linux 声卡es8323无法工作
在使用reload的板子的时候,使用kernel时4.4的内核,dts里面默认配置了firefly的es8323的声卡,声卡信息也能够枚举出来,使用这个声卡播放.wav格式文件的时候插上耳机,耳机里面没有声音,你们这边有调试过吗?这个声卡在4.4内核中能够正常工作嘛 若是有调试过麻烦提供一些帮助谢谢!
root@linaro-alip:/home/linaro/work# aplay -l
card 0: rockchipfirefly [rockchip,firefly-codec], device 0: ff890000.i2s-i2s-hifi i2s-hifi-0
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: rockchipfirefly [rockchip,firefly-codec], device 1: ff890000.i2s-ES8323 HiFi ES8323 HiFi-1
Subdevices: 1/1
card 1: ROCKCHIPSPDIF [ROCKCHIP,SPDIF], device 0: ff8b0000.sound-dit-hifi dit-hifi-0
Subdevices: 1/1
音频相关log:
[ 4.380612] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/sound[0]’
[ 4.380659] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/sound[0]’
[ 4.509115] asoc-simple-card sound: i2s-hifi ↔ ff890000.i2s mapping ok
[ 4.526876] asoc-simple-card sound: ES8323 HiFi ↔ ff890000.i2s mapping ok
[ 4.533944] asoc-simple-card sound: ASoC: no sink widget found for MIC1
[ 4.540825] asoc-simple-card sound: ASoC: Failed to add route Microphone Jack → direct → MIC1
[ 4.549675] asoc-simple-card sound: ASoC: no sink widget found for MIC2
[ 4.556481] asoc-simple-card sound: ASoC: Failed to add route Microphone Jack → direct → MIC2
[ 4.565306] asoc-simple-card sound: ASoC: no source widget found for micbias1
[ 4.572505] asoc-simple-card sound: ASoC: Failed to add route micbias1 → direct → Microphone Jack
[ 4.581707] asoc-simple-card sound: ASoC: no source widget found for HPOL
[ 4.588644] asoc-simple-card sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 4.597434] asoc-simple-card sound: ASoC: no source widget found for HPOR
[ 4.604365] asoc-simple-card sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 4.617837] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/spdif-sound[0]’
[ 4.617848] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/spdif-sound[0]’
[ 4.618745] asoc-simple-card spdif-sound: dit-hifi ↔ ff8b0000.sound mapping ok
linux系统,可以使用amixer对声卡进行调试
kernel 4.4 目前声卡能够工作,但是声音很小,使用amixer无法对音量进行调节,你们在4.4的kernel里面有没有调试过这个声卡,麻烦帮忙分析下,谢谢!
root@linaro-alip:/home/linaro/work# amixer controls
numid=2,iface=PCM,name=‘AUDIO MODE’
numid=1,iface=PCM,name=‘ELD’
jason0592 发表于 2018-8-20 16:09
kernel 4.4 目前声卡能够工作,但是声音很小,使用amixer无法对音量进行调节,你们在4.4的kernel里面有没 …
你把所有的cotrols列出来看看啊
是在不行就自己加几个
zoro 发表于 2018-8-24 09:11
你把所有的cotrols列出来看看啊
是在不行就自己加几个
好的 rk3288 linux4.4kernel的固件在哪里下载啊?
你看看这个帖子有没有帮助
http://dev.t-firefly.com/forum.php?mod=viewthread&tid=52741&page=1#pid118517
你好!我也遇到了这个问题,请问你是怎么解决的呢?
act8846 regular 不对,调整下,就行了。
https://github.com/FireflyTeam/kernel/commit/70c19eb6929b42506374e7e5f371248408102895
