在RK3399上,android系统进不去,画面停留在Android字体logo处
[ 1.301509] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 1.407993] Rebooting in 5 seconds..
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
I2C Send Start Bit Timeout
No pmic detect.
can't find dts node for pwm1
#Boot ver: 2016-12-06#1.05
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
rk lcdc - 0 dclk set: dclk = 205000000HZ, pll select = 1, div = 4
edp pll locked
Aux Transaction fail!
link training success.
unable to config video
no fuel gauge found
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x010121e8)
ramdisk @ 0x05bf0000 (0x012bcc50)
bootrk: do_bootm_linux...
Loading Device Tree to 0000000005600000, end 0000000005614d47 ... OK
Add bank:0000000000200000, 00000000f7e00000
Starting kernel ...
[ 0.000000] Linux version 4.4.30 (root@Ubuntu-Z) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Dec 6 10:47:55 CST 2016
[ 0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000edc00000, size 128 MiB
[ 0.000000] Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7efa000 s45248 r8192 d32576 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 999432
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00020000@0x0002C000(recovery),0x00038000@0x0004C000(backup),0x00040000@0x00084000(cache),0x00600000@0x000C4000(system),0x00008000@0x006C4000(metadata),0x00002000@0x006CC000(baseparamer),0x00000400@0x006CE000(frp),-@0x006CE400(userdata) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000:0x01000000 loader.timestamp=2016-12-06_10:38:03
[ 0.000000] software IO TLB [mem 0xf7eb2000-0xf7ef2000] (0MB) mapped at [ffffffc0f7eb2000-ffffffc0f7ef1fff]
[ 0.000000] Memory: 3787496K/4061184K available (9982K kernel code, 1160K rwdata, 4468K rodata, 768K init, 1043K bss, 142616K reserved, 131072K cma-reserved)
[ 0.000000] .init : 0xffffff8008eb0000 - 0xffffff8008f70000 ( 768 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008a40000 ( 9984 KB)
[ 0.000000] .rodata : 0xffffff8008a40000 - 0xffffff8008eb0000 ( 4544 KB)
[ 0.000000] .data : 0xffffff8008f70000 - 0xffffff80090920a8 ( 1161 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] ITS: allocated 65536 Devices @e9000000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000e9080000
[ 0.000000] CPU0: using LPI pending table @0x00000000e9090000
[ 0.001711] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.002743] pid_max: default: 32768 minimum: 301
[ 0.003246] Security Framework initialized
[ 0.003642] SELinux: Initializing.
[ 0.004076] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004717] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006234] Initializing cgroup subsys freezer
[ 0.006703] Initializing cgroup subsys debug
[ 0.007611] sched-energy: Sched-energy-costs installed from DT
[ 0.008170] CPU0: update cpu_capacity 401
[ 0.008608] ASID allocator initialised with 65536 entries
[ 0.026917] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.028209] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.042948] Detected VIPT I-cache on CPU1
[ 0.042981] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.043019] CPU1: using LPI pending table @0x00000000e9200000
[ 0.043063] CPU1: update cpu_capacity 401
[ 0.043067] CPU1: Booted secondary processor [410fd034]
[ 0.054949] Detected VIPT I-cache on CPU2
[ 0.054968] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.055000] CPU2: using LPI pending table @0x00000000e9230000
[ 0.055028] CPU2: update cpu_capacity 401
[ 0.055031] CPU2: Booted secondary processor [410fd034]
[ 0.066986] Detected VIPT I-cache on CPU3
[ 0.067004] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.067036] CPU3: using LPI pending table @0x00000000e9270000
[ 0.067063] CPU3: update cpu_capacity 401
[ 0.067066] CPU3: Booted secondary processor [410fd034]
[ 1.080070] CPU4: failed to come online
[ 1.096522] Detected PIPT I-cache on CPU5
[ 1.096551] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 1.096588] CPU5: using LPI pending table @0x00000000e92e0000
[ 1.096628] CPU5: update cpu_capacity 1024
[ 1.096631] CPU5: Booted secondary processor [410fd082]
[ 1.096728] Brought up 5 CPUs
[ 1.099429] SMP: Total of 5 processors activated.
[ 1.099880] CPU features: detected feature: GIC system register CPU interface
[ 1.100577] CPU: All CPU(s) started at EL2
[ 1.101000] alternatives: patching kernel code
[ 1.102611] devtmpfs: initialized
[ 1.121401] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 1.127388] pinctrl core: initialized pinctrl subsystem
[ 1.130862] NET: Registered protocol family 16
[ 1.131821] schedtune: init normalization constants...
[ 1.132317] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 1.132940] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 1.133562] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 1.134185] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 1.134829] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 1.135453] schedtune: CLUSTER[5] min_pwr: 65 max_pwr: 1108
[ 1.136074] schedtune: CPU[5] min_pwr: 65 max_pwr: 1108
[ 1.136703] Unable to handle kernel NULL pointer dereference at virtual address 00000010
[ 1.137471] pgd = ffffff800919b000
[ 1.137796] [00000010] *pgd=00000000f7ffe003, *pud=00000000f7ffe003, *pmd=0000000000000000
[ 1.138593] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 1.139126] Modules linked in:
[ 1.139425] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.30 #1
[ 1.139988] Hardware name: rockchip,rk3399-excavator-edp (DT)
[ 1.140537] task: ffffffc0e9160000 ti: ffffffc0e9168000 task.ti: ffffffc0e9168000
[ 1.141250] PC is at schedtune_init+0x21c/0x3ac
[ 1.141684] LR is at schedtune_init+0x20c/0x3ac
[ 1.142117] pc : [<ffffff80080de924>] lr : [<ffffff80080de914>] pstate: 60000045
[ 1.142818] sp : ffffffc0e916bcd0
[ 1.143135] x29: ffffffc0e916bcd0 x28: ffffff8008f77bf0
[ 1.143645] x27: ffffffc0e92957e0 x26: ffffff8008f77000
[ 1.144156] x25: ffffff8008d436a8 x24: ffffff8008d43669
[ 1.144664] x23: ffffffc0e9269400 x22: ffffff8009098000
[ 1.145173] x21: ffffff8008f4de40 x20: ffffff8008d43000
[ 1.145682] x19: ffffffc0e92957c0 x18: 0000000000000078
[ 1.146192] x17: 000000000000000e x16: 0000000000000007
[ 1.146701] x15: ffffff8008a99000 x14: 0fffffffffffffff
[ 1.147211] x13: 0000000000000030 x12: 0101010101010101
[ 1.147721] x11: 7f7f7f7f7f7f7f7f x10: 59ff5c345a544f42
[ 1.148230] x9 : ffffffffffffffff x8 : ffffffc0e9269c00
[ 1.148738] x7 : 0000000000000005 x6 : ffffff8009099981
[ 1.149248] x5 : 0000000000000002 x4 : 0000000000000000
[ 1.149756] x3 : 0000000000000000 x2 : cb88537fdc8ba61e
[ 1.150266] x1 : 0000000000000020 x0 : 0000000000000000
[ 1.150776]
[ 1.150776] PC: 0xffffff80080de8a4:
[ 1.151250] e8a4 f9400402 51000421 f861784a aa1903e2 b9401001 f9400c00 51000421 f9003baa
[ 1.152053] e8c4 8b011001 f940d2c0 8b0a0000 f900d2c0 f9400429 910682c1 f9003fa9 f9400420
[ 1.152851] e8e4 8b090000 f9000420 d2800401 910263a0 940a3fac f9403baa 910263a1 f9403fa9
[ 1.153649] e904 9119e280 aa0a03e2 aa0903e3 9401fee0 f94037a8 f9401261 f94033a7 f9400100
[ 1.154446] e924 f9400800 f9401000 ca000020 92401c00 b4fff8e0 d4210000 f9400273 f9400ae0
[ 1.155244] e944 eb00027f 54fff3c1 910682d5 94005024 f940d2c2 b0006661 9124e421 9119e280
[ 1.156041] e964 f94006a3 b0006337 911c92f7 9401fec8 f94006b4 f940d2c0 cb000294 2a1403e0
[ 1.156838] e984 940a67b0 2a0003e1 f9000aa0 d3609c02 d368bc03 b0006320 911ac000 52800015
[ 1.157637]
[ 1.157637] LR: 0xffffff80080de894:
[ 1.158110] e894 f90033a7 f90037a8 f9400c00 b9400001 f9400402 51000421 f861784a aa1903e2
[ 1.158909] e8b4 b9401001 f9400c00 51000421 f9003baa 8b011001 f940d2c0 8b0a0000 f900d2c0
[ 1.159707] e8d4 f9400429 910682c1 f9003fa9 f9400420 8b090000 f9000420 d2800401 910263a0
[ 1.160506] e8f4 940a3fac f9403baa 910263a1 f9403fa9 9119e280 aa0a03e2 aa0903e3 9401fee0
[ 1.161304] e914 f94037a8 f9401261 f94033a7 f9400100 f9400800 f9401000 ca000020 92401c00
[ 1.162102] e934 b4fff8e0 d4210000 f9400273 f9400ae0 eb00027f 54fff3c1 910682d5 94005024
[ 1.162898] e954 f940d2c2 b0006661 9124e421 9119e280 f94006a3 b0006337 911c92f7 9401fec8
[ 1.163696] e974 f94006b4 f940d2c0 cb000294 2a1403e0 940a67b0 2a0003e1 f9000aa0 d3609c02
[ 1.164496]
[ 1.164496] SP: 0xffffffc0e916bc50:
[ 1.164970] bc50 09098000 ffffff80 e9269400 ffffffc0 08d43669 ffffff80 08d436a8 ffffff80
[ 1.165768] bc70 08f77000 ffffff80 e92957e0 ffffffc0 08f77bf0 ffffff80 e916bcd0 ffffffc0
[ 1.166566] bc90 080de914 ffffff80 e916bcd0 ffffffc0 080de924 ffffff80 60000045 00000000
[ 1.167364] bcb0 00000001 00000000 00000001 00000000 ffffffff ffffffff 00000000 00000000
[ 1.168162] bcd0 e916bd90 ffffffc0 08082ba4 ffffff80 080de708 ffffff80 08f84b20 ffffff80
[ 1.168959] bcf0 e93f1cc0 ffffffc0 08f76000 ffffff80 08f84b20 ffffff80 00000000 00000000
[ 1.169757] bd10 08eb04a4 ffffff80 08f12310 ffffff80 09096000 ffffff80 08f12320 ffffff80
[ 1.170555] bd30 00000005 00000000 e9269c00 ffffffc0 00000041 00000000 00000454 00000000
[ 1.171357]
[ 1.171357] X6: 0xffffff8009099901:
[ 1.171831] 9900 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.172629] 9920 00000000 00000000 00000000 00000000 00000000 00000000 30303020 32303330
[ 1.173428] 9940 32343337 39205d38 20303439 312e3120 35333137 58205d37 30203a36 66666678
[ 1.174226] 9960 38666666 30393030 30393939 300a3a31 64303830 34313965 70205d3e 74617473
[ 1.175023] 9980 36203a65 30303030 0a353430 3030300a 0a303130 30353436 38373134 30303135
[ 1.175821] 99a0 20303030 390a736e 32303235 20323935 740a736e 726f7720 20200a6b 302e3020
[ 1.176619] 99c0 30303030 20205d30 76202020 6c6c616d 3a20636f 66783020 66666666 30303866
[ 1.177416] 99e0 30303038 20303030 7830202d 66666666 64626666 66666662 30303030 28202020
[ 1.178215] 9a00 32202020 47203634 5b0a2942 20202020 30302e30 30303030 2020205d 20202020
[ 1.179015]
[ 1.179015] X8: 0xffffffc0e9269b80:
[ 1.179489] 9b80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.180287] 9ba0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.181084] 9bc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.181881] 9be0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.182678] 9c00 00000000 00000000 00000000 00000000 e92957c0 ffffffc0 00000005 00000000
[ 1.183476] 9c20 0000000a 00000000 00000020 0000007d 00000001 00000002 00000001 00000000
[ 1.184273] 9c40 00000000 00000000 00000000 00000000 0000102f 00000001 fffedc23 00000000
[ 1.185071] 9c60 00000005 00000000 000016c9 00000000 fffedd16 00000000 00000004 00000000
[ 1.185872]
[ 1.185872] X15: 0xffffff8008a98f80:
[ 1.186354] 8f80 74707572 00000000 08433cb0 ffffff80 08433bf4 ffffff80 30353238 696b732e
[ 1.187152] 8fa0 78745f70 745f6e65 00747365 00000000 30353238 5f726e2e 74726175 00000073
[ 1.187950] 8fc0 30353238 6168732e 695f6572 00737172 180c0600 00001218 00001e1e 00000000
[ 1.188747] 8fe0 00000b0b 00000000 2d2a2800 00000000 08d8f4b0 ffffff80 00010001 00000000
[ 1.189545] 9000 00000000 00000000 08d7e66d ffffff80 00010001 00000000 00000000 00000000
[ 1.190343] 9020 08d7e6f4 ffffff80 00010001 00000000 00000000 00000000 08d7e6fa ffffff80
[ 1.191141] 9040 00010001 00000000 00000000 00000000 08d7e74b ffffff80 00100010 08040181
[ 1.191938] 9060 0000000e 00000100 08d7e700 ffffff80 00010001 00000000 00000000 00000000
[ 1.192740]
[ 1.192740] X19: 0xffffffc0e9295740:
[ 1.193222] 5740 616d6f64 00306e69 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.194020] 5760 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.194817] 5780 30757063 ffffff00 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.195615] 57a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.196413] 57c0 e92955c0 ffffffc0 00000001 00000001 e9295800 ffffffc0 e90edc00 ffffffc0
[ 1.197209] 57e0 00000020 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.198007] 5800 00000001 00000000 00000400 00000000 00000400 00000000 fffedc25 00000000
[ 1.198805] 5820 00000000 00000001 000000ff 00000000 00000000 00000000 00000000 00000000
[ 1.199605]
[ 1.199605] X20: 0xffffff8008d42f80:
[ 1.200087] 2f80 75725f63 6d69746e 65730065 74733e2d 73697461 73636974 6961772e 74735f74
[ 1.200886] 2fa0 00747261 3e2d6573 74617473 69747369 732e7363 7065656c 6174735f 73007472
[ 1.201684] 2fc0 733e2d65 69746174 63697473 6c622e73 5f6b636f 72617473 65730074 74733e2d
[ 1.202482] 2fe0 73697461 73636974 656c732e 6d5f7065 73007861 733e2d65 69746174 63697473
[ 1.203279] 3000 6c622e73 5f6b636f 0078616d 3e2d6573 74617473 69747369 652e7363 5f636578
[ 1.204076] 3020 0078616d 3e2d6573 74617473 69747369 732e7363 6563696c 78616d5f 2d657300
[ 1.204874] 3040 6174733e 74736974 2e736369 74696177 78616d5f 2d657300 6174733e 74736974
[ 1.205670] 3060 2e736369 74696177 6d75735f 2e202000 30332d25 25203a73 0a646c6c 2d657300
[ 1.206470]
[ 1.206470] X21: 0xffffff8008f4ddc0:
[ 1.206952] ddc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.207750] dde0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.208547] de00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.209344] de20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.210141] de40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.210939] de60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.211736] de80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.212533] dea0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.213331]
[ 1.213331] X22: 0xffffff8009097f80:
[ 1.213812] 7f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.214608] 7fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.215406] 7fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.216203] 7fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.217000] 8000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.217797] 8020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.218594] 8040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.219391] 8060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.220190]
[ 1.220190] X23: 0xffffffc0e9269380:
[ 1.220671] 9380 e9269200 ffffffc0 e92693a9 ffffffc0 00000000 00000000 00000000 00000000
[ 1.221470] 93a0 e9269200 ffffffc0 e9269268 ffffffc0 e9269288 ffffffc0 e9269388 ffffffc0
[ 1.222268] 93c0 e9269200 ffffffc0 e9269288 ffffffc0 00000000 00000000 00000000 00000000
[ 1.223066] 93e0 e9269200 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.223863] 9400 00000000 00000000 e9268a00 ffffffc0 e92955c0 ffffffc0 00000005 00000000
[ 1.224661] 9420 0000000a 00000000 00000020 0000007d 00000001 00000002 00000001 00000000
[ 1.225459] 9440 00000000 00000000 00000000 00000000 0000102f 00000001 fffedc1b 00000000
[ 1.226257] 9460 0000000a 00000000 00000b64 00000000 fffedd16 00000000 00000000 00000000
[ 1.227056]
[ 1.227056] X24: 0xffffff8008d435e9:
[ 1.227538] 35e8 65726320 20657461 65726f6d 61687420 6425206e 68635320 75546465 6220656e
[ 1.228337] 3608 74736f6f 20676e69 756f7267 000a7370 63733601 74646568 3a656e75 696e6920
[ 1.229135] 3628 6f6e2074 6c616d72 74617a69 206e6f69 736e6f63 746e6174 2e2e2e73 3601000a
[ 1.229933] 3648 65686373 6e757464 6e203a65 6e65206f 79677265 646f6d20 64206c65 0a617461
[ 1.230732] 3668 554c4300 52455453 702a255b 005d6c62 63733601 74646568 3a656e75 312d2520
[ 1.231530] 3688 6d207337 705f6e69 203a7277 756c3525 78616d20 7277705f 3525203a 000a756c
[ 1.232328] 36a8 5b555043 005d6425 63733601 74646568 3a656e75 69737520 6e20676e 616d726f
[ 1.233127] 36c8 617a696c 6e6f6974 6e6f6320 6e617473 6d207374 203a6c75 73207525 203a3168
[ 1.233925] 36e8 73207525 203a3268 000a7525 63733601 74646568 3a656e75 72657620 20796669
[ 1.234725]
[ 1.234725] X25: 0xffffff8008d43628:
[ 1.235207] 3628 6f6e2074 6c616d72 74617a69 206e6f69 736e6f63 746e6174 2e2e2e73 3601000a
[ 1.236005] 3648 65686373 6e757464 6e203a65 6e65206f 79677265 646f6d20 64206c65 0a617461
[ 1.236801] 3668 554c4300 52455453 702a255b 005d6c62 63733601 74646568 3a656e75 312d2520
[ 1.237600] 3688 6d207337 705f6e69 203a7277 756c3525 78616d20 7277705f 3525203a 000a756c
[ 1.238397] 36a8 5b555043 005d6425 63733601 74646568 3a656e75 69737520 6e20676e 616d726f
[ 1.239196] 36c8 617a696c 6e6f6974 6e6f6320 6e617473 6d207374 203a6c75 73207525 203a3168
[ 1.239993] 36e8 73207525 203a3268 000a7525 63733601 74646568 3a656e75 72657620 20796669
[ 1.240791] 3708 6d726f6e 7a696c61 6f697461 6f63206e 6174736e 2e73746e 000a2e2e 63733601
[ 1.241590]
[ 1.241590] X26: 0xffffff8008f76f80:
[ 1.242072] 6f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.242870] 6fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.243667] 6fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.244464] 6fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.245260] 7000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.246056] 7020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.246852] 7040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.247650] 7060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.248449]
[ 1.248449] X27: 0xffffffc0e9295760:
[ 1.248931] 5760 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.249728] 5780 30757063 ffffff00 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.250526] 57a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.251322] 57c0 e92955c0 ffffffc0 00000001 00000001 e9295800 ffffffc0 e90edc00 ffffffc0
[ 1.252120] 57e0 00000020 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.252918] 5800 00000001 00000000 00000400 00000000 00000400 00000000 fffedc25 00000000
[ 1.253715] 5820 00000000 00000001 000000ff 00000000 00000000 00000000 00000000 00000000
[ 1.254512] 5840 00000001 00000001 00000001 00000001 ffffffff 00000001 00000000 00000000
[ 1.255311]
[ 1.255311] X28: 0xffffff8008f77b70:
[ 1.255793] 7b70 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.256589] 7b90 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.257386] 7bb0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.258183] 7bd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.258979] 7bf0 00000006 00000000 00000013 00000000 00000000 00000000 00000000 00000000
[ 1.259776] 7c10 00000000 00000000 00000000 00000000 00000000 00000000 09089118 ffffff80
[ 1.260574] 7c30 00000000 00000000 00000000 00000000 00000000 00000000 0000000a 00000000
[ 1.261372] 7c50 00400000 0000000a 00000003 00000000 00000000 00000000 00000000 00000000
[ 1.262171]
[ 1.262171] X29: 0xffffffc0e916bc50:
[ 1.262653] bc50 09098000 ffffff80 e9269400 ffffffc0 08d43669 ffffff80 08d436a8 ffffff80
[ 1.263451] bc70 08f77000 ffffff80 e92957e0 ffffffc0 08f77bf0 ffffff80 e916bcd0 ffffffc0
[ 1.264249] bc90 080de914 ffffff80 e916bcd0 ffffffc0 080de924 ffffff80 60000045 00000000
[ 1.265047] bcb0 00000001 00000000 00000001 00000000 ffffffff ffffffff 00000000 00000000
[ 1.265844] bcd0 e916bd90 ffffffc0 08082ba4 ffffff80 080de708 ffffff80 08f84b20 ffffff80
[ 1.266642] bcf0 e93f1cc0 ffffffc0 08f76000 ffffff80 08f84b20 ffffff80 00000000 00000000
[ 1.267439] bd10 08eb04a4 ffffff80 08f12310 ffffff80 09096000 ffffff80 08f12320 ffffff80
[ 1.268236] bd30 00000005 00000000 e9269c00 ffffffc0 00000041 00000000 00000454 00000000
[ 1.269033]
[ 1.269178] Process swapper/0 (pid: 1, stack limit = 0xffffffc0e9168020)
[ 1.269816] Stack: (0xffffffc0e916bcd0 to 0xffffffc0e916c000)
[ 1.270365] bcc0: ffffffc0e916bd90 ffffff8008082ba4
[ 1.271111] bce0: ffffff80080de708 ffffff8008f84b20 ffffffc0e93f1cc0 ffffff8008f76000
[ 1.271857] bd00: ffffff8008f84b20 0000000000000000 ffffff8008eb04a4 ffffff8008f12310
[ 1.272602] bd20: ffffff8009096000 ffffff8008f12320 0000000000000005 ffffffc0e9269c00
[ 1.273349] bd40: 0000000000000041 0000000000000454 ffffff8008f76000 ffffff8008f78000
[ 1.274094] bd60: ffffffc0e93f1cc0 5b005d355b555043 ffffff005d005d35 0000000000000000
[ 1.274840] bd80: ffffff8008eb04a4 cb88537fdc8ba61e ffffffc0e916be20 ffffff8008eb0e00
[ 1.275584] bda0: 00000000000001bd ffffff8008e97aa0 ffffff8009096000 0000000000000002
[ 1.276330] bdc0: ffffff8008f76000 ffffff8008f123a0 ffffff8008eb04a4 ffffff8008f12300
[ 1.277076] bde0: ffffff8009096000 ffffff8008f12320 ffffff8008d41a2c ffffff8008d774f6
[ 1.277821] be00: ffffff8008a7b1b8 0000000000000000 0000000200000002 cb88537fdc8ba61e
[ 1.278567] be20: ffffffc0e916bea0 ffffff8008a26fb0 ffffff8008a26fa0 0000000000000000
[ 1.279312] be40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.280057] be60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.280803] be80: 0000000000000000 ffffff8008f416b0 0000000000000000 cb88537fdc8ba61e
[ 1.281548] bea0: 0000000000000000 ffffff8008082690 ffffff8008a26fa0 0000000000000000
[ 1.282293] bec0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.283038] bee0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.283783] bf00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.284528] bf20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.285274] bf40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.286018] bf60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.286764] bf80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.287508] bfa0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.288254] bfc0: 0000000000000000 0000000000000005 0000000000000000 0000000000000000
[ 1.288998] bfe0: 0000000000000000 0000000000000000 d7fbfdfb3effbdfb bf9fff7fff7fef9d
[ 1.289741] Call trace:
[ 1.289979] Exception stack(0xffffffc0e916bae0 to 0xffffffc0e916bc10)
[ 1.290594] bae0: ffffffc0e92957c0 0000008000000000 ffffffc0e916bcd0 ffffff80080de924
[ 1.291339] bb00: 0000000060000045 000000000000003a ffffff8008f93688 000000000000221c
[ 1.292086] bb20: 0000000000000006 ffffff8008f93688 000000000000004a 00000000090997e8
[ 1.292831] bb40: ffffffc0e916bbe0 ffffff80080e8fb4 ffffff8008f76000 ffffff80080e8f80
[ 1.293577] bb60: ffffff8008f4de40 ffffff8009098000 ffffffc0e9269400 ffffff8008d43669
[ 1.294323] bb80: ffffff8008d436a8 ffffff8008f77000 ffffffc0e92957e0 cb88537fdc8ba61e
[ 1.295069] bba0: 0000000000000000 0000000000000020 cb88537fdc8ba61e 0000000000000000
[ 1.295814] bbc0: 0000000000000000 0000000000000002 ffffff8009099981 0000000000000005
[ 1.296560] bbe0: ffffffc0e9269c00 ffffffffffffffff 59ff5c345a544f42 7f7f7f7f7f7f7f7f
[ 1.297304] bc00: 0101010101010101 0000000000000030
[ 1.297771] [<ffffff80080de924>] schedtune_init+0x21c/0x3ac
[ 1.298304] [<ffffff8008082ba4>] do_one_initcall+0x17c/0x198
[ 1.298849] [<ffffff8008eb0e00>] kernel_init_freeable+0x1b8/0x270
[ 1.299435] [<ffffff8008a26fb0>] kernel_init+0x10/0xf8
[ 1.299927] [<ffffff8008082690>] ret_from_fork+0x10/0x40
[ 1.300436] Code: f94037a8 f9401261 f94033a7 f9400100 (f9400800)
[ 1.301038] ---[ end trace 97a7b2da322080cf ]---
[ 1.301509]
[ 1.302379] CPU3: stopping
[ 1.302647] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.30 #1
[ 1.303323] Hardware name: rockchip,rk3399-excavator-edp (DT)
[ 1.303868] Call trace:
[ 1.304110] [<ffffff80080884c4>] dump_backtrace+0x0/0x1c8
[ 1.304628] [<ffffff80080886a0>] show_stack+0x14/0x1c
[ 1.305114] [<ffffff8008362ae4>] dump_stack+0x8c/0xac
[ 1.305600] [<ffffff800808e334>] handle_IPI+0x140/0x284
[ 1.306099] [<ffffff8008080e80>] gic_handle_irq+0x10c/0x150
[ 1.306631] Exception stack(0xffffffc0f7f3d000 to 0xffffffc0f7f3d130)
[ 1.307246] d000: ffffffc0e91c7e20 0000008000000000 ffffffc0e91c7f50 ffffff8008084944
[ 1.307991] d020: 0000000060000045 0000000000000000 ffffffc0f7f39060 0000000000000000
[ 1.308737] d040: ffffffc0e91c7f50 ffffffc0e91c7e20 0000000000000000 0000000000000000
[ 1.309482] d060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.310227] d080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.310971] d0a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.311716] d0c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.312461] d0e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.313206] d100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.313949] d120: 0000000000000000 0000000000000000
[ 1.314416] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
[ 1.314884] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
[ 1.315404] [<ffffff80080daa50>] default_idle_call+0x20/0x28
[ 1.315946] [<ffffff80080dac84>] cpu_startup_entry+0x22c/0x380
[ 1.316504] [<ffffff800808dec8>] secondary_start_kernel+0x188/0x194
[ 1.317101] [<0000000000282978>] 0x282978
[ 1.317485] CPU1: stopping
[ 1.317751] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 4.4.30 #1
[ 1.318428] Hardware name: rockchip,rk3399-excavator-edp (DT)
[ 1.318973] Call trace:
[ 1.319214] [<ffffff80080884c4>] dump_backtrace+0x0/0x1c8
[ 1.319731] [<ffffff80080886a0>] show_stack+0x14/0x1c
[ 1.320215] [<ffffff8008362ae4>] dump_stack+0x8c/0xac
[ 1.320698] [<ffffff800808e334>] handle_IPI+0x140/0x284
[ 1.321197] [<ffffff8008080e80>] gic_handle_irq+0x10c/0x150
[ 1.321728] Exception stack(0xffffffc0f7f13000 to 0xffffffc0f7f13130)
[ 1.322343] 3000: ffffffc0e91bbe20 0000008000000000 ffffffc0e91bbf50 ffffff8008084944
[ 1.323088] 3020: 0000000060000045 0000000000000000 ffffffc0f7f0f060 0000000000000000
[ 1.323833] 3040: ffffffc0e91bbf50 ffffffc0e91bbe20 0000000000000000 0000000000000000
[ 1.324578] 3060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.325323] 3080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.326068] 30a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.326812] 30c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.327557] 30e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.328302] 3100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.329045] 3120: 0000000000000000 0000000000000000
[ 1.329512] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
[ 1.329979] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
[ 1.330497] [<ffffff80080daa50>] default_idle_call+0x20/0x28
[ 1.331039] [<ffffff80080dac84>] cpu_startup_entry+0x22c/0x380
[ 1.331597] [<ffffff800808dec8>] secondary_start_kernel+0x188/0x194
[ 1.332193] [<0000000000282978>] 0x282978
[ 1.332577] CPU5: stopping
[ 1.332852] CPU: 5 PID: 0 Comm: swapper/5 Tainted: G D 4.4.30 #1
[ 1.333544] Hardware name: rockchip,rk3399-excavator-edp (DT)
[ 1.334102] Call trace:
[ 1.334355] [<ffffff80080884c4>] dump_backtrace+0x0/0x1c8
[ 1.334883] [<ffffff80080886a0>] show_stack+0x14/0x1c
[ 1.335377] [<ffffff8008362ae4>] dump_stack+0x8c/0xac
[ 1.335870] [<ffffff800808e334>] handle_IPI+0x140/0x284
[ 1.336379] [<ffffff8008080e80>] gic_handle_irq+0x10c/0x150
[ 1.336921] Exception stack(0xffffffc0f7f67000 to 0xffffffc0f7f67130)
[ 1.337547] 7000: ffffffc0e91cfe20 0000008000000000 ffffffc0e91cff50 ffffff8008084944
[ 1.338308] 7020: 0000000060000045 0000000000000000 ffffffc0f7f63060 0000000000000000
[ 1.339067] 7040: ffffffc0e91cff50 ffffffc0e91cfe20 0000000000000000 0000000000000000
[ 1.339826] 7060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.340585] 7080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.341344] 70a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.342103] 70c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.342862] 70e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.343621] 7100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.344379] 7120: 0000000000000000 0000000000000000
[ 1.344855] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
[ 1.345331] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
[ 1.345860] [<ffffff80080daa50>] default_idle_call+0x20/0x28
[ 1.346412] [<ffffff80080dac84>] cpu_startup_entry+0x22c/0x380
[ 1.346979] [<ffffff800808dec8>] secondary_start_kernel+0x188/0x194
[ 1.347588] [<0000000000282978>] 0x282978
[ 1.347981] CPU2: stopping
[ 1.348248] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.30 #1
[ 1.348925] Hardware name: rockchip,rk3399-excavator-edp (DT)
[ 1.349471] Call trace:
[ 1.349711] [<ffffff80080884c4>] dump_backtrace+0x0/0x1c8
[ 1.350229] [<ffffff80080886a0>] show_stack+0x14/0x1c
[ 1.350712] [<ffffff8008362ae4>] dump_stack+0x8c/0xac
[ 1.351196] [<ffffff800808e334>] handle_IPI+0x140/0x284
[ 1.351695] [<ffffff8008080e80>] gic_handle_irq+0x10c/0x150
[ 1.352227] Exception stack(0xffffffc0f7f28000 to 0xffffffc0f7f28130)
[ 1.352843] 8000: ffffffc0e91c3e20 0000008000000000 ffffffc0e91c3f50 ffffff8008084944
[ 1.353589] 8020: 0000000060000045 0000000000000000 ffffffc0f7f24060 0000000000000000
[ 1.354333] 8040: ffffffc0e91c3f50 ffffffc0e91c3e20 0000000000000000 0000000000000000
[ 1.355079] 8060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.355825] 8080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.356569] 80a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.357315] 80c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.358061] 80e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.358807] 8100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 1.359551] 8120: 0000000000000000 0000000000000000
[ 1.360018] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
[ 1.360486] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
[ 1.361004] [<ffffff80080daa50>] default_idle_call+0x20/0x28
[ 1.361546] [<ffffff80080dac84>] cpu_startup_entry+0x22c/0x380
[ 1.362104] [<ffffff800808dec8>] secondary_start_kernel+0x188/0x194
[ 1.362701] [<0000000000282978>] 0x282978
[ 1.363086] CRU:
[ 1.363278] 00000000: 00000044 00001201 80000000 00000108 00000007 00007f00 00000000 00000000
[ 1.364096] 00000020: 00000044 00001201 80000000 00000108 00000007 00007f00 00000000 00000000
[ 1.364913] 00000040: 00000037 00001201 8000031f 00000108 00000007 00007f00 00000000 00000000
[ 1.365730] 00000060: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
[ 1.366547] 00000080: 00000063 00001401 80000000 00000108 00000007 00007f00 00000000 00000000
[ 1.367366] 000000a0: 000001f4 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
[ 1.368184] 000000c0: 00000063 00001102 80000000 00000008 00000007 00007f00 00000000 00000000
[ 1.369001] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.369818] 00000100: 00000300 00000505 00000140 00006404 00000043 00008341 00000320 00000101
[ 1.370634] 00000120: 00000101 00004141 00000101 00000101 00004101 00008323 00003183 00000500
[ 1.371452] 00000140: 0000013d 00000300 00004a87 00000103 00009303 00008307 00001007 00001007
[ 1.372270] 00000160: 00008107 00000107 00003107 000002dc 00000300 00000300 00000300 00000000
[ 1.373088] 00000180: 00006300 00000200 00000200 00000200 00000200 00000200 00003f3f 00000041
[ 1.373906] 000001a0: 00000000 00000000 00000101 00000421 00000700 000002dc 00000004 00000141
[ 1.374723] 000001c0: 00000141 00000103 00000003 00000005 00000005 00000101 00000101 00008181
[ 1.375541] 000001e0: 0000033f 00000005 00000f1f 00000f0f 00000f0f 00000f0f 00000f0f 00000f0f
[ 1.376359] 00000200: 000000c5 000000c5 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.377176] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.377994] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.378812] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.379630] 00000280: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60
[ 1.380448] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 00000000 00000000
[ 1.381265] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.382082] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.382900] 00000300: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.383717] 00000320: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.384535] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.385351] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.386168] 00000380: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.386984] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.387801] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.388618] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.389435] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.390251] 00000420: 000000bc 00007070 00000000 00000014 00000000 00000000 00000000 00000000
[ 1.391069] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.391886] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.392704] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.393520] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.394336] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.395153] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.395971] 00000500: 00000000 00000000 00640064 00000000 00000003 00000001 00000000 00000000
[ 1.396788] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.397604] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.398420] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.399234] 00000580: 00000004 00000000 00000004 00000000 00000004
[ 1.399819] PMU CRU:
[ 1.400041] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 00000000 00000000
[ 1.400859] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.401677] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.402496] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.403315] 00000080: 0000070d 00001986 00000d0d 0000000d 000002dc 00000200 0bb8ea60 0bb8ea60
[ 1.404134] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.404952] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.405771] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.406589] 00000100: 00000000 00000000 00000000 00000000 00000024 00000000 00000000 00000000
[ 1.407404] 00000120: 00000000 00000180 00000000 00000000 00000000
