HI:
各位大侠,请问下,我现在准备在FIREFLY的板子上调试一个USB CAMERA,不知道RK3288支持哪些型号的USB CAMERA,是不是ANDROID 已经支持了USB CAMERA,我只要一般的USB CAMERA都可以使用拉,是不是即插即用,或者说RK3288支持哪些特定的USB CAMERA呢
一般的UVC都可以
试过罗技的C170、C920、C930E
C170也是支持UVC的么,我在淘宝上买个UVC的应该就可以了吧,这个不知道行不行,http://detail.tmall.com/item.htm?spm=a230r.1.14.1.Xl0Vcv&id=15779726595&ad_id=&am_id=&cm_id=140105335569ed55e27b&pm_id=&abbucket=4
还有,我如果要添加USB CAMERA,我在3288的KERNEL里面需要改些什么,还有ANDROID层也有没有需要改的东东啊
5454ty 发表于 2015-3-4 14:12
C170也是支持UVC的么,我在淘宝上买个UVC的应该就可以了吧,这个不知道行不行,http://detail.tmall.com/it …
我的攝像頭我插上後看 dmesg 有顯示…但是android camera app 打開會失敗 ?
我也試過插者上電跟上電後插攝像頭 .. camera app 都開不起來 ..
請問有要做任何特殊動作嗎 ?
在Android 底下開APP失敗的log
[ 97.973229] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 97.981784] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 97.990154] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 98.000666] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 98.007052] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 98.014348] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 98.021592] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 98.030081] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 98.036842] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 98.045722] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 98.054156] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 98.062380] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 98.069818] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 98.077307] D1:camsys_release(734): camsys_marvin(ed880d10) is closed
[ 98.201812] Enter::rk29_hw_params----52
[ 98.206560] Enter:rk29_hw_params, 86, rate=44100
[ 98.211146] Enter:rk29_hw_params, 104, LRCK=64
[ 98.431345] Enter::rk29_hw_params----52
[ 98.436094] Enter:rk29_hw_params, 86, rate=44100
[ 98.440668] Enter:rk29_hw_params, 104, LRCK=64
[ 98.563933] init: sys_prop: permission denied uid:10019 name:sys.glibgui
[ 98.791445] Enter::rk29_hw_params----52
[ 98.796292] Enter:rk29_hw_params, 86, rate=44100
[ 98.800971] Enter:rk29_hw_params, 104, LRCK=64
[ 99.013679] Enter::rk29_hw_params----52
[ 99.018491] Enter:rk29_hw_params, 86, rate=44100
[ 99.023046] Enter:rk29_hw_params, 104, LRCK=64
crazycat 发表于 2015-5-7 01:45
在Android 底下開APP失敗的log[ 97.973229] E:camsys_sysctl_extdev(333): Sysctl 11 failed, becaus …
把具体的摄像头和sdk版本发一下
後來需求改成需要500萬像素的攝像頭打算從新買過..
請問下面這顆說有支援UVC ,這樣可以用嗎 ?
http://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.14.oux9IE&id=37593799403
你們有推薦500萬像素的攝像頭嗎 ?
