[ 637.066393] mali ff9a0000.gpu: Flush for GPU page table update did not complete. Issueing GPU soft-reset to recover
[ 639.791765] mali ff9a0000.gpu: Resetting GPU (allowing up to 500 ms)
[ 639.798237] mali ff9a0000.gpu: Register state:
[ 639.802968] mali ff9a0000.gpu: GPU_IRQ_RAWSTAT=0x00000200 GPU_STATUS=0x00000009
[ 639.810780] mali ff9a0000.gpu: JOB_IRQ_RAWSTAT=0x00000000 JOB_IRQ_JS_STATE=0x00000002 JOB_IRQ_THROTTLE=0x00000000
[ 639.821620] mali ff9a0000.gpu: JS0_STATUS=0x00000000 JS0_HEAD_LO=0x00000000
[ 639.829342] mali ff9a0000.gpu: JS1_STATUS=0x00000008 JS1_HEAD_LO=0xa145b400
[ 639.837041] mali ff9a0000.gpu: JS2_STATUS=0x00000000 JS2_HEAD_LO=0x00000000
[ 639.844756] mali ff9a0000.gpu: MMU_IRQ_RAWSTAT=0x00000000 GPU_FAULTSTATUS=0x00000000
[ 639.852779] mali ff9a0000.gpu: GPU_IRQ_MASK=0x00000000 JOB_IRQ_MASK=0x00000000 MMU_IRQ_MASK=0x00000000
[ 639.862978] mali ff9a0000.gpu: PWR_OVERRIDE0=0x00000000 PWR_OVERRIDE1=0x00000000
[ 639.870857] mali ff9a0000.gpu: SHADER_CONFIG=0x00010000 L2_MMU_CONFIG=0x00000000
[ 640.378804] mali ff9a0000.gpu: Failed to soft-reset GPU (timed out after 500 ms), now attempting a hard reset
[ 640.389242] mali ff9a0000.gpu: Reset complete
[ 640.389304] mali ff9a0000.gpu: t6xx: GPU fault 0x4002 from job slot 1
[ 640.400864] mali ff9a0000.gpu: t6xx: GPU fault 0x4002 from job slot 0
[ 842.103883] INFO: task kworker/u13:1:146 blocked for more than 120 seconds.
[ 842.110916] Not tainted 4.4.179 #1
[ 842.114977] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 842.122912] kworker/u13:1 D ffffff80080854d8 0 146 2 0x00000010
[ 842.130172] Workqueue: mali_jd kbase_jd_done_worker
[ 842.135173] Call trace:
[ 842.137663] [] __switch_to+0x90/0xc4
[ 842.142855] [] __schedule+0x584/0x9c8
[ 842.148122] [] schedule+0x7c/0x9c
[ 842.153041] [] schedule_preempt_disabled+0x28/0x40
[ 842.159446] [] mutex_lock_nested+0x1f4/0x37c
[ 842.165313] [] kbase_pm_context_active_handle_suspend+0x84/0x164
[ 842.172910] [] kbase_mmu_flush_invalidate+0xc8/0x1b8
[ 842.179481] [] kbase_mmu_teardown_pages+0x238/0x244
[ 842.185952] [] kbase_unmap_external_resource+0x150/0x3c0
[ 842.192861] [] jd_done_nolock+0x4e8/0x74c
[ 842.198463] [] kbase_jd_done_worker+0x2c4/0x44c
[ 842.204604] [] process_one_work+0x37c/0x630
[ 842.210372] [] worker_thread+0x2e0/0x3ac
[ 842.215883] [] kthread+0xe4/0xf4
[ 842.220703] [] ret_from_fork+0x10/0x50
[ 842.226040] INFO: lockdep is turned off.
[ 842.229982] Kernel panic - not syncing: hung_task: blocked tasks
[ 842.235987] CPU: 4 PID: 39 Comm: khungtaskd Not tainted 4.4.179 #1
[ 842.242157] Hardware name: rockchip,rk3399-mid (DT)
[ 842.247026] Call trace:
[ 842.249478] [] dump_backtrace+0x0/0x234
[ 842.254867] [] show_stack+0x24/0x30
[ 842.259919] [] dump_stack+0xb4/0xf4
[ 842.264972] [] panic+0xe8/0x240
[ 842.269673] [] watchdog+0x5a0/0x5f8
[ 842.274724] [] kthread+0xe4/0xf4
[ 842.279509] [] ret_from_fork+0x10/0x50
[ 842.284816] CPU5: stopping
[ 842.287521] CPU: 5 PID: 0 Comm: swapper/5 Not tainted 4.4.179 #1
[ 842.293522] Hardware name: rockchip,rk3399-mid (DT)
[ 842.298392] Call trace:
[ 842.300843] [] dump_backtrace+0x0/0x234
[ 842.306232] [] show_stack+0x24/0x30
[ 842.311283] [] dump_stack+0xb4/0xf4
[ 842.316334] [] handle_IPI+0x2a0/0x324
[ 842.321553] [] gic_handle_irq+0x12c/0x184
[ 842.327121] Exception stack(0xffffffc0f107bd80 to 0xffffffc0f107beb0)
[ 842.333557] bd80: ffffff80088d4b38 0000000000000000 ffffffc0f2bf59c0 00126f538e05922b
[ 842.341378] bda0: 00ffffffffffffff 00000004bc2d26f6 000000000017b0bc ffffff80088d4a40
[ 842.349198] bdc0: 0000000000000000 ffffff8008081800 0000000000001000 0000000000000000
[ 842.357017] bde0: 0000000034d5d91d 00000040e979f000 ffffffc0f1066600 0000000000000000
[ 842.364837] be00: 0000000000000000 0000000000000000 0000000030d00800 000000c3d2af3717
[ 842.372657] be20: 0000000000000000 ffffffc0ef974a00 ffffff80095ea1c0 0000000000000000
[ 842.380476] be40: 000000c3d2aa7403 ffffff800958d978 0000000002726000 0000000000e17244
[ 842.388296] be60: 0000000000000000 ffffffc0f107beb0 ffffff80088d4b38 ffffffc0f107beb0
[ 842.396116] be80: ffffff80088d4b3c 0000000060000145 ffffffc0f107beb0 ffffff80088d4afc
[ 842.403935] bea0: ffffffffffffffff ffffff80088d4b38
[ 842.408805] [] el1_irq+0xb8/0x140
[ 842.413677] [] cpuidle_enter_state+0x298/0x328
[ 842.419679] [] cpuidle_enter+0x34/0x44
[ 842.424984] [] call_cpuidle+0x70/0x78
[ 842.430202] [] cpu_startup_entry+0x398/0x3a8
[ 842.436024] [] secondary_start_kernel+0x1a8/0x1d4
[ 842.442279] [<0000000000e17188>] 0xe17188
[ 842.446291] CPU3: stopping
[ 842.449036] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.179 #1
[ 842.455050] Hardware name: rockchip,rk3399-mid (DT)
[ 842.459939] Call trace:
[ 842.462422] [] dump_backtrace+0x0/0x234
[ 842.467841] [] show_stack+0x24/0x30
[ 842.472911] [] dump_stack+0xb4/0xf4
[ 842.477978] [] handle_IPI+0x2a0/0x324
[ 842.483223] [] gic_handle_irq+0x12c/0x184
[ 842.488804] Exception stack(0xffffffc0f1073d80 to 0xffffffc0f1073eb0)
[ 842.495260] 3d80: ffffff80088d4b38 0000000000000000 ffffffc0f284b9c0 00126f538e05922b
[ 842.503104] 3da0: 00ffffffffffffff 00000004bc2d26f6 000000000017b0bc ffffff80088d4a40
[ 842.510947] 3dc0: 0000000000000000 0000000000000000 00000000000015a0 0000000000000800
[ 842.518790] 3de0: 0000000000000269 0000000100000004 0000000000000002 0000000000000000
[ 842.526633] 3e00: 0000000000000000 0000000000000000 0000000030d00800 000000c3d2af390b
[ 842.534476] 3e20: 0000000000000000 ffffffc0ef974600 ffffff80095ea1c0 0000000000000000
[ 842.542320] 3e40: 000000c3d2aaca47 ffffff800958d978 0000000002726000 0000000000e17244
[ 842.550163] 3e60: 0000000000000000 ffffffc0f1073eb0 ffffff80088d4b38 ffffffc0f1073eb0
[ 842.558007] 3e80: ffffff80088d4b3c 0000000060000145 ffffffc0f1073eb0 ffffff80088d4afc
[ 842.565847] 3ea0: ffffffffffffffff ffffff80088d4b38
[ 842.570740] [] el1_irq+0xb8/0x140
[ 842.575639] [] cpuidle_enter_state+0x298/0x328
[ 842.581657] [] cpuidle_enter+0x34/0x44
[ 842.586989] [] call_cpuidle+0x70/0x78
[ 842.592233] [] cpu_startup_entry+0x398/0x3a8
[ 842.598083] [] secondary_start_kernel+0x1a8/0x1d4
[ 842.604363] [<0000000000e17188>] 0xe17188
[ 842.608388] CPU0: stopping
[ 842.611123] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.179 #1
[ 842.617136] Hardware name: rockchip,rk3399-mid (DT)
[ 842.622024] Call trace:
[ 842.624501] [] dump_backtrace+0x0/0x234
[ 842.629918] [] show_stack+0x24/0x30
[ 842.634987] [] dump_stack+0xb4/0xf4
[ 842.640052] [] handle_IPI+0x2a0/0x324
[ 842.645296] [] gic_handle_irq+0x12c/0x184
[ 842.650877] Exception stack(0xffffff8009483d30 to 0xffffff8009483e60)
[ 842.657329] 3d20: ffffff80088d4b38 0000000000000000
[ 842.665174] 3d40: 00000040e8e76000 0000000000000020 00ffffffffffffff 00000004bc2d26f6
[ 842.673017] 3d60: 000000000017b0bc ffffff800812ef90 0000000000000000 ffffff8008081800
[ 842.680860] 3d80: 0000000000001000 0000000000000000 0000000034d5d91d 00000040e8e76000
[ 842.688704] 3da0: ffffff800948dde0 0000000000000000 0000000000000000 0000000000000000
[ 842.696536] 3dc0: 0000000030d00800 000000c3d2b03df2 0000000000000002 ffffffc0ef974000
[ 842.704380] 3de0: ffffff80095ea1c0 0000000000000001 000000c3d29fb8c8 ffffff800958d978
[ 842.712224] 3e00: ffffff800948dde0 ffffff80095ea1c0 00000000013b001c ffffff8009483e60
[ 842.720068] 3e20: ffffff80088d4b38 ffffff8009483e60 ffffff80088d4b3c 0000000060000145
[ 842.727912] 3e40: ffffff8009483e60 ffffff80088d4b34 ffffffffffffffff ffffff80088d4b38
[ 842.735754] [] el1_irq+0xb8/0x140
[ 842.740651] [] cpuidle_enter_state+0x298/0x328
[ 842.746669] [] cpuidle_enter+0x34/0x44
[ 842.751999] [] call_cpuidle+0x70/0x78
[ 842.757244] [] cpu_startup_entry+0x398/0x3a8
[ 842.763095] [] rest_init+0x164/0x174
[ 842.768249] [] start_kernel+0x3ec/0x410
[ 842.773666] [] __primary_switched+0x30/0x6c
[ 842.779427] CPU1: stopping
[ 842.782163] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.4.179 #1
[ 842.788176] Hardware name: rockchip,rk3399-mid (DT)
[ 842.793064] Call trace:
[ 842.795541] [] dump_backtrace+0x0/0x234
[ 842.800959] [] show_stack+0x24/0x30
[ 842.806027] [] dump_stack+0xb4/0xf4
[ 842.811093] [] handle_IPI+0x2a0/0x324
[ 842.816337] [] gic_handle_irq+0x12c/0x184
[ 842.821917] Exception stack(0xffffffc0f106bd80 to 0xffffffc0f106beb0)
[ 842.828372] bd80: ffffff80088d4b38 0000000000000000 ffffffc0f24a19c0 00126f538e05922b
[ 842.836217] bda0: 00ffffffffffffff 00000004bc2d26f6 000000000017b0bc ffffff80088d4a40
[ 842.844060] bdc0: 0000000000000000 0000000000000000 00000000000015a0 0000000000000000
[ 842.851904] bde0: 0000000034d5d91d 00000040e904b000 ffffffc0f1060000 0000000000000000
[ 842.859747] be00: 0000000000000000 0000000000000000 0000000030d00800 000000c3d2af3a2e
[ 842.867590] be20: 0000000000000000 ffffffc0ef974200 ffffff80095ea1c0 0000000000000000
[ 842.875435] be40: 000000c3adc77205 ffffff800958d978 0000000002726000 0000000000e17244
[ 842.883278] be60: 0000000000000000 ffffffc0f106beb0 ffffff80088d4b38 ffffffc0f106beb0
[ 842.891122] be80: ffffff80088d4b3c 0000000060000145 ffffffc0f106beb0 ffffff80088d4afc
[ 842.898962] bea0: ffffffffffffffff ffffff80088d4b38
[ 842.903856] [] el1_irq+0xb8/0x140
[ 842.908753] [] cpuidle_enter_state+0x298/0x328
[ 842.914771] [] cpuidle_enter+0x34/0x44
[ 842.920101] [] call_cpuidle+0x70/0x78
[ 842.925346] [] cpu_startup_entry+0x398/0x3a8
[ 842.931195] [] secondary_start_kernel+0x1a8/0x1d4
[ 842.937475] [<0000000000e17188>] 0xe17188
[ 842.941500] CPU2: stopping
[ 842.944235] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.4.179 #1
[ 842.950249] Hardware name: rockchip,rk3399-mid (DT)
[ 842.955137] Call trace:
[ 842.957614] [] dump_backtrace+0x0/0x234
[ 842.963032] [] show_stack+0x24/0x30
[ 842.968101] [] dump_stack+0xb4/0xf4
[ 842.973167] [] handle_IPI+0x2a0/0x324
[ 842.978412] [] gic_handle_irq+0x12c/0x184
[ 842.983992] Exception stack(0xffffffc0f106fd80 to 0xffffffc0f106feb0)
[ 842.990448] fd80: ffffff80088d4b38 0000000000000000 ffffffc0f26769c0 00126f538e05922b
[ 842.998292] fda0: 00ffffffffffffff 00000004bc2d26f6 000000000017b0bc ffffff80088d4a40
[ 843.006135] fdc0: 0000000000000000 0000000000000000 00000000000015a0 000000557bb95460
[ 843.013978] fde0: 0000000000000100 0000000000000000 0000000000000000 0000000000000001
[ 843.021823] fe00: ffffff8008136a7c 0000007fa8d1e998 0000000000000001 000000c3d2af3a2e
[ 843.029666] fe20: 0000000000000000 ffffffc0ef974400 ffffff80095ea1c0 0000000000000000
[ 843.037510] fe40: 000000c3d2ae17a7 ffffff800958d978 0000000002726000 0000000000e17244
[ 843.045354] fe60: 0000000000000000 ffffffc0f106feb0 ffffff80088d4b38 ffffffc0f106feb0
[ 843.053198] fe80: ffffff80088d4b3c 0000000060000145 ffffffc0f106feb0 ffffff80088d4afc
[ 843.061039] fea0: ffffffffffffffff ffffff80088d4b38
[ 843.065933] [] el1_irq+0xb8/0x140
[ 843.070830] [] cpuidle_enter_state+0x298/0x328
[ 843.076848] [] cpuidle_enter+0x34/0x44
[ 843.082177] [] call_cpuidle+0x70/0x78
[ 843.087422] [] cpu_startup_entry+0x398/0x3a8
[ 843.093272] [] secondary_start_kernel+0x1a8/0x1d4
[ 843.099551] [<0000000000e17188>] 0xe17188
[ 843.103574] CRU:
[ 843.105415] 00000000: 00000044 00002201 80000000 00000108 00000007 00007f00 00000000 00000000
[ 843.113936] 00000020: 00000043 00001101 80000000 00000108 00000007 00007f00 00000000 00000000
[ 843.122457] 00000040: 00000064 00001301 8000031f 00000108 00000007 00007f00 00000000 00000000
[ 843.130978] 00000060: 0000004b 00002602 8000031f 00000108 00000007 00007f00 00000000 00000000
[ 843.139498] 00000080: 00000064 00001301 8000031f 00000108 00000007 00007f00 00000000 00000000
[ 843.148018] 000000a0: 0000004b 00001301 80000000 00000108 00000007 00007f00 00000000 00000000
[ 843.156538] 000000c0: 000000c6 00001202 8000031f 00000008 00000007 00007f00 00000000 00000000
[ 843.165058] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.173579] 00000100: 00000100 00000202 00000140 00006707 00000083 00008581 00008320 00000141
[ 843.182099] 00000120: 00000181 00008181 00000141 00000141 00004141 00008343 00003185 00000500
[ 843.190619] 00000140: 0000010f 00000300 00004a87 0000033f 00009381 00008387 00001103 00005282
[ 843.199139] 00000160: 00008247 00000187 00001743 0000001f 00000180 00000300 00000300 00000000
[ 843.207659] 00000180: 00006300 00000200 00000200 00000200 00000200 00000200 00003f3f 00000081
[ 843.216179] 000001a0: 00000000 00000000 00004141 00000421 00008700 000002dc 00000004 00000381
[ 843.224699] 000001c0: 00000381 00000100 00000003 00000087 00000087 00000141 00000141 00008181
[ 843.233219] 000001e0: 00008320 00000007 00008f1f 00008f8f 00008f8f 00008787 00008787 00008787
[ 843.241739] 00000200: 000000c5 000000c5 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.250259] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.258779] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.267299] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.275819] 00000280: 01b97a12 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60
[ 843.284338] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 00000000 00000000
[ 843.292858] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.301378] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.309898] 00000300: 00000080 00000080 00000202 0000006b 00000c30 00000000 0000001f 000001c0
[ 843.318418] 00000320: 0000efc0 0000f0ff 0000e0ff 000001f0 00000054 0000f2f2 00000000 00000000
[ 843.326938] 00000340: 00000505 00000505 00001000 00000000 00000f84 0000000c 0000cfee 00003f00
[ 843.335458] 00000360: 0000ef60 00000020 00000ffe 000001c0 000000c0 00000fc4 00000c0c 00000190
[ 843.343978] 00000380: 00002010 00000100 0000003e 00000000 00000000 00000000 00000000 00000000
[ 843.352498] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.361018] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.369537] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.378057] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.386577] 00000420: 000000bc 00007070 00000000 00000014 00000000 00000000 00000000 00000000
[ 843.395097] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.403617] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.412137] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.420657] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.429177] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.437696] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.446216] 00000500: 00000000 00000000 00640064 00000000 00000003 00000001 00000000 00000000
[ 843.454736] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.463256] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.471776] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.480294] 00000580: 00000004 00000000 00000004 00000000 00000004
[ 843.486464] PMU CRU:
[ 843.488652] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 00000000 00000000
[ 843.497174] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.505695] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.514217] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.522739] 00000080: 0000060d 00001986 00000303 00000003 000002dc 00000200 0bb8ea60 00040050
[ 843.531260] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.539782] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.548303] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.556825] 00000100: 00000ffc 0000fb80 0000000f 00000000 00000024 00000000 00000000 00000000
[ 843.565345] 00000120: 00000000 00000000 00000000 00000000 00000003
[ 843.571516] PMU:
[ 843.573355] 00000000: 00000000 00000000 00000000 00000000 00000000 d18f0300 d18f0300 00000000
[ 843.581877] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.590398] 00000040: 00000000 00000000 00000000 00000000 00000000 d99f833f 00000000 00000000
[ 843.598920] 00000060: 30400d78 30400d78 30400d78 00000010 00000000 00007e00 00000000 28800000
[ 843.607442] 00000080: 000003c0 00011940 00005dc0 000003c0 00005dc0 00000060 0000000f 00000018
[ 843.615963] 000000a0: 00000018 00000018 00000018 00000006 00000006 00005dc0 00005dc0 00005dc0
[ 843.624485] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 3fffffff 00000000
[ 843.633006] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.641523] Kernel Offset: disabled
[ 843.645007] Memory Limit: none
[ 843.648071] rockchip-thermal ff260000.tsadc: channal 0: temperature(47 C)
[ 843.654855] rockchip-thermal ff260000.tsadc: channal 1: temperature(53 C)
[ 843.661637] THERMAL REGS:
[ 843.664259] 00000000: 00000200 00010133 00000033 00000000 00000000 00000000 00000000 00000000
[ 843.672779] 00000020: 0000022f 00000229 00000000 00000000 0000024e 00000279 00000000 00000000
[ 843.681300] 00000040: 000002a5 000002a5 00000000 00000000 00000000 00000000 00000000 00000000
[ 843.689821] 00000060: 00000004 00000004 00000753 00000753 00000000 00000000 00000000 00000000
[ 843.698338] 00000080: 00000000 00000000
[ 843.711685] —[ end Kernel panic - not syncing: hung_task: blocked tasks
[ 865.673495] Watchdog detected hard LOCKUP on cpu 5
[ 865.678120] ------------[ cut here ]------------
[ 865.682928] WARNING: at kernel/watchdog.c:352
[ 865.687279] Modules linked in:
[ 865.690353]
[ 865.691850] CPU: 4 PID: 39 Comm: khungtaskd Not tainted 4.4.179 #1
[ 865.698020] Hardware name: rockchip,rk3399-mid (DT)
[ 865.702889] task: ffffffc0f138b300 task.stack: ffffffc0f0edc000
[ 865.708809] PC is at watchdog_timer_fn+0x170/0x2e8
[ 865.713594] LR is at watchdog_timer_fn+0x170/0x2e8
[ 865.718379] pc : [] lr : [] pstate: 600001c5
[ 865.725764] sp : ffffffc0f2859db0
[ 865.729078] x29: ffffffc0f2859db0 x28: 0000000000000005
[ 865.734429] x27: ffffff8009487b60 x26: ffffff8009452558
[ 865.739780] x25: ffffffc0f2a1c570 x24: ffffffc0f0edfae0
[ 865.745130] x23: 0000000000000000 x22: 0000000000000000
[ 865.750480] x21: ffffff8009486000 x20: ffffff80094525d0
[ 865.755830] x19: ffffff8009452000 x18: ffffff808a344c67
[ 865.761180] x17: 0000000000000009 x16: 000000000000002d
[ 865.766531] x15: 0000000000000000 x14: 00000000000a46d7
[ 865.771880] x13: 000000000000000a x12: 0000000000000030
[ 865.777231] x11: 00000000fffffffe x10: ffffff800a344c6f
[ 865.782581] x9 : 0000000005f5e0ff x8 : ffffff80083da7ac
[ 865.787931] x7 : 0000000000000001 x6 : ffffff800810acb4
[ 865.793281] x5 : 0000000000000000 x4 : 0000000000000001
[ 865.798631] x3 : 0000000000000000 x2 : ffffffc0f138b300
[ 865.803981] x1 : ffffffc0f138b300 x0 : 0000000000000026
[ 865.809332]
[ 865.809332] PC: 0xffffff8008154a30:
[ 865.814297] 4a30 f9401000 d63f0000 aa0003e1 aa1b03e2 aa1903e0 97ff3506 b50003f6 91022694
[ 865.822609] 4a50 d538d080 38606a81 34000041 38206a9f 97ffff7b a94153f3 52800020 a9425bf5
[ 865.830919] 4a70 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020283 f87a6840 f8636845
[ 865.839230] 4a90 91022294 eb05001f 54000ba0 f8236840 f87c7b60 3834681f 17ffffda 9400e419
[ 865.847541] 4ab0 d4210000 f87c7b60 52800021 38346801 17ffffd4 97fe029d f944eaa1 36080961
[ 865.855851] 4ad0 b9401341 34000921 531f7821 d35efc00 8b21c2c1 cb000021 b6f80881 6b160016
[ 865.864162] 4af0 54000840 91022a99 d538d080 38796801 34000101 91024294 f8746802 d5384101
[ 865.872472] 4b10 eb01005f 54fffa80 3839681f 17ffffd1 34000157 f00112a1 52800000 912c6021
[ 865.880784]
[ 865.880784] LR: 0xffffff8008154a30:
[ 865.885748] 4a30 f9401000 d63f0000 aa0003e1 aa1b03e2 aa1903e0 97ff3506 b50003f6 91022694
[ 865.894059] 4a50 d538d080 38606a81 34000041 38206a9f 97ffff7b a94153f3 52800020 a9425bf5
[ 865.902369] 4a70 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020283 f87a6840 f8636845
[ 865.910679] 4a90 91022294 eb05001f 54000ba0 f8236840 f87c7b60 3834681f 17ffffda 9400e419
[ 865.918989] 4ab0 d4210000 f87c7b60 52800021 38346801 17ffffd4 97fe029d f944eaa1 36080961
[ 865.927299] 4ad0 b9401341 34000921 531f7821 d35efc00 8b21c2c1 cb000021 b6f80881 6b160016
[ 865.935609] 4af0 54000840 91022a99 d538d080 38796801 34000101 91024294 f8746802 d5384101
[ 865.943918] 4b10 eb01005f 54fffa80 3839681f 17ffffd1 34000157 f00112a1 52800000 912c6021
[ 865.952229]
[ 865.952229] SP: 0xffffffc0f2859d30:
[ 865.957193] 9d30 00000000 00000000 00000000 00000000 f0edfae0 ffffffc0 f2a1c570 ffffffc0
[ 865.965503] 9d50 09452558 ffffff80 09487b60 ffffff80 00000005 00000000 f2859db0 ffffffc0
[ 865.973814] 9d70 08154ab0 ffffff80 f2859db0 ffffffc0 08154ab0 ffffff80 600001c5 00000000
[ 865.982123] 9d90 094869d0 ffffff80 000000d2 00000000 00000000 00000080 081233d4 ffffff80
[ 865.990433] 9db0 f2859e20 ffffffc0 08122ffc ffffff80 f2a1c570 ffffffc0 f2a1bd00 ffffffc0
[ 865.998744] 9dd0 0928c000 ffffff80 f2a1bdc0 ffffffc0 08c27000 ffffff80 f2a1bd90 ffffffc0
[ 866.007054] 9df0 00000003 00000000 09506848 ffffff80 0928c000 ffffff80 44c22785 000000c9
[ 866.015364] 9e10 f2a1c570 ffffffc0 094869d0 ffffff80 f2859eb0 ffffffc0 081233f8 ffffff80
[ 866.023675]
[ 866.023675] X1: 0xffffffc0f138b280:
[ 866.028639] b280 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.036949] b2a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.045259] b2c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.053568] b2e0 600d5515 6d554504 55050541 45115544 4505c545 45455545 74545555 45544558
[ 866.061878] b300 00000012 00000000 ffffffff ffffffff 00010002 00000000 00000000 00000000
[ 866.070188] b320 f0edc000 ffffffc0 00000002 00208040 00000000 00000000 00000000 00000000
[ 866.078498] b340 00000001 00000004 00000003 00000000 00084716 00000001 cfcb9980 ffffffc0
[ 866.086808] b360 00000004 00000001 00000078 00000078 00000078 00000000 08c28590 ffffff80
[ 866.095119]
[ 866.095119] X2: 0xffffffc0f138b280:
[ 866.100073] b280 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.108382] b2a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.116692] b2c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.125002] b2e0 600d5515 6d554504 55050541 45115544 4505c545 45455545 74545555 45544558
[ 866.133311] b300 00000012 00000000 ffffffff ffffffff 00010002 00000000 00000000 00000000
[ 866.141621] b320 f0edc000 ffffffc0 00000002 00208040 00000000 00000000 00000000 00000000
[ 866.149931] b340 00000001 00000004 00000003 00000000 00084716 00000001 cfcb9980 ffffffc0
[ 866.158241] b360 00000004 00000001 00000078 00000078 00000078 00000000 08c28590 ffffff80
[ 866.166553]
[ 866.166553] X6: 0xffffff800810ac34:
[ 866.171506] ac34 97fff901 363801d8 d51b4238 97ffb962 b9407ba0 34fff180 f0007780 9104b000
[ 866.179817] ac54 52800002 52812b21 97fefc49 942c147a 17ffff85 d2800002 17ffffe2 97ffc42d
[ 866.188128] ac74 d51b4238 17fffff3 f942af40 b900375f b4000040 f902af5f aa1703e0 942c27d6
[ 866.196438] ac94 aa1903e2 52800021 9105c260 97ffd0aa 91044260 97ffb3ad aa1703e0 942c26a0
[ 866.204749] acb4 f9401754 aa1803e1 f944cb55 aa1703e0 942c27f0 eb1402bf 540000a1 b9407fa0
[ 866.213059] acd4 34ffe160 97fffecc 17ffff09 97fffd29 35ffeca0 17fffffa a9b57bfd 910003fd
[ 866.221369] acf4 a90153f3 a9025bf5 a90363f7 a9046bf9 a90573fb 2a0103f5 2a0003f8 aa0203f9
[ 866.229679] ad14 aa0503fc aa1e03e0 a9077ba4 f90043a3 d503201f 31000abf 54000581 52800020
[ 866.237990]
[ 866.237990] X8: 0xffffff80083da72c:
[ 866.242944] a72c 9400054a aa1303e0 94000554 52800000 a94153f3 f94013f5 a8c37bfd d65f03c0
[ 866.251254] a74c f9400413 17fffff6 f9400813 17fffff4 f9400c13 17fffff2 128002a0 17fffff5
[ 866.259564] a76c 71001c1f 54000161 f940a4e0 f9400c00 b4000140 a9bf7bfd aa0603e2 aa0403e1
[ 866.267875] a78c 910003fd 940004ce a8c17bfd d65f03c0 128002a0 d65f03c0 12800160 d65f03c0
[ 866.276184] a7ac a9bb7bfd 7100081f 910003fd a9025bf5 aa0403f6 a90153f3 aa0603f5 a90363f7
[ 866.284494] a7cc f940a4f3 54000181 f9400660 b4000a20 2a1503e2 aa1603e1 9400047d 52800000
[ 866.292805] a7ec a94153f3 a9425bf5 a94363f7 a8c57bfd d65f03c0 71000c1f 54000061 f9400a60
[ 866.301115] a80c 17fffff3 71001c1f 54000061 f9400e60 17ffffef 35000820 51000420 7100041f
[ 866.309426]
[ 866.309426] X10: 0xffffff800a344bef:
[ 866.314475] 4bec 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.322785] 4c0c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.331095] 4c2c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.339405] 4c4c 00000000 00000000 00000000 00000000 00000000 00000001 00000000 30303020
[ 866.347715] 4c6c 332e3636 31373736 34205d35 20633663 332e3636 32343930 58205d36 203a3031
[ 866.356025] 4c8c 66667830 66666666 61303038 62343433 0a3a6665 35313830 30626134 70205d3e
[ 866.364335] 4cac 74617473 36203a65 30303030 0a356331 20303030 30303030 30303030 20676e0a
[ 866.372645] 4ccc 61682061 72206472 74657365 300a300a 700a3030 676e690a 55504720 666f7320
[ 866.380956] 4cec 65722d74 20746573 72206f74 6c6f7365 0a2e6576 6c756166 74732074 73757461
[ 866.389269]
[ 866.389269] X18: 0xffffff808a344be7:
[ 866.394317] 4be4 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.402633] 4c04 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.410944] 4c24 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.419257] 4c44 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.427568] 4c64 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.435880] 4c84 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.444192] 4ca4 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.452504] 4cc4 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.460816] 4ce4 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.469128]
[ 866.469128] X19: 0xffffff8009451f80:
[ 866.474177] 1f80 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.482488] 1fa0 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.490800] 1fc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.499112] 1fe0 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.507423] 2000 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.515735] 2020 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.524047] 2040 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.532359] 2060 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.540671]
[ 866.540671] X20: 0xffffff8009452550:
[ 866.545720] 2550 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.554031] 2570 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.562343] 2590 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.570655] 25b0 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.578967] 25d0 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.587278] 25f0 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.595589] 2610 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.603901] 2630 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.612214]
[ 866.612214] X21: 0xffffff8009485f80:
[ 866.617263] 5f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.625573] 5fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.633882] 5fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.642191] 5fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.650500] 6000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.658809] 6020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.667119] 6040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.675428] 6060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 866.683739]
[ 866.683739] X24: 0xffffffc0f0edfa60:
[ 866.688788] fa60 000001c0 00000000 00000000 00000000 00000000 00000000 00000006 00000000
[ 866.697097] fa80 0000003d 00000000 0a3454ca ffffff80 0000da14 00000006 00000000 00000000
[ 866.705407] faa0 09004caa ffffff80 00000000 00000001 f0edfb60 ffffffc0 0810b334 ffffff80
[ 866.713717] fac0 f0edfbc0 ffffffc0 08ffdabc ffffff80 f0edfc10 ffffffc0 0808276c ffffff80
[ 866.722027] fae0 00000e31 00000000 dda2a2b3 00000004 000003e8 00000000 00000007 00000000
[ 866.730337] fb00 00000001 00000000 f2a1ac20 ffffffc0 00000001 00000000 00000001 00000000
[ 866.738646] fb20 083da7ac ffffff80 05f5e0ff 00000000 0a344c6f ffffff80 fffffffe 00000000
[ 866.746956] fb40 00000030 00000000 0000000a 00000000 000adc05 00000000 00000000 00000000
[ 866.755266]
[ 866.755266] X25: 0xffffffc0f2a1c4f0:
[ 866.760315] c4f0 00000004 00000000 08153044 ffffff80 00000001 00000000 f2a1c508 ffffffc0
[ 866.768625] c510 f2a1c508 ffffffc0 f2a1c518 ffffffc0 f2a1c518 ffffffc0 081531cc ffffff80
[ 866.776935] c530 f1007cf8 ffffffc0 f1007c20 ffffffc0 00020002 00000000 00000000 00000000
[ 866.785245] c550 00000001 00000000 000000d8 00000000 000000d2 00000000 f1138000 ffffffc0
[ 866.793555] c570 f2a1c570 ffffffc0 00000000 00000000 00000000 00000000 44c22280 000000c9
[ 866.801866] c590 44c22280 000000c9 08154940 ffffff80 f2a1bdc0 ffffffc0 00000000 0000001a
[ 866.810176] c5b0 08154914 ffffff80 63746177 676f6468 0000342f 00000000 000000d1 00000000
[ 866.818486] c5d0 00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[ 866.826796]
[ 866.826796] X26: 0xffffff80094524d8:
[ 866.831845] 24d8 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.840157] 24f8 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.848469] 2518 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.856781] 2538 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.865093] 2558 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.873404] 2578 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.881716] 2598 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.890027] 25b8 ******** ******** ******** ******** ******** ******** ******** ********
[ 866.898340]
[ 866.898340] X27: 0xffffff8009487ae0:
[ 866.903389] 7ae0 00000001 00000000 00000001 00000000 000003e8 00000000 f7f097c0 ffffffc0
[ 866.911699] 7b00 000001d5 00000000 f7f09780 ffffffc0 00000001 00000000 00000098 00000000
[ 866.920009] 7b20 001d5000 00001000 00000001 00000000 f7f09800 ffffffc0 f7f0bc00 ffffffc0
[ 866.928318] 7b40 00000006 00000000 00000005 00000014 f7f09640 ffffffc0 f2102000 ffffffc0
[ 866.936628] 7b60 e8e76000 00000040 e904b000 00000040 e9220000 00000040 e93f5000 00000040
[ 866.944939] 7b80 e95ca000 00000040 e979f000 00000040 00000000 00000000 00000000 00000000
[ 866.953249] 7ba0 00000002 00000000 00001828 00000000 00010000 00000000 000f7fff 00000000
[ 866.961559] 7bc0 0001da34 00000000 00002000 00000000 00000000 0000fffa 00000000 00000000
[ 866.969870]
[ 866.969870] X29: 0xffffffc0f2859d30:
[ 866.974919] 9d30 00000000 00000000 00000000 00000000 f0edfae0 ffffffc0 f2a1c570 ffffffc0
[ 866.983229] 9d50 09452558 ffffff80 09487b60 ffffff80 00000005 00000000 f2859db0 ffffffc0
[ 866.991540] 9d70 08154ab0 ffffff80 f2859db0 ffffffc0 08154ab0 ffffff80 600001c5 00000000
[ 866.999850] 9d90 094869d0 ffffff80 000000d2 00000000 00000000 00000080 081233d4 ffffff80
[ 867.008160] 9db0 f2859e20 ffffffc0 08122ffc ffffff80 f2a1c570 ffffffc0 f2a1bd00 ffffffc0
[ 867.016470] 9dd0 0928c000 ffffff80 f2a1bdc0 ffffffc0 08c27000 ffffff80 f2a1bd90 ffffffc0
[ 867.024780] 9df0 00000003 00000000 09506848 ffffff80 0928c000 ffffff80 44c22785 000000c9
[ 867.033090] 9e10 f2a1c570 ffffffc0 094869d0 ffffff80 f2859eb0 ffffffc0 081233f8 ffffff80
[ 867.041399]
[ 867.042895] —[ end trace 28f1d46ae92b8a97 ]—
[ 867.047510] Call trace:
[ 867.049959] Exception stack(0xffffffc0f2859bc0 to 0xffffffc0f2859cf0)
[ 867.056394] 9bc0: ffffff8009452000 0000008000000000 ffffffc0f2859db0 ffffff8008154ab0
[ 867.064214] 9be0: 00000000600001c5 000000000000003d ffffffc0f2a1c570 ffffff800a3454c8
[ 867.072033] 9c00: ffffff800a344000 ffffff80094a0000 ffffff8009004caa 0000000000000000
[ 867.079853] 9c20: ffffffc0f2859cd0 ffffff800810b334 ffffffc0f2859d30 ffffff8009008ccf
[ 867.087672] 9c40: ffffff8009486000 0000000000000000 0000000000000000 ffffffc0f0edfae0
[ 867.095492] 9c60: ffffffc0f2a1c570 ffffff8009452558 ffffff8009487b60 0000000000000005
[ 867.103311] 9c80: 0000000000000026 ffffffc0f138b300 ffffffc0f138b300 0000000000000000
[ 867.111130] 9ca0: 0000000000000001 0000000000000000 ffffff800810acb4 0000000000000001
[ 867.118950] 9cc0: ffffff80083da7ac 0000000005f5e0ff ffffff800a344c6f 00000000fffffffe
[ 867.126768] 9ce0: 0000000000000030 000000000000000a
[ 867.131639] [] watchdog_timer_fn+0x170/0x2e8
[ 867.137464] [] __hrtimer_run_queues+0x3b4/0x5b8
[ 867.143550] [] hrtimer_interrupt+0xac/0x1bc
[ 867.149289] [] arch_timer_handler_phys+0x38/0x50
[ 867.155461] [] handle_percpu_devid_irq+0x1c8/0x364
[ 867.161812] [] generic_handle_irq+0x2c/0x44
[ 867.167550] [] __handle_domain_irq+0xb4/0xb8
[ 867.173371] [] gic_handle_irq+0xb8/0x184
[ 867.178853] Exception stack(0xffffffc0f0edfae0 to 0xffffffc0f0edfc10)
[ 867.185288] fae0: 0000000000000e31 00000004dda2a2b3 00000000000003e8 0000000000000007
[ 867.193108] fb00: 0000000000000001 ffffffc0f2a1ac20 0000000000000001 0000000000000001
[ 867.200927] fb20: ffffff80083da7ac 0000000005f5e0ff ffffff800a344c6f 00000000fffffffe
[ 867.208747] fb40: 0000000000000030 000000000000000a 00000000000adc05 0000000000000000
[ 867.216567] fb60: 000000000000002d 0000000000000009 ffffff808a344c67 0000000000005dc0
[ 867.224386] fb80: 0000000000000000 000000000000558c 00000000000055f0 0000000000000030
[ 867.232205] fba0: 0000000000418958 ffffff800948dc47 ffffff8009629e80 ffffff800928c000
[ 867.240025] fbc0: 00000001000840c8 ffffffc0f0edfc10 ffffff800843ff48 ffffffc0f0edfc10
[ 867.247844] fbe0: ffffff800843ff00 0000000080000145 00000001000840c8 ffffffc0f0edfc40
[ 867.255663] fc00: ffffffffffffffff ffffffc0f0edfc40
[ 867.260533] [] el1_irq+0xb8/0x140
[ 867.265404] [] __delay+0x24/0x48
[ 867.270190] [] __const_udelay+0x24/0x2c
[ 867.275578] [] panic+0x23c/0x240
[ 867.280363] [] watchdog+0x5a0/0x5f8
[ 867.285413] [] kthread+0xe4/0xf4
[ 867.290198] [] ret_from_fork+0x10/0x50
