linux-QT::fakeroot: preload library `libfakeroot.so' not found, aborting.
编译buildroot时:
在linux-QT的buildroot源码目录下:
buildroot$ make
printf ’ /bin/busybox f 4755 0 0 - - - - -\n /usr/libexec/dbus-daemon-launch-helper f 4755 0 0 - - - - -\n /dev/console c 622 0 0 5 1 - - -\n’ >> /home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/build/_device_table.txt
echo “/home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/host/usr/bin/makedevs -d /home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/build/_device_table.txt /home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/target” >> /home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/build/_fakeroot.fs
echo " PATH=“/home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/host/bin:/home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/host/sbin:/home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/host/usr/bin:/home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/host/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games” mke2img -d /home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/target -G 4 -R 1 -B 0 -I 0 -o /home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/images/rootfs.ext2" >> /home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/build/_fakeroot.fs
chmod a+x /home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/build/_fakeroot.fs
PATH=“/home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/host/bin:/home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/host/sbin:/home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/host/usr/bin:/home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/host/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games” /home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/host/usr/bin/fakeroot – /home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/build/_fakeroot.fs
fakeroot: preload library `libfakeroot.so’ not found, aborting.
make[1]: *** [/home/niuyi/rk3288_src/qt/system.img/buildroot-2016.02/output/images/rootfs.ext2] Error 1
make: *** [_all] Error 2
buildroot$sudo apt-get install libfakeroot
Reading package lists… Done
Building dependency tree
libfakeroot is already the newest version
已经是最新版本,怎么还是not found?
如何解决这个问题?
楼主问题解决了吗?我也遇到了
