?
Your article really caught my attention, thank you for sharing it. Get free CY0-001 latest test braindumps to level up your IT knowledge. Wishing you success!
Wenn Sie Ihre IT-Fähigkeiten erhöhen und die CIPS L4M6 Zertifizierungsprüfung einmalig bestehen möchten, können Sie auf ZertSoft vertrauen. Denn ZertSoft kann Ihnen helfen, das Prüfungszertifikat zu bekommen, indem wir Ihnen die zutreffendesten und genauesten Fragenkataloge zur CIPS L4M6 Zertifizierungsprüfung anbieten. Wenn Sie mit dem Kaufen noch zögern, können Sie die Demo auf unserer Webseite ZertSoft herunterladen. Wir sind sicher, dass Sie nicht enttäuscht sein werden.
I’m genuinely grateful for your share, this article is fantastic! I’m offering the DP-700 valid braindumps free exam that helped me land my promotion and pay raise. It’s free today—good luck achieving your career goals!
This article is absolutely inspiring, thank you for sharing! The 300-715 valid exam review helped me get promoted and earn a raise, and now it’s open for free. Wishing you all rapid career growth!
