贵司官方wiki中的3288的固件中,版本是u-boot2017-02版本,请问怎么实现开机logo呢
leung先森 发表于 2018-9-25 10:10
http://dev.t-firefly.com/forum.php?mod=viewthread&tid=13610&highlight=����logo
rk3288_bootloader_v1.00.06.bin这是目前的u-boot版本,对应源码是贵司u-boot-master版本,修改内核的logo,烧写进去还是没有显示,我怀疑是不是u-boot的开机logo功能没有打开呢?
这是开机log:
U-Boot 2017.02-RK3288-06 (Sep 25 2018 - 10:31:57)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 816000000HZ
periph pll = 297000000HZ
ddr pll = 396000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059b9c4c
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059b9e4c
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059c9a4c
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059c9c4c
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-16777215 pin-255
No pmic detect.
can’t find dts node for pwm0
#Boot ver: 2018-09-25#2.30
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
misc partition not found!
雾都大帝 发表于 2018-9-25 10:56
rk3288_bootloader_v1.00.06.bin这是目前的u-boot版本,对应源码是贵司u-boot-master版本,修改内核的log …
替换logo.bmp后烧写resource.img生效
{:4_123:}
我的u-boot版本是rk3288_bootloader_v1.00.06.bin,内核是kernel4.4.77版本,这个方法测试过,但是没有开机logo显示,就是在wiki下载固件也没有显示logo,,,目前的问题有两个,我在看一些资料,说开机logo要显示,要确保u-boot中lcd驱动打开,然后因为设备树是uboot和内核公用,所以想请教一下设备数中开机logo的配置。麻烦leung先森分享一下。谢谢
