源码是最新的,添加之后启动信息如下:
DDR Version 1.00 20160530
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-10 (Oct 08 2016 - 15:45:52)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2016-10-08#2.30
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
pll_src = 0, dclk_hz = 205000000, dclk_div = 2
edp pll locked
link training success.
unable to config video
no fuel gauge found
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006a17d0)
ramdisk @ 0x05bf0000 (0x002ad1a8)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c335 … OK
一直重复在 Starting kernel …
请问是什么问题
