板子需要安装 一个AppImage文件,查了文档,需要appstream才能安装,查下网上教程,下载了appstream_0.9.4-1ubuntu1_arm64.deb libappstream3_0.9.4-1ubuntu1_arm64.deb,修改运行权限后,并执行:sudo dpkg -i appstream_0.9.4-1ubuntu1_arm64.deb libappstream3_0.9.4-1ubuntu1_arm64.deb
提示如下:
(Reading database … 123090 files and directories currently installed.)
Preparing to unpack appstream_0.9.4-1ubuntu1_arm64.deb …
Unpacking appstream (0.9.4-1ubuntu1) over (0.9.4-1ubuntu1) …
Preparing to unpack libappstream3_0.9.4-1ubuntu1_arm64.deb …
Unpacking libappstream3:arm64 (0.9.4-1ubuntu1) over (0.9.4-1ubuntu1) …
dpkg: dependency problems prevent configuration of appstream:
appstream depends on libglib2.0-0 (>= 2.46); however:
Package libglib2.0-0:arm64 is not configured yet.
dpkg: error processing package appstream (–install):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libappstream3:arm64:
libappstream3:arm64 depends on libglib2.0-0 (>= 2.46); however:
libappstream3:arm64 depends on libprotobuf-lite9v5; however:
Package libprotobuf-lite9v5 is not installed.
libappstream3:arm64 depends on libxapian22v5; however:
Package libxapian22v5 is not installed.
libappstream3:arm64 depends on libxml2 (>= 2.7.4); however:
Package libxml2:arm64 is not configured yet.
dpkg: error processing package libappstream3:arm64 (–install):
Processing triggers for man-db (2.8.3-2ubuntu0.1) …
Processing triggers for libc-bin (2.27-3ubuntu1.2) …
appstream
libappstream3:arm64
还请老师指点下要如何处理!!(SD卡刷好系统,已经有先运行了unminimize)
