我的rk3399上安装firefly提供的ubuntu18版本,在上面运行新手教程中的指令崩溃:
root@firefly:~# ffmpeg -y -c:v h264_rkmpp -i /usr/local/test.mp4 -an -vf hwdownload,format=nv12,format=yuv420p output.yuv
Rga built version:06fc7c4
ffmpeg version 4.1.4-1firefly2 Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 7 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)
configuration: --prefix=/usr --extra-version=1firefly2 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --disable-libaom --disable-libmysofa --disable-libvidstab --enable-libdrm --enable-librga --enable-rkmpp --enable-version3 --disable-libopenh264 --disable-vaapi --disable-vdpau --disable-decoder=h264_v4l2m2m --disable-decoder=vp8_v4l2m2m --disable-decoder=mpeg2_v4l2m2m --disable-decoder=mpeg4_v4l2m2m --disable-muxer=‘ac3,eac3,mlp,truehd’ --disable-encoder=‘ac3_fixed,ac3,mlp,truehd’ --disable-demuxer=‘ac3,eac3,mlp,truehd,dts,dtshd’ --disable-parser=‘ac3,mlp’ --disable-decoder=‘ac3,eac3,mlp,dolby_e’ --enable-shared --disable-doc
libavutil 56. 22.100 / 56. 22.100
libavcodec 58. 35.100 / 58. 35.100
libavformat 58. 20.100 / 58. 20.100
libavdevice 58. 5.100 / 58. 5.100
libavfilter 7. 40.101 / 7. 40.101
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 3.100 / 5. 3.100
libswresample 3. 3.100 / 3. 3.100
libpostproc 55. 3.100 / 55. 3.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from ‘/usr/local/test.mp4’:
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
creation_time : 1970-01-01T00:00:00.000000Z
encoder : Lavf52.64.2
Duration: 00:00:10.00, start: 0.000000, bitrate: 6836 kb/s
Stream #0:0(und): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p(yuv420p) , 1920x1080 [SAR 1:1 DAR 16:9], 6664 kb/s, 24 fps, 30 tbr, 30 tbn, 60 tbc (default)
Metadata:
handler_name : VideoHandler
Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 166 kb/s (default)
Metadata:
handler_name : SoundHandler
mpp[17630]: mpp_info: mpp version: 3fedc6cd author: zouxf 2020-10-23 Merge remote-tracking branch ‘firefly-linux/firefly’
mpp[17630]: mpp_rt: NOT found ion allocator
mpp[17630]: mpp_rt: found drm allocator
mpp[17630]: mpp: deprecated block control, use timeout control instead
librga:RGA_GET_VERSION:3.02,3.020000
ctx=0x55829f0720,ctx->rgaFd=15
Stream mapping:
Stream #0:0 → #0:0 (h264 (h264_rkmpp) → rawvideo (native))
Press [q] to stop, [?] for help
[h264_rkmpp @ 0x5582a298c0] Decoder noticed an info change (1920x1080), format=0
Impossible to convert between the formats supported by the filter ‘graph 0 input from stream 0:0’ and the filter ‘auto_scaler_0’
Error reinitializing filters!
Failed to inject frame into filter network: Function not implemented
Error while processing the decoded data for stream #0:0
free(): invalid next size (normal)
Aborted
root@firefly:~# ls
