rk3399 通过 hdmi 接上电视开机动画出现异常(开机动画概率性显示在屏幕右下角,而不是在中间位置),异常Log如下:
[HDMI] sucess output HDMI.
PHY PLL not locked: PCLK_ON=1,TMDSCLK_ON=0
failed to display kernel logo
checkKey
vbus = 0
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x011f7de0)
ramdisk @ 0x05bf0000 (0x001a5bbc)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 0000000005614cd5 … OK
Add bank:0000000000200000, 000000007fe00000
[ 0.000000] Linux version 4.4.55 (seeiner@seeiner) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Sep 12 07:13:10 UTC 2017
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07ef02000 s45248 r8192 d32576 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 515592
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2017-08-18_13:31:52 hdmi.vic=-1 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0x7edb5000-0x7edf5000] (0MB) mapped at [ffffffc07edb5000-ffffffc07edf4fff]
[ 0.000000] Memory: 2019776K/2095104K available (11198K kernel code, 1375K rwdata, 4952K rodata, 832K init, 1078K bss, 58944K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009050000 - 0xffffff8009120000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b70000 ( 11200 KB)
[ 0.000000] .rodata : 0xffffff8008b70000 - 0xffffff8009050000 ( 4992 KB)
[ 0.000000] .data : 0xffffff8009120000 - 0xffffff8009277ca0 ( 1376 KB)
[ 0.000000] ITS: allocated 65536 Devices @7c400000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000007c480000
[ 0.000000] CPU0: using LPI pending table @0x000000007c490000
[ 0.001837] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002802] pid_max: default: 32768 minimum: 301
[ 0.003298] Security Framework initialized
[ 0.003688] SELinux: Initializing.
[ 0.004120] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004748] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006187] Initializing cgroup subsys freezer
[ 0.006615] Initializing cgroup subsys debug
[ 0.007870] sched-energy: Sched-energy-costs installed from DT
[ 0.008420] CPU0: update cpu_capacity 401
[ 0.008871] ASID allocator initialised with 65536 entries
[ 0.025696] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.026910] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039080] Detected VIPT I-cache on CPU1
[ 0.039111] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039146] CPU1: using LPI pending table @0x000000007c5f0000
[ 0.039189] CPU1: update cpu_capacity 401
[ 0.039192] CPU1: Booted secondary processor [410fd034]
[ 0.049082] Detected VIPT I-cache on CPU2
[ 0.049102] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049134] CPU2: using LPI pending table @0x000000007c620000
[ 0.049160] CPU2: update cpu_capacity 401
[ 0.049164] CPU2: Booted secondary processor [410fd034]
[ 0.059119] Detected VIPT I-cache on CPU3
[ 0.059137] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059169] CPU3: using LPI pending table @0x000000007c660000
[ 0.059196] CPU3: update cpu_capacity 401
[ 0.059199] CPU3: Booted secondary processor [410fd034]
[ 0.069157] Detected PIPT I-cache on CPU4
[ 0.069184] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069220] CPU4: using LPI pending table @0x000000007c6a0000
[ 0.069260] CPU4: update cpu_capacity 1024
[ 0.069264] CPU4: Booted secondary processor [410fd082]
[ 0.079185] Detected PIPT I-cache on CPU5
[ 0.079203] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079235] CPU5: using LPI pending table @0x000000007c6e0000
[ 0.079262] CPU5: update cpu_capacity 1024
[ 0.079265] CPU5: Booted secondary processor [410fd082]
[ 0.079349] Brought up 6 CPUs
[ 0.091445] SMP: Total of 6 processors activated.
[ 0.091887] CPU features: detected feature: GIC system register CPU interface
[ 0.092557] CPU: All CPU(s) started at EL2
[ 0.092980] alternatives: patching kernel code
[ 0.094633] devtmpfs: initialized
[ 0.114358] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.115290] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.116906] pinctrl core: initialized pinctrl subsystem
[ 0.120002] Failed to find legacy iommu devices
[ 0.120995] NET: Registered protocol family 16
[ 0.122120] schedtune: init normalization constants…
[ 0.122608] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.123220] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.123832] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.124459] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.125070] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.125682] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.126294] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.126906] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.127516] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.128138] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.128852] schedtune: verify normalization constants…
[ 0.129349] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.129872] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.130392] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.130913] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.131435] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.131966] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.132487] schedtune: configured to support 4 boost groups
[ 0.142006] cpuidle: using governor ladder
[ 0.155365] cpuidle: using governor menu
[ 0.155750] Registered FIQ tty driver
[ 0.156729] vdso: 2 pages (1 code @ ffffff8008b76000, 1 data @ ffffff8009124000)
[ 0.157448] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.158894] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.183608] console [pstore0] enabled
[ 0.184154] pstore: Registered ramoops as persistent store backend
[ 0.184737] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.188747] console [ttyFIQ0] enabled
[[ 0.188747] console [ttyFIQ0] enabled
[ 0.189303] bootconsole [uart0] disabled
[ 0.190519] Registered fiq debugger ttyFIQ0
[ 0.243799] Rockchip hdmi driver version 2.0
[ 0.245892] iommu: Adding device ff650000.vpu_service to group 0
[ 0.245976] iommu: Adding device ff660000.rkvdec to group 1
[ 0.246041] iommu: Adding device ff670000.iep to group 2
[ 0.246163] iommu: Adding device ff8f0000.vop to group 3
[ 0.246237] iommu: Adding device ff900000.vop to group 4
[ 0.246329] iommu: Adding device ff910000.isp to group 5
[ 0.246403] iommu: Adding device ff920000.isp to group 6
[ 0.247057] rk_iommu ff670800.iommu: can’t get aclk
[ 0.247079] rk_iommu ff670800.iommu: can’t get hclk
[ 0.247899] SCSI subsystem initialized
[ 0.248246] usbcore: registered new interface driver usbfs
[ 0.248291] usbcore: registered new interface driver hub
[ 0.248359] usbcore: registered new device driver usb
[ 0.248700] media: Linux media interface: v0.10
[ 0.248738] Linux video capture interface: v2.00
[ 0.248867] pps_core: LinuxPPS API ver. 1 registered
[ 0.248878] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.248903] PTP clock support registered
[ 0.250218] Advanced Linux Sound Architecture Driver Initialized.
[ 0.250710] Bluetooth: Core ver 2.21
[ 0.250742] NET: Registered protocol family 31
[ 0.250752] Bluetooth: HCI device and connection manager initialized
[ 0.250769] Bluetooth: HCI socket layer initialized
[ 0.250783] Bluetooth: L2CAP socket layer initialized
[ 0.250812] Bluetooth: SCO socket layer initialized
[ 0.252068] clocksource: Switched to clocksource arch_sys_counter
[ 0.290898] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.291741] NET: Registered protocol family 2
[ 0.292200] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.292307] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.292430] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.292500] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.292529] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.292683] NET: Registered protocol family 1
[ 0.293139] Trying to unpack rootfs image as initramfs…
[ 0.379851] Freeing initrd memory: 1684K (ffffffc005bf0000 - ffffffc005d95000)
[ 0.380393] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.380477] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.383061] audit: initializing netlink subsys (disabled)
[ 0.383125] audit: type=2000 audit(0.376:1): initialized
[ 0.391542] VFS: Disk quotas dquot_6.6.0
[ 0.391669] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.393064] fuse init (API version 7.23)
[ 0.397540] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.397569] io scheduler noop registered
[ 0.397731] io scheduler cfq registered (default)
[ 0.399007] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.401501] Firefly GPIO Test Program Probe
[ 0.401572] Firefly gpio putout
[ 0.401605] firefly:the gpio:157
[ 0.403504] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.403532] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.403550] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.925439] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.925503] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.926152] rockchip ion idev is NULL
[ 0.926166] rga2 ff680000.rga: rga ion client create success!
[ 0.926398] rga: Driver loaded successfully ver:3.02
[ 0.927103] iep: failed to find iep power down clock source.
[ 0.927411] IEP Power ON
[ 0.927565] IEP Power OFF
[ 0.927595] IEP Driver loaded succesfully
[ 0.927688] Module initialized.
[ 0.931421] rk-vcodec ff650000.vpu_service: No core reset resource define
[ 0.931476] rk-vcodec ff650000.vpu_service: do not have pd_video
[ 0.931500] rk-vcodec ff650000.vpu_service: probe device
[ 0.931542] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07bc57010
[ 0.931683] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.931740] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.932156] rk-vcodec ff650000.vpu_service: init success
[ 0.935818] rk-vcodec ff660000.rkvdec: No core reset resource define
[ 0.935927] rk-vcodec ff660000.rkvdec: do not have pd_video
[ 0.935947] rk-vcodec ff660000.rkvdec: probe device
[ 0.935988] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07bc57810
[ 0.936120] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.936180] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.936474] rk-vcodec ff660000.rkvdec: init success
[ 0.937887] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.937907] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.939294] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.939312] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.939558] rockchip-cpuinfo cpuinfo: Serial : 0000000000000
[ 0.940769] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.942254] console [ttyS0] disabled
[ 0.942299] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 0.942827] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.943353] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 39, base_baud = 1500000) is a 16550A
[ 0.943699] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 0.947521] mali ff9a0000.gpu: Failed to get regulator
[ 0.947544] mali ff9a0000.gpu: Power control initialization failed
[ 0.947781] Unable to detect cache hierarchy from DT for CPU 0
[ 0.958832] brd: module loaded
[ 0.963472] loop: module loaded
[ 0.963974] zram: Added device: zram0
[ 0.964507] relay GPIO Test Program Probe
[ 0.964617] relay gpio putout
[ 0.964820] SCSI Media Changer driver v0.25
[ 0.965788] rockchip-pinctrl pinctrl: pin gpio1-8 already requested by ff370000.serial; cannot claim for ff1d0000.spi
[ 0.965814] rockchip-pinctrl pinctrl: pin-40 (ff1d0000.spi) status -22
[ 0.965831] rockchip-pinctrl pinctrl: could not request pin 40 (gpio1-8) from group spi1-tx on device rockchip-pinctrl
[ 0.965848] rockchip-spi ff1d0000.spi: Error applying setting, reverse things back
[ 0.965982] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 0.965996] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 0.966888] tun: Universal TUN/TAP device driver, 1.6
[ 0.966900] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.967816] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 0.967835] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 0.967847] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 0.968031] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 0.968044] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 0.973118] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.973129] Ring mode enabled
[ 0.973138] DMA HW capability register supported
[ 0.973147] Normal descriptors
[ 0.973157] RX Checksum Offload Engine supported (type 2)
[ 0.973166] TX Checksum insertion supported
[ 0.973174] Wake-Up On Lan supported
[ 0.973216] Enable RX Mitigation via HW Watchdog Timer
[ 1.039634] libphy: stmmac: probed
[ 1.039654] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.039667] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.040391] PPP generic driver version 2.4.2
[ 1.040566] PPP BSD Compression module registered
[ 1.040584] PPP Deflate Compression module registered
[ 1.040613] PPP MPPE Compression module registered
[ 1.040633] NET: Registered protocol family 24
[ 1.040673] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.040686] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.040708] Rockchip WiFi SYS interface (V1.00) …
[ 1.040793] usbcore: registered new interface driver catc
[ 1.040836] usbcore: registered new interface driver kaweth
[ 1.040852] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.040893] usbcore: registered new interface driver pegasus
[ 1.040935] usbcore: registered new interface driver rtl8150
[ 1.040977] usbcore: registered new interface driver r8152
[ 1.040992] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.041050] usbcore: registered new interface driver hso
[ 1.041100] usbcore: registered new interface driver asix
[ 1.041142] usbcore: registered new interface driver ax88179_178a
[ 1.041184] usbcore: registered new interface driver cdc_ether
[ 1.041229] usbcore: registered new interface driver cdc_eem
[ 1.041271] usbcore: registered new interface driver dm9601
[ 1.041323] usbcore: registered new interface driver smsc75xx
[ 1.041375] usbcore: registered new interface driver smsc95xx
[ 1.041417] usbcore: registered new interface driver gl620a
[ 1.041461] usbcore: registered new interface driver net1080
[ 1.041504] usbcore: registered new interface driver plusb
[ 1.041546] usbcore: registered new interface driver rndis_host
[ 1.041589] usbcore: registered new interface driver cdc_subset
[ 1.041631] usbcore: registered new interface driver zaurus
[ 1.041674] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.041734] usbcore: registered new interface driver int51x1
[ 1.041778] usbcore: registered new interface driver kalmia
[ 1.041822] usbcore: registered new interface driver ipheth
[ 1.041868] usbcore: registered new interface driver sierra_net
[ 1.041909] usbcore: registered new interface driver cx82310_eth
[ 1.041964] usbcore: registered new interface driver cdc_ncm
[ 1.042007] usbcore: registered new interface driver qmi_wwan
[ 1.042051] usbcore: registered new interface driver cdc_mbim
[ 1.043212] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.046356] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.046940] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.046959] ehci-pci: EHCI PCI platform driver
[ 1.047016] ehci-platform: EHCI generic platform driver
[ 1.048798] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.048826] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.048974] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.058761] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.058887] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.058903] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.058917] usb usb1: Product: EHCI Host Controller
[ 1.058928] usb usb1: Manufacturer: Linux 4.4.55 ehci_hcd
[ 1.058940] usb usb1: SerialNumber: fe3c0000.usb
[ 1.059385] hub 1-0:1.0: USB hub found
[ 1.059417] hub 1-0:1.0: 1 port detected
[ 1.059891] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.059920] ohci-platform: OHCI generic platform driver
[ 1.060352] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.060379] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.060497] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.116209] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.116231] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.116246] usb usb2: Product: Generic Platform OHCI controller
[ 1.116259] usb usb2: Manufacturer: Linux 4.4.55 ohci_hcd
[ 1.116270] usb usb2: SerialNumber: fe3e0000.usb
[ 1.116688] hub 2-0:1.0: USB hub found
[ 1.116722] hub 2-0:1.0: 1 port detected
[ 1.117495] usbcore: registered new interface driver cdc_acm
[ 1.117507] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.117570] usbcore: registered new interface driver usblp
[ 1.117618] usbcore: registered new interface driver cdc_wdm
[ 1.117664] usbcore: registered new interface driver uas
[ 1.117740] usbcore: registered new interface driver usb-storage
[ 1.117783] usbcore: registered new interface driver ums-alauda
[ 1.117825] usbcore: registered new interface driver ums-cypress
[ 1.117867] usbcore: registered new interface driver ums-datafab
[ 1.117909] usbcore: registered new interface driver ums_eneub6250
[ 1.117950] usbcore: registered new interface driver ums-freecom
[ 1.117991] usbcore: registered new interface driver ums-isd200
[ 1.118032] usbcore: registered new interface driver ums-jumpshot
[ 1.118077] usbcore: registered new interface driver ums-karma
[ 1.118119] usbcore: registered new interface driver ums-onetouch
[ 1.118161] usbcore: registered new interface driver ums-sddr09
[ 1.118202] usbcore: registered new interface driver ums-sddr55
[ 1.118244] usbcore: registered new interface driver ums-usbat
[ 1.118326] usbcore: registered new interface driver usbserial
[ 1.118363] usbcore: registered new interface driver usbserial_generic
[ 1.118397] usbserial: USB Serial support registered for generic
[ 1.118445] usbcore: registered new interface driver option
[ 1.118474] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.118575] usbcore: registered new interface driver trancevibrator
[ 1.118592] usb20_otg: version 3.10a 21-DEC-2012
[ 1.118788] usb20_host: version 3.10a 21-DEC-2012
[ 1.122551] usbcore: registered new interface driver xpad
[ 1.122602] usbcore: registered new interface driver usb_acecad
[ 1.122650] usbcore: registered new interface driver aiptek
[ 1.122698] usbcore: registered new interface driver gtco
[ 1.122748] usbcore: registered new interface driver hanwang
[ 1.122796] usbcore: registered new interface driver kbtab
[ 1.122812] ==gsl_ts_init==
[ 1.122840] ret=0
[ 1.126565] .. rk pwm remotectl v1.1 init
[ 1.126800] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.127178] sensor_register_slave:mma8452,id=17
[ 1.127197] sensor_register_slave:lis3dh,id=7
[ 1.127213] sensor_register_slave:mma7660,id=18
[ 1.127229] sensor_register_slave:lsm303d,id=22
[ 1.127245] sensor_register_slave:mpu6880_acc,id=24
[ 1.127260] sensor_register_slave:mpu6500_acc,id=25
[ 1.127276] sensor_register_slave:lsm330_acc,id=26
[ 1.127292] sensor_register_slave:akm8975,id=28
[ 1.127307] sensor_register_slave:akm8963,id=29
[ 1.127323] sensor_register_slave:l3g4200d,id=43
[ 1.127339] sensor_register_slave:l3g20d,id=44
[ 1.127354] sensor_register_slave:ewtsa,id=45
[ 1.127369] sensor_register_slave:lsm330_gyro,id=48
[ 1.127385] sensor_register_slave:cm3217,id=50
[ 1.127400] sensor_register_slave:cm3218,id=51
[ 1.128048] i2c /dev entries driver
[ 1.129180] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.129242] fan53555-reg: supplied by vcc5v0_sys
[ 1.131460] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.131505] fan53555-reg: supplied by vcc5v0_sys
[ 1.133767] rk808 0-001b: Pmic Chip id: 0x0
[ 1.136871] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.136922] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.137003] DCDC_REG1: supplied by vcc3v3_sys
[ 1.137652] DCDC_REG2: supplied by vcc3v3_sys
[ 1.138131] DCDC_REG3: supplied by vcc3v3_sys
[ 1.138328] DCDC_REG4: supplied by vcc3v3_sys
[ 1.138704] LDO_REG1: supplied by vcc3v3_sys
[ 1.139740] LDO_REG2: supplied by vcc3v3_sys
[ 1.140618] LDO_REG3: supplied by vcc3v3_sys
[ 1.141514] LDO_REG4: supplied by vcc3v3_sys
[ 1.142398] LDO_REG5: supplied by vcc3v3_sys
[ 1.143282] LDO_REG6: supplied by vcc3v3_sys
[ 1.144181] LDO_REG7: supplied by vcc3v3_sys
[ 1.145064] LDO_REG8: supplied by vcc3v3_sys
[ 1.145947] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.146162] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.149427] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.149944] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009684000
[ 1.150482] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009686000
[ 1.163669] fusb302 4-0022: port 0 probe success
[ 1.163703] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009688000
[ 1.164439] IR NEC protocol handler initialized
[ 1.164455] IR RC5(x/sz) protocol handler initialized
[ 1.164470] IR RC6 protocol handler initialized
[ 1.164483] IR JVC protocol handler initialized
[ 1.164497] IR Sony protocol handler initialized
[ 1.164512] IR SANYO protocol handler initialized
[ 1.164526] IR Sharp protocol handler initialized
[ 1.164541] IR MCE Keyboard/mouse protocol handler initialized
[ 1.164556] IR XMP protocol handler initialized
[ 1.164645] usbcore: registered new interface driver uvcvideo
[ 1.164655] USB Video Class driver (1.1.1)
[ 1.164673] CamSys driver version: v0.33.11, CamSys head file version: v0.13.0
[ 1.165713] D1:camsys_platform_probe(1399): compatible is rockchip,rk3399-isp
[ 1.165713]
[ 1.165807] D1:camsys_mipiphy_probe_cb(204): ff910000.isp mipi phy0 probe success (reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.165807]
[ 1.165832] D1:camsys_mipiphy_probe_cb(204): ff910000.isp mipi phy1 probe success (reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.165832]
[ 1.166656] D1:camsys_platform_probe(1527): ff910000.isp memory:
[ 1.166673] D1:camsys_platform_probe(1543): Register memory (phy: 0xff910000 vir: 0xffffff8009690000 size: 0x4000)
[ 1.166688] D1:camsys_platform_probe(1535): I2c memory (phy: 0x7b04a000 vir: 0xffffffc07b04a000 size: 0x1000)
[ 1.166702] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.166713] D1:camsys_platform_probe(1557): Probe ff910000.isp device success
[ 1.167842] D1:camsys_platform_probe(1399): compatible is rockchip,rk3399-isp
[ 1.167842]
[ 1.167911] D1:camsys_mipiphy_probe_cb(204): ff920000.isp mipi phy0 probe success (reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.167911]
[ 1.167934] D1:camsys_mipiphy_probe_cb(204): ff920000.isp mipi phy1 probe success (reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.167934]
[ 1.168689] D1:camsys_platform_probe(1527): ff920000.isp memory:
[ 1.168704] D1:camsys_platform_probe(1543): Register memory (phy: 0xff920000 vir: 0xffffff8009698000 size: 0x4000)
[ 1.168719] D1:camsys_platform_probe(1535): I2c memory (phy: 0x7b062000 vir: 0xffffffc07b062000 size: 0x1000)
[ 1.168767] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.168779] D1:camsys_platform_probe(1557): Probe ff920000.isp device success
[ 1.169114] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.169240] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.169481] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.169585] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.170828] rockchip_cpu_avs: cluster0 leakage=17 adjust_volt=0
[ 1.170864] rockchip_cpu_avs: cluster1 leakage=29 adjust_volt=0
[ 1.171971] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.172590] device-mapper: uevent: version 1.0.3
[ 1.172880] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.176385] Bluetooth: HCI UART driver ver 2.3
[ 1.176400] Bluetooth: HCI UART protocol H4 registered
[ 1.176411] Bluetooth: HCI UART protocol LL registered
[ 1.176426] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.176437] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.176448] rtk_btusb: Register usb char device interface for BT driver
[ 1.176668] usbcore: registered new interface driver rtk_btusb
[ 1.181029] sdhci: Secure Digital Host Controller Interface driver
[ 1.181046] sdhci: Copyright(c) Pierre Ossman
[ 1.181061] Synopsys Designware Multimedia Card Interface Driver
[ 1.181858] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.181934] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.181956] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.182007] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.182040] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.182124] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.182138] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.182862] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.182906] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.182926] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.182975] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.182999] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.183089] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.183329] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.183470] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.195495] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.209885] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.210143] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.211813] sdhci-arasan fe330000.sdhci: No vmmc regulator found
这块了解大大牛麻烦帮忙看下,谢谢!
