MIPI屏幕点亮,进不去操作系统,显示FAILED TO BIND
MIPI屏幕点亮,停留在LOGO界面,进不去操作系统
LOG信息如下,跪求大神帮忙!
U-Boot 2014.10-RK3399-06 (Aug 01 2019 - 20:47:30)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01000000
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2019-08-01#1.09
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
Warn: route-hdmi: connector node is not available
failed to find phy node
pwrctr_name:lcd-rst, parse gpio:1053, atv_val=1,delay:6ms
no fuel gauge found
Using display timing dts
Detailed mode clock 136000 kHz, flags[a]
H: 1080 1106 1108 1144
V: 2160 2168 2172 2176
bus_format: 100a
rk lcdc - 0 dclk set: dclk = 136000000HZ, pll select = 1, div = 1
pwrctr: set lcd-rst(1053)=1,delay:6ms
rockchip_phy_power_on: failed to find phy power on funcs
failed to wait for phy clk lane stop state
failed to display kernel logo
checkKey
vbus = 0
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x01325008)
ramdisk @ 0x05bf0000 (0x007b1b04)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 0000000005616a15 … OK
Add bank:0000000009400000, 00000000eec00000
[ 0.000000] Linux version 4.4.83 (root@liuty-OptiPlex-9020) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Jul 15 16:26:46 CST 2019
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6eea000 s45696 r8192 d32128 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 995336
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2019-08-01_20:47:30 hdmi.vic=-1 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0xf6ea2000-0xf6ee2000] (0MB) mapped at [ffffffc0f6ea2000-ffffffc0f6ee1fff]
[ 0.000000] Memory: 3919752K/4044800K available (11838K kernel code, 1428K rwdata, 5436K rodata, 832K init, 1116K bss, 108664K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009170000 - 0xffffff8009240000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008c10000 ( 11840 KB)
[ 0.000000] .rodata : 0xffffff8008c10000 - 0xffffff8009170000 ( 5504 KB)
[ 0.000000] .data : 0xffffff8009240000 - 0xffffff80093a5008 ( 1429 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] ITS: allocated 65536 Devices @f1800000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000f1880000
[ 0.000000] CPU0: using LPI pending table @0x00000000f1890000
[ 0.009922] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.021203] pid_max: default: 32768 minimum: 301
[ 0.026334] Security Framework initialized
[ 0.030839] SELinux: Initializing.
[ 0.034776] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.042143] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.050793] Initializing cgroup subsys freezer
[ 0.055687] Initializing cgroup subsys debug
[ 0.061273] sched-energy: Sched-energy-costs installed from DT
[ 0.067695] CPU0: update cpu_capacity 401
[ 0.072149] ASID allocator initialised with 65536 entries
[ 0.094957] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.105069] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.128736] Detected VIPT I-cache on CPU1
[ 0.128765] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.128802] CPU1: using LPI pending table @0x00000000f1a00000
[ 0.128844] CPU1: update cpu_capacity 401
[ 0.128847] CPU1: Booted secondary processor [410fd034]
[ 0.138726] Detected VIPT I-cache on CPU2
[ 0.138745] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.138777] CPU2: using LPI pending table @0x00000000f1a30000
[ 0.138805] CPU2: update cpu_capacity 401
[ 0.138808] CPU2: Booted secondary processor [410fd034]
[ 0.148764] Detected VIPT I-cache on CPU3
[ 0.148783] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.148815] CPU3: using LPI pending table @0x00000000f1a70000
[ 0.148842] CPU3: update cpu_capacity 401
[ 0.148845] CPU3: Booted secondary processor [410fd034]
[ 0.158807] Detected PIPT I-cache on CPU4
[ 0.158836] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.158875] CPU4: using LPI pending table @0x00000000f1ab0000
[ 0.158914] CPU4: update cpu_capacity 1024
[ 0.158917] CPU4: Booted secondary processor [410fd082]
[ 0.168832] Detected PIPT I-cache on CPU5
[ 0.168850] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.168887] CPU5: using LPI pending table @0x00000000f1ae0000
[ 0.168915] CPU5: update cpu_capacity 1024
[ 0.168917] CPU5: Booted secondary processor [410fd082]
[ 0.168999] Brought up 6 CPUs
[ 0.311444] SMP: Total of 6 processors activated.
[ 0.316614] CPU features: detected feature: GIC system register CPU interface
[ 0.324458] CPU: All CPU(s) started at EL2
[ 0.328992] alternatives: patching kernel code
[ 0.336398] devtmpfs: initialized
[ 0.354567] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.365305] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.372887] pinctrl core: initialized pinctrl subsystem
[ 0.380093] Failed to find legacy iommu devices
[ 0.385437] NET: Registered protocol family 16
[ 0.390726] schedtune: init normalization constants…
[ 0.396382] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.403563] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.410742] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.417920] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.425099] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.432278] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.439455] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.446633] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.453808] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.460985] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.469404] schedtune: verify normalization constants…
[ 0.475244] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.481379] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.487504] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.493629] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.499756] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.505881] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.512009] schedtune: configured to support 5 boost groups
[ 0.531499] cpuidle: using governor ladder
[ 0.549367] cpuidle: using governor menu
[ 0.553712] Registered FIQ tty driver
[ 0.558097] vdso: 2 pages (1 code @ ffffff8008c16000, 1 data @ ffffff8009244000)
[ 0.566257] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.574441] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.599928] console [pstore0] enabled
[ 0.604124] pstore: Registered ramoops as persistent store backend
[ 0.610929] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.619073] sip_fiq_debugger_uart_irq_tf_init error: -2
[ 0.624832] fiq debugger bind fiq to trustzone failed: -2
[ 0.631051] console [ttyFIQ0] enabled
[[ 0.631051] console [ttyFIQ0] enabled
[ 0.638288] bootconsole [uart0] disabled
[ 0.650314] Registered fiq debugger ttyFIQ0
[ 0.687873] Rockchip hdmi driver version 2.0
[ 0.690032] iommu: Adding device ff650000.vpu_service to group 0
[ 0.690103] iommu: Adding device ff660000.rkvdec to group 1
[ 0.690167] iommu: Adding device ff670000.iep to group 2
[ 0.690287] iommu: Adding device ff8f0000.vop to group 3
[ 0.690363] iommu: Adding device ff900000.vop to group 4
[ 0.690460] iommu: Adding device ff910000.isp to group 5
[ 0.690539] iommu: Adding device ff920000.isp to group 6
[ 0.691213] rk_iommu ff670800.iommu: can’t get aclk
[ 0.691230] rk_iommu ff670800.iommu: can’t get hclk
[ 0.692107] SCSI subsystem initialized
[ 0.692463] usbcore: registered new interface driver usbfs
[ 0.692514] usbcore: registered new interface driver hub
[ 0.692584] usbcore: registered new device driver usb
[ 0.692914] media: Linux media interface: v0.10
[ 0.692956] Linux video capture interface: v2.00
[ 0.693086] pps_core: LinuxPPS API ver. 1 registered
[ 0.693096] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.693123] PTP clock support registered
[ 0.694508] Advanced Linux Sound Architecture Driver Initialized.
[ 0.694949] Bluetooth: Core ver 2.21
[ 0.694997] NET: Registered protocol family 31
[ 0.695007] Bluetooth: HCI device and connection manager initialized
[ 0.695023] Bluetooth: HCI socket layer initialized
[ 0.695037] Bluetooth: L2CAP socket layer initialized
[ 0.695065] Bluetooth: SCO socket layer initialized
[ 0.696060] rockchip-cpuinfo cpuinfo: Serial : 4d34a8b71a96f9b8
[ 0.696584] clocksource: Switched to clocksource arch_sys_counter
[ 0.735668] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.735899] NET: Registered protocol family 2
[ 0.736315] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.736501] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.736747] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.736830] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.736876] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.737062] NET: Registered protocol family 1
[ 0.737551] Trying to unpack rootfs image as initramfs…
[ 1.073479] Freeing initrd memory: 7876K
[ 1.074061] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.074148] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.079457] audit: initializing netlink subsys (disabled)
[ 1.079522] audit: type=2000 audit(0.953:1): initialized
[ 1.103541] VFS: Disk quotas dquot_6.6.0
[ 1.103659] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.106687] fuse init (API version 7.23)
[ 1.107724]
[ 1.107724] TEE Core Framework initialization (ver 1:0.1)
[ 1.107751] TEE armv7 Driver initialization
[ 1.108084] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 1.108099] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 1.108260] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 1.113314] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.113338] io scheduler noop registered
[ 1.113498] io scheduler cfq registered (default)
[ 1.114708] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 1.115749] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 1.120170] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 1.120191] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 1.120208] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.643336] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.643513] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.644970] iep: failed to find iep power down clock source.
[ 1.645571] IEP Power ON
[ 1.645777] IEP Power OFF
[ 1.645883] IEP Driver loaded succesfully
[ 1.646085] Module initialized.
[ 1.646666] rk-vcodec ff650000.vpu_service: probe device
[ 1.646718] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f10f1c10
[ 1.646886] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.646941] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.647363] rk-vcodec ff650000.vpu_service: init success
[ 1.651309] rk-vcodec ff660000.rkvdec: probe device
[ 1.651353] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f10f2410
[ 1.651499] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.651555] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.651842] rk-vcodec ff660000.rkvdec: init success
[ 1.653186] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.653205] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.654530] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.654547] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.655894] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.657374] console [ttyS0] disabled
[ 1.657403] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.657922] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 1.658277] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 1.661623] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.661841] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.661866] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 1.662113] rockchip-drm display-subsystem: master bind failed: -517
[ 1.663319] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 1.663343] ff960000.dsi.0 supply power not found, using dummy regulator
[ 1.663946] mali ff9a0000.gpu: Failed to get regulator
[ 1.663960] mali ff9a0000.gpu: Power control initialization failed
[ 1.664260] Unable to detect cache hierarchy from DT for CPU 0
[ 1.708325] brd: module loaded
[ 1.733045] loop: module loaded
[ 1.736908] zram: Added device: zram0
[ 1.737430] SCSI Media Changer driver v0.25
[ 1.741863] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.741881] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.742608] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 1.912893] wk2xxx_probe() GENA = 0xFF
[ 1.912909] spi driver error!!!
[ 1.912935] wk2xxxspi: probe of spi0.0 failed with error 1
[ 1.912962] register spi return v = :0
[ 1.913026] tun: Universal TUN/TAP device driver, 1.6
[ 1.913036] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.914051] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.914070] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.914084] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.914115] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.914288] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.919305] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.919432] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.919442] Ring mode enabled
[ 1.919451] DMA HW capability register supported
[ 1.919460] Normal descriptors
[ 1.919470] RX Checksum Offload Engine supported (type 2)
[ 1.919479] TX Checksum insertion supported
[ 1.919488] Wake-Up On Lan supported
[ 1.919532] Enable RX Mitigation via HW Watchdog Timer
[ 1.986098] libphy: stmmac: probed
[ 1.986113] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04) active
[ 1.986125] eth%d: PHY ID 0143bcb2 at 25 IRQ POLL (stmmac-0:19)
[ 1.986137] eth%d: PHY ID 0143bcb2 at 26 IRQ POLL (stmmac-0:1a)
[ 1.986874] PPP generic driver version 2.4.2
[ 1.987061] PPP BSD Compression module registered
[ 1.987079] PPP Deflate Compression module registered
[ 1.987110] PPP MPPE Compression module registered
[ 1.987133] NET: Registered protocol family 24
[ 1.987182] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.987194] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.987215] Rockchip WiFi SYS interface (V1.00) …
[ 1.987296] usbcore: registered new interface driver catc
[ 1.987343] usbcore: registered new interface driver kaweth
[ 1.987361] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.987399] usbcore: registered new interface driver pegasus
[ 1.987447] usbcore: registered new interface driver rtl8150
[ 1.987491] usbcore: registered new interface driver r8152
[ 1.987509] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.987564] usbcore: registered new interface driver hso
[ 1.987616] usbcore: registered new interface driver asix
[ 1.987663] usbcore: registered new interface driver ax88179_178a
[ 1.987708] usbcore: registered new interface driver cdc_ether
[ 1.987751] usbcore: registered new interface driver cdc_eem
[ 1.987795] usbcore: registered new interface driver dm9601
[ 1.987849] usbcore: registered new interface driver smsc75xx
[ 1.987904] usbcore: registered new interface driver smsc95xx
[ 1.987948] usbcore: registered new interface driver gl620a
[ 1.987991] usbcore: registered new interface driver net1080
[ 1.988034] usbcore: registered new interface driver plusb
[ 1.988079] usbcore: registered new interface driver rndis_host
[ 1.988124] usbcore: registered new interface driver cdc_subset
[ 1.988171] usbcore: registered new interface driver zaurus
[ 1.988216] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.988279] usbcore: registered new interface driver int51x1
[ 1.988323] usbcore: registered new interface driver kalmia
[ 1.988368] usbcore: registered new interface driver ipheth
[ 1.988417] usbcore: registered new interface driver sierra_net
[ 1.988463] usbcore: registered new interface driver cx82310_eth
[ 1.988516] usbcore: registered new interface driver cdc_ncm
[ 1.988560] usbcore: registered new interface driver qmi_wwan
[ 1.988605] usbcore: registered new interface driver cdc_mbim
[ 1.995413] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd
[ 2.001777] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 2.002347] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.002365] ehci-pci: EHCI PCI platform driver
[ 2.002422] ehci-platform: EHCI generic platform driver
[ 2.006043] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.006071] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 2.006213] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.013271] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.013411] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.013427] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.013441] usb usb1: Product: EHCI Host Controller
[ 2.013453] usb usb1: Manufacturer: Linux 4.4.83 ehci_hcd
[ 2.013464] usb usb1: SerialNumber: fe380000.usb
[ 2.013914] hub 1-0:1.0: USB hub found
[ 2.013947] hub 1-0:1.0: 1 port detected
[ 2.017800] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 2.017826] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 2.017949] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 2.026601] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.026720] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.026735] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.026748] usb usb2: Product: EHCI Host Controller
[ 2.026759] usb usb2: Manufacturer: Linux 4.4.83 ehci_hcd
[ 2.026770] usb usb2: SerialNumber: fe3c0000.usb
[ 2.027176] hub 2-0:1.0: USB hub found
[ 2.027208] hub 2-0:1.0: 1 port detected
[ 2.027672] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.027700] ohci-platform: OHCI generic platform driver
[ 2.027978] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.028003] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 2.028123] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.084066] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.084083] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.084096] usb usb3: Product: Generic Platform OHCI controller
[ 2.084108] usb usb3: Manufacturer: Linux 4.4.83 ohci_hcd
[ 2.084120] usb usb3: SerialNumber: fe3a0000.usb
[ 2.084528] hub 3-0:1.0: USB hub found
[ 2.084561] hub 3-0:1.0: 1 port detected
[ 2.085069] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 2.085094] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 2.085197] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 2.140720] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.140736] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.140749] usb usb4: Product: Generic Platform OHCI controller
[ 2.140761] usb usb4: Manufacturer: Linux 4.4.83 ohci_hcd
[ 2.140772] usb usb4: SerialNumber: fe3e0000.usb
[ 2.141195] hub 4-0:1.0: USB hub found
[ 2.141229] hub 4-0:1.0: 1 port detected
[ 2.141994] usbcore: registered new interface driver cdc_acm
[ 2.142007] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.142068] usbcore: registered new interface driver usblp
[ 2.142115] usbcore: registered new interface driver cdc_wdm
[ 2.142163] usbcore: registered new interface driver uas
[ 2.142251] usbcore: registered new interface driver usb-storage
[ 2.142295] usbcore: registered new interface driver ums-alauda
[ 2.142338] usbcore: registered new interface driver ums-cypress
[ 2.142381] usbcore: registered new interface driver ums-datafab
[ 2.142422] usbcore: registered new interface driver ums_eneub6250
[ 2.142464] usbcore: registered new interface driver ums-freecom
[ 2.142505] usbcore: registered new interface driver ums-isd200
[ 2.142546] usbcore: registered new interface driver ums-jumpshot
[ 2.142588] usbcore: registered new interface driver ums-karma
[ 2.142629] usbcore: registered new interface driver ums-onetouch
[ 2.142675] usbcore: registered new interface driver ums-sddr09
[ 2.142717] usbcore: registered new interface driver ums-sddr55
[ 2.142759] usbcore: registered new interface driver ums-usbat
[ 2.142843] usbcore: registered new interface driver usbserial
[ 2.142883] usbcore: registered new interface driver usbserial_generic
[ 2.142914] usbserial: USB Serial support registered for generic
[ 2.142962] usbcore: registered new interface driver ch341
[ 2.142992] usbserial: USB Serial support registered for ch341-uart
[ 2.143039] usbcore: registered new interface driver cp210x
[ 2.143068] usbserial: USB Serial support registered for cp210x
[ 2.143127] usbcore: registered new interface driver option
[ 2.143156] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.143351] usbcore: registered new interface driver pl2303
[ 2.143381] usbserial: USB Serial support registered for pl2303
[ 2.143439] usbcore: registered new interface driver trancevibrator
[ 2.143455] usb20_otg: version 3.10a 21-DEC-2012
[ 2.143619] usb20_host: version 3.10a 21-DEC-2012
[ 2.147369] usbcore: registered new interface driver xpad
[ 2.147425] usbcore: registered new interface driver usb_acecad
[ 2.147473] usbcore: registered new interface driver aiptek
[ 2.147522] usbcore: registered new interface driver gtco
[ 2.147568] usbcore: registered new interface driver hanwang
[ 2.147614] usbcore: registered new interface driver kbtab
[ 2.147628] ==gsl_ts_init==
[ 2.147657] ret=0
[ 2.148019] .. rk pwm remotectl v1.1 init
[ 2.148240] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 2.148515] remotectl-pwm ff420030.pwm: set irq err, set support_psci to 0 !!
[ 2.148626] sensor_register_slave:mma8452,id=17
[ 2.148640] sensor_register_slave:lis3dh,id=7
[ 2.148653] sensor_register_slave:mma7660,id=18
[ 2.148668] sensor_register_slave:lsm303d,id=22
[ 2.148682] sensor_register_slave:mpu6880_acc,id=24
[ 2.148696] sensor_register_slave:mpu6500_acc,id=25
[ 2.148709] sensor_register_slave:lsm330_acc,id=26
[ 2.148723] sensor_register_slave:akm8975,id=28
[ 2.148737] sensor_register_slave:akm8963,id=29
[ 2.148750] sensor_register_slave:l3g4200d,id=43
[ 2.148764] sensor_register_slave:l3g20d,id=44
[ 2.148777] sensor_register_slave:ewtsa,id=45
[ 2.148790] sensor_register_slave:lsm330_gyro,id=48
[ 2.148804] sensor_register_slave:cm3217,id=50
[ 2.148817] sensor_register_slave:cm3218,id=51
[ 2.149421] i2c /dev entries driver
[ 2.150498] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.150569] fan53555-reg: supplied by vcc5v0_sys
[ 2.152225] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.152274] fan53555-reg: supplied by vcc5v0_sys
[ 2.154059] rk808 0-001b: Pmic Chip id: 0x0
[ 2.157166] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.157218] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.157299] DCDC_REG1: supplied by vcc3v3_sys
[ 2.157954] DCDC_REG2: supplied by vcc3v3_sys
[ 2.158447] DCDC_REG3: supplied by vcc3v3_sys
[ 2.158656] DCDC_REG4: supplied by vcc3v3_sys
[ 2.159028] LDO_REG1: supplied by vcc3v3_sys
[ 2.160084] LDO_REG2: supplied by vcc3v3_sys
[ 2.160974] LDO_REG3: supplied by vcc3v3_sys
[ 2.161865] LDO_REG4: supplied by vcc3v3_sys
[ 2.162758] LDO_REG5: supplied by vcc3v3_sys
[ 2.163652] LDO_REG6: supplied by vcc3v3_sys
[ 2.164554] LDO_REG7: supplied by vcc3v3_sys
[ 2.165456] LDO_REG8: supplied by vcc3v3_sys
[ 2.166349] SWITCH_REG1: supplied by vcc3v3_sys
[ 2.166563] SWITCH_REG2: supplied by vcc3v3_sys
[ 2.169857] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.170368] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009854000
[ 2.170978] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009856000
[ 2.171375] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff8009858000
[ 2.171913] GSLX680 Enter gsl_ts_probe
[ 2.479941] gsl_ts_probe–1253, i2c_master_recv fail
[ 2.480169] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800985a000
[ 2.481350] IR NEC protocol handler initialized
[ 2.481369] IR RC5(x/sz) protocol handler initialized
[ 2.481387] IR RC6 protocol handler initialized
[ 2.481404] IR JVC protocol handler initialized
[ 2.481420] IR Sony protocol handler initialized
[ 2.481437] IR SANYO protocol handler initialized
[ 2.481454] IR Sharp protocol handler initialized
[ 2.481471] IR MCE Keyboard/mouse protocol handler initialized
[ 2.481489] IR XMP protocol handler initialized
[ 2.481636] usbcore: registered new interface driver uvcvideo
[ 2.481647] USB Video Class driver (1.1.1)
[ 2.481669] CamSys driver version: v0.34.3, CamSys head file version: v0.13.0
[ 2.486773] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 2.486905] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 2.487146] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 2.487246] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 2.489342] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.490078] device-mapper: uevent: version 1.0.3
[ 2.490352] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.493821] Bluetooth: HCI UART driver ver 2.3
[ 2.493835] Bluetooth: HCI UART protocol H4 registered
[ 2.493846] Bluetooth: HCI UART protocol LL registered
[ 2.493860] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 2.493871] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 2.493881] rtk_btusb: Register usb char device interface for BT driver
[ 2.494076] usbcore: registered new interface driver rtk_btusb
[ 2.494423] cpu cpu0: leakage=24
[ 2.510748] cpu cpu0: temp=38750, pvtm=150239 (150584 + -345)
[ 2.510973] cpu cpu0: pvtm-sel=2
[ 2.511254] cpu cpu4: leakage=45
[ 2.523408] cpu cpu4: temp=38750, pvtm=157913 (158126 + -213)
[ 2.523552] cpu cpu4: pvtm-sel=2
[ 2.527789] sdhci: Secure Digital Host Controller Interface driver
[ 2.527804] sdhci: Copyright(c) Pierre Ossman
[ 2.527817] Synopsys Designware Multimedia Card Interface Driver
[ 2.528580] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.528690] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.528712] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.528764] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.528790] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.528834] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.528847] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.529580] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.529631] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.529650] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.529691] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.529713] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.529799] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.530338] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.531948] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.531962] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.559991] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.561319] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.564862] usbcore: registered new interface driver usbhid
[ 2.564879] usbhid: USB HID core driver
[ 2.565231] inv-mpu-iio 4-0068: int_config=0,level_shifter=0,client.addr=68,client.irq=69
[ 2.565246] inv-mpu-iio 4-0068: 0
[ 2.565258] inv-mpu-iio 4-0068: -1
[ 2.565269] inv-mpu-iio 4-0068: 0
[ 2.565280] inv-mpu-iio 4-0068: -1
[ 2.565291] inv-mpu-iio 4-0068: 0
[ 2.565301] inv-mpu-iio 4-0068: 0
[ 2.565313] inv-mpu-iio 4-0068: 0
[ 2.565324] inv-mpu-iio 4-0068: 0
[ 2.565334] inv-mpu-iio 4-0068: -1
[ 2.565345] inv-mpu-iio 4-0068:
[ 2.565353] inv_mpu_iio: secondary_i2c_addr=0
[ 2.565539] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.604181] mmc0: MAN_BKOPS_EN bit is not set
[ 2.616151] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.616996] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[ 2.617465] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[ 2.626672] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[ 2.627063] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[ 2.627610] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 2.627626] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 2.627639] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 2.627650] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 2.627662] resource: 0x001000000 – 0x002000000 (16 MB)
[ 2.627675] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 2.627686] boot: 0x003800000 – 0x005800000 (32 MB)
[ 2.627698] recovery: 0x005800000 – 0x007800000 (32 MB)
[ 2.627710] backup: 0x007800000 – 0x00e800000 (112 MB)
[ 2.627722] cache: 0x00e800000 – 0x016800000 (128 MB)
[ 2.627735] system: 0x016800000 – 0x076800000 (1536 MB)
[ 2.627746] metadata: 0x076800000 – 0x077800000 (16 MB)
[ 2.627758] baseparamer: 0x077800000 – 0x077c00000 (4 MB)
[ 2.627771] userdata: 0x077c00000 – 0x3a3a00000 (12990 MB)
[ 2.627843] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 2.667201] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.770791] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.873844] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.977176] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.080509] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.183843] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.287176] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.390577] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.493862] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.700877] i2c i2c-4: inv_mpu_probe failed -6
[ 3.700971] inv-mpu-iio: probe of 4-0068 failed with error -5
[ 3.701051] inv_mpu_iio: inv_mpu_init:746
[ 3.702201] ashmem: initialized
[ 3.706794] ff100000.saradc supply vref not found, using dummy regulator
[ 3.709806] rknandbase v1.1 2016-11-08
[ 3.720306] usbcore: registered new interface driver snd-usb-audio
[ 3.725190] lkd tc358749x_parse_dts: power(1)
[ 3.725338] lkd tc358749x_parse_dts: int(0)
[ 3.725484] lkd tc358749x_parse_dts: reset(1)
[ 3.736542] tc358749x 1-000f: tc358749x_parse_dts success
[ 3.736658] tc358749x 1-000f: tc358749x_i2c_probe success
[ 3.737087] asoc-simple-card rt5640-sound: asoc_simple_card_dai_link_of: Can’t find codec DT node
[ 3.737100] asoc-simple-card rt5640-sound: parse error -22
[ 3.737115] asoc-simple-card: probe of rt5640-sound failed with error -22
[ 3.740661] u32 classifier
[ 3.740681] Actions configured
[ 3.740727] Netfilter messages via NETLINK v0.30.
[ 3.740803] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.741193] ctnetlink v0.93: registering with nfnetlink.
[ 3.742083] xt_time: kernel timezone is -0000
[ 3.743113] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.743367] arp_tables: (C) 2002 David S. Miller
[ 3.744476] Initializing XFRM netlink socket
[ 3.744946] NET: Registered protocol family 10
[ 3.756951] mip6: Mobile IPv6
[ 3.756984] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.760683] sit: IPv6 over IPv4 tunneling driver
[ 3.761196] NET: Registered protocol family 17
[ 3.761224] NET: Registered protocol family 15
[ 3.761266] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.764180] Bridge firewalling registered
[ 3.764199] Ebtables v2.0 registered
[ 3.764660] Bluetooth: RFCOMM TTY layer initialized
[ 3.764675] Bluetooth: RFCOMM socket layer initialized
[ 3.764711] Bluetooth: RFCOMM ver 1.11
[ 3.764727] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.764735] Bluetooth: BNEP filters: protocol multicast
[ 3.764747] Bluetooth: BNEP socket layer initialized
[ 3.764759] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.764770] Bluetooth: HIDP socket layer initialized
[ 3.764808] l2tp_core: L2TP core driver, V2.0
[ 3.764827] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 3.764840] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 3.765245] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 3.765327] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 3.765335] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 3.765344] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 3.765409] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 3.765417] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 3.765428] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 3.765489] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.765907] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 3.765942] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 3.765969] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 3.765995] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 3.766404] [BT_RFKILL]: Request irq for bt wakeup host
[ 3.766457] [BT_RFKILL]: ** disable irq
[ 3.766653] [BT_RFKILL]: bt_default device registered.
[ 3.776613] sensor_register_slave:mpu6880_gyro,id=47
[ 3.777353] Registered cp15_barrier emulation handler
[ 3.777543] Registered setend emulation handler
[ 3.778747] registered taskstats version 1
[ 3.780217] rockchip ion idev is NULL
[ 3.780238] rga2 ff680000.rga: rga ion client create success!
[ 3.780720] rga: Driver loaded successfully ver:3.02
[ 3.782507] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.782711] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.782733] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.782992] rockchip-drm display-subsystem: master bind failed: -517
[ 3.783361] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.783372] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.783407] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.784318] mali ff9a0000.gpu: leakage=31
[ 3.794592] vendor storage:20160801 ret = 0
[ 3.807892] mali ff9a0000.gpu: temp=37500, pvtm=126233 (126417 + -184)
[ 3.808835] mali ff9a0000.gpu: pvtm-sel=2
[ 3.810143] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 3.811022] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 3.812000] mali ff9a0000.gpu: Probed as mali0
[ 3.818948] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 3.819014] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 5
[ 3.819392] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 3.819484] xhci-hcd xhci-hcd.5.auto: irq 234, io mem 0xfe800000
[ 3.819738] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.819769] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.819797] usb usb5: Product: xHCI Host Controller
[ 3.819820] usb usb5: Manufacturer: Linux 4.4.83 xhci-hcd
[ 3.819842] usb usb5: SerialNumber: xhci-hcd.5.auto
[ 3.820795] hub 5-0:1.0: USB hub found
[ 3.820863] hub 5-0:1.0: 1 port detected
[ 3.821366] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 3.821403] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 6
[ 3.821527] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.821712] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.821741] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.821766] usb usb6: Product: xHCI Host Controller
[ 3.821789] usb usb6: Manufacturer: Linux 4.4.83 xhci-hcd
[ 3.821811] usb usb6: SerialNumber: xhci-hcd.5.auto
[ 3.822641] hub 6-0:1.0: USB hub found
[ 3.822704] hub 6-0:1.0: 1 port detected
[ 3.825084] xhci-hcd xhci-hcd.5.auto: remove, state 1
[ 3.825132] usb usb6: USB disconnect, device number 1
[ 3.854033] xhci-hcd xhci-hcd.5.auto: Host not halted after 16000 microseconds.
[ 3.854063] xhci-hcd xhci-hcd.5.auto: Host controller not halted, aborting reset.
[ 3.854139] xhci-hcd xhci-hcd.5.auto: USB bus 6 deregistered
[ 3.854171] xhci-hcd xhci-hcd.5.auto: remove, state 1
[ 3.854208] usb usb5: USB disconnect, device number 1
[ 3.854814] xhci-hcd xhci-hcd.5.auto: USB bus 5 deregistered
[ 3.860799] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 3.860836] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 5
[ 3.861078] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 3.861141] xhci-hcd xhci-hcd.6.auto: irq 235, io mem 0xfe900000
[ 3.861317] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.861338] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.861356] usb usb5: Product: xHCI Host Controller
[ 3.861371] usb usb5: Manufacturer: Linux 4.4.83 xhci-hcd
[ 3.861386] usb usb5: SerialNumber: xhci-hcd.6.auto
[ 3.861955] hub 5-0:1.0: USB hub found
[ 3.862000] hub 5-0:1.0: 1 port detected
[ 3.862331] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 3.862356] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 6
[ 3.862440] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.862566] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.862587] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.862604] usb usb6: Product: xHCI Host Controller
[ 3.862620] usb usb6: Manufacturer: Linux 4.4.83 xhci-hcd
[ 3.862634] usb usb6: SerialNumber: xhci-hcd.6.auto
[ 3.863185] hub 6-0:1.0: USB hub found
[ 3.863228] hub 6-0:1.0: 1 port detected
[ 3.864661] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.864768] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 3.864794] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 3.864832] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 3.864863] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 3.864920] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 3.864936] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 3.865275] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 3.876751] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.890258] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 3.891178] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.891357] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 3.891370] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 3.891398] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 3.891428] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 3.891514] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 3.891827] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[ 3.891957] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 3.893451] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 3.906868] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.913570] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 3.921246] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 3.923734] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[ 3.927136] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.927673] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.927727] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.928359] rockchip-drm display-subsystem: master bind failed: -517
[ 3.928941] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.928968] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.929032] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.934024] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.934550] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.934604] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.935227] rockchip-drm display-subsystem: master bind failed: -517
[ 3.935775] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.935802] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.935864] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.941375] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.941896] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.941949] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.942554] rockchip-drm display-subsystem: master bind failed: -517
[ 3.943079] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.943106] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.943170] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.948025] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.948387] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.948424] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.948858] rockchip-drm display-subsystem: master bind failed: -517
[ 3.949249] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.949268] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.949317] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.950030] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 3.953007] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.953428] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.953466] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.953898] rockchip-drm display-subsystem: master bind failed: -517
[ 3.954281] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.954300] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.954347] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.957976] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.958343] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.958379] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.958805] rockchip-drm display-subsystem: master bind failed: -517
[ 3.959178] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.959197] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.959244] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.962820] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.963181] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.963218] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.963715] rockchip-drm display-subsystem: master bind failed: -517
[ 3.964131] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.964150] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.964199] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.967718] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.967992] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.968021] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.968363] rockchip-drm display-subsystem: master bind failed: -517
[ 3.968680] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.968694] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.968735] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.971515] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.971788] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.971817] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.972148] rockchip-drm display-subsystem: master bind failed: -517
[ 3.972467] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.972481] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.972522] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.975674] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.975953] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.975990] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.976340] rockchip-drm display-subsystem: master bind failed: -517
[ 3.976808] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.976822] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.976863] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.980153] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.980447] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.980475] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.980838] rockchip-drm display-subsystem: master bind failed: -517
[ 3.981169] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.981183] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.981224] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.984099] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.984373] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.984402] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.984735] rockchip-drm display-subsystem: master bind failed: -517
[ 3.985036] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.985050] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.985090] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.988166] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.988402] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.988427] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.988716] rockchip-drm display-subsystem: master bind failed: -517
[ 3.988984] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.988996] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.989031] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.991519] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.991744] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.991769] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.992050] rockchip-drm display-subsystem: master bind failed: -517
[ 3.992304] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.992316] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.992352] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.994820] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.995050] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.995075] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.995357] rockchip-drm display-subsystem: master bind failed: -517
[ 3.995614] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.995626] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.995662] ff960000.dsi.0 supply power not found, using dummy regulator
[ 3.998206] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 3.998431] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 3.998456] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 3.998738] rockchip-drm display-subsystem: master bind failed: -517
[ 3.998991] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 3.999002] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 3.999038] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.001561] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.001790] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.001815] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.002101] rockchip-drm display-subsystem: master bind failed: -517
[ 4.002354] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.002365] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.002401] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.004994] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.005221] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.005245] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.005529] rockchip-drm display-subsystem: master bind failed: -517
[ 4.005783] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.005795] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.005830] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.008295] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.008523] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.008548] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.008832] rockchip-drm display-subsystem: master bind failed: -517
[ 4.009089] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.009100] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.009136] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.011698] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.011933] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.011957] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.012242] rockchip-drm display-subsystem: master bind failed: -517
[ 4.012495] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.012507] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.012543] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.015119] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.015349] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.015375] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.015657] rockchip-drm display-subsystem: master bind failed: -517
[ 4.015915] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.015927] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.015963] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.018725] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.018952] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.018977] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.019264] rockchip-drm display-subsystem: master bind failed: -517
[ 4.019526] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.019537] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.019573] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.022092] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.022318] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.022342] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.022623] rockchip-drm display-subsystem: master bind failed: -517
[ 4.022876] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.022888] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.022924] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.025361] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.025590] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.025615] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.025900] rockchip-drm display-subsystem: master bind failed: -517
[ 4.026152] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.026164] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.026200] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.028795] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.028991] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.029013] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.029262] rockchip-drm display-subsystem: master bind failed: -517
[ 4.029493] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.029503] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.029536] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.031723] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.031918] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.031946] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.032195] rockchip-drm display-subsystem: master bind failed: -517
[ 4.032420] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.032430] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.032463] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.034739] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.034935] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.034956] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.035201] rockchip-drm display-subsystem: master bind failed: -517
[ 4.035429] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.035439] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.035472] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.038162] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.038359] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.038380] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.038633] rockchip-drm display-subsystem: master bind failed: -517
[ 4.038865] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.038875] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.038909] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.041141] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.041341] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.041363] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.041609] rockchip-drm display-subsystem: master bind failed: -517
[ 4.041834] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.041844] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.041877] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.043981] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.044176] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.044198] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.044442] rockchip-drm display-subsystem: master bind failed: -517
[ 4.044663] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.044673] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.044705] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.046926] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.047127] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.047147] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.047404] rockchip-drm display-subsystem: master bind failed: -517
[ 4.047633] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.047643] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.047676] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.049741] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.049969] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.049991] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.050243] rockchip-drm display-subsystem: master bind failed: -517
[ 4.050467] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.050477] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.050510] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.052659] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.052858] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.052880] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.053119] rockchip-drm display-subsystem: master bind failed: -517
[ 4.053383] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.053393] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.053427] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.055514] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.055712] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.055733] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.055976] rockchip-drm display-subsystem: master bind failed: -517
[ 4.056201] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.056211] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.056244] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.058394] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.058589] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.058610] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.058847] rockchip-drm display-subsystem: master bind failed: -517
[ 4.059067] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.059077] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.059111] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.061245] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.061440] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.061461] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.061704] rockchip-drm display-subsystem: master bind failed: -517
[ 4.061925] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.061936] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.061969] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.064125] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.064319] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.064342] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.064587] rockchip-drm display-subsystem: master bind failed: -517
[ 4.064820] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.064830] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.064863] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.067372] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.067917] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.067971] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.068598] rockchip-drm display-subsystem: master bind failed: -517
[ 4.069146] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.069173] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.069236] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.074093] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.074323] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.074348] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.074644] rockchip-drm display-subsystem: master bind failed: -517
[ 4.074926] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.074938] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.074973] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.077477] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.077703] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.077728] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.078006] rockchip-drm display-subsystem: master bind failed: -517
[ 4.078269] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.078281] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.078317] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.079983] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.080094] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.080108] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.080236] rockchip-drm display-subsystem: master bind failed: -517
[ 4.080352] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.080359] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.080378] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.081574] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.081679] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.081694] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.081818] rockchip-drm display-subsystem: master bind failed: -517
[ 4.081923] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.081930] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.081950] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.083059] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.083160] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.083173] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.083324] rockchip-drm display-subsystem: master bind failed: -517
[ 4.083433] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.083440] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.083459] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.084635] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.084737] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.084751] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.084872] rockchip-drm display-subsystem: master bind failed: -517
[ 4.084976] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.084983] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.085001] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.086115] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.086218] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.086231] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.086352] rockchip-drm display-subsystem: master bind failed: -517
[ 4.086454] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.086460] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.086477] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.087716] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.087818] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.087832] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.087957] rockchip-drm display-subsystem: master bind failed: -517
[ 4.088065] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.088072] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.088091] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.089224] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.089324] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.089338] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.089460] rockchip-drm display-subsystem: master bind failed: -517
[ 4.089564] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.089571] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.089590] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.090781] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.090884] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.090897] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.091022] rockchip-drm display-subsystem: master bind failed: -517
[ 4.091128] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.091134] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.091154] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.092278] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.092377] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.092390] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.092512] rockchip-drm display-subsystem: master bind failed: -517
[ 4.092616] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.092623] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.092642] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.093843] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.093962] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.093976] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.094322] rockchip-drm display-subsystem: master bind failed: -517
[ 4.094436] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.094443] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.094462] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.095572] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.095672] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.095686] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.095805] rockchip-drm display-subsystem: master bind failed: -517
[ 4.095907] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.095914] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.095931] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.097138] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.097238] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.097251] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.097374] rockchip-drm display-subsystem: master bind failed: -517
[ 4.097485] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.097491] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.097511] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.098612] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.098711] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.098725] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.098844] rockchip-drm display-subsystem: master bind failed: -517
[ 4.098945] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.098951] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.098971] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.100088] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.100193] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.100206] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.100330] rockchip-drm display-subsystem: master bind failed: -517
[ 4.100437] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.100443] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.100462] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.101746] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.101848] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.101862] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.101983] rockchip-drm display-subsystem: master bind failed: -517
[ 4.102086] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.102092] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.102111] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.103228] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.103503] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.103517] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.103646] rockchip-drm display-subsystem: master bind failed: -517
[ 4.103763] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.103770] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.103789] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.104920] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.105020] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.105033] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.105153] rockchip-drm display-subsystem: master bind failed: -517
[ 4.105258] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.105264] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.105283] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.106399] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.106502] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.106516] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.106667] rockchip-drm display-subsystem: master bind failed: -517
[ 4.106780] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.106786] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.106805] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.108014] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.108117] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.108131] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.108253] rockchip-drm display-subsystem: master bind failed: -517
[ 4.108359] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.108366] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.108384] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.109491] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.109591] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.109604] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.109727] rockchip-drm display-subsystem: master bind failed: -517
[ 4.109829] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.109836] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.109855] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.111086] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.111186] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.111199] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.111320] rockchip-drm display-subsystem: master bind failed: -517
[ 4.111426] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.111433] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.111452] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.112564] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.112663] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.112676] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.112797] rockchip-drm display-subsystem: master bind failed: -517
[ 4.112902] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.112909] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.112926] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.114190] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.114296] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.114309] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.114432] rockchip-drm display-subsystem: master bind failed: -517
[ 4.114537] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.114544] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.114562] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.115732] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.115833] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.115846] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.115968] rockchip-drm display-subsystem: master bind failed: -517
[ 4.116072] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.116079] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.116098] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.117352] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.117452] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.117466] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.117589] rockchip-drm display-subsystem: master bind failed: -517
[ 4.117695] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.117701] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.117719] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.118841] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.118942] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.118956] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.119080] rockchip-drm display-subsystem: master bind failed: -517
[ 4.119184] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.119190] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.119209] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.120339] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.120439] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.120452] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.120574] rockchip-drm display-subsystem: master bind failed: -517
[ 4.120678] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.120684] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.120703] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.121999] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.122103] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.122115] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.122240] rockchip-drm display-subsystem: master bind failed: -517
[ 4.122344] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.122351] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.122369] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.123619] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.123721] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.123734] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.123860] rockchip-drm display-subsystem: master bind failed: -517
[ 4.123971] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.123978] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.123998] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.125135] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.125235] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.125248] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.125373] rockchip-drm display-subsystem: master bind failed: -517
[ 4.125479] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.125485] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.125504] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.126648] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.126750] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.126764] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.126889] rockchip-drm display-subsystem: master bind failed: -517
[ 4.127001] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.127007] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.127027] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.128324] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.128426] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.128440] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.128564] rockchip-drm display-subsystem: master bind failed: -517
[ 4.128666] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.128673] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.128692] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.129800] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.129898] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.130043] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.130175] rockchip-drm display-subsystem: master bind failed: -517
[ 4.130296] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.130302] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.130322] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.131459] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.131560] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.131573] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.131696] rockchip-drm display-subsystem: master bind failed: -517
[ 4.131799] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.131805] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.131824] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.132943] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.133040] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.133053] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.133175] rockchip-drm display-subsystem: master bind failed: -517
[ 4.133309] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.133316] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.133336] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.134510] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.134612] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.134626] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.134750] rockchip-drm display-subsystem: master bind failed: -517
[ 4.134859] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.134865] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.134885] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.136035] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.136138] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.136151] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.136277] rockchip-drm display-subsystem: master bind failed: -517
[ 4.136385] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.136392] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.136411] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.137728] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.137833] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.137846] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.137973] rockchip-drm display-subsystem: master bind failed: -517
[ 4.138084] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.138091] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.138111] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.139275] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.139380] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.139393] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.139515] rockchip-drm display-subsystem: master bind failed: -517
[ 4.139624] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.139630] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.139649] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.140922] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.141023] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.141036] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.141161] rockchip-drm display-subsystem: master bind failed: -517
[ 4.141271] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.141278] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.141299] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.142607] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.142707] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.142720] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.142845] rockchip-drm display-subsystem: master bind failed: -517
[ 4.142951] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.142958] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.142977] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.144294] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.144398] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.144412] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.144537] rockchip-drm display-subsystem: master bind failed: -517
[ 4.144649] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.144655] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.144675] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.145843] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.145944] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.145958] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.146083] rockchip-drm display-subsystem: master bind failed: -517
[ 4.146192] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.146199] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.146218] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.147426] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.147527] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.147541] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.147666] rockchip-drm display-subsystem: master bind failed: -517
[ 4.147774] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.147780] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.147800] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.149104] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.149204] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.149218] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.149343] rockchip-drm display-subsystem: master bind failed: -517
[ 4.149452] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.149459] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.149479] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.150774] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.150879] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.150892] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.151018] rockchip-drm display-subsystem: master bind failed: -517
[ 4.151131] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.151138] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.151157] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.152340] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.152446] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.152460] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.152587] rockchip-drm display-subsystem: master bind failed: -517
[ 4.152697] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.152704] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.152723] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.153913] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.154013] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.154026] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.154153] rockchip-drm display-subsystem: master bind failed: -517
[ 4.154262] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.154268] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.154289] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.155596] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.155696] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.155709] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.155833] rockchip-drm display-subsystem: master bind failed: -517
[ 4.155942] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.155948] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.155968] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.157352] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.157456] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.157469] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.157595] rockchip-drm display-subsystem: master bind failed: -517
[ 4.157709] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.157716] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.157735] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.158914] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.159018] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.159031] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.159159] rockchip-drm display-subsystem: master bind failed: -517
[ 4.159268] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.159274] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.159294] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.160486] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.160588] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.160600] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.160725] rockchip-drm display-subsystem: master bind failed: -517
[ 4.160837] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.160843] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.160863] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.162180] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.162281] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.162295] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.162421] rockchip-drm display-subsystem: master bind failed: -517
[ 4.162530] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.162536] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.162555] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.163942] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.164044] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.164057] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.164181] rockchip-drm display-subsystem: master bind failed: -517
[ 4.164296] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.164303] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.164322] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.165507] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.165611] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.165624] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.165752] rockchip-drm display-subsystem: master bind failed: -517
[ 4.165859] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.165866] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.165886] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.167090] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.167191] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.167205] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.167330] rockchip-drm display-subsystem: master bind failed: -517
[ 4.167442] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.167448] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.167468] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.168794] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.168897] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.168911] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.169040] rockchip-drm display-subsystem: master bind failed: -517
[ 4.169149] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.169156] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.169175] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.170572] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.170674] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.170688] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.170814] rockchip-drm display-subsystem: master bind failed: -517
[ 4.170933] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.170940] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.170959] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.172146] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.172248] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.172262] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.172389] rockchip-drm display-subsystem: master bind failed: -517
[ 4.172497] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.172503] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.172522] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.173724] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.173829] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.173843] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.173970] rockchip-drm display-subsystem: master bind failed: -517
[ 4.174085] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.174092] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.174111] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.175432] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.175534] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.175546] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.175673] rockchip-drm display-subsystem: master bind failed: -517
[ 4.175783] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.175790] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.175808] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.177200] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.177302] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.177316] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.177443] rockchip-drm display-subsystem: master bind failed: -517
[ 4.177561] panel-simple-dsi ff960000.dsi.0: request lcd-rst gpio fail:-16
[ 4.177567] panel_simple: parse lcd-rst: gpio=157, atv_val=1, delay=6ms
[ 4.177587] ff960000.dsi.0 supply power not found, using dummy regulator
[ 4.178775] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.178880] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.178894] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 4.179020] rockchip-drm display[[ 4.180348][[ [[ 4.182042] r[[[[[ 4.183804] r[[ [[ 4.185374][[ [[ 4.186958][[ [[[ 4.188511[[ [[[ 4.190198] [[[ [ 4.191782][[ [[ 4.193349][[ [[ 4.195055] r[[[ [ 4.196792] r[[ [[ 4.198393][[ [[ 4.199964][[[[[[ 4.201668] [[ [[ 4.203418] r[[ [[[ 4.205016][[[ [ 4.206568][[ [[ 4.208315] r[[[ [ 4.209851[ [ [[ 4.211571][[[[[ 4.213126][[ [[[ 4.214851] [[ [[ 4.216417][[ [ [ 4.218160][[[[[[ 4.219725[:[[ [ 4.221391] [[[ [ 4.222968][[[ [[ 4.224694][[[ [ 4.226261][[[ [ 4.228011] r[[ [[ 4.229662] [[ [ [ 4.231417][[[[[[ 4.232990[ [[ [ 4.234664] [[[ [ 4.236228][[[ [[ 4.237969][[ [[ 4.239551][[ [[[ 4.241306] [ [[[[ 4.242955][ [[ [ 4.244717] [[[ [ 4.246303][[ [[[ 4.248065] [p[[[[ 4.249708][ [ [[ 4.251470] [[[ [ 4.253057][[ [[[ 4.254824] [[[[[[ 4.256404][[ [[[ 4.258168][[ [[ 4.259752][[ [
[ 4.261443] [[[ [ 4.263023][[ [ [ 4.264777][f[[[[ 4.266371][[ [[ 4.268076] [[[[[[ 4.269669][[ [[ 4.271418] [[[ [ 4.273001][[ [[[ 4.274621][[[ [ 4.276202][[ [[ [ 4.277958][[ [[[ 4.279558][[[ [ 4.281327] r[[ [[ 4.282997] [ [ [[ 4.284755] [[[ [ 4.286366][[[[ [ 4.288101] [[[[[[ 4.289692][[ [[[ 4.291451][[ [[ 4.293050][[[[ [ 4.294767] [[ [[[ 4.296359][[ [[[ 4.298129][[ [[ 4.299727][ [[ [ 4.301443] [[[[[[ 4.303037][[ [[[ 4.304811][[ [[ 4.306414] [[ [[ 4.308141] [ [[ [ 4.309729][[ [ [ 4.311495][[[[[[ 4.313109][[ [[[ 4.314840] [[ [[ 4.316437][[[ y[[ 4.318223] [[ [[ 4.319838][ [ [[ 4.321560] [[[[[[ 4.323165][ [[[ [ 4.324952][ [[ [ 4.326576][ [[ [ 4.328376] r[[ [[ 4.330107] r[[ [[[ 4.331768][[ [[ 4.333402] [[ [[ 4.335172] r[ [[[[ 4.336923] r[[[ [ 4.338582] [[[ [ 4.340226] [[[ [ 4.342012] r[[[[[[ 4.343845] ro[[[ [ 4.345512] [[[ [ 4.347199] [[ [[[ 4.348985] r[[ [[ 4.350843] ro[[ [[[ 4.352486][[ [[[ 4.354121][[ [[ 4.355893] ro[[[ [ 4.357628] r[[[ [ 4.359284] [[[ [ 4.361023] r[[[ [ 4.362802] r[[[[[[ 4.364661] ro[[[ [ 4.366302] [[[ [ 4.368135] ro[[ [[ 4.370042] roc[[ [[ 4.371723] [[ [[ 4.373381] [[[[ [ 4.375172] r[[ [[ 4.377005] ro[[ [[[ 4.378677][ [[[[ 4.380326][ [[ [ 4.382116] r[[ [[ 4.383967] ro[ [[ [ 4.385631] [[[ [ 4.387300]
跪求大神解答!万分感谢!
