android5.1修改内核后无法正常进入系统
因系统需要用最新的android5.1源码commit:3e3038c,添加了7.85寸液晶屏功能,及安装了串口驱动,分别根据http://developer.t-firefly.com/forum.php?mod=viewthread&tid=8121&highlight=7.85��和http://developer.t-firefly.com/thread-1085-1-2.html操作修改了源码,编译了内核kernel.img以及boot.img,resouce.img烧录后无法正常启动,调试信息见2楼
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory
OK
Memory
OK
U-Boot 2014.10-RK3288-10 (Oct 13
2016 - 10:04:48)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
po
wer key: bank-0 pin-5
pm
ic:act8846
can
't find dts node for pwm1
Secur
eBootEn = 0, SecureBootLock = 0
#Boot ver: 2016-10-13#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
pll_src = 0, dclk_hz = 205000000, dclk_div = 2
edp pll locke
d
link training success.
unable to config video
no fuel gauge found
SDM_Read FLT_ERROR, LBA = 197e0, iret = 4
SdmmcInit = 2 0
SdmmcInit = 2 0
ERROR: [rk_load_image_from_storage]: bootrk: failed to read ramdisk
Unable to boot:boot
try to start recovery
Secure Boot state: 0
kernel @ 0x02000000 (0x006a2ee8)
ramdisk @ 0x05bf0000 (0x002c6ad0)
bootrk: do_bootm_linux…
Loading Device Tree to
05600000, end 0561c78d … OK
[ 0.000000] Linux version 3.10.0 (ruanjg@tchipserver2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #23 SMP PREEMPT Thu Dec 1 10:47:58 CST 2016
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000,
offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(28000000) align(0)
[ 0.000000] cma: CMA: reserved 640 MiB at 55c00000
[ 0.000000] ion_reserve: cma reserved base 55c00000 size 671088640
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f15000 s13376 r8192 d15296 u36864
[ 0.000000] Bui
lt 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00200000@0x0039C000(userdata),0x00020000@0x0059C000(radical_update),-@
0x005BC000(user) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2016-10-13_10:04:48
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1353180k/1353180k available, 743972k reserved, 884736K highmem
[ 0.000000] vector : 0xffff0000 - 0xf
fff1000 ( 4 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0ba8704 (11906 kB)
[ 0.000000] .init : 0xc0ba9000 - 0xc0c02440 ( 358 kB)
[ 0.000000] .data : 0xc0c04000 - 0xc0d96140 (1609 kB)
[ 0.000000] .bss : 0xc0d96140 - 0xc0eb92bc (1165 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:11
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:10
[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10
000000ns, wraps every 4294967286ms
[ 0.344422] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.344437] pid_max: default: 32768 minimum: 301
[ 0.344554] Security Framework initialized
[ 0.344571] SELinux: Initializing.
[ 0.344644] Mount-cache hash table entries: 512
[ 0.345285] Initializing cgroup subsys debug
[ 0.345301] Initializing cgroup subsys memory
[ 0.345327] Initializing cgroup subsys freezer
[ 0.345357] CPU: Testing write buffer coherency: ok
[ 0.345671] /cpus/cpu@0 missing clock-frequency property
[ 0.345684] /cpus/cpu@1 missing clock-frequency property
[ 0.345693] /cpus/cpu@2 missing clock-frequency property
[ 0.345702] /cpus/cpu@3 missing clock-frequency property
[ 0.345754] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.345804] Setting up static identity map for 0xc085be38 - 0xc085be90
[ 0.348098] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x184d (version 3.1)
[ 0.422572] CPU1: Booted secondary processor
[ 0.422605] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.442241] CPU2: Booted secondary processor
[ 0.442265] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.461947] CPU3: Booted secondary processor
[ 0.461971] CPU3: thread -1, cpu 3, socket 5, mpi
dr 80000503
[ 0.462072] Brought up 4 CPUs
[ 0.462101] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.462109] CPU: All CPU(s) started in SVC mode.
[ 0.462844] devtmpfs: initialized
[ 0.467064] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.468163] pinctrl core: initialized pinctrl subsystem
[ 0.468409] regulator-dummy: no parameters
[ 0.492997] NET: Registered protocol family 16
[ 0.494790] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.495125] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc0e9458c (version 0.1)
[ 0.495376] Registered FIQ tty driver
[ 0.495782] fiq-debugger is disabled in device tree
[ 0.496410] rockchip_get_bank_d
ata:name=base start=0xff750000,end=0xff7500ff
[ 0.496431] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.496450] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.496466] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.496558] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.496623] rockchip_get_bank_data:name=/pinctrl@ff7
70000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.496694] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.496759] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.496820] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.496883] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.496945] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.497008] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00f
f
[ 0.497076] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.497141] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.497154] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.497165] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.497176] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.497802] rockchip_interrupts_register:bank_num=7
[ 0.499711] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.499733] of_get_gpio_init_config:gpio[1] = 136, value = 0
[ 0.499797] rockchip_pinctrl_probe:init ok
[ 0.506883] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.506969] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.506982] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.507148] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.507222] rk_iommu ff950800.vip_mmu: IOVMM: Created
[ 0.507234] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.507403] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.507475] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.507487] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.507652] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.507730] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.507742] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.507916] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.507988] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.508000] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.
508165] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.508239] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.508252] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.508431] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.508504] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.508516] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.510347]
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.510360] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.510972] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.510999] DDR DEBUG: version 1.00 20150126
[ 0.511028] DDR DEBUG: Channel a:
[ 0.511036] DDR DEBUG: DDR3 Device
[ 0.511050] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.511058] DDR DEBUG: Channel b:
[ 0.511065] DDR DEBUG: DDR3 Device
[ 0.511077] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.511086] DDR DEBUG: addr=0xda0000
[ 0.511096] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.511105] DDR DEBUG: socAddr[0]=0xda0000, socAddr[1]=0xda0100
[ 0.511114] DDR DEBUG: chAddr[0]=0xda0000, chAddr[1]=0xda0000
[ 0.511125] DDR DEBUG: dtar[0]=0x1b4000, dtar[1]=0x1b4000
[ 0.511179] DDR DEBUG: init success!!! freq=200MHz
[ 0.511186] DDR DEBUG
: Channel a:
[ 0.511199] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.511212] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.511224] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.511236] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.511247] DDR DEBUG: ZE
RR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.511256] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.511265] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.511272] DDR DEBUG: Channel b:
[ 0.511284] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.511296] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.511309] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.511321] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.511332] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.511341] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.511349] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.535722] bio: create slab at 0
[ 0.536207] Rockchip hdmi driver version 2.0
[ 0.
536207] .
[ 0.537394] SCSI subsystem initialized
[ 0.537557] usbcore: registered new interface driver usbfs
[ 0.537602] usbcore: registered new interface driver hub
[ 0.537691] usbcore: registered new device driver usb
[ 0.540366] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.541321] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.541789] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.542041] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.542832] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.542964] media: Linux media interface: v0.10
[ 0.543014] Linux video capture interface: v2.00
[ 0.543072] pps_core: LinuxPPS API ver. 1 registered
[ 0.543082] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.543102] PTP clock support registered
[ 0.543162] i2c-core: driver [bq24296] using legacy suspend method
[ 0.543171] i2c-core: driver [bq24296] using legacy resume method
[ 0.543916] ion_drm_heap_create: 0@0
[ 0.544036] Rockchip ion module is successfully loaded (v1.1)
[ 0.544197] Advanced Linux Sound Architecture Driver Initialized.
[ 0.544635] Bluetooth: Core ver 2.16
[ 0.544671] NET: Registered protocol family 31
[ 0.544680] Bluetooth: HCI device and connection manager initialized
[ 0.544696] Bluetooth: HCI socket layer initialized
[ 0.544709] Bluetooth: L2CAP socket
layer initialized
[ 0.544736] Bluetooth: SCO socket layer initialized
[ 0.544970] cfg80211: Calling CRDA to update world regulatory domain
[ 0.545685] act8846_i2c_probe,line=898
[ 0.546682] act8846_parse_dt,line=746
[ 0.547173] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.547194] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.547209] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.547224] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.549299] act_dcdc1: 1200 mV
[ 0.552254] vccio: 3300 mV
[ 0.554111] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.557061] act_dcdc4: 2000 mV
[ 0.558297] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.560595] act_ldo2: 1050 mV
[ 0.562900] act_ldo3: 2800 mV
[ 0.565194] act_ldo4: 3300 mV
[ 0.567488] act_ldo5: 3300 mV
[ 0.569810] act_ldo6: 1100 mV
[ 0.572125] vcc_18: 1800 mV
[ 0.574436] act_ldo8: 1850 mV
[ 0.579191] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.583907] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.584693] rk808_i2c_probe,line=1355
[ 0.586025] The device is not rk808 -11
[ 0.586110] rk808: probe of
0-001b failed with error -11
[ 0.586190] i2c-core: driver [rk818] using legacy suspend method
[ 0.586200] i2c-core: driver [rk818] using legacy resume method
[ 0.587918] Switching to clocksource arch_sys_counter
[ 0.611580] rga: Module initialized.
[ 0.612295] rga2 ff920000.rga: rga ion client create success!
[ 0.612463] rga: Driver loaded succesfully
[ 0.612669] fb disp policy is box
[ 0.612711] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.612722] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.613021] rk-screen rk_screen.8: rockchip screen probe success
[ 0.613194] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
[ 0.613216] rk32-lvds: probe of ff96c000.lvds failed with error -22
[ 0.613709] rk32-edp rk3
2-edp: failed to get reset
[ 0.613722] rk32-edp rk32-edp: failed to get reset
[ 0.613823] rk32-edp rk32-edp: rk32 edp driver probe success
[ 0.614364] pwr_ctr_name:lcd_en
[ 0.614364] pwr_type:gpio
[ 0.614364] gpio:13
[ 0.614364] atv_val:1
[ 0.614364] delay:10
[ 0.614364]
[ 0.614611] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.614922] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.615091] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.615265] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.615990] rk3288-lcdc lcdc0: lcdc0: dclk:205000000>>fps:61
[ 0.616005] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.639962] rk_battery_charger_detect_cb , battery_charger_detect 1
0.662980] alloc_buffer:ion_phy_addr=0x10000000
[ 0.682813] fb0:phy:10000000>>vir:e0991000>>len:0x2500000
[ 0.702852] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaaf000
[ 0.702883] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.703096] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.703109] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.703386] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.703729] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.703907] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.704077] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.704887] unknow screen type: 0
[ 0.704960] rk3288-lcdc lcdc1: lcdc1: dclk:205000000>>fps:1991
[ 0.704974] rk3288-lcdc
lcdc1: wakeup from standby!
[ 0.710732] fb4:phy:10000000>>vir:e0991000>>len:0x2500000
[ 0.710748] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 0.711617] rockchip_set_mux:warning ignore bank num 15
[ 0.711768] rockchip_set_mux:warning ignore bank num 15
[ 0.711888] rockchip_set_mux:warning ignore bank num 15
[ 0.712007] rockchip_set_mux:warning ignore bank num 15
[ 0.712129] rockchip_set_mux:warning ignore bank num 15
[ 0.712242] rockchip_set_mux:warning ignore bank num 15
[ 0.712822] rockchip_set_mux:warning ignore bank num 15
[ 0.712983] rockchip_set_mux:warning ignore bank num 15
[ 0.713526] rockchip_set_mux:warning ignore bank num 15
[ 0.713677] rockchip_set_mux:warning ignore bank num 15
0.714228] rockchip_set_mux:warning ignore bank num 15
[ 0.714388] rockchip_set_mux:warning ignore bank num 15
[ 0.714945] rockchip_set_mux:warning ignore bank num 15
[ 0.715098] rockchip_set_mux:warning ignore bank num 15
[ 0.716730] NET: Registered protocol family 2
[ 0.717386] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.717462] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.717534] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.717589] TCP: reno registered
[ 0.717604] UDP hash table entries: 256 (order: 1, 8192
bytes)
[ 0.717628] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.717812] NET: Registered protocol family 1
[ 0.718438] Unpacking initramfs…
[ 0.855744] Freeing initrd memory: 2840K (c5bf0000 - c5eb6000)
[ 0.856464] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.857042] vcodec_service: probe device ff9a0000.vpu_service
[ 0.857244] vcodec_service: No reset resource define
[ 0.857415] vcodec_service: ff9a0000.vpu_service: power on
[ 0.857502] vcodec_service: probe device ff9a0000.vpu_serv
ice
[ 0.857517] vcodec_service: checking hw id 4831
[ 0.858531] vcodec_service: ff9a0000.vpu_service: power off…
[ 0.858576] vcodec_service: done
[ 0.858585] vcodec_service: init success
[ 0.858660] vcodec_service: probe device ff9c0000.hevc_service
[ 0.858999] vcodec_service: ff9c0000.hevc_service: power on
[ 0.859061] vcodec_service: probe device ff9c0000.hevc_service
[ 0.859076] vcodec_service: checking hw id 6867
[ 0.859323] vcodec_service: ff9c0000.hevc_service: power off…
[ 0.859363] vcodec_service: done
[ 0.859371] vcodec_service: init success
[ 0.859514] rknandbase v1.0 2014-03-31
[ 0.859643] rknand: probe of ff400000.nandc failed with error -1
[ 0.859759] rknand_driver:ret = 0
[ 0.861614] audit: initializing netlink socket (disabled)
[ 0.861681] type=2000 audit(0.510:1): initialized
[ 0.862488] bounce pool size: 64 pages
[ 0.867095] fuse init (API version 7.22)
[ 0.867473] msgmni has been set to 952
0.869306] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.869324] io scheduler noop registered
[ 0.869334] io scheduler deadline registered
[ 0.869449] io scheduler cfq registered (default)
[ 0.871063] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 0.871758] IEP Driver loaded succesfully
[ 0.871849] Module initialized.
[ 0.872664] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.872681] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.874025] dma-pl330 ff
250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.874042] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.874343] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API
[ 0.874359] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM
[ 0.874368] pwm_regulator_probe:error
[ 0.874389] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral
[ 0.874584] rk_serial.c v1.8 2014-03-04
[ 0.874811] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 8
7) is a rk29_serial.0
[ 0.874999] serial ff180000.serial: membase e4ebe000
[ 0.875160] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 0.875341] serial ff190000.serial: membase e4ee2000
[ 0.875482] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 0.875575] 2, baud is:115200
[ 0.877148] console [ttyS2] enabled
[ 0.877323] serial ff690000.serial: membase fed60000
[ 0.877518] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 0.877686] serial ff1b0000.serial: membase e4ee4000
[ 0.880513] loop: module loaded
[ 0.880885] zram: Created 1 device(s) …
[ 0.881065] i2c i2c-1: mpu_probe: 0
0.881187] 6mldl_cfg:Reset MPU6050 B1
[ 0.905198] mldl_cfg:prod_ver 8 , prod_rev 165
[ 0.910319] i2c i2c-1: Installing irq using 192
[ 0.910337] i2c i2c-1: Module Param interface = mpuirq
[ 0.910645] i2c i2c-1: inv_mpu_register_slave: +mpu6050 Type 1: Addr: 68 IRQ: 0, Adapt: 1
[ 0.911146] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 0.911161] i2c-core: driver [mpu6050B1] using legacy resume method
[ 0.911179] mpu_init: Probe name mpu6050B1
[ 0.911338] ak8963_mod_init: Probe name ak8963_mod
[ 0.912100] SCSI Media Changer driver v0.25
[ 0.912361] dws->regs: e4ee6000
[ 0.913597] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[ 0.913890] tun: Universal TUN/TAP device driver, 1.6
[ 0.913903] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.914018] vmac_init.
[ 0.914595] stmmac_probe_config_dt: Can not read property: pmu_
regulator.
[ 0.914612] stmmac_probe_config_dt: clock input/output? (input).
[ 0.914625] stmmac_probe_config_dt: TX delay(0x30).
[ 0.914637] stmmac_probe_config_dt: RX delay(0x20).
[ 0.914685] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 0.914697] stmmc_pltfr_init:
[ 0.914706] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 0.914729] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 0.914741] stmmc_pltfr_init: init for RGMII
[ 0.914752] tx delay=0x30
[ 0.914752] rx delay=0x20
[ 0.914768] tx delay=0x30
[ 0.914768] rx delay=0x20
[ 0.915211] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.915224] Normal descriptors
[ 0.915232] Ring mode enabled
[ 0.915244] DMA HW capability register supported
0.915256] RX Checksum Offload Engine supported (type 2)
[ 0.915266] TX Checksum insertion supported
[ 0.915276] Wake-Up On Lan supported
[ 0.915311] Enable RX Mitigation via HW Watchdog Timer
[ 0.915747] PPP generic driver version 2.4.2
[ 0.915890] PPP BSD Compression module registered
[ 0.915904] PPP Deflate Compression module registered
[ 0.915928] PPP MPPE Compression module registered
[ 0.915941] NET: Registered protocol family 24
[ 0.915979] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.915994] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.916007] Rockchip WiFi SYS interface (V1.00) …
[ 0.91
6042] esp_mem_init enter date Oct 24 2016 17:19:46
[ 0.916054] esp_mem_init VERSION [V2.5]
[ 0.916098] esp_mem_init complete
[ 0.916182] usbcore: registered new interface driver catc
[ 0.916221] usbcore: registered new interface driver kaweth
[ 0.916234] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.916281] usbcore: registered new interface driver pegasus
[ 0.916323] usbcore: r
egistered new interface driver rtl8150
[ 0.916362] usbcore: registered new interface driver r8152
[ 0.916374] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.916440] usbcore: registered new interface driver hso
[ 0.916484] usbcore: registered new interface driver asix
[ 0.916525] usbcore: registered new interface driver ax88179_178a
[ 0.916570] usbcore: registered new interface driver cdc_ether
[ 0.916609] usbcore: registered new interface driver cdc_eem
[ 0.916647] usbcore: registered new interface driver dm9601
[ 0.916685] usbcore: registered new interface driver dm9620
[ 0.916731] usbcore: registered new interface driver smsc75xx
[ 0.916777] usbcore: registered
new interface driver smsc95xx
[ 0.916822] usbcore: registered new interface driver gl620a
[ 0.916863] usbcore: registered new interface driver net1080
[ 0.916903] usbcore: registered new interface driver plusb
[ 0.916943] usbcore: registered new interface driver rndis_host
[ 0.916981] usbcore: registered new interface driver cdc_subset
[ 0.917018] usbcore: registered new interface driver zaurus
[ 0.917064] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.917128] usbcore: registered new interface driver int51x1
[ 0.917175] usbcore: registered new interface driver kalmia
[ 0.917215] usbcore: registered new interface driver ipheth
[ 0.917257] usbcore: registered new interface driver sierra_net
[ 0.917297]
usbcore: registered new interface driver cx82310_eth
[ 0.917345] usbcore: registered new interface driver cdc_ncm
[ 0.917384] usbcore: registered new interface driver qmi_wwan
[ 0.917429] usbcore: registered new interface driver cdc_mbim
[ 0.917442] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.919888] EHCI: ehci_rk_probe e4f40000 e4f40010
[ 0.919905] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 0.919936] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 0.920264] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 0.932401] rockchip_ehci_host ff5
00000.usb: USB 2.0 started, EHCI 1.00
[ 0.932487] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.932504] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.932520] usb usb1: Prer: Linux 3.10.0 ehci_hcd
[ 0.932547] usb usb1: SerialNumber: ff500000.usb
[ 0.933011] hub 1-0:1.0: USB hub found
[ 0.933036] hub 1-0:1.0: 1 port detected
[ 0.933201] EHCI: ehci_rk_probe ok
[ 0.933318] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.933621] usbcore: registered new interface driver cdc_acm
[ 0.933636] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.933692] usbcore: registered new interface driver usblp
[ 0.933736] usbcore: registered new interface driver cdc_wdm
[ 0.933798] usbco
re: registered new interface driver usb-storage
[ 0.933838] usbcore: registered new interface driver ums-alauda
[ 0.933882] usbcore: registered new interface driver ums-cypress
[ 0.933922] usbcore: registered new interface driver ums-datafab
[ 0.933960] usbcore: registered new interface driver ums_eneub6250
[ 0.933998] usbcore: registered new interface driver ums-freecom
[ 0.934038] usbcore: registered new interface driver ums-isd200
[ 0.934076] usbcore: registered new interface driver ums-jumpshot
[ 0.934115] usbcore: registered new interface driver ums-karma
[ 0.934155] usbcore: registered new interface driver ums-onetouch
[ 0.934234] usbcore: registered new interface driver ums-sddr55
[ 0.934278] usbcore: registered new interface
driver ums-usbat
[ 0.934367] usbcore: registered new interface driver usbserial
[ 0.934416] usbcore: registered new interface driver usbserial_generic
[ 0.934449] usbserial: USB Serial support registered for generic
[ 0.934491] usbcore: registered new interface driver option
[ 0.934522] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.934597] usbcore: registered new interface driver trancevibrator
[ 0.934610] usb20_otg: version 3.10a 21-DEC-2012
[ 0.935060] e4f80040
[ 0.935073] Core Release: 3.10a
[ 0.935086] Setting default values for core params
[ 0.935230] Using Buffer DMA mode
[ 0.935243] Periodic Transfer Interrupt Enhancement - disabled
[ 0.935254] Multiprocessor Interrupt Enhancement - disabled
[ 0.935266] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.935277] ^^^^^^^^^^^^^^^^^Device Mode
[ 0.935291] Dedicated Tx FIFOs mode
[ 0.935312] pcd_init otg_dev = ddf41000
[ 0.935471] usb20_otg ff580000.usb: DWC OTG Controller
[ 0.935503] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 0.935533] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 0.935594] usb usb2: New USB device found, idVendor=1d6b,:
[ 0.935626] usb usb2: Product: DWC OTG Controller
[ 0.935638] usb usb2: Manufacturer:
Linux 3.10.0 dwc_otg_hcd
[ 0.935651] usb usb2: SerialNumber: ff580000.usb
[ 0.936077] hub 2-0:1.0: USB hub found
[ 0.936102] hub 2-0:1.0: 1 port detected
[ 0.936421] usb20_host: version 3.10a 21-DEC-2012
[ 0.938952] e5000040
[ 0.938967] Core Release: 3.10a
[ 0.938979] Setting default values for core params
[ 0.939111] Using Buffer DMA mode
[ 0.939123] Periodic Transfer Interrupt Enhancement - disabled
[ 0.939134] Multiprocessor Interrupt Enhancement - disabled
[ 0.939146] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.939156] ^^^^^^^^^^^^^^^^^^Host Mode
[ 0.939186] usb20_host ff540000.usb: DWC OTG Controller
[ 0.939213] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 0.939246] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 0.939339] In
it: Power Port (0)
[ 0.939396] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.939414] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.939428] usb usb3: Product: DWC OTG Controller
[ 0.939441] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.939454] usb usb3: SerialNumber: ff540000.usb
[ 0.939873] hub 3-0:1.0: USB hub found
[ 0.939901] hub 3-0:1.0: 1 port detected
[ 0.940600] usbcore: registered new interface driver xpad
[ 0.940657] usbcore: registered new interface driver usb_acecad
[ 0.940703] usbcore: registered new interface driver aiptek
[ 0.940747] usbcore: registered new interface driver gtco
[ 0.940792] usbcore: registered new interface driver hanwang
0.940843] usbcore: registered new interface driver kbtab
[ 0.940896] usbcore: registered new interface driver wacom
[ 0.941027] ==gsl_ts_init==
[ 0.941098] GSLX680 Enter gsl_ts_probe
[ 0.941370] gsl_ts_probe–1282, i2c_master_recv sucess
[ 0.941385] ==kzalloc success=
[ 0.941397] gsl_ts_probe-1313
[ 0.961912] [GSLX680] Enter gslX680_ts_init
[ 0.962156] input: gslX680 as /devices/ff140000.i2c/i2c-1/1-0040/input/input0
[ 0.962331] gsl_ts_probe-1348
[ 0.962344] org chip_type=36
[ 1.021680] chip_type=36, reg=36
[ 1.079977] test_i2c-405: Enter
[ 1.080458] I read reg 0xf0 is 0
[ 1.099978] I write reg 0xf0 0x12
[ 1.119802] I read reg 0xf0 is 0x12
[ 1.119814] test_i2c-424: Exit
[ 1.286620] ==
===========gsl_load_fw start==============
[ 1.286632] --------------3680B-----------------------
[ 2.222773] =============gsl_load_fw end==============
[ 2.222788] ----------3680B---------
[ 2.309986] ----------3680B---------
[ 2.369947] [GSLX680] End gsl_ts_probe
[ 2.370003] ret=0
[ 2.370311] sensor_register_slave:mma8452,id=17
[ 2.370326] sensor_register_slave:gs_mc3230,id=23
[ 2.370335] gsensor_init
[ 2.370347] sensor_register_slave:mpu6880_acc,id=24
[ 2.370358] sensor_register_slave:mpu6500_acc,id=25
[ 2.370370] sensor_register_slave:cm3217,id=48
[ 2.370381] sensor_register_slave:cm3218,id=49
[ 2.370632] .. rk pwm remotectl v1.1 init
[ 2.370892] input: ff680000.pwm as /devices/ff680000.pwm/input/input1
[ 2.375763] rtc_hym8563 0-0051: rtc core: regi
stered hym8563 as rtc0
[ 2.375816] i2c /dev entries driver
[ 2.376501] IR NEC protocol handler initialized
[ 2.376514] IR RC5(x) protocol handler initialized
[ 2.376524] IR RC6 protocol handler initialized
[ 2.376534] IR JVC protocol handler initialized
[ 2.376544] IR Sony protocol handler initialized
[ 2.376554] IR RC5 (streamzap) protocol handler initialized
2.376564] IR SANYO protocol handler initialized
[ 2.376575] IR MCE Keyboard/mouse protocol handler initialized
[ 2.376736] usbcore: registered new interface driver uvcvideo
[ 2.376748] USB Video Class driver (1.1.1)
[ 2.376761] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 2.378227] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 2.378251] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 2.378271] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 2.378290] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 2.378328] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 2.378328]
[ 2.378407] D1:camsys_mipiphy_probe_cb(186): ff910000.i
sp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 2.378557] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe4ef8000 size: 0x4000)
[ 2.379254] D1:camsys_platform_probe(1447): ff910000.isp memory:
[ 2.379273] D1:camsys_platform_probe(1457): Register memory (phy: 0xff910000 vir: 0xe4f20000 size: 0x10000)
[ 2.379290] D1:camsys_platform_probe(1452): I2c memory (phy: 0x1dee1000 vir: 0xddee1000 size: 0x1000)
[ 2.379305] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 2.379318] D1:camsys_platform_probe(1472): Probe ff910000.isp device success
[ 2.379767] not find test_power_in
it dev node
[ 2.379826] i2c-core: driver [bq27320] using legacy suspend method
[ 2.379838] i2c-core: driver [bq27320] using legacy resume method
[ 2.380200] rockchip_temp_probe,line=364
[ 2.437905] tsadc ff280000.tsadc: initialized
[ 2.438290] device-mapper: uevent: version 1.0.3
[ 2.438553] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 2.438860] Bluetooth: HCI UART driver ver 2.2
[ 2.438876] Bluetooth: HCI H4 protocol initialized
[ 2.438887] Bluetooth: HCILL protocol initialized
[ 2.438899] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 2.438911] rtk_btusb: Register usb char device interface f
or BT driver
[ 2.439095] usbcore: registered new interface driver rtk_btusb
[ 2.442426] cpufreq version 1.0, suspend freq 1200 MHz
[ 2.442630] cpuidle: using governor ladder
[ 2.442643] cpuidle: using governor menu
[ 2.442680] Synopsys Designware Multimedia Card Interface Driver
[ 2.442693] MHSC version = Ver 2.00 2015-06-10
[ 2.443011] dw cru_regsbase addr 0x1d8.
[ 2.443023] dw cru_reset_offset val 3.
[ 2.443039] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 2.443081] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 2.443390] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 2.443551] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 2.443679] 1358..dw_mci_set_ios: no card. [mmc0]
[ 2.457600] 1358..dw_mci_set_ios: no card. [mmc0]
[ 2.477308] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 2
.477329] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo/sbin/sh: No controlling tty: open /dev/tty: No such device or a
[ 2.477347] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 2.477654] dw cru_regsbase addr 0x1d8.
[ 2.477667] dw cru_reset_offset val 0.
[ 2.47ddress
/sbin/sh: warning: won’t have full job control
7681] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 2.477719] dwmmc_rockchip ff0c0000.rk
[ 2.478482] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 2.478635] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 2.479087] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 2.479169] 1358..dw_mci_set_ios: no card. [mmc1]
[ 2.496948] 1358..dw_mci_set_ios: no card. [mmc1]
[ 2.509405] mmc0: BKOPS_EN bit is not set
[ 2.511281] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 2.513566] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 2.513590] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 2.513610] [mmc0] tuning r
egsbase addr 0x218.
[ 2.514395] [mmc0] Data transmission error !!! MINTSTS: [0x00002000]
[ 2.514406] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 2.514436] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 2.514462] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 2.514470] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 2.514492] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 2.514540] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-248 (23 len)
[ 2.514553] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 282-282 (1 len)
[ 2.514564] dwmmc_rockchip
ff0f0000.rksdmmc: Best phase range 0-248 (23 len)
[ 2.514573] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 124
[ 2.514616] mmc0: new HS200 MMC card at address 0001
[ 2.514884] mmcblk0: mmc0:0001 AJNB4R 14.5 GiB
[ 2.515205] rkpart: partition size too small (4)
[ 2.515222] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 2.515231] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 2.515241] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 2.515249] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 2.515258] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 2.515266] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 2.515275] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 2.515283] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 2.515292] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 2.515300] kpanic: 0x01
2000000 – 0x012400000 (4 MB)
[ 2.515308] system: 0x012400000 – 0x072400000 (1536 MB)
[ 2.515316] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 2.515325] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 2.515333] userdata: 0x073800000 – 0x0b3800000 (1024 MB)
[ 2.515341] radical_update: 0x0b3800000 – 0x0b7800000 (64 MB)
[ 2.515350] user: 0x0b7800000 – 0x3a3a00000 (11970 MB)
[ 2.515380] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16[ 2.516700] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 2.516714] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 2.517034] dw cru_regsbase addr 0x
1d8.
[ 2.517042] dw cru_reset_offset val 1.
[ 2.517052] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 2.517090] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 2.517323] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 2.517454] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 2.517699] 1358..dw_mci_set_ios: no card. [mmc2]
[ 2.536313] 1358..dw_mci_set_ios: no card. [mmc2]
[ 2.556011] 1358..dw_mci_set_ios: no card. [mmc2]
[ 2.556033] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 d
eep fifo
[ 2.556046] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 2.556341] leds-gpio leds.30: pins are not configured from the driver
[ 2.556555] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.558039] usbcore: registered new interface driver usbhid
[ 2.558049] usbhid: USB HID core driver
[ 2.558179] ashmem: initialized
[ 2.558303] logger: created 256K log ‘log_main’
[ 2.558396] logger: created 256K log ‘log_events’
[ 2.558488] logger: created 256K log ‘log_radio’
[ 2.558589] logger: created 256K log ‘log_system’
[ 2.559721] input: rk29-keypad as /devices/ff10
0000.adc/key.33/input/input2
[ 2.560579] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 2.560596] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 2.560607] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 2.560619] ES8323 2-0010: Error applying setting, reverse things back
[ 2.560909] es8323 probe i2c recv ok
[ 2.561890] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 2.562477] es8323_probe
[ 2.910213] dwc_otg_hcd_enable, enable host controller
[ 3.013574] Using Buffer DMA mode
[ 3.013580] Periodic Transfer Inte
[ 3.013586] Multiprocessor Interrupt Enhancement - disabled
[ 3.013592] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.013599] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.013612] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.057885] Init: Power Port (0)
[ 3.195954] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 3.195964] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 3.195974] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 3.195981] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 3.195990] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 3.195998] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 3.196006] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 3.196014] ES
8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 3.196022] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 3.196030] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 3.196039] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 3.196046] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 3.196054] ES8323 2-0010: ASoC: no dapm match for L
INPUT1 → LAMP → Left PGA Mux
[ 3.196061] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 3.196068] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 3.196075] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 3.196086] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 3.196103] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 3.196118] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 3.196126] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 3.196135] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 3.196142] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 3.196150] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 3.196158]
ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 3.196167] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 3.196174] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 3.196183] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 3.196190] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 3.196198] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 3.196206] ES8323 2-001
0: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 3.196214] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 3.196222] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 3.196242] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 3.196250] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 3.196258] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 3.196265] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 3.196274] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 3.196282] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 3.196290] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 3.196298] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 3.196306] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 3.196313] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 3.196321] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 3.196328] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 3.196442] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 3.196452] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 3.196463] ES8323 2-0010: ASoC: mux
Right PGA Mux has no paths
[ 3.196474] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 3.196494] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 3.202666] rockchip-es8323 rockchip-es8323.28: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[ 3.203038] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.28/sound/card0/input3
[ 3.203442] u32 classifier
[ 3.203448] Actions configured
[ 3.203459] Netfilter messages via NETLINK v0.30.
[ 3.203514] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.203763] ctnetlink v0.93: regist
ering with nfnetlink.
[ 3.203820] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 3.203826] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 3.204028] xt_time: kernel timezone is -0000
[ 3.204180] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.204285] arp_tables: (C) 2002 David S. Miller
[ 3.204315] TCP: cubic registered
[ 3.204320] Initializing XFRM netlink socket
[ 3.204481] NET: Registered protocol family 10
[ 3.204900] mip6: Mobile IPv6
[ 3.204922] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.205026] sit: IPv6 over IPv4 tunneling driver
[ 3.205282] NET: Regi
stered protocol family 17
[ 3.205303] NET: Registered protocol family 15
[ 3.205342] Bridge firewalling registered
[ 3.205353] Ebtables v2.0 registered
[ 3.205504] Bluetooth: RFCOMM TTY layer initialized
[ 3.205526] Bluetooth: RFCOMM socket layer initialized
[ 3.205532] Bluetooth: RFCOMM ver 1.11
[ 3.205539] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.205544] Bluetooth: BNEP filters: protocol multicast
[ 3.205553] Bluetooth: BNEP socket layer initialized
[ 3.205559] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.205567] Bluetooth: HIDP socket layer initialized
[ 3.205589] l2tp_core: L2TP core driver, V2.0
[ 3.205601] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 3.205607] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 3.205817] [WLAN_RFKILL]: Enter rfkill_wlan
_probe
[ 3.205827] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 3.205835] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 3.205842] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 3.205849] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 3.205856] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 3.205874] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 3.205891] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property
: WIFI,host_wake_irq = 158, flags = 0.
[ 3.205897] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 3.205921] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 3.205928] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 3.205964] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.206080] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 3.206093] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 3.206105] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 3.206116] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 3.206127] [BT_RFKILL]: bluetooth_platdata_parse_d
t: get property: BT,wake_host_irq = 159.
[ 3.206173] [BT_RFKILL]: Request irq for bt wakeup host
[ 3.206263] [BT_RFKILL]: ** disable irq
[ 3.206325] [BT_RFKILL]: ap6335 device registered.
[ 3.206917] rk3288_init_suspend
[ 3.206927] rk3288_suspend_init enter
[ 3.207127] rk3288_suspend_init: pm_ctrbits =200005
[ 3.207155] gpio_get_dts_info suspend:4
[ 3.207161] gpio_get_dts_info resume:4
[ 3.207166] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 3.207188] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 3.207301] clks_gating_suspend_init:clkgt info ok
[ 3.207378] Registering SWP/SWPB emulation
handler
[ 3.207388] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
[ 3.209657] ddrfreq: verion 1.2 20140526
[ 3.209669] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 3.209675] ddrfreq: auto-freq=0
[ 3.209680] ddrfreq: auto-freq-table[0] 240MHz
[ 3.209685] ddrfreq: auto-freq-table[1] 324MHz
[ 3.209689] ddrfreq: auto-freq-table[2] 456MHz
[ 3.209694] ddrfreq: auto-freq-table[3] 528MHz
[ 3.215549] regulator-dummy: disabling
[ 3.215765] =======================================================
[ 3.215771] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 3.215776] ====================
[ 3.215781] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 3.215829] dhd_module_init: in
[ 3.215836] ======== bcm_wlan_set_plat_data ========
[ 3.215842] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 3.215860] host_oob_irq: 198
[ 3.215865] host_oob_irq_flags=4
[ 3.215869] dhd_wifi_platform_load: Enter
[ 3.215877] pcd_pullup, is_on 0
[ 3.215882] Power-up adapter ‘DHD generic adapter’
[ 3.215902] wifi_platform_set_power = 1
[ 3.215907] ======== PULL WL_REG_ON HIGH! ========
[ 3.215912] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.215916] file system registered
[ 3.215922] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 3.215927] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
3.216409] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 3.216418] android_usb gadget: Number of LUNs=2
[ 3.216424] lun0: LUN: removable file: (no medium)
[ 3.216429] lun1: LUN: removable file: (no medium)
[ 3.216553] android_usb gadget: android_usb ready
[ 3.216626] sensor_init: Probe name sensors
[ 3.216641] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 3.217163] rtc_hym8563 0-0051: setting system clock to 2016-12-15 14:55:46 UTC (1481813746)
[ 3.222999] rockchip-spdif-card rockchip-spdif-card.26: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
3.223660] usbcore: registered new interface driver snd-usb-audio
[ 3.223668] ALSA device list:
[ 3.223673] #0: RK_ES8323
[ 3.223677] #1: RK-SPDIF-CARD
[ 3.223890] 2, baud is:115200
[ 3.224036] Freeing unused kernel memory: 356K (c0ba9000 - c0c02000)
[ 3.254637] Indeed it is in host mode hprt0 = 00021501
[ 3.323491] [WLAN_RFKILL]: wifi turn on power. 156
[ 3.425261] type=1403 audit(1481813746.700:2): policy loaded auid=4294967295 ses=4294967295
[ 3.431770] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 3.431854] Indeed it is in host mode hprt0 = 00001101
[ 3.450166] init:
could not import file ‘/init.recovery.rk30board.rc’ from ‘/init.rc’
[ 3.451694] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 3.451742] bat_cap: oldcap_path no exist
[ 3.451817] init: invalid gid ‘trace’
[ 3.451889] healthd: No charger supplies found
[ 3.451904] healthd: No battery devices found
[ 3.530142] wifi_platform_bus_enumerate device present 1
[ 3.530158] ======== Card detection to detect SDIO card! ========
[ 3.530168] mmc2:mmc host rescan start!
[ 3.559952] init: /dev/hw_random not found
[ 3.560053] 2, baud is:115200
[ 3.628765] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 3.628775] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.6287
82] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 3.629166] hub 3-1:1.0: USB hub found
[ 3.629225] hub 3-1:1.0: 4 ports detected
[ 3.676151] init: /dev/hw_random not found
[ 3.676872] android_usb: already disabled
[ 3.677015] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 3.677031] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 3.746655] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 3.781363] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.782887] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.784407] mmc2: queui
[ 3.787136] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.835196] yemk:mpu6050_load_cablic
[ 3.835209] mpu6050_load_cablic: open file /dev/mtd/mtd6
[ 3.840134] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 3.840159] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 3.840219] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 3.841932] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.841958] mmc2: new high speed SDIO card at address 0001
[ 3.858156] bcmsdh_register: register client driver
[ 3.858235] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.858306] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.858319] bus num (host idx)=2, slot num (rca)=1
[ 3.858328] found
adapter info ‘DHD generic adapter’
[ 3.858561] F1 signature read @0x18000000=0x16224335
[ 3.860581] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 3.860881] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 3.860928] wifi_platform_get_mac_addr
[ 3.860940] ======== bcm_wlan_get_mac_address ========
[ 3.860949] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 3.860960] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[65:7a:d1:17:3a:98]
[ 3.860969] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 3.860984] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
[ 3.86102
9] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 3.861332] wl_create_event_handler(): thread:wl_event_handler:87 started
[ 3.861338] tsk Enter, tsk = 0xc5b8149c
[ 3.861475] dhd_attach(): thread:dhd_watchdog_thread:88 started
[ 3.861534] dhd_attach(): thread:dhd_dpc:89 started
[ 3.861546] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 3.861588] dhd_attach(): thread:dhd_rxf:8a started
[ 3.861603] dhd_deferred_work_init: work queue initialized
[ 3.861717] dhdsdio_probe_init: set use_rxchain 1 from config.txt
[ 3.867119] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 3.867119] Compiled in drivers/net/wir
eless/bcmdhd on Dec 1 2016 at 10:47:50
[ 3.867489] Register interface [wlan0] MAC: e0:76:d0:f0:c0:a8
[ 3.867489]
[ 3.867515] dhd_prot_ioctl : bus is down. we have nothing to do
[ 3.867550] bcmsdh_oob_intr_unregister: Enter
[ 3.867561] bcmsdh_oob_intr_unregister: irq is not registered
[ 3.867574] dhd_txglom_enable: enable 0
[ 3.867582] dhd_bus_devreset: WLAN OFF DONE
[ 3.867621] wifi_platform_set_power = 0
[ 3.867630] ======== PULL WL_REG_ON LOW! ========
[ 3.867639] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.972936] [WLAN_RFKILL]: wifi shut off power.
[ 3.972950] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 3.972957] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.973015] dhd_module_init: Exit err=0
[ 8.225831] drmboot: module license ‘unspecified’ taints kernel.
[ 8.225853] Disabling lock debugging d
ue to kernel taint
[ 8.226086] drm init, 20140910
[ 8.226702] drm init ok
[ 8.226829] init: Unable to open persistent property directory /data/property errno: 2
[ 8.227495] android_usb: already disabled
[ 8.227542] 2, baud is:115200
[ 8.227662] init: using deprecated syntax for specifying property ‘ro.product.manufacturer’, use ${name} instead
[ 8.227714] init: using deprecated syntax for specifying property ‘ro.product.model’, use ${name} instead
[ 8.227757] init: using deprecated syntax for specifying property ‘ro.serialno’, use ${name} instead
[ 8.227772] init: property ‘ro.serialno’ doesn’t exist while expanding ‘$ro.serialno’
[ 8.227790] init: cannot
expand ‘$ro.serialno’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 8.228832] init: Warning! Service console needs a SELinux domain defined; please fix!
[ 8.231164] read descriptors
[ 8.231177] read strings
[ 8.231203] pcd_pullup, is_on 1
[ 8.237835] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts:
[ 8.286273] rk3288-lcdc lcdc0: blank mode:0
[ 8.286283] I’am in gsl_ts_resume() start
[ 8.381255] ----------3680B---------
[ 8.441010] ------------[ cut here ]------------
[ 8.441022] WARNING: at kernel/irq/manage.c:432 enable_irq+0x50/0x6c()
[ 8.441025] Unbalanced enable for IRQ 193
[ 8.441030] Modules linked in: drmboot(P)
[ 8.441036] CPU: 0 PID: 139 Comm: recovery Tainted: P
3.10.0 #23
[ 8.441052] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 8.441060] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68)
[ 8.441066] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 8.441073] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (enable_irq+0x50/0x6c)
[ 8.441082] [] (enable_irq+0x50/0x6c) from [] (rk_ts_early_resume+0xb0/0xc0)
[ 8.441089] [] (rk_ts_early_resume+0xb0/0x
c0) from [] (fb_notifier_callback+0x60/0x9c)
[ 8.441098] [] (fb_notifier_callback+0x60/0x9c) from [] (notifier_call_chain+0x38/0x68)
[ 8.441105] [] (notifier_call_chain+0x38/0x68) from [] (__blocking_notifier_call_chain+0x44/0x58)
[ 8.441112] [] (__blocking_notifier_call_chain+0x44/0x58) from [] (blocking_notifier_call_chain+0x14/0x18)
[ 8.441121] [] (blocking_notifier_call_chain+0x14/0x18) from [] (fb_blank+0x7c/0x88)
[ 8.441128] [] (fb_blank+0x7c/0x88) from [] (
do_fb_ioctl+0x518/0x5a0)
[ 8.441135] [] (do_fb_ioctl+0x518/0x5a0) from [] (do_vfs_ioctl+0x210/0x240)
[ 8.441141] [] (do_vfs_ioctl+0x210/0x240) from [] (SyS_ioctl+0x50/0x6c)
[ 8.441148] [] (SyS_ioctl+0x50/0x6c) from [] (ret_fast_syscall+0x0/0x30)
[ 8.441152] —[ end trace 8115275de23fb6e7 ]—
[ 8.814211] [otg id chg] last id -1 current id 1
[ 8.814227] PortPower off
[ 8.814233] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 8.933284] Using Buffer DMA mode
[ 8.933292] Periodic Transfer Interrupt Enhancement - disabled
[ 8.933297] Multiprocessor Interrupt Enhancement - disabled
[ 8.933303] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 8.933308] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.424301] ****
vbus detect******
[ 9.426478] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 9.603528] Using Buffer DMA mode
[ 9.603534] Periodic Transfer Interrupt Enhancement - disabled
[ 9.603539] Multiprocessor Interrupt Enhancement - disabled
[ 9.603544] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.603550] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.603589] soft connect!!!
[ 9.719759] USB RESET
[ 9.810459] android_work: sent uevent USB_STATE=CONNECTED
[ 9.813949] USB RESET
[ 9.976442] android_usb gadget: high-speed config #1: android
[ 9.976509] android_work: sent uevent USB_STATE=CONFIGURED
[ 10.447703] type=1400 audit(1481813753.840:3): avc: denied { create } for pid=33 comm="
kworker/1:1" name=“es8323_mic_state” scontext=u:r:kernel:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[ 10.447735] type=1400 audit(1481813753.840:4): avc: denied { write } for pid=33 comm=“kworker/1:1” path=“/data/es8323_mic_state” dev=“rootfs” ino=2272 scontext=u:r:kernel:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[ 10.447759] es8323_mic_state_ctrl read:
[ 10.447772] mic_state_switch 0
[ 10.447778] hp_det = 0,insert hp
[ 10.447782] hp mic use intern
[ 12.811173] EXT4-fs (mmcblk0p12): recovery complete
[ 12.811196] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts:
[ 12.816003] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts:
[ 62.491815] healthd: battery none chg=
你的内核有个错误,先修正这个错误
isle 发表于 2016-12-16 09:02
你的内核有个错误,先修正这个错误
请问你什么错误啊
3.10.0 #23
[ 8.441025] Unbalanced …
这个manage.c我没有修改过怎么会出错?我用的是你们给的android5.1的源码然后在git上更新的
你是跑android还是ubuntu啊 感觉你发错版块了。
跑android的能帮忙转下板块不
跑android的能帮忙转下板块不
跑android的能帮忙转下板块不
嚓 ,我竟然没有权限,召唤版主 。要不你去android版块重新发下吧。
