如何修改代码,实现GPIO引脚的复用功能
举个例子,如下图,
比如说现在的SPI0_CSN0,我也不知道原来内核是把他当作普通的GPIO用还是当作特殊功能引脚用的,但是现在我想把它变成一个普通的GPIO来使用,我改如何修改它,让它变成普通的GPIO来使用.
请高手指点
图好像没有看到,我再传一次图,
wiki讲到了:http://wiki.t-firefly.com/index.php/Firefly-RK3288/GPIO
谢谢!!!!
thanks very much
rockchip,pull = <VALUE_PULL_DISABLE>;rockchip,drive = <VALUE_DRV_DEFAULT>;这两个属性代表什么意思?
一个是上下拉配置,一个是IO驱动能力配置
QQQQQQQ
static int rockchip_i2c_probe(struct platform_device *pdev){ struct rockchip_i2c *i2c = NULL; struct resource *res; struct device_node *np = pdev->dev.of_node; int ret;// … i2c->sda_gpio = of_get_gpio(np, 0); if (!gpio_is_valid(i2c->sda_gpio)) { dev_err(&pdev->dev, “sda gpio is invalid\n”); return -EINVAL; } ret = devm_gpio_request(&pdev->dev, i2c->sda_gpio, dev_name(&i2c->adap.dev)); if (ret) { dev_err(&pdev->dev, “failed to request sda gpio\n”); return ret; } i2c->scl_gpio = of_get_gpio(np, 1); if (!gpio_is_valid(i2c->scl_gpio)) { dev_err(&pdev->dev, “scl gpio is invalid\n”); return -EINVAL; } ret = devm_gpio_request(&pdev->dev, i2c->scl_gpio, dev_name(&i2c->adap.dev)); if (ret) { dev_err(&pdev->dev, “failed to request scl gpio\n”); return ret; } i2c->gpio_state = pinctrl_lookup_state(i2c->dev->pins->p, “gpio”); if (IS_ERR(i2c->gpio_state)) { dev_err(&pdev->dev, “no gpio pinctrl state\n”); return PTR_ERR(i2c->gpio_state); } pinctrl_select_state(i2c->dev->pins->p, i2c->gpio_state); gpio_direction_input(i2c->sda_gpio); gpio_direction_input(i2c->scl_gpio); pinctrl_select_state(i2c->dev->pins->p, i2c->dev->pins->default_state);// …}
这个函数中为什么先去申请gpio,然后再设置pin脚为gpio功能呢?我理解应该先去设置pin脚为gpio后,才能去申请gpio然后对gpio进行操作。
那请问下,如何才能把引脚复用改成i2c呢?
大佬们 链接打不开呀,一样的需求问题
学习,感谢分享
链接失效了,有没有新的有效的链接?
