Unable to detect the device in lsusb
Hi,
I have downloaded the Android 7.1 SDK for Firefly-rk3399 and Built it.
I successfully flashed the images on the board.Android got booted up
I enabled the Developer options → USB debugging.
When i connect the USB type-C cable from RK3399 to My PC,
the board does not showup in lsusb details.
anvesh@anvesh:~/firefly-rk3399/kernel$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 413c:2113 Dell Computer Corp.
Bus 001 Device 015: ID 413c:301a Dell Computer Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Thanks and Regards,
Anvesh N
try to flash the new firmware to make sure if is it okay with the hardware.
Can you please give me the link for the new firmware ? sorry for the inconvenience caused.
Thanks,
Anvesh N
anveshdotneeli Posted at 6/5/2018 14:48
Thanks …
http://en.t-firefly.com/doc/download/index/id/3.html
leung先森 Posted at 6/5/2018 15:24
I have already checked with Android 7.1 firmware image.
I have enabled Developer options in that image.
Still the lsusb can not detect the rk-3399 device.
If it is a hardware problem, then how am i able to flash the images through the same usb port ?
May be the device is in host mode.. how can i check the mode of device ?
please help.
Thanks and Regards,
Anvesh N
anveshdotneeli Posted at 6/5/2018 16:48
I have enabled Developer options in that …
If you had flash the firmware 20180412 , the adb connect problem have fixed and ignore below.
Or u can see the links below, push the drmservice into your board and retry.
http://bbs.t-firefly.com/forum.php?mod=viewthread&tid=2202
leung先森 Posted at 6/6/2018 10:01
O …
Hi leung,
I have established adb over ethernet.
Whenever i am trying to connect Type-C usb cable to my Ubuntu PC, in order to access adb through usb, Getting the following error in dmesg.
[ 429.195843] phy phy-ff770000.syscon:usb2-phy@e450.6: charger = USB_SDP_CHARGER
[ 429.247778] fusb302 4-0022: connection has disconnected
[ 429.426780] fusb302 4-0022: connection has disconnected
[ 429.603807] fusb302 4-0022: connection has disconnected
[ 429.780402] fusb302 4-0022: connection has disconnected
[ 429.956793] fusb302 4-0022: connection has disconnected
[ 430.134148] fusb302 4-0022: connection has disconnected
[ 430.309773] fusb302 4-0022: connection has disconnected
[ 430.486585] fusb302 4-0022: connection has disconnected
[ 430.663876] fusb302 4-0022: connection has disconnected
[ 430.844945] fusb302 4-0022: connection has disconnected
[ 431.026581] fusb302 4-0022: connection has disconnected
[ 431.204932] fusb302 4-0022: connection has disconnected
[ 431.384369] fusb302 4-0022: connection has disconnected
[ 431.560147] fusb302 4-0022: connection has disconnected
[ 431.739063] fusb302 4-0022: connection has disconnected
[ 431.920725] fusb302 4-0022: connection has disconnected
[ 432.099713] fusb302 4-0022: connection has disconnected
[ 432.280952] fusb302 4-0022: connection has disconnected
[ 432.458049] fusb302 4-0022: connection has disconnected
[ 432.638815] fusb302 4-0022: connection has disconnected
[ 432.818030] fusb302 4-0022: connection has disconnected
[ 432.995190] fusb302 4-0022: connection has disconnected
[ 433.178709] fusb302 4-0022: connection has disconnected
[ 433.359867] fusb302 4-0022: connection has disconnected
[ 433.538134] fusb302 4-0022: connection has disconnected
[ 433.718607] fusb302 4-0022: connection has disconnected
[ 433.899673] fusb302 4-0022: connection has disconnected
[ 434.124878] fusb302 4-0022: connection has disconnected
please help us to get resolve.
Thanks and Regards,
Anvesh N
anveshdotneeli Posted at 6/7/2018 00:18
Hi leung,
I do not meet this issue yet , u can insert tpye-c reverse surface and try.
Or try other PC
leung先森 Posted at 6/7/2018 10:43
Or try other PC
No, i have tried with different PC and also with the other rk-3399 board i have.
Both are failing in fusb_state_attach_wait_sink()
please find the total logs in the attachment.
[ 179.704869] fusb302 4-0022: fusb_state_attach_wait_sink
[ 179.704967] fusb302 4-0022: connection has disconnected
[ 179.824634] phy phy-ff770000.syscon:usb2-phy@e450.6: charger = USB_SDP_CHARGER
[ 179.887515] fusb302 4-0022: fusb_state_attach_wait_sink
[ 179.887599] fusb302 4-0022: connection has disconnected
[ 180.078213] fusb302 4-0022: fusb_state_attach_wait_sink
[ 180.078313] fusb302 4-0022: connection has disconnected
[ 180.260817] fusb302 4-0022: fusb_state_attach_wait_sink
[ 180.260900] fusb302 4-0022: connection has disconnected
[ 180.443622] fusb302 4-0022: fusb_state_attach_wait_sink
[ 180.443713] fusb302 4-0022: connection has disconnected
[ 180.627010] fusb302 4-0022: fusb_state_attach_wait_sink
[ 180.627102] fusb302 4-0022: connection has disconnected
Regards,
Anvesh N
dmesg_logs.tar.gz (25.1 KB)
anveshdotneeli Posted at 6/7/2018 14:52
Both are failing …
Not insert type-c , it will output the log like that ?
I recommand you contact firefly and send it back to fix it .
I can’t thank you enough for your article, it really made an impression. Free Pass leader SPLK-1002 dumps materials available for all—good luck!
This is a truly magnificent article, thank you for sharing your thoughts. The Exam 220-1201 study solutions content is impressive, and it’s available at no cost.
I appreciate your article deeply, it left a strong impression on me. The New Service-Cloud-Consultant exam cram materials are here for free. Wishing you good luck!
South Korean consumers have shown keen interest in customized and high-end models; coupled with persistently low marriage rates and mounting social pressures, sex doll torsos are quietly finding their way into an increasing number of South Korean households. Price points ranging from 1 million to 5 million KRW cater to a full spectrum of needs, from entry-level to premium options.
