[ 3.224903] cif_isp10_v4l2_drv_probe: probing…
[ 3.229534] rkisp10 ff910000.cif_isp: can’t request region for resource [mem 0xff910000-0xff91ffff]
[ 3.238578] cif_isp10_pltfrm_dev_init(992) ERR: devm_ioremap_resource failed
[ 3.245666] cif_isp10_pltfrm_dev_init(1029) ERR: could not get default pinstate
[ 3.252961] cif_isp10_pltfrm_dev_init WARN: could not get pins_sleep pinstate
[ 3.260092] cif_isp10_pltfrm_dev_init WARN: could not get pins_inactive pinstate
[ 3.267610] 1-gpios-cifpower: gpio=-2
[ 3.271654] ov13850.pltfrm_camera_module_init_gpio WARN: GPIO #11 (‘rockchip,pwr-gpio’) may be reused!
[ 3.306340] ov13850.ov_camera_module_write_config(182) ERR: no active sensor configuration
[ 3.314415] ov13850.ov_camera_module_write_config(233) ERR: failed with error -14
[ 3.322225] ov13850.pltfrm_camera_module_read_reg(996) ERR: i2c read from offset 0x0000300a failed with error -6
[ 3.332578] ov13850.pltfrm_camera_module_read_reg(996) ERR: i2c read from offset 0x0000300b failed with error -6
[ 3.342769] ov13850.ov13850_check_camera_id(1861) ERR: register read failed, camera module powered off?
[ 3.352153] ov13850.ov13850_check_camera_id(1879) ERR: failed with error (-6)
[ 3.359308] ov13850.ov_camera_module_attach(256) ERR: failed with error -6
[ 3.366206] cif_isp10_img_src_v4l2_i2c_subdev_to_img_src(59) ERR: failed with error -6
[ 3.374108] cif_isp10_img_src_to_img_src(70) ERR: to_img_src failed!
[ 3.380461] cif_isp10_img_src_to_img_src(78) ERR: failed with error -14
[ 3.387075] cif_isp10_img_srcs_init(1080) ERR: failed with error -14
[ 3.393415] cif_isp10_create(5480) ERR: cif_isp10_img_srcs_init failed
[ 3.399934] cif_isp10_create(5515) ERR: failed with error -14
root@firefly:~# dmesg | grep camera
[ 3.448300] of_get_named_gpiod_flags: can’t parse ‘rockchip,gpios-cifpower’ property of node ‘/i2c@ff150000/camera-module@10[0]’
[ 3.452271] of_get_named_gpiod_flags: parsed ‘rockchip,pd-gpio’ property of node ‘/i2c@ff150000/camera-module@10[0]’ - status (0)
[ 3.452283] of_get_named_gpiod_flags: parsed ‘rockchip,pwr-gpio’ property of node ‘/i2c@ff150000/camera-module@10[0]’ - status (0)
[ 3.452289] of_get_named_gpiod_flags: can’t parse ‘rockchip,flash-gpio’ property of node ‘/i2c@ff150000/camera-module@10[0]’
[ 3.452294] of_get_named_gpiod_flags: can’t parse ‘rockchip,torch-gpio’ property of node ‘/i2c@ff150000/camera-module@10[0]’
[ 3.452304] of_get_named_gpiod_flags: parsed ‘rockchip,rst-gpio’ property of node ‘/i2c@ff150000/camera-module@10[0]’ - status (0)
[ 3.452383] ov13850.pltfrm_camera_module_init_gpio WARN: GPIO #11 (‘rockchip,pwr-gpio’) may be reused!
[ 3.487091] ov13850.ov_camera_module_write_config(182) ERR: no active sensor configuration
[ 3.495200] ov13850.ov_camera_module_write_config(233) ERR: failed with error -14
[ 4.501184] ov13850.pltfrm_camera_module_read_reg(996) ERR: i2c read from offset 0x0000300a failed with error -110
[ 5.511035] ov13850.pltfrm_camera_module_read_reg(996) ERR: i2c read from offset 0x0000300b failed with error -110
[ 5.521791] ov13850.ov13850_check_camera_id(1861) ERR: register read failed, camera module powered off?
[ 5.531528] ov13850.ov13850_check_camera_id(1879) ERR: failed with error (-110)
[ 5.539488] ov13850.ov_camera_module_attach(256) ERR: failed with error -110
