VPU allocate failed
各位大神,我用rk3288的开发板, android 4.4.3,硬解播放视频,在连续播放3个小时左右后,系统报错:
01-02 08:01:23.590 I/native-activity( 9234): File url: 3.mkv
01-02 08:01:23.590 I/native-activity( 9234): fullUrl: /mnt/sdcard/Movies/3.mkv
01-02 08:01:23.590 I/native-activity( 9234): Stream start!
01-02 08:01:23.590 I/native-activity( 9234): flow_or_file = 0
01-02 08:01:23.590 I/native-activity( 9234): Format matroska,webm probed with size=2048 and score=100
01-02 08:01:23.590 I/native-activity( 9234): st:0 removing common factor 1000000 from timebase
01-02 08:01:23.590 I/native-activity( 9234): st:1 removing common factor 1000000 from timebase
01-02 08:01:23.590 I/native-activity( 9234): err{or,}_recognition separate: 1; 1
01-02 08:01:23.590 I/native-activity( 9234): err{or,}_recognition combined: 1; 10001
01-02 08:01:23.590 I/native-activity( 9234): Unsupported bit depth: 0
01-02 08:01:23.770 I/native-activity( 9234): Probe buffer size limit 65535 reached
01-02 08:01:23.770 I/native-activity( 9234): stream_component_open audio!!!
01-02 08:01:23.770 I/native-activity( 9234): -------------------decID = 86018
01-02 08:01:23.770 I/native-activity( 9234): -------------------decTYPE = 1
01-02 08:01:23.770 I/native-activity( 9234): Stream Open: not specified codec, use default codec!
01-02 08:01:23.770 I/native-activity( 9234): Stream Open: prepare codec done!
01-02 08:01:23.770 I/native-activity( 9234): sample rate :48000, channels :2 bitspersample: 16
01-02 08:01:23.770 I/native-activity( 9234): mIndex… = 3, isConverted = 0
01-02 08:01:23.770 I/native-activity( 9234): 1
01-02 08:01:23.770 I/native-activity( 9234): err{or,}_recognition separate: 1; 10001
01-02 08:01:23.770 I/native-activity( 9234): err{or,}_recognition combined: 1; 10001
01-02 08:01:23.770 I/native-activity( 9234): Unsupported bit depth: 0
01-02 08:01:23.800 I/native-activity( 9234): 3
01-02 08:01:23.800 I/native-activity( 9234): avctx->codec_type=1
01-02 08:01:23.800 I/native-activity( 9234): audio thread task…: 773d8020
01-02 08:01:23.800 I/native-activity( 9234): stream_component_open video!!!
01-02 08:01:23.800 I/native-activity( 9234): -------------------decID = 28
01-02 08:01:23.800 I/native-activity( 9234): -------------------decTYPE = 0
01-02 08:01:23.800 I/native-activity( 9234): Stream Open: prepare codec done!
01-02 08:01:23.800 I/native-activity( 9234): 1
01-02 08:01:23.800 I/native-activity( 9234): err{or,}_recognition separate: 1; 10001
01-02 08:01:23.800 I/native-activity( 9234): err{or,}_recognition combined: 1; 10001
01-02 08:01:23.800 I/native-activity( 9234): rkdec_init
01-02 08:01:23.800 I/native-activity( 9234): codec_id = 28
01-02 08:01:23.800 I/native-activity( 9234): rkdec_ctx= 0x0
01-02 08:01:23.800 I/native-activity( 9234): rkdec_ctx1= 0x7c4c3120
01-02 08:01:23.800 I/native-activity( 9234): rkdec_prepare
01-02 08:01:23.800 I/native-activity( 9234): avctx->width = 1920, avctx->height = 1080
01-02 08:01:23.800 I/native-activity( 9234): avctx->extradata_size = 41
01-02 08:01:23.800 I/H264_DEBUG( 9234): init done status 0, ts_en = 0
01-02 08:01:23.800 I/H264_DEBUG( 9234): rockchip libstagefright verson!
01-02 08:01:23.800 I/native-activity( 9234): avctx->extradata 7c3da0e8: size: 41
01-02 08:01:23.800 I/native-activity( 9234): avctx->codec_type=0
01-02 08:01:23.800 I/native-activity( 9234): video thread task…: 773d8020
01-02 08:01:23.800 I/native-activity( 9234): ic->duration = 295680000,outFrameCountAll = 8870
01-02 08:01:23.800 I/native-activity( 9234): outPerFrameTime = 33334
01-02 08:01:23.800 I/native-activity( 9234): CodecId → 28
01-02 08:01:23.800 I/native-activity( 9234): Stream 773d8020 started successfully…!
01-02 08:01:23.800 I/native-activity( 9234): !!! fps = 30
01-02 08:01:23.800 I/native-activity( 9234): Unknown entry 0xF0
01-02 08:01:23.800 I/native-activity( 9234): avformat_seek_file ret= 1984269997
01-02 08:01:23.800 I/native-activity( 9234): seekPos = 0 ,eof = 0, outDuration = 295680
01-02 08:01:23.800 I/native-activity( 9234): Start stream 0 /mnt/sdcard/Movies/3.mkv successed (0)!
01-02 08:01:23.800 I/native-activity( 9234): duration = 295680, frameCount = 8870
01-02 08:01:23.800 I/native-activity( 9234): openFileArray[1]=295680,openFileArray[2]=8870
01-02 08:01:23.810 I/H264_DEBUG( 9234): found skipRedundantSlices
01-02 08:01:23.810 I/H264_DEBUG( 9234): Width 1920 Height 1088
01-02 08:01:23.810 I/H264_DEBUG( 9234): displaywidth 1920, dispalyheigt 1080
01-02 08:01:24.080 E/ion ( 9234): mmap failed: Out of memory
01-02 08:01:24.080 E/vpu_dma_buf( 9234): vpu_dmabuf_alloc:166: ion map failed
01-02 08:01:24.080 E/vpu_mem_dmabuf( 9234): VPU Allocate failed
01-02 08:01:24.100 E/ion ( 9234): mmap failed: Out of memory
01-02 08:01:24.100 E/vpu_dma_buf( 9234): vpu_dmabuf_alloc:166: ion map failed
01-02 08:01:24.100 E/vpu_mem_dmabuf( 9234): VPU Allocate failed
01-02 08:01:24.120 E/ion ( 9234): mmap failed: Out of memory
01-02 08:01:24.120 E/vpu_dma_buf( 9234): vpu_dmabuf_alloc:166: ion map failed
01-02 08:01:24.120 E/vpu_mem_dmabuf( 9234): VPU Allocate failed
01-02 08:01:24.140 E/H264_DEBUG( 9234): h264bsdAllocateDpbImage failed
01-02 08:01:24.140 E/H264_DEBUG( 9234): FATAL ERROR: -4
01-02 08:01:24.140 E/H264_DEBUG( 9234): ERROR: SLICE_HEADER
01-02 08:01:25.440 D/H264_DEBUG( 9234): found resync point
01-02 08:01:25.440 E/ion ( 9234): mmap failed: Out of memory
01-02 08:01:25.440 E/vpu_dma_buf( 9234): vpu_dmabuf_alloc:166: ion map failed
01-02 08:01:25.440 E/vpu_mem_dmabuf( 9234): VPU Allocate failed
01-02 08:01:25.460 E/ion ( 9234): mmap failed: Out of memory
01-02 08:01:25.460 E/vpu_dma_buf( 9234): vpu_dmabuf_alloc:166: ion map failed
01-02 08:01:25.460 E/vpu_mem_dmabuf( 9234): VPU Allocate failed
01-02 08:01:25.480 E/ion ( 9234): mmap failed: Out of memory
01-02 08:01:25.480 E/vpu_dma_buf( 9234): vpu_dmabuf_alloc:166: ion map failed
01-02 08:01:25.480 E/vpu_mem_dmabuf( 9234): VPU Allocate failed
01-02 08:01:25.500 E/H264_DEBUG( 9234): h264bsdAllocateDpbImage failed
01-02 08:01:25.500 E/H264_DEBUG( 9234): FATAL ERROR: -4
01-02 08:01:25.500 E/H264_DEBUG( 9234): ERROR: SLICE_HEADER
01-02 08:01:26.910 D/H264_DEBUG( 9234): found resync point
01-02 08:01:26.910 E/ion ( 9234): mmap failed: Out of memory
01-02 08:01:26.910 E/vpu_dma_buf( 9234): vpu_dmabuf_alloc:166: ion map failed
01-02 08:01:26.910 E/vpu_mem_dmabuf( 9234): VPU Allocate failed
01-02 08:01:26.940 E/ion ( 9234): mmap failed: Out of memory
01-02 08:01:26.940 E/vpu_dma_buf( 9234): vpu_dmabuf_alloc:166: ion map failed
01-02 08:01:26.940 E/vpu_mem_dmabuf( 9234): VPU Allocate failed
01-02 08:01:26.960 E/ion ( 9234): mmap failed: Out of memory
01-02 08:01:26.960 E/vpu_dma_buf( 9234): vpu_dmabuf_alloc:166: ion map failed
01-02 08:01:26.960 E/vpu_mem_dmabuf( 9234): VPU Allocate failed
01-02 08:01:26.980 E/H264_DEBUG( 9234): h264bsdAllocateDpbImage failed
01-02 08:01:26.980 E/H264_DEBUG( 9234): FATAL ERROR: -4
01-02 08:01:26.980 E/H264_DEBUG( 9234): ERROR: SLICE_HEADER
