问下买回来的板子firefly-rk3288待机时异常alarm唤醒问题
买回来的板子发现当按下power键待机后,串口控制台上显示:
326.093288] PM: suspend entry 2013-01-21 08:55:35.293032615 UTC
[ 326.093422] PM: Syncing filesystems … done.
[ 326.124471] Freezing user space processes … (elapsed 0.004 seconds) done.
[ 326.129253] Freezing remaining freezable tasks … (elapsed 0.003 seconds) done.
[ 326.132616] Suspending console(s) (use no_console_suspend to debug)
01-armoff-logdp-osc_offddrc_off2345dDd543210
系统深度睡眠后,不到一分钟又被自动唤醒了,加上调试信息是发现:
在kernel/power/suspend.c里面的suspend函数里面又执行了:
326.147402] alrm set RTC date/time 2013-01-21(1) 08:56:01
[ 326.149329] start_alarm----294
奇怪我没设置alarm,怎么会在这个地方又设置了alarm唤醒闹钟啊?
烧哪版固件,把完整的log附上来分析
我也遇到了,楼主解决了么?
这个问题怎么解决的啊?接上USB调试不会出现上述打印,拔掉后再重启会出现楼主相同的log,再也唤不醒了
3288公版软件暂不支持深度休眠功能
