平台:RK3399proJD4
源码版本:6802ae33f30a38ffe2ca44df0298d414d821b1e1
问题描述:使用源码编译出的镜像烧入后,开启系统相机时会崩溃(不论接不接摄像头(OV13850));后尝试了使用官方固件,可以正常打开相机并成像;
源码未进行实质改动:
zhang@zhang-OptiPlex-3070:~/workspace/rk3399pro/AIO-RK3399Pro$ git status
warning: 不能访问 ‘log/.gitignore’: 权限不够
位于分支 master
未跟踪的文件:
(使用 “git add <文件>…” 以包含要提交的内容)
.bundle/
kernel/arch/arm64/boot/dts/rockchip/rk3399pro-firefly-usbacm-zhang.dtsi
kernel/drivers/media/i2c/ov13850-back.c
kernel/drivers/media/i2c/ov13850-zhang.c
kernel/drivers/media/i2c/soc_camera/rockchip/ov13850_v4l2-i2c-subdev-zhang.c
kernel/drivers/media/i2c/soc_camera/rockchip/ov_camera_module-zhang.c
kernel/drivers/media/i2c/soc_camera/rockchip/rk_camera_module-zhang.c
linuxTool-v1.0/
log/
耗费了 15.73 秒以枚举未跟踪的文件。‘status -uno’ 也许能提高速度,
但您需要小心不要忘了添加新文件(参见 ‘git help status’)。
提交为空,但是存在尚未跟踪的文件(使用 “git add” 建立跟踪)
崩溃log如下:
05-25 02:30:04.860 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:04.877 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:05.077 1211 2241 D AudioHardwareTiny: start_output_stream:721 out = 0xe7429000,device = 0x408,outputs[OUTPUT_HDMI_MULTI] = 0x0
05-25 02:30:05.077 1266 1521 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.camera2/com.android.camera.CameraLauncher bnds=[621,151][911,332]} from uid 10008
05-25 02:30:05.077 1211 2241 D AudioHardwareTiny: read_out_sound_card: buf = 0 [rkhdmidpsound ]: rk-hdmi-dp-soun - rk-hdmi-dp-sound
05-25 02:30:05.077 1211 2241 D AudioHardwareTiny: get_card_number: number =0,card_name = 0 [rkhdmidpsound ]: rk-hdmi-dp-soun - rk-hdmi-dp-sound
05-25 02:30:05.077 1211 2241 D AudioHardwareTiny: read_out_sound_card: buf = rk-hdmi-dp-sound
05-25 02:30:05.077 1211 2241 D AudioHardwareTiny: read_out_sound_card: buf = 1 [rockchiprk809co]: rockchip_rk809- - rockchip,rk809-codec
05-25 02:30:05.077 1211 2241 D AudioHardwareTiny: get_card_number: number =1,card_name = 1 [rockchiprk809co]: rockchip_rk809- - rockchip,rk809-codec
05-25 02:30:05.077 1211 2241 D AudioHardwareTiny: read_out_sound_card: buf = rockchip,rk809-codec
05-25 02:30:05.077 1211 2241 D alsa_route: route_info->sound_card 0, route_info->devices 0
05-25 02:30:05.078 1211 2241 D alsa_route: route_set_controls() set route 11
05-25 02:30:05.081 1211 2241 D AudioHardwareTiny: start_output_stream:816, out = 0xe7429000
05-25 02:30:05.083 1211 2241 W StreamHAL: Error from HAL stream in function get_presentation_position: Operation not permitted
05-25 02:30:05.084 1211 2241 W StreamHAL: Error from HAL stream in function get_presentation_position: Operation not permitted
05-25 02:30:05.102 1266 1521 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.camera2/com.android.camera.CameraActivity}----com.android.camera2
05-25 02:30:05.113 1266 1402 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.camera2/com.android.camera.CameraActivity}----com.android.camera2
05-25 02:30:05.116 2077 2077 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@4fcf009
05-25 02:30:05.131 1266 1280 E memtrack: Couldn’t load memtrack module
05-25 02:30:05.132 1266 1280 W android.os.Debug: failed to get memory consumption info: -1
05-25 02:30:05.154 2077 2077 V CAM_QuickActivity: START onCreate: Activity = com.android.camera.CameraActivity@47b83c5
05-25 02:30:05.154 2077 2077 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraActivity.onCreateTasks - START
05-25 02:30:05.156 2077 2077 D CAM_LocationManager: Using legacy location provider.
05-25 02:30:05.169 2077 2077 D CAM_MemoryManagerImpl: Max native memory: 358 MB
05-25 02:30:05.176 2077 2077 W SoundPool: Use of stream types is deprecated for operations other than volume control
05-25 02:30:05.176 2077 2077 W SoundPool: See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
05-25 02:30:05.176 2077 2077 I CAM_OneCamFtrCnfgCrtr: CaptureModule? true
05-25 02:30:05.180 1266 1402 I ActivityManager: START u0 {act=android.intent.action.MAIN cmp=com.android.camera2/com.android.camera.PermissionsActivity} from uid 10056
05-25 02:30:05.194 1266 1402 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.camera2/com.android.camera.PermissionsActivity}----com.android.camera2
05-25 02:30:05.202 1266 1280 E memtrack: Couldn’t load memtrack module
05-25 02:30:05.203 1266 1280 W android.os.Debug: failed to get memory consumption info: -1
05-25 02:30:05.211 2077 2077 V CAM_Profiler: [ 56.675ms][ui] GUARD: CameraActivity.onCreateTasks - [10.070ms] Glide.setup
05-25 02:30:05.213 2077 2077 V CAM_Profiler: [ 58.972ms][ui] GUARD: CameraActivity.onCreateTasks - [ 2.298ms] OneCameraManager.get
05-25 02:30:05.221 2077 2077 E SoundPool: error loading /product/media/audio/ui/camera_click.ogg
05-25 02:30:05.222 2077 2077 I CameraManagerGlobal: Connecting to camera service
05-25 02:30:05.247 2077 2368 I OMXClient: IOmx service obtained
05-25 02:30:05.248 459 923 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
05-25 02:30:05.254 459 923 E OMXNodeInstance: getConfig(0xf2590300:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
05-25 02:30:05.258 251 251 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x778022c100, 32768)
05-25 02:30:05.258 2077 2077 V CAM_Profiler: [104.232ms][ui] GUARD: CameraActivity.onCreateTasks - [ 0.677ms] computePictureSizes
05-25 02:30:05.274 251 251 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x778022c100, 32768)
05-25 02:30:05.275 251 251 I chatty : uid=1000(system) allocator@1.0-s identical 1 line
05-25 02:30:05.275 251 251 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x778022c100, 32768)
05-25 02:30:05.277 2077 2077 D OpenGLRenderer: Skia GL Pipeline
05-25 02:30:05.279 251 251 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x778022c100, 32768)
05-25 02:30:05.280 251 251 I chatty : uid=1000(system) allocator@1.0-s identical 2 lines
05-25 02:30:05.281 251 251 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x778022c100, 32768)
05-25 02:30:05.287 1266 1280 E memtrack: Couldn’t load memtrack module
05-25 02:30:05.287 1266 1280 W android.os.Debug: failed to get memory consumption info: -1
05-25 02:30:05.295 2077 2077 W CAM_Log : Tag RoundedThumbnailView is 1 chars longer than limit.
05-25 02:30:05.389 2077 2077 W CAM_Log : Tag ModeOptionsScreenEffects is 5 chars longer than limit.
05-25 02:30:05.416 1266 1280 E memtrack: Couldn’t load memtrack module
05-25 02:30:05.416 1266 1280 W android.os.Debug: failed to get memory consumption info: -1
05-25 02:30:05.425 2077 2077 I CAM_BottomBar: isHorizontal = false, isPortrait = false
05-25 02:30:05.488 2077 2077 I CAM_Profiler: [333.893ms][ui] GUARD: CameraActivity.onCreateTasks - [227.941ms] setContentView()
05-25 02:30:05.503 2077 2077 I CAM_Profiler: [349.210ms][ui] GUARD: CameraActivity.onCreateTasks - [15.317ms] Configure Camera UI
05-25 02:30:05.511 2077 2077 V CAM_CameraController: Closing camera
05-25 02:30:05.513 2077 2358 W CAM2PORT_AndCamAgntImp: Releasing camera without any camera opened.
05-25 02:30:05.514 2077 2077 V CAM_ModulesInfo: EnableCaptureModule = true
05-25 02:30:05.516 2077 2077 V CAM_Profiler: [ 0.000ms][ui] GUARD: new CaptureModule - START
05-25 02:30:05.519 2077 2077 V CAM_Profiler: [ 2.312ms][ui] GUARD: new CaptureModule - STOP
05-25 02:30:05.519 2077 2077 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@33d7d4]
05-25 02:30:05.527 2077 2077 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@33d7d4, com.android.camera.ButtonManager@98e561f]
05-25 02:30:05.528 2077 2077 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@33d7d4, com.android.camera.ButtonManager@98e561f, com.android.camera.widget.IndicatorIconController@caa0f35]
05-25 02:30:05.528 2077 2077 V CAM_Profiler: [374.044ms][ui] GUARD: CameraActivity.onCreateTasks - [ 9.246ms] Init Current Module UI
05-25 02:30:05.528 2077 2077 V CAM_Profiler: [ 0.000ms][ui] GUARD: CaptureModule.init - START
05-25 02:30:05.529 2077 2077 D CAM_CaptureModule: init UseAutotransformUiLayout = false
05-25 02:30:05.531 2077 2077 D AndroidRuntime: Shutting down VM
05-25 02:30:05.533 2077 2077 E AndroidRuntime: FATAL EXCEPTION: main
05-25 02:30:05.533 2077 2077 E AndroidRuntime: Process: com.android.camera2, PID: 2077
05-25 02:30:05.533 2077 2077 E AndroidRuntime: java.lang.RuntimeException: Unable to start activity ComponentInfo{com.android.camera2/com.android.camera.CameraActivity}: java.lang.ArrayIndexOutOfBoundsException: length=0; index=0
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2951)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3086)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at android.app.servertransaction.LaunchActivityItem.execute(LaunchActivityItem.java:78)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:108)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:68)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1816)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:106)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at android.os.Looper.loop(Looper.java:193)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:6718)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:858)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: Caused by: java.lang.ArrayIndexOutOfBoundsException: length=0; index=0
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at com.android.camera.CaptureModule.getFacingFromCameraId(CaptureModule.java:1629)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at com.android.camera.CaptureModule.init(CaptureModule.java:427)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at com.android.camera.CameraActivity.onCreateTasks(CameraActivity.java:1801)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at com.android.camera.util.QuickActivity.onCreate(QuickActivity.java:114)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at android.app.Activity.performCreate(Activity.java:7171)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at android.app.Activity.performCreate(Activity.java:7162)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1271)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2931)
05-25 02:30:05.533 2077 2077 E AndroidRuntime: … 11 more
05-25 02:30:05.538 2077 2077 I Process : Sending signal. PID: 2077 SIG: 9
05-25 02:30:05.597 1204 1204 I Zygote : Process 2077 exited due to signal (9)
05-25 02:30:05.598 1266 1521 I ActivityManager: Process com.android.camera2 (pid 2077) has died: fore TOP
05-25 02:30:05.598 1266 1284 W libprocessgroup: kill(-2077, 9) failed: No such process
05-25 02:30:05.598 1266 1284 I libprocessgroup: Successfully killed process cgroup uid 10056 pid 2077 in 0ms
05-25 02:30:05.599 1266 1521 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.camera2/com.android.camera.PermissionsActivity}----com.android.camera2
05-25 02:30:05.623 2382 2382 I Zygote : seccomp disabled by setenforce 0
05-25 02:30:05.625 1266 1283 I ActivityManager: Start proc 2382:com.android.camera2/u0a56 for activity com.android.camera2/com.android.camera.PermissionsActivity
05-25 02:30:05.666 2382 2382 I android.camera: The ClassLoaderContext is a special shared library.
05-25 02:30:05.667 2382 2382 I android.camera: The ClassLoaderContext is a special shared library.
05-25 02:30:05.680 2382 2382 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraApp onCreate() - START
05-25 02:30:05.680 2382 2382 V CAM_Profiler: [ 0.000ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - START
05-25 02:30:05.682 2382 2382 V CAM_Profiler: [ 1.077ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - [ 1.077ms] PreferenceManager.getDefaultSharedPreferences
05-25 02:30:05.683 2382 2382 V CAM_Profiler: [ 2.814ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - [ 1.737ms] preferences.getLong
05-25 02:30:05.683 2382 2382 V CAM_Profiler: [ 2.974ms][ui] GUARD: FirstRunDetector getTimeOfFirstRun - STOP
05-25 02:30:05.683 2382 2382 V CAM_Profiler: [ 4.467ms][ui] GUARD: CameraApp onCreate() - [ 4.467ms] initializeTimeOfFirstRun
05-25 02:30:05.684 2382 2382 V CAM_Profiler: [ 4.694ms][ui] GUARD: CameraApp onCreate() - [ 0.226ms] UsageStatistics.initialize
05-25 02:30:05.685 2382 2382 V CAM_Profiler: [ 5.555ms][ui] GUARD: CameraApp onCreate() - [ 0.861ms] clearNotifications
05-25 02:30:05.685 2382 2382 V CAM_Profiler: [ 5.555ms][ui] GUARD: CameraApp onCreate() - STOP
05-25 02:30:05.699 2382 2382 V CAM_QuickActivity: START onCreate: Activity = com.android.camera.PermissionsActivity@47b83c5
05-25 02:30:05.714 2382 2382 D CAM_MemoryManagerImpl: Max native memory: 358 MB
05-25 02:30:05.715 274 310 W SurfaceFlinger: Attempting to set client state on removed layer: Surface(name=AppWindowToken{7379ac0 token=Token{535f443 ActivityRecord{6585f2 u0 com.android.camera2/com.android.camera.CameraLauncher t6}}})/@0x5c733f0 - animation-leash#0
05-25 02:30:05.715 274 310 W SurfaceFlinger: Attempting to set client state on removed layer: Surface(name=AppWindowToken{18c886b token=Token{976b1ba ActivityRecord{8db82e5 u0 com.android.launcher3/.Launcher t4}}})/@0x418c36e - animation-leash#0
05-25 02:30:05.715 274 310 W SurfaceFlinger: Attempting to destroy on removed layer: Surface(name=AppWindowToken{7379ac0 token=Token{535f443 ActivityRecord{6585f2 u0 com.android.camera2/com.android.camera.CameraLauncher t6}}})/@0x5c733f0 - animation-leash#0
05-25 02:30:05.715 274 310 W SurfaceFlinger: Attempting to destroy on removed layer: Surface(name=AppWindowToken{18c886b token=Token{976b1ba ActivityRecord{8db82e5 u0 com.android.launcher3/.Launcher t4}}})/@0x418c36e - animation-leash#0
05-25 02:30:05.718 2382 2382 V CAM_QuickActivity: END onCreate: Activity = com.android.camera.PermissionsActivity@47b83c5
05-25 02:30:05.722 2382 2382 V CAM_QuickActivity: START onStart: Activity = com.android.camera.PermissionsActivity@47b83c5
05-25 02:30:05.722 2382 2382 V CAM_QuickActivity: END onStart: Activity = com.android.camera.PermissionsActivity@47b83c5
05-25 02:30:05.722 2382 2382 V CAM_QuickActivity: START onResume: Activity = com.android.camera.PermissionsActivity@47b83c5
05-25 02:30:05.723 2382 2382 V CAM_QuickActivity: onResume(): isKeyguardLocked() = false
05-25 02:30:05.723 2382 2382 V CAM_QuickActivity: onResume → onResumeTasks()
05-25 02:30:05.724 2382 2382 V CAM_PermissionsActivity: requestPermissions count: 1
05-25 02:30:05.726 1266 1554 I ActivityManager: START u0 {act=android.content.pm.action.REQUEST_PERMISSIONS pkg=com.android.packageinstaller cmp=com.android.packageinstaller/.permission.ui.GrantPermissionsActivity (has extras)} from uid 10056
05-25 02:30:05.739 1266 1554 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.packageinstaller/com.android.packageinstaller.permission.ui.GrantPermissionsActivity}----com.android.packageinstaller
05-25 02:30:05.741 2382 2382 V CAM_QuickActivity: END onResume: Activity = com.android.camera.PermissionsActivity@47b83c5
05-25 02:30:05.742 2382 2382 D OpenGLRenderer: Skia GL Pipeline
05-25 02:30:05.763 2382 2382 V CAM_QuickActivity: START onPause: Activity = com.android.camera.PermissionsActivity@47b83c5
05-25 02:30:05.763 2382 2382 V CAM_QuickActivity: onPause → onPauseTasks()
05-25 02:30:05.763 2382 2382 V CAM_QuickActivity: END onPause: Activity = com.android.camera.PermissionsActivity@47b83c5
05-25 02:30:05.763 1266 1554 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.packageinstaller/com.android.packageinstaller.permission.ui.GrantPermissionsActivity}----com.android.packageinstaller
05-25 02:30:05.765 2212 2212 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@cb220e
05-25 02:30:05.778 2382 2399 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 947; [Func] : base_context_deal_with_version_affairs_rk_ext;
05-25 02:30:05.778 2382 2399 I mali_so : arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘16@0’.
05-25 02:30:05.778 2382 2399 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 914; [Func] : determine_policy_against_patch_for_sf_memory_leak;
05-25 02:30:05.778 2382 2399 I mali_so : cmdline : com.android.camera2, we should GO THROUGH patch_for_sf_memory_leak.
05-25 02:30:05.778 2382 2399 D mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 955; [Func] : base_context_deal_with_version_affairs_rk_ext;
05-25 02:30:05.778 2382 2399 D mali_so : current process is NOT sf, to bail out.
05-25 02:30:05.784 274 1066 E BufferQueueProducer: [com.android.launcher3/com.android.launcher3.Launcher#0] disconnect: not connected (req=1)
05-25 02:30:05.784 1824 1893 W libEGL : EGLNativeWindowType 0x7274592010 disconnect failed
05-25 02:30:05.790 2382 2399 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
05-25 02:30:05.790 2382 2399 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
05-25 02:30:05.790 2382 2399 I OpenGLRenderer: Initialized EGL, version 1.4
05-25 02:30:05.790 2382 2399 D OpenGLRenderer: Swap behavior 2
05-25 02:30:05.800 2382 2399 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
05-25 02:30:05.827 2382 2399 D GRALLOC-ROCKCHIP: RK_GRAPHICS_VER=commit-id:6802ae33f3
05-25 02:30:05.860 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:05.871 1266 1280 I ActivityManager: Displayed com.android.packageinstaller/.permission.ui.GrantPermissionsActivity: +776ms
05-25 02:30:05.877 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:05.895 2212 2212 D OpenGLRenderer: Skia GL Pipeline
05-25 02:30:05.908 1406 1406 D StatusBar: disable disable2
05-25 02:30:05.931 2212 2411 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 947; [Func] : base_context_deal_with_version_affairs_rk_ext;
05-25 02:30:05.931 2212 2411 I mali_so : arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘16@0’.
05-25 02:30:05.931 2212 2411 I mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 914; [Func] : determine_policy_against_patch_for_sf_memory_leak;
05-25 02:30:05.931 2212 2411 I mali_so : cmdline : com.android.packageinstaller, we should GO THROUGH patch_for_sf_memory_leak.
05-25 02:30:05.931 2212 2411 D mali_so : [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 955; [Func] : base_context_deal_with_version_affairs_rk_ext;
05-25 02:30:05.931 2212 2411 D mali_so : current process is NOT sf, to bail out.
05-25 02:30:05.940 2212 2411 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
05-25 02:30:05.941 2212 2411 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
05-25 02:30:05.941 2212 2411 I OpenGLRenderer: Initialized EGL, version 1.4
05-25 02:30:05.941 2212 2411 D OpenGLRenderer: Swap behavior 2
05-25 02:30:05.950 2212 2411 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
05-25 02:30:05.975 2212 2411 D GRALLOC-ROCKCHIP: RK_GRAPHICS_VER=commit-id:6802ae33f3
05-25 02:30:05.997 2212 2411 D : set stream to NULL
05-25 02:30:06.024 2212 2411 I chatty : uid=10011(com.android.packageinstaller) RenderThread identical 8 lines
05-25 02:30:06.027 2212 2411 D : set stream to NULL
05-25 02:30:06.027 274 389 W SurfaceFlinger: Attempting to set client state on removed layer: Splash Screen com.android.camera2#0
05-25 02:30:06.027 274 389 W SurfaceFlinger: Attempting to destroy on removed layer: Splash Screen com.android.camera2#0
05-25 02:30:06.029 2212 2411 D : set stream to NULL
05-25 02:30:06.635 1824 1824 W ViewRootImpl[Launcher]: Cancelling event due to no window focus: MotionEvent { action=ACTION_CANCEL, actionButton=0, id[0]=0, x[0]=764.2385, y[0]=246.21075, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=114137, downTime=112433, deviceId=5, source=0x2002 }
05-25 02:30:06.033 2212 2411 D : set stream to NULL
05-25 02:30:06.861 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:06.877 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:07.018 2212 2411 D : set stream to NULL
05-25 02:30:07.046 2212 2411 I chatty : uid=10011(com.android.packageinstaller) RenderThread identical 4 lines
05-25 02:30:07.051 2212 2411 D : set stream to NULL
05-25 02:30:07.518 1266 1554 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.camera2/com.android.camera.PermissionsActivity}----com.android.camera2
05-25 02:30:07.532 2382 2382 V CAM_PermissionsActivity: onPermissionsResult counts: 1:1
05-25 02:30:07.533 1406 1406 D StatusBar: disable disable2
05-25 02:30:06.636 1824 1824 I chatty : uid=10008(com.android.launcher3) identical 2 lines
05-25 02:30:06.637 1824 1824 W ViewRootImpl[Launcher]: Cancelling event due to no window focus: MotionEvent { action=ACTION_CANCEL, actionButton=0, id[0]=0, x[0]=764.2385, y[0]=246.21075, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=114137, downTime=112433, deviceId=5, source=0x2002 }
05-25 02:30:07.550 1266 2381 I ActivityManager: START u0 {act=android.intent.action.MAIN cmp=com.android.camera2/com.android.camera.CameraActivity} from uid 10056
05-25 02:30:07.560 1266 2381 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.camera2/com.android.camera.CameraActivity}----com.android.camera2
05-25 02:30:07.567 1266 2381 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.camera2/com.android.camera.CameraActivity}----com.android.camera2
05-25 02:30:07.576 2382 2382 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@fa38e22
05-25 02:30:07.581 2382 2382 V CAM_QuickActivity: START onCreate: Activity = com.android.camera.CameraActivity@2588707
05-25 02:30:07.581 2382 2382 V CAM_Profiler: [ 0.000ms][ui] GUARD: CameraActivity.onCreateTasks - START
05-25 02:30:07.582 2382 2382 D CAM_LocationManager: Using legacy location provider.
05-25 02:30:07.590 2382 2382 W SoundPool: Use of stream types is deprecated for operations other than volume control
05-25 02:30:07.590 2382 2382 W SoundPool: See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
05-25 02:30:07.591 2382 2382 I CAM_OneCamFtrCnfgCrtr: CaptureModule? true
05-25 02:30:07.601 2382 2382 V CAM_Profiler: [ 19.140ms][ui] GUARD: CameraActivity.onCreateTasks - [ 8.457ms] Glide.setup
05-25 02:30:07.604 2382 2382 V CAM_Profiler: [ 22.066ms][ui] GUARD: CameraActivity.onCreateTasks - [ 2.926ms] OneCameraManager.get
05-25 02:30:07.626 2382 2382 E SoundPool: error loading /product/media/audio/ui/camera_click.ogg
05-25 02:30:07.627 2382 2382 I CameraManagerGlobal: Connecting to camera service
05-25 02:30:07.632 2382 2382 V CAM_Profiler: [ 50.545ms][ui] GUARD: CameraActivity.onCreateTasks - [ 0.623ms] computePictureSizes
05-25 02:30:07.658 2382 2382 W CAM_Log : Tag RoundedThumbnailView is 1 chars longer than limit.
05-25 02:30:07.660 2382 2435 I OMXClient: IOmx service obtained
05-25 02:30:07.661 459 923 I OMXMaster: makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
05-25 02:30:07.664 459 923 E OMXNodeInstance: getConfig(0xf2590300:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
05-25 02:30:07.667 251 251 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x778022c100, 32768)
05-25 02:30:07.681 251 251 I chatty : uid=1000(system) allocator@1.0-s identical 6 lines
05-25 02:30:07.681 251 251 W AshmemAllocator: ashmem_create_region(32768) returning hidl_memory(0x778022c100, 32768)
05-25 02:30:07.723 461 461 I npu_monitor: type=1400 audit(0.0:416): avc: denied { read } for name=“temp” dev=“sysfs” ino=8936 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=file permissive=1
05-25 02:30:07.723 461 461 I npu_monitor: type=1400 audit(0.0:417): avc: denied { open } for path=“/sys/devices/virtual/thermal/thermal_zone0/temp” dev=“sysfs” ino=8936 scontext=u:r:npu_monitor:s0 tcontext=u:object_r:sysfs_temp:s0 tclass=file permissive=1
05-25 02:30:07.732 2382 2382 W CAM_Log : Tag ModeOptionsScreenEffects is 5 chars longer than limit.
05-25 02:30:07.762 2382 2382 I CAM_BottomBar: isHorizontal = false, isPortrait = false
05-25 02:30:07.769 274 310 W SurfaceFlinger: Attempting to set client state on removed layer: Dim Layer for - Task=6#0
05-25 02:30:07.769 274 310 W SurfaceFlinger: Attempting to destroy on removed layer: Dim Layer for - Task=6#0
05-25 02:30:07.819 2382 2382 I CAM_Profiler: [237.387ms][ui] GUARD: CameraActivity.onCreateTasks - [185.033ms] setContentView()
05-25 02:30:07.831 2382 2382 V CAM_Profiler: [250.012ms][ui] GUARD: CameraActivity.onCreateTasks - [12.625ms] Configure Camera UI
05-25 02:30:07.838 2382 2382 V CAM_CameraController: Closing camera
05-25 02:30:07.839 2382 2429 W CAM2PORT_AndCamAgntImp: Releasing camera without any camera opened.
05-25 02:30:07.839 2382 2382 V CAM_ModulesInfo: EnableCaptureModule = true
05-25 02:30:07.840 2382 2382 V CAM_Profiler: [ 0.000ms][ui] GUARD: new CaptureModule - START
05-25 02:30:07.842 2382 2382 V CAM_Profiler: [ 1.226ms][ui] GUARD: new CaptureModule - STOP
05-25 02:30:07.842 2382 2382 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@e112ba3]
05-25 02:30:07.846 2382 2382 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@e112ba3, com.android.camera.ButtonManager@fe8162a]
05-25 02:30:07.846 2382 2382 V CAM_SettingsManager: listeners: [com.android.camera.app.CameraAppUI@e112ba3, com.android.camera.ButtonManager@fe8162a, com.android.camera.widget.IndicatorIconController@1f671b8]
05-25 02:30:07.847 2382 2382 V CAM_Profiler: [265.341ms][ui] GUARD: CameraActivity.onCreateTasks - [ 5.040ms] Init Current Module UI
05-25 02:30:07.847 2382 2382 V CAM_Profiler: [ 0.000ms][ui] GUARD: CaptureModule.init - START
05-25 02:30:07.847 2382 2382 D CAM_CaptureModule: init UseAutotransformUiLayout = false
05-25 02:30:07.849 2382 2382 D AndroidRuntime: Shutting down VM
05-25 02:30:07.849 2382 2382 E AndroidRuntime: FATAL EXCEPTION: main
05-25 02:30:07.849 2382 2382 E AndroidRuntime: Process: com.android.camera2, PID: 2382
05-25 02:30:07.849 2382 2382 E AndroidRuntime: java.lang.RuntimeException: Unable to start activity ComponentInfo{com.android.camera2/com.android.camera.CameraActivity}: java.lang.ArrayIndexOutOfBoundsException: length=0; index=0
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2951)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3086)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at android.app.servertransaction.LaunchActivityItem.execute(LaunchActivityItem.java:78)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:108)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:68)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1816)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:106)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at android.os.Looper.loop(Looper.java:193)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:6718)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:858)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: Caused by: java.lang.ArrayIndexOutOfBoundsException: length=0; index=0
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at com.android.camera.CaptureModule.getFacingFromCameraId(CaptureModule.java:1629)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at com.android.camera.CaptureModule.init(CaptureModule.java:427)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at com.android.camera.CameraActivity.onCreateTasks(CameraActivity.java:1801)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at com.android.camera.util.QuickActivity.onCreate(QuickActivity.java:114)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at android.app.Activity.performCreate(Activity.java:7171)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at android.app.Activity.performCreate(Activity.java:7162)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1271)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2931)
05-25 02:30:07.849 2382 2382 E AndroidRuntime: … 11 more
05-25 02:30:07.851 1266 2381 W ActivityManager: Force finishing activity com.android.camera2/com.android.camera.CameraActivity
05-25 02:30:07.857 1266 1282 I ActivityManager: Showing crash dialog for package com.android.camera2 u0
05-25 02:30:07.861 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:07.877 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:07.893 274 970 E BufferQueueProducer: [com.android.packageinstaller/com.android.packageinstaller.permission.ui.GrantPermissionsActivity#0] disconnect: not connected (req=1)
05-25 02:30:07.893 2212 2411 W libEGL : EGLNativeWindowType 0x72744b7010 disconnect failed
05-25 02:30:07.893 2212 2411 D OpenGLRenderer: endAllActiveAnimators on 0x727449bb00 (RippleDrawable) with handle 0x7261bfe480
05-25 02:30:07.894 1266 2287 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
05-25 02:30:07.894 1266 2287 I ConfigStore: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
05-25 02:30:07.895 1266 2287 I OpenGLRenderer: Initialized EGL, version 1.4
05-25 02:30:07.895 1266 2287 D OpenGLRenderer: Swap behavior 2
05-25 02:30:07.903 1266 2287 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
05-25 02:30:07.923 1266 2287 D : set stream to NULL
05-25 02:30:08.353 1266 1281 W ActivityManager: Activity pause timeout for ActivityRecord{68b3412 u0 com.android.camera2/com.android.camera.CameraActivity t6 f}
05-25 02:30:07.953 1266 2287 I chatty : uid=1000(system) RenderThread identical 10 lines
05-25 02:30:07.957 1266 2287 D : set stream to NULL
05-25 02:30:08.356 1266 1281 E ActivityManager: getPackageFerformanceMode–ComponentInfo{com.android.launcher3/com.android.launcher3.Launcher}----com.android.launcher3
05-25 02:30:08.398 1824 1893 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
05-25 02:30:08.861 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:08.878 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:09.862 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:09.878 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:10.614 1211 1236 D AudioHardwareTiny: do_out_standby,out = 0xe7429000,device = 0x408
05-25 02:30:10.616 1211 1236 D alsa_route: route_set_controls() set route 24
05-25 02:30:10.622 1211 1236 D AudioHardwareTiny: close device
05-25 02:30:10.862 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:10.879 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:11.863 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:11.879 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:12.864 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:12.880 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:13.864 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:13.880 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:14.865 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:14.881 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:15.865 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:15.881 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:16.866 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:16.882 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:17.867 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:17.882 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:18.468 1266 1281 W ActivityManager: Activity destroy timeout for ActivityRecord{68b3412 u0 com.android.camera2/com.android.camera.CameraActivity t6 f}
05-25 02:30:18.469 1266 1281 W ActivityManager: Activity destroy timeout for ActivityRecord{ead7725 u0 com.android.camera2/com.android.camera.PermissionsActivity t6 f}
05-25 02:30:18.496 274 970 W SurfaceFlinger: Attempting to destroy on removed layer: AppWindowToken{21836ab token=Token{5c730fa ActivityRecord{ead7725 u0 com.android.camera2/com.android.camera.PermissionsActivity t6}}}#0
05-25 02:30:18.867 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:18.883 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:19.868 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:19.883 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:20.868 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:20.884 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:21.869 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:21.884 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:22.869 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:22.885 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:23.870 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:23.885 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:24.870 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:24.886 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1.0::IRadio/slot1. Waiting another…
05-25 02:30:25.871 464 464 W ServiceManagement: Waited one second for android.hardware.gatekeeper@1.0::IGatekeeper/default. Waiting another…
05-25 02:30:25.886 2302 2302 W ServiceManagement: Waited one second for android.hardware.radio@1
